Like Tree18Likes
 Old 11-29-2015, 10:36 AM   #41
Don
Don's Avatar
Posts: 181   (View Stats)
Don has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond repute
Ohhhhh yea. Dumb on my part lol
Don is offline   Reply With Quote
 Old 11-29-2015, 06:02 PM   #42
Don
Don's Avatar
ok still wont let me open it with ATR.. error pops up that says "invalid base map file. please verify vehicle and vendor of the map"
 Old 11-29-2015, 10:53 PM   #43
btstarcher's Avatar
Posts: 4,852   (View Stats)
You've had ATR installed and working right? And you're not just opening the map; you're opening ATR and loading the map?
SnailTune in progress
 Old 11-30-2015, 04:04 AM   #44
Don
Don's Avatar
Yea, it's worked before and yes I'm opening the program then trying to load the map. Maybe I should send cobb another request or do you think it's because my car is a 2010?
 Old 11-30-2015, 10:29 PM   #45
btstarcher's Avatar
Shouldn't make any difference. I'm not sure why it isn't working.
 Old 12-05-2015, 07:15 AM   #46
Don
Don's Avatar
yea still not working. ohh well
 Old 02-16-2016, 11:43 AM   #47
texasboy21's Avatar
Posts: 559   (View Stats)
texasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the world
Anyone running the tune? How is it?
2012 MazdaSpeed3 - HTP 3" intake, ETS TIMC, Autotech internals, Corksport racepipe, Accessport V3, custom Freektune, CP-E RMM, Koni sports, Progress Technology RSB, AWR endlinks
2003 A4 1.8TQ
APR stg2+, MTM 420cc injectors, EuroCode FMIC, PSi testpipe, Techtonics Tuning downpipe, Forge TIP, Hyperboost DV, 240mm clutch, LWFW flywheel, B5S4 calipers, Goodridge SS lines, Stern snub, motor and transmission mounts, Powerflex rear diff bushing, 034MotorSports rear diff. carrier bushing inserts, JHM SS shifter, solid linkage, stabilizer bushing and weighted knob, Vogtland Jr. Cup Kit, B7 RS4 front and rear sway bars.
texasboy21 is offline   Reply With Quote
 Old 02-16-2016, 12:06 PM   #48
Don
Don's Avatar
I tried. My accessport and atr won't allow me to do anything with it
texasboy21 likes this.
 Old 02-16-2016, 04:18 PM   #49
texasboy21's Avatar
I have a pump that im getting ready to install. I will see if I can load it into ATR.
2003 A4 1.8TQ
 Old 02-18-2016, 04:31 PM   #50
BAT-man's Avatar
Posts: 719   (View Stats)
BAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the world
Groaned at 29 Times in 14 Posts
Other folks have been able to open and use the maps. You have to fiddle with the ATR a bit.
I drive fast, I turn fast, I do everything fast. I even breakfast. I tend to confuse people with my sudden changes of heart. Sometimes I even confuse myself, which tends to cause problems.
"... if u can't find' em - grind 'em"
- old Chinese proverb
http://www.mazdamotorsports.com/
BAT-man is offline   Reply With Quote
 Old 02-19-2016, 03:47 PM   #51
texasboy21's Avatar
Seeing as this will be my first time loading a map into ATR, can you offer any assistance or tips? I have the Cobb ATR pdf, but its all a bit strange until you do it first hand.
2003 A4 1.8TQ
 Old 02-19-2016, 03:53 PM   #52
Don
Don's Avatar
You're supposed to be able to load it to ATR rename it and load it to your accessport.. This way you will be able to load it.. Personally it won't let me even load it to ATR. I stopped trying because it was pissing me off haha
 Old 02-22-2016, 11:02 AM   #53
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
@texasboy21; Just open it with ATR and re-save it. That's all. I just suggest either renaming it or saving it to a different directory so you don't overwrite the original file.
FWIW I had no problem loading this map in ATR.
 Old 02-22-2016, 11:30 AM   #54
Don
Don's Avatar
What year is your speed3
Edit-nevermind I just seen your sig
 Old 02-22-2016, 05:46 PM   #55
PolishMs3's Avatar
Posts: 56   (View Stats)
PolishMs3 is just really nicePolishMs3 is just really nicePolishMs3 is just really nicePolishMs3 is just really nice
So is this map only safe to run on a stock car? I currently am running a stg 3 ots map and I like the timing advance on it, feels like it has a lot more power but im looking for a more linear gain and not just in the 4k rpm range.
PolishMs3 is offline   Reply With Quote
 Old 02-22-2016, 07:54 PM   #56
texasboy21's Avatar
Its very clearing explained the map is for a stock car with an upgraded HPFP.
2003 A4 1.8TQ
 Old 02-22-2016, 09:06 PM   #57
BAT-man's Avatar
My tune was, as stated for a COMPLETELY STOCK gen2 MS3.
However, you should NOT run a Stage 3 map on a COMPLETELY STOCK car. Ever. That tune was never meant to apply to stock parameters, and unless you modified it severely, those timing changes aren't doing much for you, and may in fact rob you of power and make the car prone to detonation. There are specific mods Cobb lists as required for Stage 3, and the tune needs to be further refined after that.
 Old 02-22-2016, 11:00 PM   #58
PolishMs3's Avatar
However, you should NOT run a Stage 3 map on a COMPLETELY STOCK car. Ever. That tune was never mean to apply to stock parameters, and unless you modified it severely, those timing changes aren't doing much for you, and may in fact rob you of power and make the car prone to detonation. There are specific mods Cobb lists as required for Stage 3, and the tune needs to be further refined after that.
My car isn't stock I was just wondering what you would need to change on YOUR map in order for it to work well with a couple basic bolt ons.
I understand what was explained...maybe I should have phrased my question a little better. I'm just seeing if it would be bad to run this map if the car ISNT stock.
Last edited by PolishMs3; 02-22-2016 at 11:00 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-23-2016, 05:28 AM   #59
BAT-man's Avatar
Heh. Those changes you speak of. They are called a tune - They are very possible I've since added a 3" intake and have mainly updated the mafcal to accommodate. The rest of the tune stayed the same, save for some additional smoothing out here and there.
The Following User Says Thank You to BAT-man For This Useful Post:
Vansquish (05-04-2016)
 Old 02-23-2016, 06:59 AM   #60
aznpersuazn's Avatar
Posts: 12   (View Stats)
aznpersuazn has a spectacular aura aboutaznpersuazn has a spectacular aura about
This. The difference is mind blowing.
BAT-man likes this.
aznpersuazn is offline   Reply With Quote
The Following User Says Thank You to aznpersuazn For This Useful Post:
BAT-man (02-23-2016)
 Old 02-23-2016, 07:52 AM   #61
Shwaykid's Avatar
Posts: 646   (View Stats)
@Silaramic; read up homie
2008 Mazdaspeed3 GT
Jet Black Wax (06/24/2017)
 Old 02-23-2016, 08:06 AM   #62
@Silaramic; get more fasts.
sent from my Nexus 6P
 Old 05-03-2016, 10:51 PM   #63
6kipps's Avatar
Posts: 86   (View Stats)
6kipps is a name known to all6kipps is a name known to all6kipps is a name known to all6kipps is a name known to all6kipps is a name known to all6kipps is a name known to all
Bat-man,
After taking a look at the latest version of the map and comparing to what I've seen in the Cobb and Corksport maps and the guidance in the noob tuning guide, I have a couple of questions:
1) AFRs. It appears that your tune runs a little richer overall. Is this purely to be conservative under WOT?
2) Fuel pressure. Even though you're running with upgraded internals, the pressures remain stock. Why not run higher?
3) Waste Gate. The WGDC curve you are using is very different than the others I've seen, where a lot is demanded early on, tapers a bit in the 3-5k rpm range, then climbs again. What's the thought/theory behind it?
My self tuning experience is fairly limited and I've followed the MSF tuning guides and tips fairly closely. Just want to expand my knowledge in the realm of the possible. Thanks in advance!
6kipps is offline   Reply With Quote
 Old 05-04-2016, 04:00 AM   #64
speedfreak44's Avatar
Posts: 1,391   (View Stats)
Neutral  +1 score
I haven't reviewed the tune but
1. Afr ranging from 11.3-12.0 have been seen to do nearly the same power output on our engines
2. Fuel pressure does not gain anything not even injector head room
3. High wgdc at start is for spool up then taper to hold desired boost and increased again to keep holding desired boost
texasboy21 and kinder like this.
The line up:
 Old 05-04-2016, 09:06 AM   #65
sharksinspace's Avatar
Posts: 766   (View Stats)
Groans: 126
I'm a complete tuning n00b, so please bear with me on this dumb question -- I have Corksport SRI/TIP, BPV and HPFP, no exhaust work done at the moment other than a reso delete which is purely for sound...would you foresee any benefits/issues in running this B.1.7.9 map over COBB's OTS Stage 1+? I have the 91 octane Stage 1+ on my car at the moment (though I always fill up with 93), and am just wondering how this would compare until I've done a couple more mods worthy of an e-tune. I also actually drive a genjuan, for what that's worth, but I presume it doesn't really make much of a difference. Thanks!
 Old 05-04-2016, 06:49 PM   #66
6kipps's Avatar
Speedfreak44 please take a look at the map:
***Max enrich and knock tables have AFR's at 10.3 (for example)***
***Why then do the tuning guides and OTS maps go beyond stock pressure?***
***WGDC at WOT starts around 36 and progressively climbs to around 90, which is almost exactly the opposite of the limited "conventional" tuning I've seen.
The points you bring up are consistent with what I've read and am using philosophically in my self-tunes. Just trying to figure out why they are what they are.
 Old 05-18-2016, 12:09 PM   #67
ThizSpeed3's Avatar
Posts: 253   (View Stats)
ThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond repute
anybody try the Bat-man tune? i see peoples downloaded it any feedback from you guys?
ThizSpeed3 is offline   Reply With Quote
 Old 05-18-2016, 03:21 PM   #68
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Please tell me you are asking because you want to flash it to your car...
 Old 05-19-2016, 02:18 PM   #69
6kipps's Avatar
Not yet. I'm mid-stream on another self-tune after changing to one-step colder plugs and internals. Once I get those sorted, I'm going to give Bat-man's a try.
I've looked at his map several times to see how it compares to my current map and have narrowed down my curiousity to the WGDC response.
 Old 05-25-2016, 07:46 PM   #70
BAT-man's Avatar
Neutral  +1 score
Sorry been away for a bit and looks like Speedfreak answered for me but I'll try to fill in the additional blanks:
This is done purely for safety reasons, as you can see I target 11.3 in the WOT tables, but in case of knock, I want to allow the car to run as rich as 10.3. Max enrich in this case has nothing to do with target AFR under WOT, only with allowable AFRs when KR is present.
Though I suppose you could use it to set a ceiling on all and any AFRs if you set it higher than your highest targeted AFR (say 17... that'd be nuts though).
I see no reason to target any pressure higher than that required to keep the AFRs where they need to be. I would rather not wear out the pump, and AFAIK higher pressures are only used in cases where you're trying to jam more fuel into the engine but your IDC values are already maxed out. To me that's a bad scenario anyway - it means you need aux fuelling, not crazy high presures which the rest fo the system may not have been built to support.
I don't know what conventional tuning you've seen, but logic (and logs) tell me that to limit boost in the low range, lower WGDCs are required, and they need to be set to higher amounts to keep the boost levels high at high rpms. My logic, btw, was to enter values that are still too low and let the ECU try to correct UP (only slightly as I set max correction pretty low too), rather than set them higher than needed and have the ECU correct DOWN. My approach is pure conservatism. And I still make the power I want. By the way, with a 3" intake (and now 3.5") my WGDCs have dropped significantly starting 2,500 rpm, between 6 to 11 units lower from 2,500-7,000, now that the car has less trouble breathing and the turbo isn't struggling to make the targeted boost (I'm finally boosting 17.5 across the rpm range, holding 17 at top end and peaking to 18.5 in the 3.5-4k range). This is WITH much decreased WGDC values.
I hear ya, I'm the same way, I like to know the "why" behind the how.
kinder likes this.
6kipps (05-26-2016)
 Old 05-25-2016, 08:02 PM   #71
BAT-man's Avatar
I would not run my tune while using a SRI/TIP - I had to retune when I switched to a 3" TIP/Intake.
That brings me to a point I want to make - A stock tune is super conservative and dumps the AFRs into the high 9s at WOT and high rpm. It's hard to blow it up, but I would still not run a TIP/SRI with it, because it seems like one can never be too sure of where the lean spots may be due t this change. The Stage 1 is less conservative. Hence, I would def. not run it. I would get tuned with those mods in mind, but make sure you have a tuner who doesn't just tune WOT, but also part throttle and cruise. Those took the longest for me to dial in.
My 2 cents - Having spent a great deal of time dialing in part throttle and realizing how different it will be from car to car, I would presume that few tuners ever really focus on that, because it simply takes too long to do say 40+ logs and runs and retunes, vs. WOT tuning which requires maybe 10 logs/tunes at the best for most of the folks. Which is why I advertise self-tuning. I'll get off my soapbox now.
The Following 2 Users Say Thank You to BAT-man For This Useful Post:
dvcn (07-04-2016), sharksinspace (05-27-2016)
 Old 05-26-2016, 11:25 AM   #72
6kipps's Avatar
Thanks for filling in your logic for me - makes sense now.
The WGDC profiles I've seen in the OTS maps and the noob tuning guides usuallt open to 100% from 0-2500rpm(ish), decrease mid-range to maintain desired boost, then climb back to help in the higher rpm's.
As an engineer, I've never been a fan of operating a system at max capacity/capability because it leaves no margin for compensation. Anything I can do in my maps to only use what's required and leave safety margins in place is a bene.
Time to get back to work and stop gaffing off...
 Old 05-27-2016, 10:29 AM   #73
g00s3y's Avatar
Groans: 438
Neutral  -1 score
No one should be running any tune that hasn't been calibrated for their car, and their car only.
There is no reason to run a tune someone else made for someone else's car. Doing so is stupid, and will only lead to bad things happening.
 Old 06-18-2016, 02:00 PM   #74
6kipps's Avatar
Generally, I agree with you. But, we routinely load OTS maps into our cars from COBB, CS, and others and assume the pro tuners haven't goobered anything up. OTS maps appear to be a common point to depart from as we start our individual self-tuning journeys.
I finished 90% of the re-tuning I wanted to get done post-plug and internal install (still haven't gotten boost back where I want it). I did several logged runs, then modified the map with ONLY the WGDC profile from this thread to see what would happen. The only mods to the profile I did were to smooth it into my existing WGDC (which I've tweaked for fuel economy in the >40% throttle realm using examples from bnoon's thread) AND decrease the highest values by 10% to give me a little extra cushion on top. My car is a DD.
Attached are the best before and after logs with the corresponding VD. The runs were performed over the same stretch of road in about the same conditions. There is some error induced because I always use the same weight values to minimize additional variable impacts (and because I'm a little too lazy to compute it).
Here they are:
v1.6 6_13 datalog2.csv
v1.6 6_10 datalog2.csv
VD Output.pdf
In my limited experiment, there is a good gain in HP and TQ. What stood out to me was the smoother increase in boost, maintaining of boost, and the smoother increase of WG. The car also accelerates smoother and the power addition is not nearly as abrupt.
The only target not met in either map was boost (which is where I'm going to focus my efforts for the near term). Still learning, but I now have more methods at my disposal as I keep playing with the car.
Hope this helps!
 Old 06-18-2016, 02:13 PM   #75
BAT-man's Avatar
Glad it helped. Getting rid of that blue boost bump around 3-3.5k has been one of my goals with the tune, and it looks like it's working on other cars. Very happy to see that. I am however surprised to see a whp/tq gain in that same spot, given lower boost. Unless you messed with AFRs and timing, which you said you didn't it's probably a matter of the conditions.
 Old 06-18-2016, 06:36 PM   #76
6kipps's Avatar
In my base map I have messed around with the AFRs from 1500-3500 rpm and up to around .5ish on the load, running as high as 17.1 for fuel economy while cruising. So, I have a divot in my boost, fuel, and WGDC to help out. I'm still a little inconsistent in my logging technique, so it takes 3-4 runs at a time to get one decent set of data. What I believe also helps is the improvement of building boost your profile seems to have done in this particular situation. When I get home later, I'll post the recent map for comparison.
 Old 06-18-2016, 10:41 PM   #77
6kipps's Avatar
Here's the two maps for comparison.
Chris Stage 1.6.ptm
Chris Stage 1.7a.ptm
After going back to review again, I evidently did a little adjustment in the AFR around the .13/.19 load at 2000-3000rpm. However, I don't think that minor adjust would account for the output changes. I would attribute some to user (me) error in datalogging, consistent WOT runs, and data input into VD (using the same weight number).
At this point, I'm more interested in achieving my targets in the map than hp/tq numbers, which I view as a method to assess trends.
 Old 08-31-2016, 11:37 AM   #78
itslogics's Avatar
Posts: 3   (View Stats)
itslogics can only hope to improve
Wow very nice info here.
itslogics is offline   Reply With Quote
The Following User Says NO Thank You to itslogics For This Un-useful Post:
SofaKingAwesome (08-31-2016)
 Old 07-18-2017, 09:12 AM   #79
Reiketsu35's Avatar
Posts: 1   (View Stats)
Reiketsu35 is an unknown quantity at this point
Is this Map safe to use on a stock genpu with cobb sri and corksport axleback, reso delete?
Thanks
Reiketsu35 is offline   Reply With Quote
 Old 07-18-2017, 12:15 PM   #80
6kipps's Avatar
I wouldn't suggest it. I installed HPFP internals and one step colder plugs prior to building/running on these maps. When I built these maps (now about 10 iterations old), I incorporated Bat-mans methodology (not cut and paste values) to the characteristics of my existing maps (including my MAF cal, which is unique to each car).
I'm not a pro-tuner, I just read a lot and carefully/sequentially change my maps, so there may be things in my tables that aren't quite right.
What I would suggest:
1) Purchase/install HPFP internals - the money and time are worth it. Chasing increased power without these is a blown engine waiting to happen.
2) If you are self-tuning, read/re-read Noddy's guide to tuning (I always catch another tidbit when I re-visit), then adjust your WGDC to conceptually match what Bat-man is working off of and go from there. This is an iterative process, so take it slow and methodically. Self-tuning isn't hard, but it takes time and patience.
3) If you're uncomfortable working the tables in a map, pay a professional to built one that meets your goals.
2013 MS3: COBB AP v3, CS SRI/TIP, CP-E TMIC, UR TP, CS HPFP, CS BPV, JBR OCC, COBB shift weight, Conti DWS, some rice...
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f428/stock-mazdaspeed-3-genpu-tune-results-33whp-195501/
Stock MPS - Looking To Mod - Page 2 This thread Refback 11-18-2015 07:18 PM
Drag race results for GenPU k04 doctavus Drag Racing 5 01-09-2014 10:12 PM
Results of a tune by RichTune snypeZ MazdaSpeed 3/6 - ECU Computer Tuning 32 06-08-2013 12:41 PM
First tune w/bolt-ons in lug Ford Focus ST Ecoboost - General Discussion 27 10-17-2012 02:40 PM
Dyno results after lex tune Zbrit00x 2010 MS3 - Dyno Sheets/Discussions 6 02-25-2012 05:48 PM
GM sales increase, but tight stocks crimp results Haltech Automotive News 0 08-02-2011 10:00 PM
Page generated in 0.64258 seconds with 36 queries
