![]() Join Date: Apr 2011 Location: Manassas, VA
(Thread Starter) | Not Ranked : 0 score I've searched and it seems the only way to test is to read the ap fuel pressure after car is off. I get 500 psi and it increases slightly. Then another time I have the fuel pressure drop below 60 with car off. Is there a How to on replacing this part? Thanks in advance. |
![]() Join Date: Dec 2010 Location: Humble, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,643
| Not Ranked : 0 score HOW-TO: Replace Relief Valve (RV) The test you performed is the reccomended test. I am diagnosing this issue with a buddy's car now. Sometimes fuel pressure shits the bed, sometimes it holds strong. My car with key on engine off drops pressure real low...it does not build...but my fuel pressure with car on is spot on. Weird.
__________________ 2011 Speed3-BT and shit ![]() "There is a war going on for your mind. If you are thinking, you are winning. Resistance is victory. Defeat is impossible. Your weapons are already in hand. Reach within you and find the means by which to gain your freedom. Fight with tools. Your fate,and that of everyone you know, depends on it." TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
(Thread Starter) | Not Ranked : 0 score Well I got the 2150 upgrade garage fuel relief and no change. Pressure still drops between 3k and 4k rpm. Now what. I can't just keep throwing money at everything. Please help. |
| Not Ranked : 0 score Is the fuel pressure failing at peak load? my guess is internals |
![]() Join Date: Apr 2011 Location: Weston, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,511
Groans: 39
| Not Ranked : 0 score If its dropping at peak load, around 2.0 +, then your internals are bad.
__________________ 2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold 2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs |
| The Following 3 Users Say Thank You to G26 For This Useful Post: |
| Not Ranked : 0 score If not at peak load, then possible it is your in tank filter clogged up?
| Neutral : +1 score Or spill valve, post logs op! This thread is useless without a log |
(Thread Starter) | Not Ranked : 0 score I apologize. Here is a log from a day ago. |
Groans: 39
| Not Ranked : 0 score What internals do you have? That looks like the kmd drop fuel psi at max load syndrome lol.
(Thread Starter) | Not Ranked : 0 score Yes I have the KMD internals. This log was taken in 4th gear at 2500 RPM to 6500 rpm. |
![]() Join Date: Feb 2012 Location: Quantico, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,434
| Not Ranked : 0 score Your "Actual" is great. (HPFP Act. Press. (PSI) vs HPFP Des. Press. (PSI))...but the desired is dropping off? You can leave it so your commanding 1749 across the RPM range.... the Fuel Pressure Relief Valve is still giving you over 2000 psi NP. And peak load is happening 3000 rpm prior to the strange drop off? I'm curious as to whats going on...subbed.
__________________ [SIGPIC][/SIGPIC] 2013 Scion FR-S (Whiteout) GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_Nameless Race Pipe_RBF600_Ferodo DS2500_PTUNING Tuned Less parking more racing |
(Thread Starter) | Not Ranked : 0 score I have a dyno session set for tomorrow morning should I cancel it based on the log? |
Groans: 39
__________________ 2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold 2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs | |
| The Following User Says Thank You to G26 For This Useful Post: | leon78 (05-08-2012) |
| Not Ranked : 0 score Ahh, thanks....I looked over that dip where it goes down to 1350ish cuz it jumps right back up just fine. Why does the Calculated Load effect the mechanics of the HPFP (KMD wise) ?, electric signal says time for fuel cut?
Groans: 39
| Not Ranked : 0 score Because load is effectively torque. At max torque fueling demands are the greatest.
(Thread Starter) | Not Ranked : 0 score I removed the internals last week and inspected them. I wasnt sure what I was looking for but I did take some pictures. |
(Thread Starter) | Not Ranked : 0 score I'm concerned about the dyno session should I not go? I dont know how bad this is. |
![]() Join Date: Jul 2011 Location: Clarksville, TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,279
| Not Ranked : 0 score Pretty sure this isn't bad internals, it looks more like some sort of fuel cut to me. Are you running the HPRV in this log? Who is tuning you? @phate may have a little more insight on this.
__________________ "Intelligence isn't the ability to store information, but to find it" - Albert Einstein "When I read about the evils of drinking, I quit reading" - Henry Youngman |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score here is the log with the upgraded hpfp relief valve. Boost_Creep has been tuning me great guy he thinks it maybe internals but can find anyone local to switch out with to test. |
![]() | | #20 | ![]() |
| Not Ranked : 0 score This opened to jiberish for me, and I am not excel smart enough to unjiberish it
![]() | | #21 | ![]() |
| Not Ranked : 0 score Same..the log is in the wrong format in excel...can't read it.
![]() | | #22 | ![]() |
@Boost_creep PS - The data log he posted just needs to be parsed by using the "Text To" function in Excel.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | |
| The Following 3 Users Say Thank You to phate For This Useful Post: |
![]() | | #23 | ![]() |
(Thread Starter) | Not Ranked : 0 score well, I just took off the spill valve and it looked perfect. No gunk or anything not that I was running E85. I only us 93.
Any way to test the internals? I just bought the upgraded relief valve and dont have the money to drop another $300+. Last edited by twintzs; 05-08-2012 at 09:32 AM. Reason: MSF Database - Automerged Doublepost | |
| The Following User Says Thank You to twintzs For This Useful Post: | Boost_creep (05-08-2012) |
![]() | | #24 | ![]() |
Groans: 39
![]() | | #25 | ![]() |
![]() Join Date: Nov 2010 Location: Riverhead, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,457
If you still have your warranty card, kmd should replace them for you. I personally have not had to go down that road, but it appears others have. Did you call kmd yet?
__________________ [SIGPIC][/SIGPIC] www.dizzytuning.com www.facebook.com/dizzytuning | |
| The Following User Says Thank You to Boost_creep For This Useful Post: | rfinkle2 (10-30-2014) |
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score I talked to some guy who sounded like a prick. Kept calling me bro and just told me that it could be a number of things and he couldnt diagnosis over the phone. Based on searching it appears i need to talk to a Mara at KMD. |
| The Following 2 Users Say Thank You to twintzs For This Useful Post: | Boost_creep (05-08-2012), leon78 (05-08-2012) |
![]() | | #27 | ![]() |
Groans: 39
| Not Ranked : 0 score Tell them you know and they know this is a common problem caused by their bull shit.
| The Following User Says Thank You to G26 For This Useful Post: | Ms3_Miami (05-08-2012) |
![]() | | #28 | ![]() |
Edit- ok, I just found it. mara@kmdtuning.com Pretty self explanatory. Lol.
![]() | | #29 | ![]() |
| Not Ranked : 0 score Same thing happened to me, pulled my kmds and they looked fine. swapped spill valves with the kmds still in the pump and the problem went away for a couple pulls and came back. I ended up putting in a new pump with AT internals and no problems since then but I still think my in tank is going out because even at wot my pressure dips to 1650. |
![]() | | #30 | ![]() |
![]() | | #31 | ![]() |
| Not Ranked : 0 score let me see if I can find some recent logs Seems like pressure isnt dipping anymore so it looks like it was the pump/spill valve |
![]() | | #32 | ![]() |
Groans: 39
| Not Ranked : 0 score Autotechs ftw. 11k miles and counting.
![]() | | #33 | ![]() |
Groans: 39
| Not Ranked : 0 score Btw, just had a local nator guy install his ptp fp internals, and his fp is dipping bad.
![]() | | #34 | ![]() |
| Not Ranked : 0 score We have a local 3071 car that had PTP internals and had to ditch them for another option...They just wouldn't put the pressure out that was needed. DJ was tuning the car actually. The internals were an older batch though, so maybe they have changed.
![]() | | #35 | ![]() |
| Not Ranked : 0 score Internals are hit and miss, no matter which way you go. I've worked with several cars with PTP pumps that work great, as well as KMD, CPE, and AT.
| The Following 5 Users Say Thank You to phate For This Useful Post: | atvfreek (05-08-2012), Boost_creep (05-09-2012), mrmonk7663 (05-08-2012), Ms3_Miami (05-08-2012), rfinkle2 (10-30-2014) |
![]() | | #36 | ![]() |
| Not Ranked : 0 score Honestly, this is a rather unfortunate thing ...but yes it is true.
| The Following User Says Thank You to mrmonk7663 For This Useful Post: | Ms3_Miami (05-08-2012) |
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score Just a random thought could the low pressure be how I'm taking my logs. I get into 4th gear cruise until I get to 2500 RPMs then I hit the log button on the AP then I stomp on the gas to 6500/7000 rpm. |
![]() | | #38 | ![]() |
| Not Ranked : 0 score No.
![]() | | #39 | ![]() |
![]() Join Date: Jul 2011 Location: Miami Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,829
Groans: 55
. I know two guys on here that have the PTP fp internals for 30k miles on E85 without an issue
__________________ 08 Black Mica Ms3~full bolt ons/Nishan Tuned-Sold NATOR FL | |
| The Following User Says Thank You to Ms3_Miami For This Useful Post: | rfinkle2 (10-30-2014) |
![]() | | #40 | ![]() |
![]() Join Date: May 2016
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Hi everyone. I have a 2011 Mazdaspeed 3. Until about 2 weeks ago everything was great. I was on my way home from work when all of a sudden I lost all power and my car started jerking violently and the throttle did nothing. The idle would almost stall but would keep running. I was able to make it home going on 10 mph. I checked my fuel pressure and it seems to be lower than normal. Does anyone know if the fuel pressure relief valve would cause this problem? Thanks |
| High Pressure Relief Valve Option | SilverDemon | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 161 | 04-29-2011 08:10 PM |
