 Old 09-05-2014, 03:57 PM   #1
jrsmith's Avatar
Posts: 93   (View Stats)
jrsmith has a reputation beyond reputejrsmith has a reputation beyond reputejrsmith has a reputation beyond reputejrsmith has a reputation beyond reputejrsmith has a reputation beyond reputejrsmith has a reputation beyond reputejrsmith has a reputation beyond reputejrsmith has a reputation beyond reputejrsmith has a reputation beyond reputejrsmith has a reputation beyond reputejrsmith has a reputation beyond repute
Default Need some help wiring up backup camera for my D5151
Hey guys,
So I've been running the D5151 in my 08 Mazdaspeed 3 for a few months now, working great. Decided I will get a backup camera for this unit. I picked up a generic Mazda 3 camera from ebay (pictured). I am a little bit confused with all of the red power wires on the yellow video cable. Anyway here is what I plan to do. Let me know if I am on track.
I will not use both red wires on the yellow video wire (not needed because D5151 supports automatic camera activation via canbus. I will run the yellow RCA cable along lower passenger side and plug into the rca plug at the back of the D5151. For the other power wire I will find a ground spot on the body for the black wire, and for the red wire I will connect it to the wire that powers the backup lights.
Sound about right?
jrsmith is offline   Reply With Quote
 Old 09-05-2014, 05:01 PM   #2
ArmanRus's Avatar
Posts: 1,566   (View Stats)
Groans: 42
Sounds about right. In my old Mazda3 sedan, there was a wire harness right above the scissor jack area. I don't know if it is the same for the Mazdaspeed though.
What you can do also is tap the RED wire on the RCA to the 12V reverse switch on the radio harness if you can find it. Then splice the other end of the RED wire to the camera power. That way you only need to find a ground point.
 Old 09-05-2014, 07:24 PM   #3
jrsmith's Avatar
Ok, I didn't realize there was continuity between the red wires on the Yellow rca cable. I'm pretty sure the D5151 doesn't have a +12v reverse switch, it only has a rca backup camera hookup (i'll have to double check though). If I tap into say the cigarette lighter for 12v, will the camera be powered on all the time?
 Old 09-05-2014, 07:32 PM   #4
ArmanRus's Avatar
Groans: 42
Yeah it is continuous. It was meant for the older models where you tap that to a signal wire on the back of the headunit, that way it auto-switches to the reverse cam. I just looked at the wiring diagram and it doesn't seem to have a reverse signal.
You don't want to tap the cig lighter, the cam will be on all the time.
The Following User Says Thank You to ArmanRus For This Useful Post:
jrsmith (09-05-2014)
 Old 09-05-2014, 07:51 PM   #5
Liltoaster540's Avatar
Posts: 238   (View Stats)
Liltoaster540 has a reputation beyond reputeLiltoaster540 has a reputation beyond reputeLiltoaster540 has a reputation beyond reputeLiltoaster540 has a reputation beyond reputeLiltoaster540 has a reputation beyond reputeLiltoaster540 has a reputation beyond reputeLiltoaster540 has a reputation beyond reputeLiltoaster540 has a reputation beyond reputeLiltoaster540 has a reputation beyond reputeLiltoaster540 has a reputation beyond reputeLiltoaster540 has a reputation beyond repute
When I installed my D5151 with the backup cam I had to run the wires up under the headliner and down the trunk to the reverse lights. I'm not sure if this was necessary but it worked.
Originally I tapped the cigarette lighter but it would show the backup all the time.
SOLD-->2008 Mazdaspeed 3:
Cobb AccessPort - Cobb SRI - Autotech HPFP Internals - JBR Chrome-Molly RMM - JBR SSP - JBR SB
DISI Turbo Inlet Pipe -Test Pipe
2006 Mazdaspeed 6:
Eagle Rods - Autotech Internals - Cobb AccessPort
Liltoaster540 is offline   Reply With Quote
 Old 09-05-2014, 09:33 PM   #6
jrsmith's Avatar
I think i'll try finding the reverse light wire that comes off the pjb. It's supposed to be a green/black wire (from here Reminder... where to locate the reverse indicator wire on Mazda3 - Mazda3 Forums : The #1 Mazda 3 Forum). I have the pjb connector pinout as well so I should be able to figure it out.
 Old 01-08-2018, 10:15 AM   #7
dolbouck7's Avatar
Posts: 21   (View Stats)
dolbouck7 is an unknown quantity at this point
I know this is super old,
but was it the Green\black wire by the PJB?
In the process of doing this myself.
Bone Stock!...Well, maybe a JBR OCC and a Corksport silicone Elbow.
dolbouck7 is offline   Reply With Quote
Backup Camera from ebayz bioevolve 2010 MS3 - Car Audio & Electronics 27 01-27-2017 07:58 AM
HOW-TO: Rearview/Backup Camera skeurton 2010 MS3 - How-To's 26 07-15-2013 07:53 AM
Backup camera on CX-7 Uther CX-7 > Car Audio & Electronics 6 07-11-2012 11:41 AM
backup camera help dgillie CX-7 > Car Audio & Electronics 0 04-15-2012 10:12 PM
Page generated in 0.28041 seconds with 24 queries
