| MazdaSpeed 3/6 - Car Audio & Electronics MazdaSpeed 3/6 - Car Audio & Electronics - Tired of that stock stereo? Installing Nav units or mods to your current system? Come talk about it here. |
![]() Join Date: Mar 2012 Location: Portland, Oregon
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 83
(Thread Starter) | Not Ranked : 0 score PERFORM THIS AT YOUR OWN RISK IF YOU FRY YOUR STEREO ITS NOT MY FAULT!!!!!!!! Doing this wire job will allow you to hook any device with a headphone jack up to your Bose stereo and run the AUX even though you dont have the AUX cable plug in. if you have SAT radio this can still work you just have to plug in the wires in the same spots in pair with your SAT radio PLuG. Please forgive the bad pics and the long write up, trying to be detailed and just tore my car apart at work and put it back together taking pics to write this up just now. SUPPLIES: Phillips screw driver, Flat Head Screw Driver, Headphone / AUX extension cable, 4 plug computer cable (can get at any local comp store). takes about 30 min. I did this on a manual so the dash removal will be a little different if you have a AUTOMATIC. SAFEST IF YOU UNPLUG BATTERY FIRST (although i didnt) Pull the E Brake all the way up - Open cup holder, there are 6 tabs to remove the first section, 3 on each side. best if you life up on one side first then the other, makes it easier but dont break the tabs! with all tabs released this will part will come right up, unscrew the shift knob, Counter clockwise and remove this next part is only held on by tabs, 2 total one on each side. from the middle by the shifter softly pull it up and you will fee it release Pull up on the back and then slide the front out and it is under the dash like a lip. set aside you dont have to unplug the stuff if you dont want too. now you have exposed 4 screws, only 2 need to be removed. Top two are in green un screw these. reds dont need to be touched the whole center part is held in by 2 tabs now, from the bottom pull it back and you will feel them release. Unplug the bottom two plugs that go into the climate control this allows the center to come out more so you can remove the Stereo plug back of the stereo, left side is the Radio Controls (main) right side is where your sat radio should go and where we will be wiring into now that everything is out of the way, run your AUX cable to where you want it, i ran mine from the center storage, through where the shifter was and back up through the back of the stereo housing cut the end that you will have plug into the back of the stereo off, you will see 3 wires, red, white and silver. take the plug you bought from the computer store and cut one end off, wire the two ends together, i soddered the silver to the ground to make sure i got a good connection. then white to white and red to red. this is what the other end should look like of the computer type plug plug- now you want to take a piece of wire (red as it runs power) and we are making a jumper, put wire plugs on the end to slide over the prongs on the back of the head unit. this part will install ON THE BOTTOM ROW of prongs. one goes into the FARTHEST left BOTTOM and the other plugs into the second to last BOTTOM as seen here (if you plug into the top you will get smoke bad from the unit and can fry it!!!!)- this is a jumper for power, it tells the head unit that something is plugged in. your AUX button will work with this plugged in but no sound. Plug in the Computer cable on the BOTTOM ROW next to the rigth side. you want to be right next to your jumper plug on the right, Make sure your configuration goes like this from left to right - Jumper, Empty slot, Ground, White, Red, Empty slot Jumper side 2, empty slot. as see below Now, plug the stereo head unit back in, plug a device into the jack and push the aux button, turn the volume up and you have sound!!!!!!!!! GO TEAM! put everything back together and enjoy! I hope this write up helps and makes sense. sorry for the pics they were all on my phone and again i just did this at work to show you guys how. let me konw if you have any questions!!!! Last edited by Speeden6; 04-24-2012 at 11:12 AM. |
![]() Join Date: Mar 2008 Location: Kirkland, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 342
Groans: 87
| Not Ranked : 0 score Is there a question? Of course we are interested! |
![]() Join Date: Nov 2010 Location: Charlotte, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 124
| Not Ranked : 0 score i don't think there is a write up on this forum, there is on a few other mazda forums though. i did this myself and it's so worth it not to have to spend hundreds on an adapter.
__________________ 07 MS6 Sport............. ![]() JBR Shifter Bushings * JBR RMM * JBR PMM * SURE SRI * VG Sharkfin Antenna * 20% Tint * Cobb AP * Grimmspeed EBCS * Coolant Bypass * PG TIP * Autotech Internals * |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| I think this is the one you're looking for: First you have to remove the head unit and HVAC... Then you wire in your Aux Port...
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! Last edited by Vansquish; 04-24-2012 at 11:14 AM. |
(Thread Starter) | Not Ranked : 0 score yeah see everywhere i read said to do the glovebox thing bug i didnt have too? |
![]() Join Date: Sep 2011 Location: Jacksonville, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 360
| Not Ranked : 0 score I gotta revive this old thread here. I did the AUX install per the OP's instructions. I have left channel working fine, but no right channel audio. I noticed the OP's instructions and the instructions Vansquish posted are different. (different empty pin locations) Any insight fellas? Thanks. |
| Not Ranked : 0 score Well i just realized there are other how-to posts aside from this one. I posted here because the page was bookmarked. xD |
![]() Join Date: Apr 2013
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Quick question, would this work the same? |
![]() Join Date: Apr 2011 Location: Millsboro, De
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,597
| Not Ranked : 0 score Has anyone found any info on the J-02 Aux male connector? I've searched for hours trying to find just the connector that plugs into the CD changer/Aux/Sat plug behind the HU.
__________________ 2006 Mazdaspeed 6 GT-unDISI swap in progress 1969 Nova-540BBC-S400's-TH400-sitting on 29.5x10.5 Skreets be calling... [SIGPIC][/SIGPIC] |
![]() Join Date: Jun 2013 Location: Houston TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
Groaned at 146 Times in 20 Posts
| Not Ranked : 0 score Anyone that's done this not able to controll the volume from the head unit on aux? |
![]() Join Date: Sep 2013
Rep Power: 0 ![]() Thanks: 24
im doing this tomorrow, but what kind of wire did you use for the jumper, speaker wire? and im guesing those are heat wraps and how do i go about doing this with sat radio plugged in, everyone says its impossible and you say its possible but didnt explain how | |
![]() Join Date: May 2012 Location: Pataskala, ohio
Rep Power: 0 ![]() ![]() Thanks: 19
| Not Ranked : 0 score I'm bumping this
__________________ 2007 Red MS6 AEM CAI, Custum exhaust, AP, HPFP internals, catless DP. 2005 Red Hyundai Tiburon SE V6 6MT, K&N CAI, Borla Full exhaust, Headers-Sold |
![]() Join Date: Feb 2015
| Not Ranked : 0 score Just to let everyone know, similar to timjs comment earlier. This mod had only very bad quality left speaker audio for me in my 2006 gt MS6 with Sirius Satellite. I believe there are stereo's with different pin-outs on the back. Following the wiring presented here: http://www.mazdaspeedforum.org/forum/foru...ow-aux-mod.jpg had my aux fully functioning and sounding great! Also. I second vics6's question about having this work with the satellite radio as well.... Do you just splice the aux wires into the Sat wiring harness and short the two pins? I know you can get a Sirius vehicle mount that allows you to push the aux through the satellite connection but then you need an external $50 mount which is a pain in the ass. Thanks everyone! |
![]() Join Date: Sep 2018
| Not Ranked : 0 score just bought a 2012 mazda 3 grand touring hatchback---cant get the bluetooth to work with a cell phone---i just come here to look for an auxiliary wire so we can listen to our recorded music-----if anyone might know something out of the ordinary to tell us please do---we havent had problems with other systems but may need to do something different here to make this bluetooth work-----WHEN I PRESS THE MODE BUTTON--- SCREEN SAYS IT IS SEARCHING BUT GET NO CONNECTION WHEN PHONE IS IN BLUETOOTH FUNCTION SO AM LOST PAST THIS ACTION---------I AM LISTENING-------PRETTY SURE THE WIRED AUXILIARY WILL WORK ---I WANT TO KNOW IF I CAN GET THIS WIRE AT A DISCOUNT STORE OR AT A MAZDA DEALERSHIP THANKS JERRY EMERSON-----WILL BE INTERESTING TO HEAR WHAT EVERYONE HAS TO SAY |
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
| Help with GEN1, Non-Bose stereo upgrade!! | willc2500 | MazdaSpeed 3/6 - Car Audio & Electronics | 3 | 02-14-2012 04:31 PM |
| Bose stereo wont take my CDs | jo.jacques | MazdaSpeed 3/6 - Car Audio & Electronics | 5 | 02-14-2011 10:54 PM |
| Got rid of Bose ( finally ) New stereo system * Pix * | MGM_GT3 | MazdaSpeed 3/6 - Car Audio & Electronics | 25 | 02-13-2011 12:40 AM |
