 Old 01-21-2020, 12:19 PM   #1
msfastashell's Avatar
Posts: 36   (View Stats)
msfastashell is just really nicemsfastashell is just really nicemsfastashell is just really nicemsfastashell is just really nice
Default Stock Bose system w/ Eonon questions - MS3 Gen 1
I've been reading about ways to upgrade the stock Bose system and I'm not sure that I'm clear on several things. This will be my first time messing with car audio, I've done things like GROM adapters and the like but I feel that this will be more involved. I'm handy enough to handle the install, I'm just not sure I follow what I need to do to keep cost low but also do it right.
I just got an Eonon unit for a good price, but that's as far as I've gotten. I don't plan on adding any extra speakers/subs.
- I know I need to ditch the stock Bose amp. Do I need to buy an amp if I have the Eonon or can I run speakers straight to the Eonon?
-Can I still utilize the factory wiring harness if I ditch the stock amp and keep the factory bose speakers? (I do plan on upgrading speakers in the near future, could I utilize the factory harness with all other components being aftermarket?)
I'm trying to do all of this research myself, just making sure I understand. Any and all help is greatly appreciated!
BCM MS6, Panda interior
ZZB, destroyed block is now a table
Built block: SP63 2618 Mahle pistons, Manley H-beam rods, Clevite main and rod bearings, stock head, stock head bolts and main bolts
Stock turbo , Corksport TMIC, catless dp, Cobb tip and intake, autotech internals, pnp stock IM, SURE rmm, RPM street springs
^crashed^
2008 Mazdaspeed3 GT
BC Racing Coilovers, Cobb SRI+TIP, Cobb catted dp, GHL resonated catback, EVO X wheels w 235/40r18 Cooper Zeon RS3-A, JBR short shifter, TWM Type R knob, DNP manifold (may go back to stock)
msfastashell is offline   Reply With Quote
 Old 01-21-2020, 08:58 PM   #2
mazda62006's Avatar
Posts: 65   (View Stats)
mazda62006 is a splendid one to beholdmazda62006 is a splendid one to beholdmazda62006 is a splendid one to beholdmazda62006 is a splendid one to beholdmazda62006 is a splendid one to beholdmazda62006 is a splendid one to behold
I was able to keep my speaker and amp. The eonon should have a pre-amp wire which would allow you to turn the amp on. You will need a wiring harness that will connect to the factory wiring. Not sure which eonon you got and if it was specific to your speed 3. A good place to look for a wiring harness is Crutchfield. That will give you a good ideal of what is needed to make an aftermarket unit work in your car.
mazda62006 is offline   Reply With Quote
 Old 01-21-2020, 09:13 PM   #3
mazda62006's Avatar
I found this kit at crutchfield. Although I'm not sure the year of your car so you would have to go to the site and input your information. choose a radio and then select see installation gear.
PAC RP4-MZ11 Wiring Interface
Connect a new stereo and retain steering wheel audio controls, entertainment system, safety warning chimes, and factory amp in select 2008-up Mazdas
PAC
Item # 541RP4MZ11
PAC's RP4-MZ11 radio replacement interface lets you replace the factory radio in select 2008-up Mazdas.
 Old 01-21-2020, 11:12 PM   #4
So I have the Eonon ga5151f. It is specific to 04-09 mazda3. I'm thinking I can just use what's supplied and not need anything else if I just wanted to retain everything. But I guess what I'm asking is: I plan to upgrade speakers. I don't think I can keep the stock amp and expect any increase in sound quality, can I?
I appreciate the links, I had looked at the PAC but wasn't entirely sure what I'd use it for...
Could I just bypass the amp, keep the factory wiring and not add an amp in there while upgrading the speakers?
^crashed^
2008 Mazdaspeed3 GT
 Old 01-22-2020, 01:25 PM   #5
mazda62006's Avatar
I believe you can. I would look at the crutchfield site and look at their upgrade path. I believe it will show you what type of speakers you can use with the amp if you choose to do so. It will also show you what you can use without stock amp.
Eonon GA6163f to PAC AOEM-MAZ2 to Stock Bose .Slug 2010 MS3 - Car Audio & Electronics 5 01-17-2017 09:00 AM
Adding HD Radio on stock Bose system Chinsel MazdaSpeed 3/6 - Car Audio & Electronics 3 04-12-2010 09:00 PM
Stock BOSE system worth half a damn? koretex MazdaSpeed 3/6 - Car Audio & Electronics 11 11-05-2009 08:05 AM
Bose system questions... splat1 MazdaSpeed 3/6 - Car Audio & Electronics 1 06-17-2008 12:42 PM
Page generated in 0.25199 seconds with 21 queries
