Mazdaspeed Forums
-   CX-7 > Car Audio & Electronics (http://www.mazdaspeedforum.org/forum/forum/f125/)
-   -   how to: single amp install w/bose (http://www.mazdaspeedforum.org/forum/forum/f125/how-single-amp-install-w-bose-72745/)
ottoblotto 02-18-2011 09:39 AM
write up on how to install sub with amp on a bose setup v2.0 with better pix, descriptions, ect... lost during great server disaster of 2010...
tired of your supposed "high end" Bose system not having a bottom end like jessica alba? then do this and youll be fine...
first thing you want to do is run your power wire. remove battery, drop panel out from under the drivers side, and pop all the door sill panels along the floor.
http://i121.photobucket.com/albums/o...h/DSC01991.jpg
http://i121.photobucket.com/albums/o...h/DSC01988.jpg
http://i121.photobucket.com/albums/o...h/DSC01997.jpg
fashion some kind of modern day poker/cable puller assembly kinda like this:
http://i121.photobucket.com/albums/o...h/DSC01990.jpg
then run it through the wire harness grommet that goes through the firewall. itll poke a small enough hole to allow the cable to go through, but no water later on. had it for a few years now and havent had any water intrusion.
http://i121.photobucket.com/albums/o...h/DSC01992.jpg
http://i121.photobucket.com/albums/o...h/DSC01993.jpg
http://i121.photobucket.com/albums/o...h/DSC01989.jpg
run the cable through the door sills, make sure you go on the outboard side of the drivers seat belt. its a mofo to work, but itll go. if not just tuck it up nice and neat.
now you have power to the trunk space. this is where youre gonna have fun with splicing into wires. use whatever you want, i got these easy clip deals. have been solid for years no worries...
remove trunk bed, and get to the bose amp. it has a cover over it that just snaps out.
http://i121.photobucket.com/albums/o...h/DSC00847.jpg
http://i121.photobucket.com/albums/o...h/DSC00846.jpg
run your power back here and have your ground cable ready. i installed mine right to where the bose amp grounds the chassis i believe.
http://i121.photobucket.com/albums/o...h/DSC00844.jpg
http://i121.photobucket.com/albums/o...h/DSC01995.jpg
now on the Bose, the first one i spliced was the "remote on" cable. it is the far left hand plug on the bose amp and the furthest left cable on the bottom.
http://i121.photobucket.com/albums/o...h/DSC00841.jpg
http://i121.photobucket.com/albums/o...h/DSC02001.jpg
ok so speaker splice. two sets of cables, lefthand side of middle plug, top and bottom. one solid white and one solid grey each.
http://i121.photobucket.com/albums/o...h/DSC01987.jpg
http://i121.photobucket.com/albums/o...h/DSC00836.jpg
i used "white hot/grey not" to match up "Monster Cable" speaker wires that have white writing on one and nothing on the other. run these to your line converter. here you see the line converter. i turned all the pots down and then worked them upwards. used the line out setting on it. connected rca's and ran to amp.
http://i121.photobucket.com/albums/o...h/DSC00843.jpg
i used the scosche per recommendations. worked out great.
http://i121.photobucket.com/albums/o...h/DSC01986.jpg
http://i121.photobucket.com/albums/o...h/DSC02009.jpg
you also see that im running the amp bridged into one channel. then i ran the speaker line to sub and fired it up on a test run. was stumped why i got barely any sound and messed with the pots on line converter and amp for about five minutes before i realized that the volume was on 5 in the car... der... so i fixed that... anyway, here is the finished product.
http://i121.photobucket.com/albums/o...h/DSC02004.jpg
http://i121.photobucket.com/albums/o...h/DSC02005.jpg
http://i121.photobucket.com/albums/o...h/DSC02007.jpg
http://i121.photobucket.com/albums/o...h/DSC02006.jpg
i put all the wires away nice and tucked and when i get a chance, if ever, ill zip tie all things and make it super nice. but not a high priority for me right now... anyway, i hope this helps someone else whom enjoys music as much as i do. oh and dont rag my little pioneer 8" sub. it hits super hard and is awsome for my rock n roll... maybe someday ill grow up and buy a JL Audio or something... anyway, any questions or if i missed something let me know. hope this helps out...
Rush24 02-19-2011 10:09 AM
Thanks a ton....this will help a lot...gonna tackle this soon....gotta order up 2 Type R's and amp then I'll be good....
ottoblotto 02-20-2011 01:05 AM
save yourself some scratch and trunkspace and just get a single sub. or use the same amount of money and get a better sub. since it is sitting in the cab with you, the bass acoustics are very efficient and dont require a massive dual/tri sub setup. unless of course you really want to go boom! i have the equalizer settings on the display in the negatives and the pots turned down to 1/2 or less on everything because the bass is uber loud where in a car with an actual trunk i had everything maxed out. i have a 1000w digital monoblock running that little bitty 8" pioneer and it hits loud enough for rock to techno to r&b. anyway, just my thoughts...
edit:
this will suffice:
mikomi 02-21-2011 10:36 AM
I prefer self-enclosed subs like the pioneer one. more practical. And you leave yourself tons of cargo space.
DragonLord3688 08-16-2014 01:22 PM
I have the same car, 08 cx7, I have my own amp and sub box I'm putting in, but I need to use the bose speakers for all the doors and stuff, I hooked it all up and realized I have the bass, but no speakers now... I'm trying to see if by following your guide here, can I still hook up the speakers running through the remote for my own amp / subs? this is very time sensitive!
Ozynigma 08-16-2014 08:18 PM
Quote:
Then resurrecting a 3 year old thread may not be your best option.
Sorry I can't help I don't have the Bose system in my CX7.
Try searching some of the other threads on upgrading the sub amp.
Mgraham84403 12-21-2016 06:06 PM
Factory amp plug
I realize this is an old thread but I'm hoping you can answer a few questions for me. Why did you unplug the factory amp plug? Did you reconnect it after installation?
Thanks, Matt
donny1584 09-18-2019 02:22 PM
Anyone know why the photos are blurry and unreadable?
Vansquish 09-18-2019 08:42 PM
Potato camera from 2011.
Page generated in 0.20639 seconds with 11 queries
