 Old 05-24-2015, 10:10 AM   #1
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
They actually recovered rather quickly thank you very much. In less than two days they were back to normal.
Well I object to that assertion.
Absent detrimental consequences due to changes in offset such as bumpsteer, a wider track will get you faster through the turns.
Not that the OP is really using the spacers for that purpose.
...but it wouldn't be "absent detrimental consequences" at all. You can't really widen the track with spacers without introducing the negatives (scrub radius changes, wheel rate changes, etc.).
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
Tomas (05-24-2015), WetzMS3 (05-27-2015)
Eibach pro spacer 10mm Atomic41 Mazdaspeed3/6 General Discussion 14 01-17-2017 02:06 PM
Eibach 10mm spacer kit impression /info Mazdaspeed3KHP 2010 MS3 - Wheels & Tires 2 07-30-2013 12:34 AM
Genpus + 10mm eibach spacers + ARP studs dale_gribble MazdaSpeed 3/6 - Wheels & Tires 1 02-01-2013 03:38 PM
10mm spacer + 5mm spacer Atomic41 Wheels & Tires - BLACK 3 12-05-2012 11:47 AM
Page generated in 0.24065 seconds with 21 queries
