| Revolution Performance Motorsports Revolution Performance Manufacturing (RPM) was started by three Mazda 6 enthusiasts in early 2004 under a simple premise: to develop and manufacture new products for the Mazda 6 at an affordable price. We began to realize our purpose with the short throw shifter and gas hood lifter kits for that vehicle. Since then, we have added many new aftermarket products from well-known manufacturers and continue to expand to offer products for other vehicles with the goal of having the best prices and customer service on the 'net. |
![]() | | #681 | ![]() |
![]() Join Date: Apr 2013 Location: Edmonton, Alberta, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 300
| Not Ranked : 0 score
Sent from my SGH-I747M using Tapatalk
__________________ 2012 MS3 SOLD, living in the world of Right Wheel Drive now Ol' BMO had: Autotech Internals, CS SRI+TIP, CS Short Shift Plate, CS BPV, CS TMIC, UR Catback, CP-e Stage 2 RMM, COBB AP v3.0, UR Test Pipe, JBR Weighted Shift Knob, DM OCC Kit, Koni Yellows+GC springs | |
![]() | | #682 | ![]() |
![]() Join Date: Sep 2012 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,205
| Not Ranked : 0 score You should have bought it before upgrading your suspension, totally changes how this car handles. I would recommend JBR.
__________________ 2010 Mazdaspeed3 w/tech Cobb AP V3 ║ JBR Tru 3" Wide Path ║ JBR Boost Tubes & BPV Hose ║ Cobb XLE BPV ║ CP-E TMIC ║ UR Racepipe ║ Magnaflow CBE ║ AutoTech Internals ║ GrimmSpeed EBCS ║ JBR RSB ║ SPC Camber Arms ║ KW V3 Coilovers ║ JBR IM+TB TIGs & TB Bypass ║ JBR SSP ║ E - Focus RMM ║ StopTech Slotted Rotors and EBC Yellow Stuff Pads ║ Techna-Fit SS Brake Lines |
| The Following User Says Thank You to [R]usty For This Useful Post: | justinsane87 (06-23-2014) |
![]() | | #683 | ![]() |
![]() Join Date: Oct 2013 Location: Edmonton, AB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 814
I was planning on a rsb first later on this year, but this gb came up and thought it may have been to good to pass on
__________________ 2013 Mazdaspeed 3 - GTX3076R EWG Autotechs - FreekBuilt 3.5" - UR Catless Turbo-back - AP V3 - ETS TMIC JBR 80D Trilogy/SSP/Bushings/Heavy Knob/TIGs/0.250 RSB - GFB BOV FreekTune'd - DO DVC-30 - Ground Control w/Koni Yellows - DM OCC Enkei RPF1 17x9 w/ PSS 235/45/17 - Full Race Exhaust Mani | |
![]() | | #684 | ![]() |
![]() Join Date: Apr 2009 Location: Danbury, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,851
Groans: 58
| Not Ranked : 0 score This. The roads are awful in that area but there is no reason the car should be in the air unless the driver is going way to fast for the roads. |
| The Following User Says Thank You to daafisch For This Useful Post: | 461_SS (06-23-2014) |
![]() | | #685 | ![]() |
![]() Join Date: May 2010 Location: Holland PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 239
| Not Ranked : 0 score You don't need an aftermarket RSB.... Honestly a RSB is just a "fine tuning" device, not a band-aid. Shocks and Springs are numero uno! |
| The Following 5 Users Say Thank You to 461_SS For This Useful Post: | Crarrs (06-23-2014), daafisch (06-23-2014), Helrich (06-23-2014), Nliiitend1 (07-29-2014), phate (06-23-2014) |
![]() | | #686 | ![]() |
![]() Join Date: Jan 2011 Location: Grapevine, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 242
| Not Ranked : 0 score Ive had these on for about 2 weeks with no problems whatsoever. I picked dd/aggresive. I have a JBR rsb on as well. I'm really not sure how people are having the springs pop out at stock height (Would GC sell these with a problem like that). I rode stock height the first 2 days. After that I adjusted them and have about a 2ish-3 finger wheel gap now. Jacking up the car and adjusting them my spring came loose a bit but, not enough to even come close to coming off. I will go try it again and let y'all know. I came from cs springs and wow what a difference this set up makes. Sucks some of y'all are having these issues. |
| The Following 3 Users Say Thank You to thepatient77 For This Useful Post: |
![]() | | #687 | ![]() |
Groans: 58
| Not Ranked : 0 score I got occasional autox/race. If I did my maths correctly I have about 1.2 inches from tire to fender. I only measured the distance from rim to fender and that was 13.5cm. I run 235/45r17's which the internet tells me have a 10.5cm sidewall. I came from Swift springs and used my existing koni shocks. The ride is stiffer for sure but the car feels very stable. The ride only gets very bouncy on consecutive dips in the road. Quick bumps feel fine. The car felt a lot better at autox this past weekend and I still don't have everything aligned correctly, waiting on new tires for that (just ordered RS3 V2's today ). |
| The Following User Says Thank You to daafisch For This Useful Post: | phate (06-23-2014) |
![]() | | #688 | ![]() |
| Approved MSF Vendor ![]() Join Date: Nov 2008 Location: Euless, TX
Rep Power: 975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 850
(Thread Starter) | Not Ranked : 0 score GC is in touch with the owner bennyzoom to try to find out what happened. They did a lot of research when putting the kit together, so it doesn't seem like this is something that would be overlooked. Donovan from GC said he would make an account here to address any concerns, so you should see him here in the coming days. |
| The Following 8 Users Say Thank You to RPM For This Useful Post: | - POD - (06-24-2014), daafisch (06-24-2014), Dimenus (06-24-2014), Jdraps13 (06-23-2014), Mattyhawk1 (06-24-2014), monkey.bones.007 (06-23-2014), thepatient77 (06-23-2014), [R]usty (06-23-2014) |
![]() | | #689 | ![]() |
Groans: 433
| Not Ranked : 0 score yeah. After finally putting new endlinks on the front says (the M3 endlinks), I don't get the annoying rattle I had up front, but when I hit a nasty bump, the R front has a solid "CLUNK" that I can almost feel. No idea what it is. These suspension rattles/clunks didn't happen until I put the GC's on. Aftermarket front sway (whiteline). I've driven up on ramps and just can't tell what it may be. Kinda at my wit's end with it.
![]() | | #690 | ![]() |
![]() | | #691 | ![]() |
Groans: 58
![]() | | #692 | ![]() |
![]() Join Date: Apr 2014 Location: Cold lake / Edmonton AB
Groaned at 18 Times in 5 Posts
| Not Ranked : 0 score Anyone get their tracking numbers today? |
![]() | | #693 | ![]() |
(Thread Starter) | Not Ranked : 0 score I sent them to everyone. International orders will come to RPM first, though, so those will ship in a few days. |
| The Following User Says Thank You to RPM For This Useful Post: | Jdraps13 (06-25-2014) |
![]() | | #694 | ![]() |
![]() Join Date: Nov 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,192
Groans: 33
| Not Ranked : 0 score Anybody with the 525/600 springs have their setup dialed in? I'm at a half turn stiffer from whatever they came from GC (both front and back) and it feels very good.
__________________ 2012 Velocity Red Mica Fast: COBB AP | Autotechs | JBR 3'' WP | CS DP | CS ABE | MDM RMM | JBR RSB | NGK Plugs | JBR SSP | ETS TMIC Rice: Aeroforce Interceptor | AEM M 35psi | Konig Milligrams 18x8.5 + 35 | Z1 Star Specs | JBR Mudflaps ![]() |
| The Following User Says Thank You to Dimenus For This Useful Post: | nybe0010 (08-04-2014) |
![]() | | #695 | ![]() |
![]() Join Date: Sep 2012 Location: Rocklin, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 74
| Not Ranked : 0 score I have had an issue in the past of GC in the rear coming unseated when put on a lift. It is the one annoying thing about the kit is that if you don't pay attention when the shop puts your car on the ground sometimes the springs do not seat correctly. I am guessing but that is probably what happened is the springs did not seat correctly when the car was put on the ground. I have GC on my FIT for 7 years now and their is even more of drop with the rear suspension and the springs because of the way the fit is designed. I have never had a spring pop out but I have had to ask shops can you jack my car back up the rear springs did not seat correctly when you put the car down. I usually go and do it my self to make sure they have actually seated. Yes their are some horrible roads around here have gone through two sets of rims on that car because of the horrible roads and never had that issue. For the person that had that issue that is a truly horrible experience, and if that happened to me I would be very uncomfortable about the suspension. I am only sharing my experience with GC and insight for those with the kit as for something to watch out for. |
| The Following User Says Thank You to Bap For This Useful Post: | Jdraps13 (06-25-2014) |
![]() | | #696 | ![]() |
![]() Join Date: Nov 2010 Location: SoCal
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 35
Groaned at 9 Times in 3 Posts
| Not Ranked : 0 score [QUOTE=Dimenus;2628801]Anybody with the 525/600 springs have their setup dialed in? I'm at a half turn stiffer from whatever they came from GC (both front and back) and it feels very good.[/QUOTE I have this same setup but mine are not exactly dialed in. I havent adjusted them since they came from GC. My rear is a bit bouncy, the front feels good though |
![]() | | #697 | ![]() |
Groans: 433
| Not Ranked : 0 score This. I might need adjustable ones that go even shorter.
![]() | | #698 | ![]() |
![]() Join Date: Nov 2010 Location: Edmonton, Alberta, Canada
Groaned at 6 Times in 4 Posts
| Not Ranked : 0 score still waiting!! |
![]() | | #699 | ![]() |
![]() | | #700 | ![]() |
![]() Join Date: Jul 2012
Groaned at 46 Times in 14 Posts
| Not Ranked : 0 score <crickets >
__________________ 2017 Ford Focus RS - Stock 2004 MSM - AEM Intake - BEGI - FM Turboback - Turbosmart BPV - Hallman Boost Controller - ... "I'm a Turbo addict, I know." SCCA Philadelphia: (http://www.phillyscca.com/solo/) 2012 MS3 Silver w/ Tech Package - sold in '17 2009 WRX Stage 2- sold in '12 |
![]() | | #701 | ![]() |
(Thread Starter) | Not Ranked : 0 score You guys are the last 2 and your kits will be shipping from RPM on Monday or Tuesday, so you'll have them by the end of the week! |
![]() | | #702 | ![]() |
Groans: 33
| Not Ranked : 0 score Anybody on less than 525/600 springs? I'm very happy with this kit but I've never owned this level of performance suspension. The kit feels well dampened but you can definitely feel every bump.
![]() | | #703 | ![]() |
![]() | | #704 | ![]() |
![]() | | #705 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yes, they are! We'll send you tracking a little later and you'll have the kits by the end of the week! |
| The Following User Says Thank You to RPM For This Useful Post: | Jdraps13 (07-01-2014) |
![]() | | #706 | ![]() |
(Thread Starter) | Not Ranked : 0 score Also, in order to completely eliminate the possibility of an unseated spring, GC has made new spring cups for the rear adjuster that will ensure that it's impossible to happen. They will be sending these to every customer who has purchased a kit. |
| The Following 14 Users Say Thank You to RPM For This Useful Post: | Crarrs (07-01-2014), daafisch (07-01-2014), Dimenus (07-01-2014), gmoney542 (07-02-2014), jack_hammer (07-01-2014), JDMJOSH (07-01-2014), Jdraps13 (07-01-2014), justinsane87 (07-01-2014), Mattyhawk1 (07-09-2014), monkey.bones.007 (07-01-2014), nybe0010 (07-01-2014), thepatient77 (07-01-2014), timmcc02 (07-01-2014), [R]usty (07-01-2014) |
![]() | | #707 | ![]() |
| Not Ranked : 0 score Ground control FTW! Awesome!
![]() | | #708 | ![]() |
Groans: 33
| Not Ranked : 0 score Awesome. Thanks @RPM; And my only issue might be with large bumps / dips in the road. Though I think there's only so much you can do with stiff springs. Anyone else care to chime in?
![]() | | #709 | ![]() |
| Not Ranked : 0 score Tracking number hell yeah |
![]() | | #710 | ![]() |
![]() Join Date: Jul 2012 Location: Houston TX
Rep Power: 0 ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score When can we expect this spring cup? will they be automatically sent out, or do we need to ask for them? |
| The Following User Says Thank You to Saiyanjin2 For This Useful Post: | Jdraps13 (07-01-2014) |
![]() | | #711 | ![]() |
(Thread Starter) | Not Ranked : 0 score They're in production and they'll be automatically shipped out when they're done. I believe they should start shipping next week. |
| The Following 2 Users Say Thank You to RPM For This Useful Post: | Dimenus (07-01-2014), Saiyanjin2 (07-02-2014) |
![]() | | #712 | ![]() |
(Thread Starter) | Not Ranked : 0 score Correction, direct from GC: "We will be sending these out in a couple of weeks when they come in from our machine shop." |
![]() | | #713 | ![]() |
| Not Ranked : 0 score If I get the corksport camber plates would I still need to use the stock top hats from the car? |
![]() | | #714 | ![]() |
Groans: 58
| The Following User Says Thank You to daafisch For This Useful Post: | Saiyanjin2 (07-02-2014) |
![]() | | #715 | ![]() |
| Not Ranked : 0 score I called ground control today about camber plates. They said they will be released soon but would not give me anymore details. If anyone is looking I would hold off as I'd assume their plates are going to be pretty great.
![]() | | #716 | ![]() |
You doing yours already?
![]() | | #717 | ![]() |
![]() Join Date: Mar 2012 Location: Edmonton
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 247
Groaned at 8 Times in 5 Posts
__________________ JBR 3.0" WP // CS Racepipe // UR CBE // CS TMIC // CS SS Plate + Bushings // Autotechs // NGK's // Damond Oil Restrictor Bolt // Forge v2 // JBR RMM 88 // JBR .250 RSB // CS Springs/Struts // SPC Camber Arms // |
| The Following User Says Thank You to JDMJOSH For This Useful Post: | justinsane87 (07-03-2014) |
![]() | | #718 | ![]() |
| Not Ranked : 0 score Just wanted to say thanks to RPM and ground control. Got and installed my kit and I really enjoy them. Can't wait until my ride height and shocks are adjusted to my liking |
![]() | | #719 | ![]() |
Groans: 58
| Not Ranked : 0 score Damn it, they always say soon. A local has a set of CS plates he is offering me at a good price but I've been trying to hold out for these. |
![]() | | #720 | ![]() |
| The Following User Says Thank You to 461_SS For This Useful Post: | aforst (07-11-2014) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f408/gb-ground-control-koni-sport-coilovers-mazdaspeed-167667/ | ||||
| Konisport + ground control setup | This thread | Refback | 04-25-2014 12:49 PM | |
| Konisport + ground control setup | This thread | Refback | 04-20-2014 03:35 AM | |
| Ground control and koni yellows | Bap | 2010 MS3 - Suspension & Brakes | 212 | 10-20-2016 11:43 AM |
| Koni Yellows | martin_nj | MazdaSpeed 3/6 - Suspension & Brakes | 50 | 05-09-2012 10:27 AM |
