> Mazdaspeed Forums Performance Parts Reviews > Review Discussion
Review Discussion Want to comment on a review, do it here.
  • 1 Post By GroceryGtr
 Old 07-05-2018, 09:12 PM   #1
arnold600's Avatar
Posts: 31   (View Stats)
arnold600 is on a distinguished road
Exclamation Mazdaspeed 6 low boost issue
I have a 2006 mazdaspeed 6 with a corksport srt + tip, Cobb apv3, corksport hpfp, and some other mods. anyway, I only get 13 peak psi of boost and the most ive ever seen was 14.1 on the cobb. I looked all over my pre and post turbo connections and everything seems tight and secure. Ive also tried unplugging the battery and doing a re-flash of the cobb ots stage 1+sf 93 map. still not hitting over 13psi. my idle is smooth. However, my wastegate duty cycle on the cobb seems to be a bit suspect and starts to kick in around 10 ish psi. Thoughts?
arnold600 is offline   Reply With Quote
Low boost issue nicknguyenle 2010 MS3 - Troubleshoot/Diagnostics 4 02-05-2018 08:30 AM
Over Boost Issue, Boost leak? vincentspeed3gogh MazdaSpeed 3/6 - ECU Computer Tuning 23 12-27-2014 02:31 AM
Need Help with a possible Boost Cut issue??? EddyV1987 MazdaSpeed 3/6 - Big Turbo Builds 7 04-24-2013 04:24 PM
Boost issue sriser66 MazdaSpeed 3/6 - Turbo Induction 4 03-19-2013 10:40 PM
Page generated in 0.32873 seconds with 26 queries
