![]() | | #241 | ![]() |
| Not Ranked : 0 score Sent from my XT1585 using Tapatalk
![]() | | #242 | ![]() |
![]() Join Date: Jun 2013 Location: Northern V.A
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 22
| Neutral : -1 score what have you guys been using for the Neutral APP Translation table? My guess is that this table would affect launches as much as the 1st gear table. |
| The Following User Says NO Thank You to Franky-5-Fingaz For This Un-useful Post: | Vansquish (08-24-2016) |
![]() | | #243 | ![]() |
Rep Power: 3748 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,745
| . . . car is not in neutral when it is in first gear . . .
![]() | | #244 | ![]() |
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
| Not Ranked : 0 score Are you sure? Manual transmissions are hard.
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP |
| The Following User Says Thank You to WetzMS3 For This Useful Post: | g00s3y (08-26-2016) |
![]() | | #245 | ![]() |
![]() | | #246 | ![]() |
| Neutral : +1 score
There are sensors that let the ECU know what gear the car is in, even if the clutch is still depressed. This is how LC on the AP and things like WOT boxes know when to engage and release.
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP | |
![]() | | #247 | ![]() |
| Not Ranked : 0 score ah, point taken. Thanks for getting your point across without having to add a No Thank you. |
| The Following User Says Thank You to Franky-5-Fingaz For This Useful Post: | Vansquish (08-24-2016) |
![]() | | #248 | ![]() |
Code: 0 2.43 4.77 7.01 9.15 11.2 13.15 15 16.75 18.41 19.98 21.45 22.83 24.12 25.32 26.45 28.93 31 32.75 34.3 35.77 37.3 39.06 41.23 44 47.59 49.76 52.22 58.15 65.65 75
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
| The Following User Says Thank You to Vansquish For This Useful Post: | The Nut (08-24-2016) |
![]() | | #249 | ![]() |
![]() Join Date: Apr 2012 Location: Los Angeles
Rep Power: 426 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 956
__________________ 2012 BLACK MICA w/TECH Go: Cobb- AP(v2)//AT- Internals//ETS- TMIC//CorkSport- True 3" Intake/Camber Plates/BPV/Boost Tubes/Recirc Tube//Denso- ITV22's//NATOR- TP//JBR- 80a Duro TMM & PMM/SSP/Counterweight/Anchors//CP-E- Stage II RMM//Tri-Point- RSB w/Monster Endlinks//GT-Spec- 4 Points Ladder Brace/Mid Chassis Brace/Front 4-Point Brace/Front & Rear Lower Tie Bar/Trunk Reinforcement Brace//Bosch- 3 Bar MAP Sensor//Technafit- SS Brake Lines//KW- v3 Coilovers//Swift- Springs (8K front/6K rear)//BC- Rear Spring Perches Shoes: MB- Battles (Matte Gunmetal) 18X8 +43 wrapped wit Michelin PSS's 245/35/ZR18 Rice: Tint//Blacked Out Badging//CorkSport - Hoodlifts/Engine Compartment LEDs//JBR- Special Edition Cylindrical Knob Stereo: Full Custom Mobile Audio/Video Entertainment System 91 & Corn diagnostics by: | |
![]() | | #250 | ![]() |
![]() | | #251 | ![]() |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f426/snaild-s-throttle-table-fix-146060/ | ||||
| Hunter's Cosmic Blue Build - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum | This thread | Refback | 05-18-2015 01:02 PM | |
| Self-tuning adventure! - Mazda3 Forums : The #1 Mazda 3 Forum | This thread | Refback | 10-13-2014 11:36 AM | |
| Thinking about a tune. - Page 2 | This thread | Refback | 08-19-2014 04:33 AM | |
| Snaild on corn | snailD | 2010 MS3 - Dyno Sheets/Discussions | 13 | 11-23-2012 10:58 PM |
| Unsettling hesitation under part throttle and full throttle at first track day | dachtler | 2010 MS3 - ECU Computer Tuning | 0 | 10-01-2012 02:49 PM |
| OL/part throttle at what percent throttle? | MS3Zoom24 | Cobb ATR Support | 4 | 10-31-2009 02:37 PM |
| Do we know when the ECU uses each table? | FreeFlyFreak | Cobb ATR Support | 17 | 05-07-2009 01:54 PM |
