  • 1 Post By 801MS3
 Old 01-23-2012, 05:22 PM   #1
Burton's Avatar
Posts: 123   (View Stats)
Burton has a reputation beyond reputeBurton has a reputation beyond reputeBurton has a reputation beyond reputeBurton has a reputation beyond reputeBurton has a reputation beyond reputeBurton has a reputation beyond reputeBurton has a reputation beyond reputeBurton has a reputation beyond reputeBurton has a reputation beyond reputeBurton has a reputation beyond reputeBurton has a reputation beyond repute
Default HELP PLEASE!!
I was in third gear hit it boosted car was gutless.. It didn't pull hard and then gutless it was just gutless from the beginning.. Drove about 500 feet and my check engine light came on and would flash every minute or so. Stopped and the car just died. No idle... Started it again and somewhat held an idle but LOTS of white smoke was coming out of the exhaust so there's water/coolant somewhere I'm guessing cause that's what causes white smoke right? Pulled a plug tip was white which means one of 2 things, running lean or water on the plugs from the distance I drove before stopping... Any help?
Wheel gap is like a vagina, the more fingers you can get in the worse it is..
http://www.facebook.com/TAILORED.FAM
Burton is offline   Reply With Quote
 Old 01-23-2012, 05:26 PM   #2
Zdraveca's Avatar
Posts: 3,888   (View Stats)
Groans: 145
Blown turbo? Oil in the exhaust also causes white(ish) smoke
Sent from my T-Mobile G2
2011 MS3"Princess GRU"
GT2876r
E85 FREEKTUNE
 Old 01-23-2012, 05:27 PM   #3
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
Ummm...whatever it is, sounds like you are pretty boned...check your coolant and see if there's any oil in it. Pull all of your spark plugs and make sure that your cylinders aren't full of coolant. If there's nothing in there, do a compression test. I'm thinking the CEL is going to be p0300 - random misfire. The light usually flashes when it's a misfire.
I don't think it's your turbo because the only way it would affect your idle that much is if the wheels broke or somethin, but you would hear that. If turbo bearings fail, they make a lot of noise.
2007 CTS-V - Trying to sell
 Old 01-23-2012, 05:32 PM   #4
Burton's Avatar
I keep hearing head gasket? Which would kinda make sense but would a head gasket cause it to idle like crap?
 Old 01-23-2012, 05:43 PM   #5
ScarMS3's Avatar
Posts: 2,088   (View Stats)
Groans: 97
So first gen 3 or 6, mods? Tune? More details...also did you give a Mormon some regular coffee and tell him it was decaf...karma is a bitch.
The Following User Says Thank You to ScarMS3 For This Useful Post:
redmnsterut (02-10-2012)
 Old 01-24-2012, 01:08 AM   #6
Black Metal's Avatar
Posts: 699   (View Stats)
Black Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the world
Groans: 78
Welp pulled all the plugs did a compression test and cylinder 3 was low. Stuck a quetip taped to a straw down into the cylinder and it came out bright green. His head gasket fucked his couch. Oh and fwiw his coolant smelled like gas really bad.
- 2006 Black Mica MS6 -
- GT3071R - CP-e CAI - CP-e BT TIP - ATP Catted DP - JBR RMM - Corksport TMIC - Cobb AP -
- Autotech Internals - Turbo XS 50/50 - DSS Rear Axle - Sure Juggernaught & Dreadnaught -
- GS EBCS - H&R Springs - Sure TIG's - PNP'D Intake Manifold - EGR Delete -
12.89 @ 104.9 1.82 60' 4500' ASL on K04 20 PSI E30
12.01 @ 113.9 1.80 60' 4500' ASL on 3071 22 PSI E20
- 2004 Silver Sunlight Metallic RX-8 -
- 6MT - Stock -
Black Metal is offline   Reply With Quote
 Old 01-24-2012, 12:37 PM   #7
Burton's Avatar
How hard of a job is this to do yourself?
 Old 01-24-2012, 12:38 PM   #8
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Better check your rods now man.........potential hydrolock
07 MS3
The original Genpoo Hater
 Old 01-24-2012, 03:36 PM   #9
Burton's Avatar
Talked with a local Ford stealership and they quoted me about 1200 for parts and labor so I think I'll just go through them. Everywhere else is 1600-1800.. Also talked to them about the VVT Chain and it wouldn't be any extra cost for putting it in, I'm just paying for the chain itself. They are giving me a bit of a deal on this cause I am just barely 1200 miles over my warranty and want to help me out haha. They also replaced my smokey turbo about 8000 miles ago so I trust them. I bought it from Larry Miller and he doesn't have any Mazda dealerships so Ford is the closest thing. I'll let you guys know what the cost is final out the door because I haven't been able to find anyone that has had this done yet other than them doing themselves. How likely is the Hydrolock? I drove roughly 2 miles after this all happened..
 Old 01-24-2012, 03:40 PM   #10
You should measure piston height before you even go in to get this work done. You may have bent a rod.
 Old 01-24-2012, 06:31 PM   #11
bmylez's Avatar
Groans: 31
Ugh, that fuckin sucks, sorry.
 Old 01-24-2012, 08:06 PM   #12
Burton's Avatar
How do I measure it?
 Old 02-08-2012, 05:49 PM   #13
Burton's Avatar
Well I guess I blew my motor... I have a hole or chunk missing out of, can anyone guess? The 3rd cylinder! Ding ding ding! Anyway dropping it off at a local shop this week to start the rebuild. I'll keep you guys posted along the way and hopefully with lots of pics cause I know how much we all love to look at pictures..
 Old 02-08-2012, 06:01 PM   #14
Will fuck up ur day
Chimmike's Avatar
Groans: 433
what the hell did you do, keep driving on it?
07 MS3
Bucker (02-08-2012)
 Old 02-08-2012, 06:23 PM   #15
Burton's Avatar
For about a mile..maybe 2 haha! I was on the freeway with nowhere to pull over unless I just stopped in the middle of the lane. At 1100 at night I did not think this was a good idea haha! So yea...
The Following User Says NO Thank You to Burton For This Un-useful Post:
Chimmike (02-08-2012)
 Old 02-08-2012, 06:44 PM   #16
Will fuck up ur day
Chimmike's Avatar
Groans: 433
well, you went from "just a bent rod" to "now i need a whole fucking motor" in 5 seconds. congrats.
07 MS3
The Following 3 Users Say Thank You to Chimmike For This Useful Post:
Adam is so pro (02-08-2012), Bucker (02-08-2012), trf5000 (02-10-2012)
 Old 02-08-2012, 06:49 PM   #17
Burton's Avatar
It's cool just gives me an excuse to build it. Hate all you want I know it's my fault and I admit it. Stoked on the build though, taking it to the shop tmrw!
 Old 02-09-2012, 04:31 PM   #18
kgb
kgb's Avatar
Posts: 808   (View Stats)
kgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the world
Groans: 88
Hope the shop knows the uniqueness of building this car.
And you are so calm about it so must have money yo!
FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs
WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s
AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI
MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute
JAM SESSION........US Amps (in Series w/ Stock Amp) using
OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back)
RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors
- Acne Rear Bumper LED Reflectors
kgb is offline   Reply With Quote
 Old 02-10-2012, 09:44 AM   #19
Burton's Avatar
I am pretty confident in the guy working on the car, he has built quite a few Sti's and Evo's but never any Mazdas.. I was a little nervous about this at first but after talking with the guy I feel comfortable. I'm certainly not rich lol but what has to be done has to be done. Also found out the head gasket was perfectly fine so the poopatrator of the incident was most likely the rod breaking. Haven't gotten that far yet but only 1 cylinder was full of coolant so and the head gasket looked fine. I have been running lean do to mods and NO TUNE. Let this be a lesson to people like me that said fuck it I'll get an AP later. Something that could have cost 600 tops is now costing THOUSANDS. Anyway I'll keep you guys posted on the build. Is there a section I should move this thread to?
 Old 02-10-2012, 10:53 AM   #20
redmnsterut's Avatar
Posts: 838   (View Stats)
redmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the world
The epic fail thread... Jk Burton. Hope it goes smooth for you. Id do a lot of searching to see what the best parts to get for the rebuild are. Rebuilds require A LOT of attention to detail so make sure he is being spot on. Is this guy offering any type of warranty on his work? If not I would maybe recommend looking into a shop that will warranty their work, even though you feel "somewhat comfortable" with his work. Its better to have your ass covered in case something happens again.
Ill keep a look out for the parts you were asking about on utahmazdas
SURE RMM | SURE Shift Weight | SURE SSP | CP-E CAI | CP-E DP | CP-E TIP | COBB AP |SnailD Tunned| TEIN Springs | SU Turbosmart BPV | Autotech HPFP Internals | Autolite XP step colder plugs | JBR Heavy Shift Knob | CXracing FMIC | Block8 Single Gauge Pod | MSD DashHawk
Waiting to be installed: SURE Dreadnaught | JBR Shifter Bushings | SU Boost Tubes | P&P Intake Manifold
Soon to come:SURE Intake/TB TIG | SURE Juggernaught | RSB |
286awhp / 346lbs tq @4500 ft ASL
redmnsterut is offline   Reply With Quote
 Old 02-10-2012, 11:02 AM   #21
bmylez's Avatar
Groans: 31
Running lean may not exactly be what broke your rod. You might burn a piston or a valve, but knock/too much torque is what typically breaks a rod. Yes, you can knock from running lean, but usually it's from bad spark timing. I have a couple datalogs of running as lean as 13.5 AFR at full throttle, but had absolutely no knock because my spark wasn't crazy.
You had a case of bad luck combined with no tune.
 Old 02-10-2012, 11:39 AM   #22
Burton's Avatar
Yea I was considering just fixing the car and trading it for an 09 that is still under warranty haha! I wouldn't mind having an 09 anyway just cause I like the interior's more. But anyway I'm not to sure if it's even a busted rod yet.. I just know I have a hole in my 3rd cylinder wall about as big as your pinky finger. Not to sure what cause it yet but should find out by later today. I think this was a ling time coming because I feel my fuel pump has been going for some time now. Every once in a while I would be in 3rd gear between 3000 and 4000 RPM and would stomp it and my car would feel like it would cut out for sec but come right back. To me this sounds like fuel cut.. Any ideas? BTW not sure if I mentioned but the mods I was running were SRI, TIP, FMIC, HKS BOV full atmos and a gutted test pipe with no tune. From what I've read our fuel pumps cannot keep up with the amount of air these mods push. Not to mention no tune... FML I'll let you guys know what happened as soon as the car gets torn apart!
 Old 02-10-2012, 12:00 PM   #23
ColonR's Avatar
Posts: 1,453   (View Stats)
ColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the world
subbed for more info and pics.
1992 miata, track beast here I come with 2 bride seats!! (current)
3076r speed6 owner (traded)
2000 camaro 415rwhp thru midwest chassis fab (sold)
ColonR is offline   Reply With Quote
 Old 02-10-2012, 10:40 PM   #24
bmylez's Avatar
Groans: 31
Those mods with no tune = for the lose.
 Old 02-11-2012, 05:07 PM   #25
Burton's Avatar
I completely agree.. I just never listened! Gotta learn somehow though right? Anyone heard much about K1 rods? Thinking about buying the ones Trouble81 is selling after my mechanic gets back me..
 Old 02-24-2012, 07:26 PM   #26
HPFPUPGRADE's Avatar
Posts: 403   (View Stats)
HPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the world
Groaned at 22 Times in 17 Posts
K1 rods are powering our 640 WHP shop car, they are a great option for your build. I also like Wiseco or CP pistons.
Well motor is out ready for the damage?
Attachment 52472
I don't think that is supposed to be there... Ha! So newbs GET A TUNE! or this will most likely happen to you ha! I need all 4 pistons and rods as well obviously but just bought a CX7 long block that should be here Mon or Tue. Turbo surprisingly looks to be ok! Anyway here's the beginning I'll keep you guys posted along the way!
After looking at this picture, you may want to replace your injectors as well.
If you look at the top of the piston is appears you have an odd spray pattern from the injector. Also, look at the side, above the hole.... it looks like something was hitting/spraying on the cylinder wall. Just my observations.
Last edited by HPFPUPGRADE; 02-24-2012 at 07:26 PM. Reason: MSF Database - Automerged Doublepost
HPFPUPGRADE is offline   Reply With Quote
 Old 02-11-2012, 06:52 PM   #27
bmylez's Avatar
Groans: 31
Yeah, pretty much any rods for our car are fine. Especially if you don't want more than 500whp.
 Old 02-16-2012, 03:50 PM   #28
Burton's Avatar
The Following User Says Thank You to Burton For This Useful Post:
kunfu (02-24-2012)
 Old 02-24-2012, 02:21 PM   #29
Burton's Avatar
New motor is here! Hopefully going in this week if everything works out well!
 Old 02-24-2012, 02:26 PM   #30
Good luck man, hope the core cx-7 engine is ok and starts up no problems
 Old 02-24-2012, 04:47 PM   #31
Burton's Avatar
Thanks! Running a leak down test and tearing it apart tonight! Hopefully everything looks good!
crazyp (02-24-2012)
 Old 02-24-2012, 04:52 PM   #32
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
good luck. man is the hole only in the sleeve or through the whole cylinder wall?
 Old 02-24-2012, 06:50 PM   #33
801MS3's Avatar
Posts: 453   (View Stats)
801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world
Groans: 30
OP forgot to mention that he ran the car out of oil a while back.. I'm sure that played a major role in the eventual death of the motor.
08.5 MS3- : ATP GT3071r: cp-e XL intake: cp-e big inlet: cp-e rmm 75 Duro: cp-e e-flex motor mounts : cp-e catted down pipe: cp-e cbe,: cp-e FMIC, cp-e HPFP: cp-e safe seals : DNP Manifold: COBB AP: COBB RSB: DO stg 2 meth kit ,: SURE TIG's, : KW V2 coilovers: Konig Milligram 18x8.5 +35, Hankook ventus evo's 235/40/18, Saitek adj endlinks :HKS BPV: TWM STS:
465whp 468 wtq Best e.t 11.9 Best trap 123mph
801MS3 is offline   Reply With Quote
The Following User Says Thank You to 801MS3 For This Useful Post:
skiptowncat (02-25-2012)
 Old 02-24-2012, 07:35 PM   #34
ReD BoY's Avatar
Posts: 523   (View Stats)
ReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the world
Groaned at 32 Times in 15 Posts
Sorry, just a question for any knowledgables in here
I'm fully bolted like this fellow here was, (cp-e CAI TIP FMIC corksport TBE) and don't have the money atm for a tune. I'm a broke as hell college student. Fortunately I DOOOOO have a cp-e HPFP. Will having the fuel pump save me from anything like this happening? Or at least decrease the likelihood significantly?
I know, I know. "Get a tune you idiot." I know all that jazz. I know the error in my ways NOW but it's a little late and now I have to wait until this summer and the possibility of consistent income.
---Stupid kid can haz car.
ReD BoY is offline   Reply With Quote
 Old 02-25-2012, 06:37 PM   #35
Burton's Avatar
So the mark above the hole is actually BIG grooves in the cylinder wall, I'm guessing from the piston bouncing after hitting the hole if that makes sense? Also the weird pattern I think is basically just from the coolant "steam" cleaning the piston and cylinder ha! If you look at it compared to the other cylinders it's super clean! I'm not doubting your observation by all means just saying shit was steam cleaned like the presidents suit! Anyway I think I will replace the injectors anyway just cause I'm already in there! Thanks for the advice too, much appreciated! And @ReD BoY I would get the AP ASAP! It's really not worth risking it.. I know you may not have the money which is the reason I didn't have one but what could have cost me 600 at most is now costing 3000+ That or never WOT until you do get one.. Having the pump may help out a lot but knowing what I do now and how temperamental our cars are I would have mowed lawns or got a paper route to get the money ha! Just be safe and save everywhere you can to get an AP. In the mean time for a cheaper route get a dash hawk and monitor the shit out of your car. Sorry for the long post...
 Old 02-26-2012, 05:24 PM   #36
ReD BoY's Avatar
I have a DashHawk
What should I be watching out for?
 Old 03-04-2012, 02:29 AM   #37
skiptowncat's Avatar
Posts: 1,592   (View Stats)
Originally Posted by ReD BoY View Post
I have a DashHawk
Knock retard and fuel pressure are a must.
Tuned with by
 Old 02-25-2012, 10:58 PM   #38
801MS3's Avatar
Groans: 30
I wouldn't jump to replacing the injectors.. You can get them cleaned and tested for a fraction of the cost.. Our injectors haven't been too prone to failure.
Burton likes this.
 Old 02-26-2012, 07:52 AM   #39
bmylez's Avatar
Groans: 31
Yup, go to InjectorRX.com. I had 4 junk yard injectors that all turned out to work perfectly and InjectorRX flow-matched them for $125 shipped.
Page generated in 0.53401 seconds with 34 queries
