MAZDASPEED Protegé
> MSP - Engine, Transmission & Driveline
 Old 07-08-2012, 05:42 PM   #1
protespeed's Avatar
Posts: 7   (View Stats)
protespeed will become famous soon enoughprotespeed will become famous soon enough
Question busted rear motor mount??????
I just purchased a used 2003.5 and love it, I have noticed that the shifter seemed to raise and lower when I shifted gears. I jacked the car up and investigated I found that the rear motor mount were it affixes to the motor was missing. Upon further looking I noticed that the previous owner had some tranny work done and when re-installing the motormount he screwed the lower bot in an snpped the aluminum housing exposing half of the inner threads. My question now is how do I fix the aluminum and what size bolt woud be missing? Thanks
PROTESPEED
2003.5 mazdaspeed protege. Silver
protespeed is offline   Reply With Quote
 Old 07-08-2012, 05:49 PM   #2
The msp rmm is a bitch to get at, let alone fix. Looks like you bought a fuked car.
 Old 07-08-2012, 07:09 PM   #3
Kdawg207's Avatar
Posts: 2,389   (View Stats)
Rmm was one of the easiest direct replacement mods ever
But sounds like a much worse of an issue. Did you take a pic?
~~~NJ Nator OG~~~Then AND Now, Just Better~~~
Kdawg207 is offline   Reply With Quote
 Old 07-08-2012, 07:11 PM   #4
Front on msp is easy. Rear is a bitch. It's not a ms3...
helmetface (07-08-2012)
 Old 07-08-2012, 07:59 PM   #5
protespeed's Avatar
Default i will try to get a pic
I wil fix the mfr if I have to pull the motor, ain't scared.
PROTESPEED
Motor Mount Inserts vs. Rear Motor Mount Pro's n Con's Dre 2010 MS3 - Engine, Transmission & Driveline 23 05-21-2016 08:47 AM
oem rear motor mount giordanos4 MazdaSpeed 6 - Engine, Transmission & Driveline 2 07-21-2010 03:08 PM
another SU REAR MOTOR MOUNT armarine04 MazdaSpeed 3 - Engine, Transmission & Driveline 4 04-23-2009 06:45 AM
Page generated in 0.24770 seconds with 22 queries
