| POWERED BY POLSKA ![]() Join Date: Apr 2010 Location: Eagle, WI
Rep Power: 389 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 948
Groans: 38
(Thread Starter) | Neutral : +5 score The following applies to all 2.3 MZR DISI powered mazdas as they all share the same pump. (ms3 both gens- ms6- cx-7) GENERAL Direct injected engines require a far higher fuel pressure then a port injected engine. This is why we have two fuel pumps. We have an in-tank pump and a high pressure cam driven pump. The high pressure pump is commonly referred to on this site as the HPFP(high pressure fuel pump) and occasionaly as a CDFP(cam driven fuel pump) The in-tank pump sends fuel at a low pressure to the HPFP which vastly increases the pressure and sends the fuel to the injectors. For a very basic overview, here's a MSPaint picture: From the fuel tank, fuel gets pumped via an "in tank fuel pump" (ITFP) at ~50-60psi through the red "line"... that's enough pressure for your port injectors, and it's really all about how much fuel it can flow, rather than the pressure. The HPFP then takes this fuel, and pressurizes it up to 1600+ psi... As you modify your car and make more power the engine requires more fuel to feed the ignition process. At some point the stock HPFP will lack the ability to keep up with fuel demands. When this happens your engine enters a dangerous scary world of possible boom. Thankfully we have some upgrade options making real power a possibility for us. So how do you know when you need to upgrade? The ONLY real way to know positively is through a logging/ ecu data device which can read/log your fuel pressure, such as an access port or dashhawk. Any thing under 1600 psi at WOT is a case of needing an upgrade. However, many would say to upgrade before it is NEEDED. Who wants to drive around like a grandma while waiting for parts and install anyways? What does this look like in your logs? Well, something like this: See how it's dropping below 1600psi? this is a sure sign that the HPFP is not capable of keeping up with the fueling demands. The modification level that requires a HPFP uprade varies from model to model, gen to gen, and even car to car. (READ THE PARAGRAPH ABOVE AGAIN) GEN 1 MS3 & MS6 Most low level flow mods are ok( intake,test pipe, CBE etc) Add an upgraded intercooler or a tune and your pushing it. Add a downpipe and you might as well get the internals installed FIRST. Don't even think about upgrading your turbo without an upgrade. GEN 2 MS3 The genpu does not play as nice with the HPFP. Many need an upgrade with just an intake, and Cobb states that some HPFP's will not keep up with stage 1 maps. Upgrade should be very early on your list. CX-7**** Much like MS3's, refer to 1st and 2nd Gen MS3 above I cannot say this enough the ONLY way to know for sure is through logging. OPTIONS So you've decided to upgrade, now what? Well, you can either buy yourself an upgraded pump, or save some money and buy upgraded pump internals to install into the pump yourself. The full pump is about as easy as it can get to install, but many members here have installed internals themselves with no issues(this is the route most take). All these items are available from many different vendors both on MSF and not, and at varying prices. I am only linking to the manufacturers site and giving their prices. You will notice some are listed as VW/AUDI parts, this is because we share a common HPFP with some of their engines- do not worry about that I will list the internals kits first. Autotech part number 10-127-100k $399.95 VW Performance - Autotech Sport Tuning: Hi-Volume Fuel Pump UpGrade Kit 2.0T FSI ![]() KMD part number 03020 $329.95 Audi - A3 - 2.0T FSI - Engine - KMD Tuning - 2.0T FSI High Pressure Fuel Pump Kit - KMD Tuning & Engineering HPFPupgrade(ptp) part number HPFP00005 $349.00 Mazda DISI Do It Yourself Pump Internals | HPFPUpgrade.com CorkSport Max Flow Fuel Pump part number Gen-6-999-10 $349.99 CorkSport Max Flow HPFP Fuel Pump Internals ![]() Now for the full pumps Most pumps will require you to pay a core charge added to the price of the pump, when you install your new pump you send your old pump back to them and get your core charge refunded back to you. CP-E part number MZR23HPFP $667.56+$350 core MZR DISI 2.3 HPFpump HPFP upgrade(ptp) 2 options 1-upgrade your pump(send it to them, they upgrade it and send it back) part number HPFP00004 A-stage 1 $549.00 B-stage 2 $799.00 Mazda DISI Upgrade Your Pump | HPFPUpgrade.com 2-complete HPFP(prebuilt and core charge-no wait) part number HPFP00003 A-stage 1 $549.00+$350.00 core B-stage 2 $799.00+$350.00 core Mazda DISI Complete High Pressure Fuel Pump | HPFPUpgrade.com Need some help with install? Luckily you've found the best damn Mazdaspeed tech site in the world and we can help you with that. Fuel Pump internals Install! CDFP internals upgrade How-to: Install your Autotech fuel pump internals
__________________ BNR S3---GS 3PORT---3bar map---COBB SRI & TIP---PG/GODSPEED FMIC ---DNP MANI--- CNT catted TBE--CP-E HPFP-- DIY P&P'd intake mani---SURE TIG(mani & tb)---DIY EGR delete---DIY VCTS delete--- DIY OCC/PCV reroute(through old egr port)---CP-E S2 RMM---JBR 80 PMM---TS BPV--- SURE ANCHORS---JBR shift weight---Whiteline RSB 25%E85FREEKPERMED Last edited by Raider; 02-02-2015 at 01:49 PM. Reason: 2015 update! |
| The Following 44 Users Say Thank You to themytb For This Useful Post: | Alexsered (01-07-2014), ant_wailes (05-06-2012), Arnie1229 (01-14-2015), AZSPEED3 (02-15-2012), BIGPATTY101 (11-21-2013), BlackSpeed303 (09-20-2012), Brennan (03-01-2012), Briggs (10-16-2013), CWP_MS3 (04-26-2012), dead-zone (03-27-2012), Detox_MS3 (02-22-2013), donjohnk (04-23-2013), DonMS6 (12-06-2014), Donut (04-21-2014), dsb_chicago (01-22-2013), ericrapp0507@gmail.com (07-17-2016), Funkster777 (02-15-2013), gaspipe (03-24-2013), Gitcherex (11-21-2015), Ingle (03-16-2012), J'sSpeed3 (02-16-2012), Javi (11-19-2012), jax ms3gt (01-30-2013), Jebus (05-09-2014), Jetech (07-02-2013), kaprikorn (04-12-2013), kunfu (04-21-2012), MazdaMOFO84 (06-14-2012), meicalnissyen (04-18-2012), Menace1 (02-11-2013), MS3Dreamz (06-06-2014), MS6FL (03-13-2012), nycMS3 (03-20-2012), Qwik6 (08-11-2013), Raider (02-15-2012), redvine (07-12-2014), ruthless013 (03-23-2012), SeeMeGovan (01-26-2014), spals (03-10-2013), speed3Texas (03-28-2012), tec_41 (09-09-2015), Twofer (11-25-2012), wankular (03-20-2012), White Jade (07-11-2012) |
![]() Join Date: May 2009 Location: Huntsville, AL
Rep Power: 1431 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,522
| Not Ranked : 0 score Protip, compliments of @superskaterxes when he helped me with my install: you don't need to remove battery box or TIP/TIH when doing this install. There is enough room for you to do it without removing all that crap. End result is a lot less time spent doing the install.
__________________ True Red 2009 MS3 Damond Motorsports: RMM // Short Shift Plate Suspension: Koni Yellows // Swift Spec-r springs // Fatcat motorsports front bump stops // Rear Camber Arms Brakes: Hawk HPS pads // ATE Superblue fluid // Stainless Steel Brake Lines Other: CP-e Safe Seals // MattDamond shift plate // Masonvi shift knob // 3.5" WP w/recirc // RSB // IM + TB tigs // Synapse Engineering FMIC + BOV // Autotech internals Tune: hypnotic tuned Critical Stats: // 305whp/352tq // 13.34 @ 98 - Mason Dixon Dragway - 4/13/14 Titanium Gray 2006 Mazdaspeed 6 Damond Motorsports: OCC // Short shift plate // Turbo oil feed restrictor bolt Other: Autotech internals // Ebay M2 DP // Masonvi shift knob // |
![]() Join Date: Dec 2011 Location: Red Deer,AB Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,855
| Not Ranked : 0 score Well written...this may stop all the other over talked about pump questions...props!!
__________________ 2010 Mazdaspeed 3 Black Mica w/ Tech Package - Traded In 2014 Ford F150 FX4 Ecoboost - Current |
| The Following User Says Thank You to Dmurray06 For This Useful Post: | JMRodriguez (12-25-2016) |
![]() Join Date: Dec 2009 Location: Kirkland, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 38
| Not Ranked : 0 score I had a suggestion. Might you add something about the reliability of the kits listed above? I know that there have been some sketchy players in the past. Are all of the parts listed above high quality (or at least seem to be so far)? |
| The Following User Says Thank You to sharky For This Useful Post: | PreyStayShun (02-27-2012) |
Groans: 38
(Thread Starter) | Not Ranked : 0 score My understanding is that all these "official" threads are supposed to be unbiased as far as listings of products. Pre purchase research is always a good idea anyways. Hopefuly these threads will be around a long while and this way they will not need to be changed if a vendor goes to shit.
__________________ BNR S3---GS 3PORT---3bar map---COBB SRI & TIP---PG/GODSPEED FMIC ---DNP MANI--- CNT catted TBE--CP-E HPFP-- DIY P&P'd intake mani---SURE TIG(mani & tb)---DIY EGR delete---DIY VCTS delete--- DIY OCC/PCV reroute(through old egr port)---CP-E S2 RMM---JBR 80 PMM---TS BPV--- SURE ANCHORS---JBR shift weight---Whiteline RSB 25%E85FREEKPERMED |
![]() Join Date: Feb 2012 Location: Tyler, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,127
Groans: 75
| Not Ranked : 0 score Probably a stupid question but does upgrading the HPFP make you lose MPG? The way I see it it does.
__________________ ///VRM 2006 UNICORN Speed6 GT #02418/// STOCK AS OF 2015... Old Stuff.... /// COBB AP /// AT HPFP /// 20psi Teck5 Tune by Ekanddsm /// JBR RMM /// HTP 3" Intake System /// SURE Dreadnaught and Juggernaut /// /// Denso ITV22 /// Mystery Testpipe /// Fidanza Lightweight Flywheel /// Eagle Motorsports Full-Faced Clutch Upgrade /// /// Megan Racing Springs /// SPC Adjustable Balljoints /// JBR TIGS, EGR Delete and Coolant Bypass /// |
Groans: 38
Anyways while cruising the upgraded pump will be putting out about the same pressure as a properly working stocker. It's only at WOT that the stock pump cant keep up with flow demand at required pressure.
__________________ BNR S3---GS 3PORT---3bar map---COBB SRI & TIP---PG/GODSPEED FMIC ---DNP MANI--- CNT catted TBE--CP-E HPFP-- DIY P&P'd intake mani---SURE TIG(mani & tb)---DIY EGR delete---DIY VCTS delete--- DIY OCC/PCV reroute(through old egr port)---CP-E S2 RMM---JBR 80 PMM---TS BPV--- SURE ANCHORS---JBR shift weight---Whiteline RSB 25%E85FREEKPERMED | |
| The Following 6 Users Say Thank You to themytb For This Useful Post: | BlackSpeed303 (09-20-2012), CWP_MS3 (04-26-2012), Juyoung (04-23-2013), KingKoopaBoy (09-03-2012), MPSpeed (07-25-2013), xI Leveler Ix (03-20-2012) |
Groans: 75
| Not Ranked : 0 score YES! Thank you so much! I was pretty worried about it. Cause I'm looking at getting the Genpu and I realize its a much needed mod (practically mandatory), and I drive everyday 50+ miles, so I need as best gas mileage as possible....You know when I'm not squashing hondas
![]() Join Date: Feb 2012 Location: Sacramento, CA
Groaned at 33 Times in 13 Posts
| Not Ranked : 0 score Fuck off. Racecar!
__________________ 2010 Liquid Silver MS3 - COBB SRI/TIH, AP, JBR 88 Duro RMM, JBR Bushings, JBR SSP, AT Internals, CP-e Catted DP/RP, Michelin Pilot Super Sports 235/40 18, Motorcraft MT Fluid, Step Colder NGK's Wife's Car: 2013 CX5 AWD Grand Touring (It's slow but handles nice) OBAMA SUCKS Stratified Tune by Lex Last edited by Bosox; 03-23-2012 at 09:07 PM. |
| The Following User Says Thank You to Bosox For This Useful Post: | AwAfrican (04-20-2015) |
![]() Join Date: Apr 2012
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score So, If my '12 ms3 is getting a lean code with a cai, should I upgrade the pump or get it tuned to fix it? Not looking for too much power, 300 would be good. |
![]() Join Date: Dec 2011 Location: Baltimore, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 104
I believe I know the answer so tread lightly. Sent from my iPhone using Tapatalk | |
Groans: 38
(Thread Starter) | Not Ranked : 0 score 99% of lean codes have nothing to do with your fuel pump---- you should be looking for a vac leak first thing.
![]() Join Date: Jul 2010 Location: Victoria B.C.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
Groaned at 20 Times in 14 Posts
| Not Ranked : 0 score I just did an internal install and my idle fuel pressure is down to 60 PSI, it will climb up to around 300 with a but of throttle. Everything seams to be installed correctly and moving nicely. I followed the AT instruction and removed and cleaned everything ensuring to reinstall everything as it came out. Advice?
__________________ 2008 MazdaSpeed 3 Exhaust - Mazdaspeed & Ebay Downpipe Induction - MazdaSpeed CAI, Unknown TIP, JBR TIG's & CXR FMIC Tuning - Auto Tech Internals, Cobb Accessport, Grimmspeed 3 port EBCS Suspention - Koni FSD's, RX-8 Rims, Potenza RE - 11's 235 / 40 / 18's Drivetrain - J-Speed Shifter Plate, Sure Anchors, SU RMM Random - Pontiac G8 Horns 2013 Ford Edge Sport AWD, the family car... |
![]() Join Date: Jul 2010 Location: newbury park, california
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 33
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2 | |
| Not Ranked : 0 score Yeah, I'm going to have to. You can tell the engines not happy with me right now. I just watched some install videos and I honestly cant think of anything I did wrong.
| Not Ranked : 0 score I showed up today to work on it, started it up, and it held 430PSI. I let it idle for a bit and it was still holding 430PSI. So I took it for a drive and it was hitting all its pressure targets. Perhaps there was a nasty air bubble on the LP side that worked it way out. I have no idea. But I put about 50KM on it today before my Access Port died and it seams to be running great. Now I have to find out why my AP took a dump!
![]() Join Date: Apr 2011 Location: Weston, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,511
Groans: 39
__________________ 2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold 2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs | |
| Not Ranked : 0 score That was my guess, I was about to get more pressure out of it when reving however, everything looks to be good now... Other than my AP!
__________________ 2008 MazdaSpeed 3 Exhaust - Mazdaspeed & Ebay Downpipe Induction - MazdaSpeed CAI, Unknown TIP, JBR TIG's & CXR FMIC Tuning - Auto Tech Internals, Cobb Accessport, Grimmspeed 3 port EBCS Suspention - Koni FSD's, RX-8 Rims, Potenza RE - 11's 235 / 40 / 18's Drivetrain - J-Speed Shifter Plate, Sure Anchors, SU RMM Random - Pontiac G8 Horns 2013 Ford Edge Sport AWD, the family car... Last edited by Blackrider; 04-21-2012 at 05:22 PM. |
![]() | | #19 | ![]() |
![]() Join Date: Mar 2012
Rep Power: 0 ![]() Thanks: 3
| Not Ranked : 0 score I think i must have missed something. What makes the motor enter a dangerous area of possible boom if the stock fuel pump doesn't meet the fuel demand? Would you not just hit some peak limit and then back down? Thanks in advance. |
![]() | | #20 | ![]() |
Groans: 38
(Thread Starter) | Not Ranked : 0 score Not sure what you mean by that,but the fuel does not like to atomize properly at lower pressures amongst other things.
| The Following User Says Thank You to themytb For This Useful Post: | jrocket420a (04-26-2012) |
![]() | | #21 | ![]() |
| hidin in yo bushes ![]() Join Date: Mar 2012 Location: Soviet Maryland
Rep Power: 6573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
| The Following User Says Thank You to CWP_MS3 For This Useful Post: | jrocket420a (04-26-2012) |
![]() | | #22 | ![]() |
Groans: 38
I do not mean to call you out here-- I simply do not want people thinking as long as AFR's stay on target they are ok.
![]() | | #23 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Foothill Ranch, CA
Rep Power: 2705 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 766
| Not Ranked : 0 score yes its a vicious cycle: low pressure, ecu dumps fuel further straining pump, pig rich, low pressure etc...
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
![]() | | #24 | ![]() |
Groans: 122
| Not at all man; I don't mind being wrong. I appreciate learning new things. Thanks for the correction. So what actually bends the rods then if its not leaning out. |
![]() | | #25 | ![]() |
| Not Ranked : 0 score Ah ok i see it. By "hitting some peak", i was figuring you'd start running lean and to compensate the ecu would possibly close the throttle or something like that to regain air/fuel balance. But the ECU regulating fuel demand makes more sense. Thanks guys. |
![]() | | #26 | ![]() |
| Not Ranked : 0 score Wait, (sorry trying to rationalize all this in my head and why i should get an HPFP upgrade), if fuel pressure goes down, wouldn't this mean less fuel enters the cylinder to an extent that the motor will just shut off? Is the danger in a possible blow-up due to the fuel INSIDE the pump itself as its overworking to meet demands? |
![]() | | #27 | ![]() |
Groans: 38
(Thread Starter) | Not Ranked : 0 score Ecu regulates injector pulse width(time the inj is open) based on fuel rail pressure and amount of fuel requested. So if the ecu sees a lower pressure than it expects it just opens the injectors for a longer period of time. It is hard on the pump to try to keep up when it is past its potential, but this is not the boom im speaking of. Boom means one of your rods taking a tour of the engine bay.
![]() | | #28 | ![]() |
Groans: 38
| The Following 2 Users Say Thank You to themytb For This Useful Post: | jack_hammer (04-27-2012), jrocket420a (04-27-2012) |
![]() | | #29 | ![]() |
| Not Ranked : 0 score Ah thanks a lot man. You've definitely been helping me. And i will know doubt definitely continue to check this site out for information. That cleared up a lot of stuff. |
![]() | | #30 | ![]() |
| Not Ranked : 0 score Has anyone experience fuel leaking into the motor via the cdfp after upgrading the internals? Assuming both o-rings (inside pump and the one that joins to the motor) are okay, is it possible that the pump could leak from the internals while in operation? I'm refering to where the internals are actually outside the pump under the spring where it is in contact with the cam? |
![]() | | #31 | ![]() |
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,116
Groans: 549
__________________ it's fun to do bad things |
| The Following User Says Thank You to jack_hammer For This Useful Post: | Javi (05-21-2012) |
![]() | | #32 | ![]() |
![]() Join Date: May 2012 Location: Yukon OK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 618
| Neutral : +1 score |
| The Following 2 Users Say Thank You to Javi For This Useful Post: | Menace1 (02-11-2013), Patty-Wack (09-09-2013) |
![]() | | #33 | ![]() |
| Not Ranked : 0 score Are there any guys running intakes, turboback's, and fmic's on stock internals? Cause I really don't wanna have to crack open my block to install those as my car is my dd. |
![]() | | #34 | ![]() |
![]() Join Date: Feb 2011 Location: Waterford,CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,169
Groans: 423
| Neutral : +1 score
If so no there are no guys doing that. They all blew up. Search a bit more man.
__________________ -Pat 2008 True Red MS3 GT3071R 'n Stuff SOLD 1999 Jeep XJ 6.5" Lift | Armor | 33" Tires | Bumpers 1996 Jeep XJ 3.5" Lift | 31" GY Duratracs | Bumpers 1994 Miata 15x8's w/NT05's | KYB AGX | Hardog Roll Bar | 70D Engine Mounts | |
![]() | | #35 | ![]() |
| Not Ranked : 0 score Derpity derp. That's what I get for skimming this thread after studying for finals. |
![]() | | #36 | ![]() |
| Raider's Homie ![]() Join Date: Jul 2012 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 67
can i order this stuff directly from the cp-e website or do i gotta find them somewhere else? | |
| The Following 2 Users Say NO Thank You to Wings_Fan_1986 For This Un-useful Post: | jack_hammer (07-16-2012), smoogs12 (07-14-2012) |
![]() | | #37 | ![]() |
Groans: 423
http://www.cp-e.com/products/hpfpump...hpfpump™ Sent from my iPhone using Fapatalk.
| The Following User Says Thank You to smoogs12 For This Useful Post: | Wings_Fan_1986 (09-16-2012) |
![]() | | #38 | ![]() |
| Banned ![]() Join Date: Jun 2012
Rep Power: 0 ![]() ![]() Thanks: 11
Groaned at 38 Times in 11 Posts
| Not Ranked : 0 score Sorry if this a stupid question but would a walboro 255 be enough fuel pump for full bolt-on through stage 2? |
![]() | | #39 | ![]() |
Groans: 423
Not sure if serious. But no. Keep reading. Sent from my SCH-I535 using Tapatalk 2
| The Following User Says Thank You to smoogs12 For This Useful Post: | Mooseknuckler (07-31-2015) |
![]() | | #40 | ![]() |
Groans: 38
(Thread Starter) | Not Ranked : 0 score troll question+twilight=troll in tutu?
| The Following User Says Thank You to themytb For This Useful Post: | 07micasp3 (05-17-2013) |
