Closed Thread
 Old 12-01-2008, 04:15 AM   #1
racersir's Avatar
Posts: 71   (View Stats)
racersir is an unknown quantity at this point
Default Standback Questions
I bought a used SB 2 that I'm ready to install but I want to zero out everything before I do. How do I do that? Do I just hit back to factory default button? Also would it be safe to have everything zero out and up the boost to 17 psi?
racersir is offline
 Old 12-01-2008, 04:44 PM   #2
btkrausen's Avatar
Posts: 48   (View Stats)
btkrausen is just really nicebtkrausen is just really nicebtkrausen is just really nicebtkrausen is just really nice
zeroing out the maps means click each table on the left, like under MAF, MAP, Timing, etc and make sure the table reads all 0's.
Putting it to 17psi with everything 0'ed out is pretty much how everyone else has started out that I've seen. Run a few pulls with it like that and data log it, then begin making changes from there.
-bryan
CP-E CAI | CP-E FMIC | CP-E Standback v2 | CP-E PnP | CP-E Flash | CP-E SSQV BOV Kit | Cobb STS | Cobb Shifter Weight | SU MM | SU Test Pipe | Boost Gauge | Black out Side Markers | SU Bushings | DashHawk
To Be Installed: DNP Turbo Manifold
btkrausen is offline
 Old 12-01-2008, 07:45 PM   #3
racersir's Avatar
Thanks man I just did zero everything out, installed the SB at 17.5 psi, ran great with no problems. I just have to now install my Cobb FMIC and Denso plugs to begin tuning Thanks again
racersir is offline
 Old 12-01-2008, 07:55 PM   #4
btkrausen's Avatar
no problem. i'm still new to the sb as well, but i'm running a map that is decent for now. my boost is set at 17 for now.
-bryan
Closed Thread
CP-E Standback jhershorin MazdaSpeed 6 - Engine, Transmission & Driveline 9 10-30-2008 09:53 PM
Cp-e Standback???? oskinosmee MazdaSpeed 3/6 - ECU Computer Tuning 7 08-25-2008 06:35 PM
Standback Questions JimmyMac Custom Performance Engineering (cp-e.com) 1 07-23-2008 07:26 AM
Page generated in 0.24117 seconds with 21 queries
