 Old 01-27-2020, 01:18 AM   #1
ctkao2112's Avatar
Posts: 3   (View Stats)
ctkao2112 is an unknown quantity at this point
Default Melted piston... Cause/Fix?
Took my car to a track and 20 minutes in the engine started misfiring and blowing out exhaust smoke. Also, all of my oil was ejected. Took the engine apart to discover the piston is melted and the cylinder wall is damaged (see attached). I'm planning on buying a short block and swapping that in, but I want to make sure this won't happen again.
Can anyone identify likely causes/solutions? I'm thinking running lean/detonation, but not exactly sure what's causing it. Faulty O2 sensor? Fuel injectors? Tune? Haven't done too much in terms of diagnostics due to time constraints, so I was hoping ya'll could give me suggestions.
Engine mods:
- Cobb Stage 3 Tune
- Autotech High pressure fuel pump (HPFP)
- Corksport short ram intake
- CPE top mount intercooler
- Synapse synchronic DV diverter valve
ctkao2112 is offline   Reply With Quote
help....melted cable off of battery RACER_X Gen2 MS3 General Discussion 45 08-01-2015 08:56 AM
Melted plastic ?? meicalnissyen Mazdaspeed3/6 General Discussion 0 01-03-2015 11:35 AM
Has your Dashboard Melted? SpencerC Mazdaspeed3/6 General Discussion 25 11-23-2014 06:39 AM
Melted Bushing HiFiSpeed Gen2 MS3 General Discussion 1 10-27-2014 12:43 PM
Page generated in 0.26442 seconds with 25 queries
