> MazdaSpeed 3/6 - Wheels & Tires > Wheels & Tires - COSMIC BLUE
Wheels & Tires - COSMIC BLUE Wheels & Tires on cosmic blue cars.
 Old 11-24-2009, 08:01 PM   #1
Ftaz1's Avatar
Posts: 111   (View Stats)
Ftaz1 is a splendid one to beholdFtaz1 is a splendid one to beholdFtaz1 is a splendid one to beholdFtaz1 is a splendid one to beholdFtaz1 is a splendid one to beholdFtaz1 is a splendid one to beholdFtaz1 is a splendid one to behold
Default 225-45-18
So there has been much discussion about the largest tires you can put on stock rims with no touching.... 225-45-18 have been said to be safe.
I just order and installed some continental extreme contact 225-45-18. Fantastic tires, but I am touching on deep dips and bumps on hard corners. The touching seems to be on the inside as I cannot see any marks from the outside.
I have decided to get some smaller tires because I do not feel like dealing with the touching issues.
Will it be better/safer to go with 225-40-18 or the stock 215-45-18 to have no touching issues??
Ftaz1 is offline   Reply With Quote
 Old 11-24-2009, 08:03 PM   #2
rguevara's Avatar
Posts: 76   (View Stats)
rguevara has much to be proud ofrguevara has much to be proud ofrguevara has much to be proud ofrguevara has much to be proud ofrguevara has much to be proud ofrguevara has much to be proud ofrguevara has much to be proud ofrguevara has much to be proud of
Groaned at 6 Times in 4 Posts
I have 225/40 18. No touching, no issues. And i drive this car hard.....
rguevara is offline   Reply With Quote
 Old 11-24-2009, 08:13 PM   #3
Ftaz1's Avatar
you have 225/40/18 on a MS3, stock rims, stock suspension with no rubbing at all?
Thanks for your reply....I just wanna make sure everything is stock and there is no rubbing at all?
Which tires do you have?
I'm also wondering what the difference in ride and performance will be going from 45 to 40?
 Old 11-24-2009, 08:25 PM   #4
glocK23's Avatar
Posts: 1,753   (View Stats)
glocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the world
Groans: 701
Groaned at 655 Times in 620 Posts
I'm almost 99% sure freeflyfreak is running 225/45/18 on stock suspension with no rubbing.
glocK23 is offline   Reply With Quote
 Old 11-24-2009, 08:29 PM   #5
Ftaz1's Avatar
well it obviously depends on the tire, because I am fully stock, and definitely touching front and rear with 225-45-18 continental extreme contact tires.
I know that several people have 225-45-18's on with no touching....
I would love to know if anyone is touching with 225-40-18's on stock rims and sus??
Last edited by Ftaz1; 11-24-2009 at 08:44 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-24-2009, 08:47 PM   #6
John F's Avatar
Posts: 790   (View Stats)
John F is the leader of the worldJohn F is the leader of the worldJohn F is the leader of the worldJohn F is the leader of the worldJohn F is the leader of the worldJohn F is the leader of the worldJohn F is the leader of the worldJohn F is the leader of the worldJohn F is the leader of the worldJohn F is the leader of the worldJohn F is the leader of the world
how many of these threads you going to make?
2010 Speed Three
John F is offline   Reply With Quote
 Old 11-24-2009, 08:54 PM   #7
Ftaz1's Avatar
WTF.... I dont know how that new thread got up there....I was editing this one and a new thread started somehow. I probably fucked up as usual! Sorry!
How do you delete a thread?
 Old 11-24-2009, 09:04 PM   #8
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
i'm running 225-40-18..zero rubbing issues...stock wheels and suspension
BFGoodrich T/A KDW2's
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 11-24-2009, 11:18 PM   #9
Always Blasted
DCLXVI's Avatar
Posts: 653   (View Stats)
DCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the world
Groans: 34
Groaned at 274 Times in 34 Posts
spacers and a fender roll cost less than a new set of tires? i'd opt for an improvement instead of reversion.
07 Speed 6 GT Cobb AP Stage 2+TIHSF+TMIC 93 Octane, ETS 3.5'' TMIC, Cobb Short Ram Intake, Cobb Turbo Inlet Pipe, Turbosmart Dual Port Blow Off Valve, SU Test Pipe, Custom CPE/Magnaflow Exhaust, Corksport Strut Brace, TWM Stage 2 Short Shifter, TWM Weighted Desert Eagle Shift Knob, AWR Transmission Mount, SU Base Bushings, SU Rear Motor Mount, Optima Yellowtop Battery, PIAA Plasma Ion Fogs, EBC Red Brakes, Denso ITV22s .28 Gap, Prosport Boost Gauge, RPM Sport Springs, Bilstein Shocks, SPC Balljoints, Continental Extreme Contact DWS AAA XL, Pirelli Sottozero snow tires, 5zigen ProRacer GN+ 18x8.5.
DCLXVI is offline   Reply With Quote
 Old 11-24-2009, 11:38 PM   #10
glocK23's Avatar
Groans: 701
If he's rubbing on the inside, spacers would probably help, but then he might have an issue with rubbing on the fender wall, or I might be wrong....
 Old 11-25-2009, 03:07 AM   #11
sleeperstang1994's Avatar
Posts: 569   (View Stats)
sleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the world
Groaned at 7 Times in 5 Posts
i just installed a set of 225-45-18 blizzaks on a customers stock wheels and suspension and it had some minor rubbing on the inside. She wasnt worried about it as it was only at a full lock turn. also they were snows so they are not gonna be installed year round. I run 225-40-18. im lowered with no rubbing. i hate how the tire looks though, to small.
sleeperstang1994 is offline   Reply With Quote
 Old 11-25-2009, 04:57 AM   #12
lvmazdaspeed3's Avatar
Posts: 367   (View Stats)
lvmazdaspeed3 is the leader of the worldlvmazdaspeed3 is the leader of the worldlvmazdaspeed3 is the leader of the worldlvmazdaspeed3 is the leader of the worldlvmazdaspeed3 is the leader of the worldlvmazdaspeed3 is the leader of the worldlvmazdaspeed3 is the leader of the worldlvmazdaspeed3 is the leader of the worldlvmazdaspeed3 is the leader of the worldlvmazdaspeed3 is the leader of the worldlvmazdaspeed3 is the leader of the world
bbm:30d818c6f86cbe45john
PURPLE VOLK TE37's Cp-e FMIC, Cp-e Fuel Pump, Cp-e Catless Downpipe, Cobb AP v103l BETA map, Injen CAI, TRZ Rear Motor Mount, TRZ Transmission Mount, Weapon R Engine Torque Dampner, N2MB Wot Box w/ 2 Step
lvmazdaspeed3 is offline   Reply With Quote
 Old 11-25-2009, 05:05 AM   #13
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
i have 225/40/18's with a 1.4" drop in the front and rear...no rubbing at all
2015 Mazda 6
 Old 11-25-2009, 06:54 PM   #14
rguevara's Avatar
Stock rims & supension. I have Hankook Ventus RS2.. Got a great deal on them, for the price you cant beat it. As far as handling, all i got for comparison are the stock tires that came with the car new, the Potenzas, the potenzas are 215/45. The potenzas handled better on the curvies.... These seem to give on the curvies, although they are stickier when aggressively launched...
 Old 11-25-2009, 08:09 PM   #15
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
i go thtese 225-45-18 and no rubbing..i even got traction bars
new tires for stock rims
 Old 11-26-2009, 07:07 AM   #16
The Angry Goose
Hectik1's Avatar
Posts: 3,219   (View Stats)
Groaned at 9 Times in 6 Posts
I have 225-40-18 Continental Extreme Contacts on my MS6 wheels and have driven about 20k miles on them including a trip to the Tail of the Dragon. Never rubbed once even with a full load.
Hector
2014 Mazda 3
2008 Mazdaspeed3-SOLD
1979 Mazda Rx7
 Old 11-26-2009, 07:26 AM   #17
Doc-1's Avatar
Posts: 407   (View Stats)
Doc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the world
Groaned at 30 Times in 15 Posts
I have the Mazdaspeed springs on and it did lower the car some. I am wondering if anyone is have issues rubbing with the V12 Hankook 225/45/18?
Doc-1 is offline   Reply With Quote
 Old 11-26-2009, 10:20 PM   #18
ms3077's Avatar
Posts: 4,024   (View Stats)
ms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the world
Groans: 974
Groaned at 738 Times in 373 Posts
I have currently 225/45/18 Nitto Invo - No rubbing whatsoever, stock suspension.
I had 225/40/18 Yokohama Parada Spec 2- No rubbing whatsoever, stock suspension.
By the way the Spec 2's are the only 225/40/18 tyre still within mfg spec for the MS3 stock 7' inch rim. Other's will fit however.
ms3077 is offline   Reply With Quote
 Old 12-01-2009, 04:57 PM   #19
bbonkboy's Avatar
Posts: 40   (View Stats)
bbonkboy will become famous soon enough
Groaned at 10 Times in 3 Posts
i have 225/40/18 on all 4. there is no rubbing.
One thing i noticed with the 225/40/18 is that when the speedo says im going 70 im actually going 68. Before when i had 215/45/18 when i was going 70 i was going 70.
but 225/45/18 might/might not fix this issue, not a big issue to me.
only thing i see is that it might be a bit higher in diameter. the mid number is the ratio of width to sidewall, i think. i think you will be fine.
you'll be fine, this guy here putt 225/45/18 on his and he said he was fine:
bbonkboy is offline   Reply With Quote
 Old 12-01-2009, 05:54 PM   #20
glocK23's Avatar
Groans: 701
thinner the tire the more it will fuck with the speedo
 Old 12-01-2009, 06:01 PM   #21
Ftaz1's Avatar
I realize that each tire has a different actual diameter and width, and also, lots of guys have 225-45-18 with no rubbing, while some do. Most people have said no rubbing with 225-40-18.
So I guess it has to come down to the actuall brand/model of the tire...it also comes down to the question of who has driven their cars hard with more than 2 adults in it, with 225-40-18's and had no rubbing??
With only me, my girl and the 6 year old in the car, there is hardly any (to no) rubbing at all with the 225-45-18, but if I add 1 more adult person...it is on!
 Old 12-01-2009, 08:14 PM   #22
papabearitt's Avatar
Posts: 39   (View Stats)
papabearitt has a brilliant futurepapabearitt has a brilliant futurepapabearitt has a brilliant futurepapabearitt has a brilliant futurepapabearitt has a brilliant futurepapabearitt has a brilliant futurepapabearitt has a brilliant futurepapabearitt has a brilliant futurepapabearitt has a brilliant futurepapabearitt has a brilliant futurepapabearitt has a brilliant future
wow... so im guessing i should not try the 235's huh
IM AFRAID TO MENTION MY MODS........ THE CORPORATE SPIES FOR MAZDA WARRANTY HOLDERS MAY BE ON HERE...........
papabearitt is offline   Reply With Quote
 Old 12-01-2009, 08:28 PM   #23
Ftaz1's Avatar
You May be ok. There are guys here with 235-40-18's with no issues. Check the specs...
 Old 12-01-2009, 08:50 PM   #24
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
Yes, like me.
No rubbing with +48 offset Rota SVN's on stock suspension aside from a Cobb RSB. Now I have a baby seat in the back and have only had 1 adult in the back around 200lb, so I can't say there would be no rubbing with two people in the back of size.
Frequentflyer is offline   Reply With Quote
 Old 12-01-2009, 09:05 PM   #25
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
i've had eagle gt's 225/40s and now nitto neo gens 225/40s - no issue with either
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 12-01-2009, 09:11 PM   #26
spnkr21's Avatar
Posts: 2,827   (View Stats)
225-45 18's on rx8 rims. No rubbin
 Old 12-01-2009, 09:23 PM   #27
Ftaz1's Avatar
So here's the next question....do you guys think that adding some spacers will get rid of the rubbing, or should I just go 225-40-18?
 Old 12-01-2009, 09:31 PM   #28
AFcadet's Avatar
Posts: 937   (View Stats)
AFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the world
You ordered the wrong tires.
225-40-18 are the ones that wont rub.
AFcadet is offline   Reply With Quote
 Old 12-01-2009, 09:35 PM   #29
Ftaz1's Avatar
Originally Posted by cpolly69 View Post
i've had eagle gt's 225/40s and now nitto neo gens 255/40s - no issue with either
Dude is that a mis-type or do you have 255/40s on your car??
 Old 12-01-2009, 09:44 PM   #30
PaPaSpeed's Avatar
Posts: 602   (View Stats)
PaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the world
Well, I just got a set of 225/40/18 all seasons to run a few months. I chickened out on the 225/45's because I didn't want to take the chance of rubbing. I have the Eibach Pro Kit springs on.
CP-E Nano, CP-E Turbo inlet, CP-E TurboBack, CP-E Full Control, CP-E CDFP, CP-E Standback, Cobb RSB, ETS TMIC, SU Boost Tubes, SU MM, SU Shifter Bushings, Forge BPV, Eibach Pro Kit, Saikou Michi OCC, Denso ITV 22, Redline Hood Lifts, Redline (shift boot, armrest, e-brake cover), Amsoil 5w-30, Amsoil 75w-90, TWM A-6, Black badges, SU black side markers, 40% Tint, Rota Torques Gunmetalic.
PaPaSpeed is offline   Reply With Quote
 Old 12-06-2009, 05:15 PM   #31
I don't think so. They rub on the fenders, not on the inside, so spacers probably won't help. That's why most people that are lowered roll their fenders with 225+.
 Old 12-06-2009, 07:42 PM   #32
cpolly69's Avatar
Groans: 27
yeah it was mis-type - i failed
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 12-10-2009, 09:55 PM   #33
Ftaz1's Avatar
anybody with a MS6 with 225-45-18s? Any rubbing issues on stock suspension? I might give my 225-45-18's to a friend with a MS6 if they will fit better there than in the MS3.
 Old 12-10-2009, 11:40 PM   #34
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
I have the Hankook V12s in that size.
I have heard a very brief ;ight rub twice in the rear, only with a load and over a huge depression at speed, and not recently, only when brand new.
Normal DD no rubbing at all.
Suspension:
 Old 12-11-2009, 07:18 PM   #35
BudUMfan's Avatar
Posts: 1,204   (View Stats)
BudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the world
Groaned at 9 Times in 7 Posts
I bought arronc7's RX-8 wheels. He suggested 235/40/18 with stock suspension. Anyone have thoughts on a good size for them? Again, bone stock suspension.
BudUMfan is offline   Reply With Quote
 Old 02-27-2010, 08:33 PM   #36
R3d Baron's Avatar
Posts: 28   (View Stats)
R3d Baron is a splendid one to beholdR3d Baron is a splendid one to beholdR3d Baron is a splendid one to beholdR3d Baron is a splendid one to beholdR3d Baron is a splendid one to beholdR3d Baron is a splendid one to beholdR3d Baron is a splendid one to behold
I've got 225/45/18 Dunlops and I rubbed on hard cornering before I had my fenders rolled.
R3d Baron is offline   Reply With Quote
 Old 03-08-2010, 01:06 PM   #37
BigJimMs3's Avatar
Posts: 4,859   (View Stats)
BigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the world
Groans: 76
Groaned at 22 Times in 20 Posts
i have 225/45/17 and i rub on my stock suspension also the tires are 8 inchs wide
2006 Mazdaspeed 6
BNR S4 and supporting mods
2007 Mazdaspeed 3
Bolt on's and tune
2015 Taurus S.H.O
Intake/Tune
2016 Ford Explorer Sport
Stock
BigJimMs3 is offline   Reply With Quote
 Old 01-27-2011, 08:44 PM   #38
WWPearlMS6's Avatar
Posts: 220   (View Stats)
WWPearlMS6 is the leader of the worldWWPearlMS6 is the leader of the worldWWPearlMS6 is the leader of the worldWWPearlMS6 is the leader of the worldWWPearlMS6 is the leader of the worldWWPearlMS6 is the leader of the worldWWPearlMS6 is the leader of the worldWWPearlMS6 is the leader of the worldWWPearlMS6 is the leader of the worldWWPearlMS6 is the leader of the worldWWPearlMS6 is the leader of the world
Groaned at 188 Times in 55 Posts
Wordddddddddddd
WWPearlMS6 is offline   Reply With Quote
 Old 12-27-2018, 03:03 AM   #39
gamma500's Avatar
Posts: 38   (View Stats)
gamma500 is a splendid one to beholdgamma500 is a splendid one to beholdgamma500 is a splendid one to beholdgamma500 is a splendid one to beholdgamma500 is a splendid one to beholdgamma500 is a splendid one to beholdgamma500 is a splendid one to behold
Old post revival. Have had 235/40-18 Conti's on my stock Gen1 with RX8 rims for years w/o a rub......
gamma500 is offline   Reply With Quote
The Following User Says NO Thank You to gamma500 For This Un-useful Post:
Thor Hammer (01-02-2019)
 Old 05-09-2019, 03:55 PM   #40
Sonofnothing's Avatar
Posts: 33   (View Stats)
Sonofnothing is on a distinguished road
That's the stock size on my speed3. Many people commented on that size not rubbing, and I'm seeing that as stock tire size on Mazda's Vin decoder.
Sent from my Pixel 3 using Tapatalk
'13 ms3 * 72k * FREEKtuned * Accessport v3 * COBB SRI/TI * Autotech HPFP * ETS TMIC * CS fully mounted * CS short shift plate/bushings * Goodyear Eagle F1 Asymmetric 3 * dash designs suede * weather tech floor mats.
Sonofnothing is offline   Reply With Quote
Page generated in 0.54501 seconds with 45 queries
