> MazdaSpeed 3/6 - Wheels & Tires > Wheels & Tires - SILVER
Wheels & Tires - SILVER Wheels & Tires on silver cars.
  • 1 Post By Vansquish
 Old 08-31-2018, 10:33 AM   #11
esalem's Avatar
Posts: 5   (View Stats)
esalem is an unknown quantity at this point
Originally Posted by Solarsurge View Post
I probably should clarify what you should do if it's "stuck"...
The fuel pump has a piston that sits inside the cam follower. It's a solid piece of metal and it doesn't like to flex. If it's crooked, it won't want to come out or go in and will seem to be "stuck." You might have to straighten it out by putting pressure on the side where the bolts came undone, threading in the bolts, then loosening the bolt that is in place. It should come out if it's straight. Inspect everything and make sure nothing is damaged, including the cam follower. The cam follower is a little bucket that sits on top of the piston. That contraption looks like this:
(Intake Cam Lobes)▷[===(Fuel Pump Piston)
When you pull the piston out, stick your finger in the hole and grab onto one of the inner walls of the cam follower bucket and pull it out to inspect it. It's normal for the sides to be a little bit worn, so don't worry about scuffs unless they're big enough that you can feel them with your fingernail. As long as everything looks fine, replace your fuel pump piston and put everything back together.
Thank you for all your help man, i am going to take it apart on Sunday hopefully.
esalem is offline   Reply With Quote
I messed up sboogie Mazdaspeed3/6 General Discussion 18 03-20-2013 07:34 PM
Messed up BAD dpolseno41 Mazdaspeed3/6 General Discussion 10 03-14-2012 07:46 PM
AP messed up... glndrums
Cobb ATR Support
10 09-11-2011 12:09 PM
all messed up bmfms3 Exterior 54 07-04-2011 02:29 PM
Page generated in 0.32158 seconds with 25 queries
