> MazdaSpeed 3 - How-To's
 Old 01-02-2019, 12:00 AM   #1
Chocolie's Avatar
Posts: 3   (View Stats)
Chocolie has a little shameless behaviour in the past
Default Check Engine light
I am new to the whole tuning scene and need some help. I installed a cobb Sri intake and the check engine light for running too lean always pop up. I have check to make sure everything is all tie down. I have not gotten a turn yet and any help would come a long way. TY
Chocolie is offline   Reply With Quote
 Old 01-02-2019, 03:19 AM   #2
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
A Cobb SRI intake should work with the stock tune and MAF calibration even though there's about 10% deviation which is manageable.
So most probably you either forgot to connect one of the EBCS lines, did not tighten enough the clamp between the SRI and turbo inlet pipe, or upset the turbo inlet pipe especially if you're still using the stock one which is pretty flimsy.
Other than that you check for common mistakes such as not tightening the MAF sensor properly, or damaging it's sealing o-ring, or fitting it backwards.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
AFR check engine light. Ms3jerm MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 6 08-11-2015 09:04 AM
Check engine light came on after 7 months with light mods SwizzleSpd MazdaSpeed 3/6 - Turbo Induction 10 01-03-2013 05:15 PM
engine idle and check engine light msalva2 MazdaSpeed 3 - Engine, Transmission & Driveline 35 07-25-2012 04:48 PM
Check Engine Light Stingray69 Gen2 MS3 General Discussion 5 11-18-2011 04:37 PM
Oh No Check Engine Light! thabigo MazdaSpeed 6 - Engine, Transmission & Driveline 8 04-04-2009 01:57 PM
Page generated in 0.23717 seconds with 21 queries
