> Cobb Tuning >
Cobb Access Port/Maps
Closed Thread
 Old 05-02-2013, 08:59 PM   #1
LocoMazda's Avatar
Posts: 48   (View Stats)
LocoMazda is a splendid one to beholdLocoMazda is a splendid one to beholdLocoMazda is a splendid one to beholdLocoMazda is a splendid one to beholdLocoMazda is a splendid one to beholdLocoMazda is a splendid one to behold
Default Where to get older AP maps?
My car (Speed6) does not like the v231 map as it was not hitting the advertised 16 lbs of boost & sometimes was even less than stock boost. Stock tune the car boosts fine. I tried the v102 map and it hits the advertised 17 lbs, but that map is obviously not as smooth under normal driving vs the v231.
What maps were released in between those and is there anywhere I can get them?
Specifically the Stage 1 93 octane MS CAI v1 & Stage 1 93 octane MS CAI v1 + TIP maps
LocoMazda is offline
 Old 05-03-2013, 08:03 AM   #2
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Same answer, different forum.
OTS Maps will always be a touch hinky. They'll behave much better when refined to your own car. As we discussed previously, the mazdaspeed is a totally different animal from your BMW, and OTS maps will not behave the same.
You really do want to start from a current map, then fine tune to your goals/needs/desires.
Still, if you want to go play with old maps, below is a link to the best geriatric archive I know of. Be sure to open & resave them in your copy of ATR to avoid conflicts.
Cobb MS6 Maps
Enjoy
340hp / 371tq
TiGraySpeed6 is offline
 Old 07-28-2013, 03:30 PM   #3
Hokie D's Avatar
Posts: 157   (View Stats)
Hokie D is the leader of the worldHokie D is the leader of the worldHokie D is the leader of the worldHokie D is the leader of the worldHokie D is the leader of the worldHokie D is the leader of the worldHokie D is the leader of the worldHokie D is the leader of the worldHokie D is the leader of the worldHokie D is the leader of the worldHokie D is the leader of the world
Groaned at 4 Times in 1 Post
Ha, I just installed v2.31 maps on my '10 Speed3 after running v1.01 for the last two years. Holy crap the car feels different. Smooth. It used to be real jerky. Doesn't feel as strong now...perhaps the jerkiness made it feel more powerful before. Will do some logging and see what it's up to.
2010 Celestial Blue Mazdaspeed3 - Cobb SRI, Cobb Air Box, Cobb TIP, Autotech Internals, OBX Test Pipe, ETS TMIC, Stratified OTS 93+E85 Flash Tune, Corksport Hood Scoop, Resonator Delete, JBR Short Shift Plate - Suspension: Eibach Pro Springs, Stock Struts/Shocks, JBR Rear Sway Bar
https://youtu.be/qp4Ew15bjZE
2014 Race Red Shelby GT500 - 100% Stock
https://youtu.be/zcy-6YfO7SQ
SOLD: 1993 Reef Blue Ford Mustang 5.0L Notch - Lotsa Mods
https://youtu.be/jLdRGHEkv2A
Hokie D is offline
The Following User Says Thank You to Hokie D For This Useful Post:
mxlplx71 (07-28-2013)
Closed Thread
MS3 VS 2 LS1 GTO's and VS Older Mustang silentwolf8 Street Racing Stories ( Bench Racing ) 9 09-09-2012 05:43 PM
Ignition tables in the OTS 1.02 Gen 1 boost maps, hugely different from the Load maps FreeFlyFreak MazdaSpeed 3/6 - ECU Computer Tuning 11 08-18-2011 11:03 PM
Any input from Stage 2 ONLY maps (not + SF, MSCAI maps) steven88
8 10-15-2008 06:48 AM
Page generated in 0.24278 seconds with 22 queries
