![]() Join Date: Aug 2012
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Thanks! |
![]() Join Date: Jul 2011 Location: Northampton, Pennsylvania
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,491
Groans: 405
Groaned at 19 Times in 16 Posts
| Not Ranked : 0 score Did you attempt to take the dash apart and pull the radio? Reason why I ask is it is possible for the wire connections to become loose or for a wire to break. |
| The Following User Says Thank You to cbspd3flip For This Useful Post: | Raider (09-12-2012) |
(Thread Starter) | Not Ranked : 0 score yeah i just pulled it, looks good. Found a line out converter for subs back there all connections seem good. Any particular I should look at? |
Groans: 405
| Not Ranked : 0 score I don't really know anything in specific with the cx-7's audio and wiring, so I'm no help beyond the basics. Sorry. GL though |
(Thread Starter) | Not Ranked : 0 score thanks! maybe someone else will chime in. I am lost... |
(Thread Starter) | Not Ranked : 0 score Looks like the previous owner had someone install some kind of accessory, was checking over fuse box and followed some suspicious electrical wiring to some inline fuses. Car is at Stealership to see what they come up with. I have a 2 year extended warranty hopefully they will cover it (doubtful). |
![]() Join Date: Apr 2012 Location: Worcester ma
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score Same thing happened with my ms6 , except NO power to radio, clock display out but my heat/temp gauges work but no display. I've checke fuses and chased wires but got nothin. Any help?! |
![]() Join Date: Apr 2015 Location: Alaska
| Not Ranked : 0 score Hey did you ever solve the problem for your speed6? I have the exact same issue. My hvac works and I can load/unload a cd but radio doesn't play anything and the display above doesn't work either. Thanks! |
| My Car Radio Stopped Working | Haltech | Automotive News | 0 | 01-06-2011 10:50 PM |
| OEM LCD display with Aftermarker radio | djchris721 | MazdaSpeed 3/6 - Car Audio & Electronics | 15 | 12-21-2009 09:08 PM |
| Obama team working 'around the clock' on auto crisis | Haltech | Automotive News | 0 | 03-05-2009 01:10 PM |
| what would cause the radio to not turn on (not a fuse) | builthatch | MazdaSpeed 3/6 - Car Audio & Electronics | 0 | 11-13-2008 08:14 AM |
