> Cobb Tuning >
Cobb Access Port/Maps
 Old 02-09-2013, 10:20 PM   #1
JDMJOSH's Avatar
Posts: 642   (View Stats)
JDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the world
Groaned at 8 Times in 5 Posts
Default Confusion about map descriptions...
Looking at the map notes for a Stage1+CS+TIH 91 v231 it states I need an upgraded IC but the notes for the Stage1+CS+TIH 93 v231 says it doesn't?
Why is that? Am I ok to go with the 91 octane map without an upgraded IC anyhow?
JBR 3.0" WP // CS Racepipe // UR CBE // CS TMIC // CS SS Plate + Bushings // Autotechs // NGK's // Damond Oil Restrictor Bolt // Forge v2 // JBR RMM 88 // JBR .250 RSB // CS Springs/Struts // SPC Camber Arms //
JDMJOSH is offline   Reply With Quote
MAF Cal Breakpoint/General Confusion andrewpiro MazdaSpeed 3/6 - ECU Computer Tuning 0 05-03-2012 05:39 PM
MAF Cal confusion omgheyitskenny MazdaSpeed 3/6 - ECU Computer Tuning 12 05-01-2012 01:38 PM
Tuning Confusion... MS3KO MazdaSpeed 3/6 - ECU Computer Tuning 6 04-07-2010 11:52 AM
motor mount confusion mexicant MazdaSpeed 3 - Engine, Transmission & Driveline 62 01-03-2009 03:57 PM
Page generated in 0.23220 seconds with 21 queries
