Like Tree4Likes
 Old 06-23-2011, 01:09 PM   #41
zenger's Avatar
Posts: 602   (View Stats)
zenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the world
Groaned at 8 Times in 7 Posts
steeper gears lsd quaife or what have you, camms, intake manifold, fuel injectors, intank pump, new head,
2007-Mazdaspeed 6
BNRSIII~all supportings
Zoom Zoom Boom part out.
zenger is offline   Reply With Quote
 Old 10-04-2011, 10:59 AM   #42
leo766's Avatar
Posts: 300   (View Stats)
COILS for both the ms3 and 6, since ppl streching the stock ones is nuts, and the HKS twinpower is just too damn expensive
or a bigger Throttle body?
oh and of course any sort of body kit for a ms6 would be amazing
Fresh to High Rockies Colorado from VA DC area MS6 07 TiGray!
Cpe: FMIC, CAI, TIP, HPFP, bone engine mount
Cobb AP, Test pipe, turbosmart BPV, whitlenine swaybar
Turbine Tech: Extra front motor mount, both diff mounts +bushings
EGR Delete, mini 0803 Dash cam, Prosport Boost guage. Dash Hawk,
AWR: Trans mount with 88 duro bushings, End links front/rear(removed due to them being total garbage and got some moog stock ones for all around on rockauto.
17x7 Kosei K1 TS 15lb rims, goodyear 225/50r17 all season performance tires and RPM springs
Waiting to install: SPC Ball Joints, SS clutch line, lower engine mount bracket local car shop damaged during clutch install and thermal TB gasket and coolant inline plumbing line that can be turned on and off on demand
leo766 is offline   Reply With Quote
The Following User Says Thank You to leo766 For This Useful Post:
Alpha (10-04-2011)
 Old 10-04-2011, 11:08 AM   #43
Pedal-Force's Avatar
Posts: 419   (View Stats)
Pedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the world
Originally Posted by anthony8488 View Post
MS3 all wheel drive conversion
This would be sweet. A relatively simple bolt on awd system, that you could install with a couple buddies and a relatively well stocked garage in a weekend. If it was less than 3k or so, I think people would be interested.
The only downside to this awesome platform is the fwd. I think people will eventually get to 600+ whp, but it's useless with fwd. I plan to keep my car ten years at least, and awd would keep me from jumping to a sti or evo earlier.
Sent from my DROIDX using Tapatalk
2010 MS3 - Liquid Silver - tech package, Nav, Bose - Cobb AP - HPFP from HPFPUpgrades - JBR Cro-Mo Dogbone RMM - JBR SSP and solid bushings - tinted windows - Ultragauge - CS SRI/TIP - Super duper tranny fluid - Denso ITV22 plugs.
wish list - Catted DP, EGR block off, intake and throttle thermal gaskets, OCC, throttle coolant bypass
maybe list - BSD, top or front IC, cat back exhaust
2010 CX-7 Grand Touring - Silver - Fiance's car (owned by me though).
Pedal-Force is offline   Reply With Quote
 Old 10-04-2011, 10:43 PM   #44
leo766's Avatar
for 3k ud be lucky if the AWD they made could handle 100hp much less 600, its not as simple as you clearly think it is.. you would need a new tranny which would cost you 3k, then a custom driveshaft, 2k more, than a diff and axels with mounts that somehow latch on to anchor points that a ms3 simply doesnt have... another 1k
so your looking at 6k and another 6k in labor, so 12k and thats if your lucky
you might as well ask for a mystery box that adds 100hp for $1000 it would be much more feasable
sorry for being such a troll, but cmon man, 3k to make a car awd, even a mazda 6 cant be converted to a MS6 for anywhere close to that if at all, and not to mention if you do the math, the parts in the ms6 that make it an AWD car, actually cost about 10k all together, but they are also mass produced
but ye MAP needs to make a Intake manifold with real velocity stacks, or maybe even laminova water to air cores in it for that extra coolness super-sex
The Following 2 Users Say NO Thank You to leo766 For This Un-useful Post:
Easter Bunny (10-05-2011), Fatguy729 (10-05-2011)
 Old 10-05-2011, 01:00 AM   #45
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
Nothing pisses me off more than someone who posts a load of bullshit about something they clearly know nothing about. you are a fucking toolbag and have absolutely no clue what you're talking about...
Please do not spread misinformation on this forum about things you don't know your ass from a hole in the ground.
Considering I have personally spoke to the person building PT 5857 + AWD , who said he has LESS THAN 2k in the AWD portion of his build... kinda fucks with your whole post...
granted, no company would sell it for 3k... but most of the things you mentioned would be cake work with someone who can weld... the hardest part is relocating the fuel tank.
oh, AND PLEASE tell me why the fuck you would need a new transmission?
The Following 3 Users Say Thank You to Fatguy729 For This Useful Post:
Easter Bunny (10-05-2011), silvapain (10-11-2011), Vansquish (10-31-2014)
 Old 10-05-2011, 05:23 AM   #46
You actually don't need to relocate the fuel tank. The guy with the blog bought one made for a volvo, since they share a platform. Basically bolted on. But yeah, you need to be able to weld. I can kinda weld, but not well enough I'd trust my car to it. I've got plenty of time to learn though, before even considering this swap.
 Old 10-11-2011, 05:06 PM   #47
maperformance's Avatar
Posts: 4,979   (View Stats)
Pm me for a great deal!!!
Modern Automotive Performance
 Old 10-11-2011, 05:38 PM   #48
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Condoms. That way I'll rest assured they won't break.
Tapadatass
 Old 10-11-2011, 07:32 PM   #49
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Lol. Volk ce28n's $3000
Awd conversion kit. $3000. Riiiiiight.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 10-12-2011, 08:12 PM   #50
vrspeed10's Avatar
Posts: 1,035   (View Stats)
vrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the world
Groaned at 25 Times in 10 Posts
Intake manifold, cams and injectors
If your not first your last.
03 Speed Protege.. SOLD
10 Speed3 BT and getting my DRANK on!!!
vrspeed10 is offline   Reply With Quote
The Following User Says Thank You to vrspeed10 For This Useful Post:
Alpha (11-28-2011)
 Old 10-12-2011, 08:21 PM   #51
EL F00LI0's Avatar
Posts: 703   (View Stats)
EL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the world
3" vband dp, intake manifold, 3" tip
Tapadatass
2008 MAZDASPEED 3 GT
| Cobb SRI | Cobb XLE BPV | SURE TIP | SURE RMM | Resonators Deleted | TurboXs Catless DP |
| Cobb AP Stage 2+ | PG/Godspeed FMIC | BC Coilovers | Evo X Wheels | 245/40/18 Hankook RS3 |
| Cquence Drilled/Slotted Rotors | Hawk HPS Pads | TWM STS | Glowshift Boost Gauge | Sti V Limited Front Lip |
EL F00LI0 is offline   Reply With Quote
 Old 10-12-2011, 08:34 PM   #52
Fatguy729's Avatar
Groans: 82
IMO the injectors... Even finding a way to simply improve the oem would be the highest selling, most needed mod for this platform. There are already IM solutions, atp makes a 3 inch dp with v band adapter. Cams would be cool but unnecessary ATM IMO... Every high power speed owner will tell you the main issue is fueling.
The Following 2 Users Say Thank You to Fatguy729 For This Useful Post:
Alpha (11-28-2011), jracer (12-06-2011)
 Old 10-12-2011, 08:57 PM   #53
EL F00LI0's Avatar
The 3" dp with vband is for the ms6 not the ms3. But yes I agree with injectors.
Tapadatass
 Old 11-20-2011, 07:15 AM   #54
blackstar's Avatar
Posts: 523   (View Stats)
blackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the world
anything for the speed6 lol. We need all the options we can get.
blackstar is offline   Reply With Quote
 Old 11-28-2011, 08:15 AM   #55
NinjaT1985's Avatar
Posts: 551   (View Stats)
NinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the world
Groaned at 33 Times in 10 Posts
a FMIC for genpu that's less than $600
2012 Toyota Tacoma
NinjaT1985 is offline   Reply With Quote
 Old 11-28-2011, 09:10 AM   #56
Alpha's Avatar
Posts: 3,711   (View Stats)
As stated by many... Injectors and a proper Intake Manfiold would sell like crazy!
 Old 11-28-2011, 09:58 AM   #57
Jarods7920's Avatar
Posts: 1,415   (View Stats)
Eaaaasssy there killer...I didn't tell you 2k lol. It's more like 3-4k in just parts. You do need a new transmission, or the bell housing from a speed 6. Let me reiterate that is just in parts! I am a fabricator so I was able to build this stuff myself. For average joe to tackle just the all wheel drive you are looking at a 6-7k price tag depending on how they wanted things done.
The Following User Says Thank You to Jarods7920 For This Useful Post:
Tokay444 (11-28-2011)
 Old 11-29-2011, 11:17 AM   #58
holeinmypocket's Avatar
Posts: 1,129   (View Stats)
holeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the world
i would have thought that map would have made something by now....but this thread seems pointless
EL F00LI0 likes this.
holeinmypocket is offline   Reply With Quote
The Following User Says Thank You to holeinmypocket For This Useful Post:
thehead (11-29-2011)
 Old 12-02-2011, 02:27 PM   #59
There really has not been anything very realistic unfortunately. We offer a ported intake manifold as it is. As for a sheet metal there are not many people willing to comit to one.
The Following User Says NO Thank You to maperformance For This Un-useful Post:
holeinmypocket (01-02-2012)
 Old 12-20-2011, 12:23 AM   #60
Zoomspeed's Avatar
Posts: 370   (View Stats)
Zoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the world
A grill for genpu that would sell
Performance CobbAPCobbSRI/TIPAutotechInternalsDensoITV22 PlugsForgeBPVJBRDog Bone MountSpeed DaddyCatless DownpipeGreddyOCC
Appearance DDM5000k Headlights/3000k FogsCobbShift KnobCorksportLED Bumper LightsDepoLED Tails
E85
Zoomspeed is offline   Reply With Quote
MAPerformance Ported Intake Manifold subparpunk03 Modern Automotive Performance 153 10-27-2015 07:24 AM
Props to MAPerformance. predapio Modern Automotive Performance 8 09-26-2011 01:45 PM
MAPerformance Behind The Scenes maperformance Modern Automotive Performance 121 07-22-2011 10:55 AM
Latest Fab @ MAPerformance maperformance Modern Automotive Performance 23 05-06-2011 01:54 PM
Page generated in 0.42547 seconds with 34 queries
