(Thread Starter) | ![]() There are few fields in the world where you'll find engineers working as feverishly as they do in Formula One. With races sometimes won and lost by fractions of a second, every little bit counts, so each team retains legions of engineers, all dedicated to finding the tiniest performance edge... without running afoul of the ever-constricting regulations. This season, one of the most controversial advances has been known as FRIC, and while it's been effectively sidelined for the last few races, reports from the motorsport press indicate that is has now officially been banned by the FIA. So just what is FRIC? It stands for Front and Rear Inter-Connected suspension. Now, if you're thinking that independent suspensions are the most advanced form available, you're right, but F1 teams have been toying for years with ways to interlink the suspensions at each wheel. Why, you ask? For a number of reasons. For one, it allows for redistribution of suspension dive at the front or rear, which means that under hard braking or acceleration - when the car would either pitch back or forward - the car can be kept more stable. That, in turn, means not only are all four tires loaded evenly and optimally, but the team can also run a more aggressive aero package. It also means that the car can be set up with a softer suspension, allowing the driver to attack the curbs more aggressively, without sacrificing underbody aerodynamics. Several teams had been running FRIC systems that move hydraulic fluid between the front and rear suspensions, but voluntarily agreed to cease using them for the last two races at Hockenheim and Budapest. Now, the FIA, having apparently deemed FRIC an unfair advantage in contravention of the sporting regulations, has reportedly banned the system altogether. So while those cars may not be running on an even keel any more, at least they'll all be on an even playing field.FIA says FRIC no to trick suspensions in F1 originally appeared on Autoblog on Thu, 21 Aug 2014 13:32:00 EST. Please see our terms for use of feeds. Permalink | Email this | Comments More... |
![]() Join Date: Apr 2013 Location: Chattanooga, TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,760
Groans: 42
| Not Ranked : 0 score So it's like a hydraulic front to rear sway bar? I don't see why that would be consisdered an unfair advantage. It's what racing is about. Advancing technology.
__________________ Coming at ya with all 297/359 POWER: HTP 3" intake, Corksport BPV, Treadstone FMIC, Cobb EBCS, Autotech HPFP, CPE full catless DP ECU: self-tuned HANDLING: JBR RSB (Middle Setting) RICE: Stickers and stuff, mudflaps, floormats, Evil M, etc. RADAR: Passport Escort 9500ci |
![]() Join Date: Apr 2014 Location: Brisbane, QLD, Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 225
Agree. My 1986 BX Citroen did something similar with anti dive and no sway bars. So it's hardly new tech that should be banned. They seem to be banning anything where one team does it better than the others eg exhaust diffusers on RBRR.
__________________ CX7 - The younger, taller and sexier replacement for the MS6. 2007 CX7 2.3 DISI AWD | Forged Build | Mahle Pistons | Molnar Rods | APR studs | Corksport Turbo @25psi | ETS TMIC | Cobb XLE BOV | CS HPFP | JBR 3.5" WPI | Cooling Mist WMI | CS OCC | CX9 20x7.5's | CX9 Brakes | Pedders Lowered 40mm | VersaTuned by Stratified | |
| Not Ranked : 0 score It was more about banning something that was ridiculously expensive
| Will MS3 suspensions fit MS6 | MS6_Newb | MazdaSpeed 3/6 - Suspension & Brakes | 7 | 11-22-2013 02:55 PM |
| How To: Install ATP CEL trick kit | oh_yeams6 | MazdaSpeed 6 - How-To's | 20 | 12-07-2011 10:07 AM |
| SEMA: Matchbox 2011 Ford F-350 Super Duty by Superlift suspensions is one hot fire truck | Haltech | Automotive News | 0 | 11-04-2011 07:20 AM |
| Chrysler supplier opens Detroit plant for Jeep suspensions | Haltech | Automotive News | 0 | 06-04-2010 10:10 PM |
