| MazdaSpeed 3/6 - Wheels & Tires HaveMazdaSpeed 3 - Wheels & Tires - Have a question about wheels or tires? Need a calculator to figure out offsets? We have them in here |
![]() Join Date: Jul 2014 Location: The Rio Grande Valley, Texas. USA.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 99
Groaned at 6 Times in 4 Posts
(Thread Starter) | Not Ranked : 0 score So, due to budget constraints my choices are Hankook V12 $362, Hankook S1 $367, Kumho Ecsta 4X II $349, and finally Firehawk Indy 500 $325. Which set will have a noticeable difference in terms of ride/noise and treadwear?
__________________ [SIGPIC][/SIGPIC]It's OK to cry" - Lil B 2012 MS3 w/Tech Package Engine: CS SRI/Tip, AutoTech internals, Damond Banjo Bolt, JBR Boost Tubes, E-Focus Mount, CS Racepipe, Tuned by FREEKTUNE Trans: CS insert, CS bushings, Damond Shifter Plate Suspension: Koni Orange with OEM springs, Konig Controls 17x7 with 225/45 Conti DW's Appearance: CP-E Relocation Plate, Smoked Taillights, Bumper Guard, CS Steering wheel/Shift knob/E-brake handle,dumb stickers |
Groans: 111
| Not Ranked : 0 score Get a Michelin tyre if you want grip and comfort. The pilot supersports are as good as a decent road tyre can get.
| The Following User Says Thank You to mituc For This Useful Post: | AveryPlaysBass (09-07-2016) |
![]() Join Date: Oct 2014 Location: sudbury ON, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 82
| Not Ranked : 0 score A friend of mine had the Firehawk Indy 500 on his speed, no complaints. They seem to be holding up fairly well to some decently aggressive driving around town. I've been in the car a few times with him and didn't notice much in terms of road noise, although I've also never been on a trip in his car and that's really the only time you would notice a lot of road noise. As far as the others, I'm not sure. Supersports are great...and expensive. |
| The Following User Says Thank You to alden For This Useful Post: | AveryPlaysBass (09-07-2016) |
![]() Join Date: May 2014 Location: Coopersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 186
| Not Ranked : 0 score That's odd. I experienced minimal to no extra road noise from my Sport Comp 2's. |
![]() Join Date: Jan 2013 Location: Vancouver, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 130
| Not Ranked : 0 score I've had the Firehawk wide oval indy 500 on my speed3 for roughly the last 30K. They do last quite a while even with some occasional abuse. I will say though that their performance in even slightly cooler (below 50) weather is pretty lack luster. For road noise they are pretty decent until you get to about half their tread life and they get pretty loud, wet performance is pretty average but dry (warm) performance is pretty darn good for a cheap street tire. FWIW they are pretty good deal but if you can spend more it will yield a better experience.
__________________ 2011 Mazdaspeed3 non-tech package Drivetrain CorkSport 3.5" MAF & TIP | CP-E FMIC | Synapse BPV | CorkSport EBCS (Interrupt) | Bosch 3 bar MAP | CorkSport HPFP Internals | CP-E Catted Downpipe | CP-E Triton 3" CBE | JBR Stage 2 OCC | Kozmic Primary EGR Delete | JBR Secondary EGR delete | NGK 6510 | TB coolant Bypass | JBR IM & TB Gaskets | Damond RMM, PMM, & TMM | JBR light shift weight | TWM Full Replacement Shifter | Cobb AccessPort V3 | FreekTune Chassis JBR Front & Rear Sway Bars | JBR Billet Rear Sway Bar Brackets | Whiteline Adjustable Front&Rear sway bar links | JBR Coilovers | Corksport BBK | Corksport Lower Tie Bar | Corksport Mid Chasis Brace Rice LED bumper reflectors | Morimoto LED Fog lights | VLEDs LED Highbeams | Independent Fogs | AP Engine & HPFP cover | CorkSport Pulleys | Corksport Leather Shift Knob | Corksport Steering Wheel | Damond front plate mount | Lukas LK-9750 2ch dashcam | Eonon GA7163 | thespeedline.com blue mirrors | thespeedline.com hood dampers |
| The Following User Says Thank You to nekret For This Useful Post: | AveryPlaysBass (09-07-2016) |
(Thread Starter) | Not Ranked : 0 score I guess compared to my older Kumho's they had additional noise and rode stiffer. I mean they're not bad for short rides but on long drives they're pretty annoying.
__________________ [SIGPIC][/SIGPIC]It's OK to cry" - Lil B 2012 MS3 w/Tech Package Engine: CS SRI/Tip, AutoTech internals, Damond Banjo Bolt, JBR Boost Tubes, E-Focus Mount, CS Racepipe, Tuned by FREEKTUNE Trans: CS insert, CS bushings, Damond Shifter Plate Suspension: Koni Orange with OEM springs, Konig Controls 17x7 with 225/45 Conti DW's Appearance: CP-E Relocation Plate, Smoked Taillights, Bumper Guard, CS Steering wheel/Shift knob/E-brake handle,dumb stickers | |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
| Not Ranked : 0 score +1 for the Indy 500 got them off tire rack for 450 few months back. Good budget tires with traction look up there review/track test on tire rack. Just to be clear these are the Indy 500 not wide oval Indy 500. Also the wife dailys the speed with my 2 kids back and forth to school with these on and no complaint about road noise. |
| Not Ranked : 0 score So one trick to get some nice tires at a low cost is to check out ebay. every once and a while discount tire will offer some pretty decent discounts. I got 4 245/40/18 Michelin PSS shipped to my door for $600. Still not as affordable as the Firestone tires but they'll feel so nice (assuming I ever get my evo wheels back from powder coating).
| The Following User Says Thank You to nekret For This Useful Post: | AveryPlaysBass (09-08-2016) |
| Aint this some !!!!!! | qtrmile beast | MazdaSpeed 6 - Engine, Transmission & Driveline | 6 | 10-21-2012 11:34 AM |
| You aint no racecar unless your does this | bewsted | JAMES BARONE RACING | 19 | 08-14-2012 04:49 PM |
| Supra aint got shit | atenza_freak | Members Rides Gallery | 29 | 01-17-2011 05:09 AM |
