![]() Join Date: Nov 2018
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Thank you in advance for your assistance. |
Groans: 60
| Not Ranked : 0 score I've never seen one in the wiring diagram.
| Not Ranked : 0 score Ford used it a while back, (saw it on a 1987 tempo) not sure if they still do since everything is electronically controlled for more than 1 or 2 decade. I stripped my 2007 3 all over and didn't seen any. Why do you ask ? Are you looking blind to solve an issue by just pushing a reset ? Have you checked pump relay or resistor ?
(Thread Starter) | Not Ranked : 0 score Have an 2006 Mustang, the glass technician tripped switch changing windshield. Took me about 1-2 hours to figure it out and reset switch. Just wanted to know about mazdaspeed 3 in the event anything happens to it. Thanks for response. |
| Not Ranked : 0 score ok i see.
| Fuel door switch stuck | furinax | Mazdaspeed3/6 General Discussion | 5 | 01-11-2017 11:00 PM |
| Water Pump, Tstat, Fuel Pump Oh My! | CBear3 | Mazdaspeed3/6 General Discussion | 13 | 10-01-2015 06:03 PM |
| In tank fuel pump and fuel rail valve | Seatime3 | 2010 MS3 - Fuel, Nitrous & Water Injection | 1 | 04-30-2012 08:44 PM |
| Issues with fuel pump pressures, aftermarket pump... | ptperformance | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 0 | 10-04-2009 06:17 PM |
