![]() | | #81 | ![]() |
![]() Join Date: Jul 2014 Location: Porter Oklahoma
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,061
| Not Ranked : 0 score
__________________ 2007 BM MS6 - Sold 2010 VRM MS3 Tech - Sold |
![]() | | #82 | ![]() |
![]() Join Date: Dec 2013 Location: Huntington; LI, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 63
| Not Ranked : 0 score Sorry for the thread revival, but I tried this yesterday and it did not work for me... I first tested the green wire and found that I was getting some current through it with the headlight/foglight switches off (dim glow on my indicator light), then once the switches are engaged the indicator light brightens up fully, like it should. So this seems off from what OP said should happen... The orange wire test results were as they should be. I then used the clamp-on style t connectors (pics below for reference) to jumper the green and orange cable together. I did not cut either cable, I just used the clamp connector things like shuebox mentioned in post #76 . Thing is, after jumpering the two cables together, the fog lights still do not work independently of the headlights... The system only acts like it does in OEM configuration. Does anyone have any idea why this may be? I'm certain I found the correct wires and I know current is able to flow through the clamp connectors and my "t'ed" in jumper cable as I tested all for continuity...
__________________ 2013 Liquid Silver MS3 Mods so far: FUNCTIONAL- Cobb AP HTP 3" Intake JBR OCC, EGR delete, Under Engine PipingC(u)NT 3" Catless Downpipe Treadstone TR6 FMIC and brackets Damond RMM, PMM, TMM JBR SSP & BUSHINGS Autotech HPFP Internals AESTHETIC- DIY Mudflaps, DDM 55W HL/35W FL [SIGPIC][/SIGPIC] |
![]() | | #83 | ![]() |
![]() Join Date: Feb 2014
Rep Power: 0 ![]() ![]() Thanks: 4
| Not Ranked : 0 score This may sound dumb - but my buddy tried this and when I looked at it i found he used the wrong orange wire.. You used the green from the upper grey harness and the Orange from lower blue harness correct? If so I'm not sure what happened but I've done 4 gen pu speed 3 and they all are still working great. Double check the wires and see if mistakenly used wrong lead. Good luck with it
__________________ 2013 MS3 -CorkSport STG2 Intake w/inlet -CorkSport RMM -CorkSport CatBack Exhaust -GoFastsBits BPV -TSW wheels -Mazda THULE Roof Rack ![]() -RAGE Roof Basket -"LOWES" Lip / Skirts -Misc "Built not Bought" appearance mods ~WORKDADDY |
![]() | | #84 | ![]() |
Did you cut the wires or just jumper them together? I will check and test the wires again after work today, but I am damned near 100% sure that I'm on the correct wires... If this doesn't work I was thinking about trying the under the glove box method in this link, has anyone tried out this other method and run into issues or anything?
__________________ 2013 Liquid Silver MS3 Mods so far: FUNCTIONAL- Cobb AP HTP 3" Intake JBR OCC, EGR delete, Under Engine PipingC(u)NT 3" Catless Downpipe Treadstone TR6 FMIC and brackets Damond RMM, PMM, TMM JBR SSP & BUSHINGS Autotech HPFP Internals AESTHETIC- DIY Mudflaps, DDM 55W HL/35W FL [SIGPIC][/SIGPIC] | |
![]() | | #85 | ![]() |
![]() Join Date: Jul 2014 Location: millersville, Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 8
| Not Ranked : 0 score I believe you need to cut the wires or use a wire splice like someone else did above and said it worked. And your link appears to be for the Juan not the pu |
![]() | | #86 | ![]() |
I did have a thought that maybe the wire taps I used aren't getting a good enough bite on the stock wiring. I used the blue ones meant for 14-18g wiring. Anyone have any thoughts on this? I don't know what gauge the stock wiring is, but I know that when I tested the contacts on the wire clamps, there was current passing through as it illuminated my test light when the headlight/fog light switches were in their appropriate orientations...
![]() | | #87 | ![]() |
| Not Ranked : 0 score Guys, I appreciate the help so far, but I started another thread specific to my issue so if there are any more suggestions, please put them in that thread (link below) so there is no double posting and jumping back and forth, thanks! Independent fog light issue
![]() | | #88 | ![]() |
![]() Join Date: May 2016
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score This is excellent...! going to try this out this week end. |
![]() | | #89 | ![]() |
![]() Join Date: Apr 2019
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score So out of curiosity how would I wire this same setup to run with no lights on at all? I've looked everywhere online for a true independent mod while using the stock switch. Would be forever grateful for the knowledge. |
| The Following User Says NO Thank You to GenPuNoob For This Un-useful Post: | Db09ms3 (04-25-2019) |
![]() | | #90 | ![]() |
![]() Join Date: Mar 2019
Rep Power: 12 ![]() Thanks: 0
| Not Ranked : 0 score Wait, what are you trying to do? This post already is how to manually control the fog lights... |
![]() | | #91 | ![]() |
![]() | | #92 | ![]() |
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,505
| Not Ranked : 0 score Why would one want the fogs on completely by themselves?
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f429/how-independent-fogs-108897/ | ||||
| What Did You Do To Your Car Today? - Page 324 | This thread | Refback | 09-15-2014 07:47 PM | |
| Mega "How to" thread for genpu speed3s! - Mazda3 Forums : The #1 Mazda 3 Forum | This thread | Refback | 06-26-2014 09:13 AM | |
| GENpU HOW-TO: Independent fog light mod | This thread | Refback | 03-26-2014 06:05 AM | |
| Independent Fog Lights - Page 4 - 2010-13 Mazda 3/Mazdaspeed 3 Forums | This thread | Refback | 07-03-2013 07:30 AM | |
| Foglight en tout temps? - Mazda 3 Quebec | This thread | Refback | 01-23-2013 05:34 PM | |
| Independent Fog Lights - Page 4 - 2012 Mazda 3/Mazdaspeed 3 Forums | This thread | Refback | 11-04-2012 10:29 PM | |
| 2010 Mazda 3/Mazdaspeed 3 Forums - View Single Post - Independent Fog Lights | This thread | Refback | 07-23-2012 10:33 AM | |
| Independent Fog Lights - Page 4 - 2010 Mazda 3/Mazdaspeed 3 Forums | This thread | Pingback | 06-22-2012 09:11 AM | |
| 08.5 MS3 GT Independent Fogs | ZsSpeed3 | MazdaSpeed 3/6 - Car Audio & Electronics | 18 | 08-23-2011 12:01 PM |
| Independent fog lights | mrFanel | 2010 MS3 - Car Audio & Electronics | 4 | 03-18-2010 06:17 AM |
| Porsche and VW expected to keep NA operations independent? | Haltech | Automotive News | 0 | 08-17-2009 03:00 PM |
| Independent People | Haltech | Celeberty Smut | 0 | 07-04-2009 03:10 AM |
| Bertone design division goes independent | Haltech | Automotive News | 0 | 04-25-2008 07:30 AM |
