> 2010 MS3 - Suspension & Brakes
 Old 10-13-2018, 01:05 AM   #1
ozzy610's Avatar
Posts: 14   (View Stats)
ozzy610 is an unknown quantity at this point
Default Bumping noise at the front
I have got a bumping noise at the front when I go over deep holes or drains.it is not there on speed bumps and normal holes.i have replaced top mounts and bearings bilstein shocks and eibach springs and new arms.been In 2 garages and they cant find it.they can here it but cant find.any suggesting people.doing my head in.
ozzy610 is offline   Reply With Quote
 Old 10-13-2018, 10:18 AM   #2
doublegmoto's Avatar
Posts: 23   (View Stats)
doublegmoto will become famous soon enough
Try to check swaybar endlinks. Even when a little loose or worn will make that noise.
Sent from my LGMS631 using Tapatalk
doublegmoto is offline   Reply With Quote
 Old 10-15-2018, 11:01 AM   #3
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
End links and grease your sway bar bushings.. I spray mine with a Teflon dry spray once in a while. If they get too dry they grab and twist on the bar binding up, then release and "clunk" when they give way.
My rear bushings are urethane and were making horrible clunk noises. Cleaned, lubed with silicone grease, and problem solved. I thought something had come loose!
front-end bumping sounds when driving over bumps debuke MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 12-12-2012 04:10 PM
PLEASE HELP - FRONT END NOISE vegasmartin MazdaSpeed 3/6 - Troubleshoot/Diagnostics 18 09-28-2012 01:11 AM
front end noise laocas01 MazdaSpeed 6 - Engine, Transmission & Driveline 6 05-21-2011 06:18 PM
Front end noise. Seaton 2010 MS3 - Troubleshoot/Diagnostics 5 04-26-2011 12:41 AM
Front End Noise jrlms6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 11-29-2010 02:14 PM
Page generated in 0.23569 seconds with 22 queries
