> Cobb Tuning >
Cobb Access Port/Maps
Like Tree3Likes
  • 1 Post By TazFc3s
  • 1 Post By Sid3wayS
  • 1 Post By mxlplx71
 Old 08-27-2013, 08:53 PM   #1
Cuneo'sSpeed3's Avatar
Posts: 2   (View Stats)
Cuneo'sSpeed3 is on a distinguished road
Groaned at 7 Times in 1 Post
Default which map should I run?
2011 mazdaspeed 3 Corksport FMIC with TIH and intake CS downpipe CS high flow CAT With full CS exhaust TS BOV
Now should I run the Stage1+CS+TIH+IC 93 which has everything but the high flow cat and the down pipe
or
Stage2+CS+TIH+IC 93 which includes the HF CAT and Downpipe?
also both maps have listed CDFP - Camshaft Driven Fuel Pump
which I'm not to sure of.
if anyone has some input that would be great.
2011 MS3 - H&K lowering springs CS FMIC CS intake Turbosmart dual BOV CS down pipe CS high flow cat CS full CAT back COBB accessport V3
Cuneo'sSpeed3 is offline   Reply With Quote
The Following User Says Thank You to Cuneo'sSpeed3 For This Useful Post:
Sid3wayS (08-27-2013)
The Following 7 Users Say NO Thank You to Cuneo'sSpeed3 For This Un-useful Post:
ANITIX87 (08-28-2013), dereeek (08-27-2013), faeker (08-27-2013), Hush (08-27-2013), Jeremy3eb (08-27-2013), smoogs12 (08-28-2013), Vansquish (08-27-2013)
Page generated in 0.38270 seconds with 33 queries
