Like Tree8Likes
 Old 04-15-2016, 07:21 AM   #161
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Bilstein does not sell direct to the public, so you buy a set then send them to whoever is doing your revalve.
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 04-15-2016, 07:56 AM   #162
cocoanton's Avatar
Posts: 168   (View Stats)
cocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the world
Originally Posted by jcolton View Post
My friend just got some KW Variant 3 Coilovers for his genone MS3, and I have to say holy shit they are pretty incredible! I have seen a lot of stuff for the KW Variant 2's for the 06-07 MS6, but was curious if anyone is running the Variant 3's on their speed 6?
There is no v3 for the ms6 as to my knowledge. Wante v3 but had to s"settle" for v2. That was 4 years ago. No regrets!
cocoanton is offline   Reply With Quote
 Old 04-15-2016, 08:42 AM   #163
KevinK2's Avatar
Posts: 907   (View Stats)
KevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the world
Groaned at 79 Times in 52 Posts
Not sure on this, but is the chart for re-valves? From their website on sevice, the fine print below the chart reads like tuning just means you get a dyno sheet after a rebuild with stock parts. And any real tuning costs extra.
From Delaware
Current Fleet: 04 Mazda6, 93 Rx7 TT, 76 Triumph 750 Trident
Tracked Cars: 68 Triumph GT6 (~full race prep'd), 81 Porsche 924 Turbo, 93 Rx7 twin turbo
KevinK2 is offline   Reply With Quote
 Old 04-15-2016, 08:52 AM   #164
Eth Fiend
phate's Avatar
Yes, they offer re-valve services. I talked to them about it a long time ago, they dyno shocks before and after if you want them to, which is what I think they're referring to.
-06 MS6
 Old 04-15-2016, 09:09 AM   #165
KevinK2's Avatar
Yes, I see the bottom chart is titled re-valving service fees. But at the bottom:
"Tuning fees of $55.00 an hour apply if it is necessary to meet specific damping targets." So I guess you get a generic re-valve for that price, based on your car weight spring rates, and intended use. But if you know the damping curves your looking for, that costs extra.
From Delaware
 Old 04-23-2016, 09:26 PM   #166
jcolton's Avatar
Posts: 80   (View Stats)
jcolton is the leader of the worldjcolton is the leader of the worldjcolton is the leader of the worldjcolton is the leader of the worldjcolton is the leader of the worldjcolton is the leader of the worldjcolton is the leader of the worldjcolton is the leader of the worldjcolton is the leader of the worldjcolton is the leader of the worldjcolton is the leader of the world
Agreed, that's my bad i missed that OP was MS6. The v3's went on a speed3. I've been running corksport coilovers and they ride pretty nice! Once I figured out the adjustment stuff at lease, at first it was damn stiff. The KW v3's in comparison ride much smoother with the same if not better performance with the rebound adjustment set up properly which was damn impressive. Id love to see how the V2's ride compared to the V3's as I wouldn't think many people would screw with rebound stuff too much?
jcolton is offline   Reply With Quote
 Old 05-10-2016, 10:00 AM   #167
joscreven's Avatar
Posts: 24   (View Stats)
joscreven will become famous soon enoughjoscreven will become famous soon enough
I want to ask the gurus on here as this is the "official MS6 suspension thread". I've searched high and low and seen various competing arguments on whether to get Bilstein HDs or B8 (sports) if you have lowering springs at all. I have RS*R springs that lower the car 1.3 inches. The Bilstien info I've seen say HD struts are good from stock down to 1.5 inches. I also have seen on a few threads that people got the HDs and seemed pleased.
My question is are HD struts actually good to 1.5 inches? Or should I go with the B8s? This is a DD so no need for anything extreme. I just don't want to get the HDs and then my suspension be so screwy I have to shell out $$$ for the B8s in the end anyway. Thoughts and ansers appreciated.
joscreven is offline   Reply With Quote
 Old 05-10-2016, 10:06 AM   #168
Eth Fiend
phate's Avatar
The B6's (HD's) are fine for any amount of lowering in the MS6. The shock will not be the first item to bottom out, so it doesn't matter.
The suspension won't be 'screwy', but the B6's are very soft. The B8's supposedly have more damping, which is a good thing for performance but I haven't experienced it first hand.
-06 MS6
 Old 05-10-2016, 10:16 AM   #169
joscreven's Avatar
Thanks for the info Phate, that is a good point about something else bottoming out before the strut does...
I would be going from stock struts, so I would imagine the B6s/HDs would be an improvement, however slight. My main goal was to get rid of the incredible fender gap at stock, while still having some reasonable amount of comfort given the roads these days. I wanted to do shocks/struts together since I've heard the OEM MS6 struts don't last long with lowering springs
The Following User Says Thank You to joscreven For This Useful Post:
ZX299 (05-10-2016)
 Old 05-10-2016, 11:06 AM   #170
KevinK2's Avatar
I'd be interested in where Bilstein says the HD's are ok for 1.5" drop, no disrespect I just have not seen that. They do say B8's are good for it.
With your RS's, although not likely an issue, just make sure the springs don't get loose at full droop (standard rod length), and verify you have a proper bump stop in compression, inside the shock and/or outside .. trimmed if necessary.
I found this old link with an Rx8 on RB drop springs (~20% stiffer) and B6's, and he approves. Bilstein HD shocks impressions - RX8Club.com
From Delaware
 Old 05-10-2016, 12:41 PM   #171
joscreven's Avatar
KevinK2, you acutally make a really good point. Multiple forums mention that the HD (B6) are good from stock and "small" drops...but on further investigation I see no where that Bilstein officially say this in the product description. On the contrary I have mainly seen the product description say it's good for stock ride height.
This begs the question that if all of these people that put on HDs with lowering springs is their ride improved? By browsing forums it seems people approve, but it's hard to get anything verifiable as everyone has different opinions.
The RX8 had RB springs that only lower .5 inches. I would think the HDs probably would have been good for that minor amount of lowering.
I am going to call Bilstein. I'll be back with their responses.
 Old 05-10-2016, 01:38 PM   #172
KevinK2's Avatar
Originally Posted by joscreven View Post
.... The RX8 had RB springs that only lower .5 inches. I would think the HDs probably would have been good for that minor amount of lowering...
You have 2 things to consider here, drop and spring rate.
The RSR's are only 20-23% stiffer than stock, as is the RB's on the Rx8 (20%). This example establishes the ride quality you can expect, which sounds great from this one source.
Now consider drop. The B8's have shorter piston rods, for the shorter travel of a racing or large drop spring. This makes sure the spring does not get loose at full droop, like if you catch air speeding over a launch ramp type crest of a hill. For your case of no-HPDE track use, dd, that's about it. As far as strength of the B6, Phate is running 700 - 850 lb/in springs on B6's with modified valving, and pulling 1.3G's on corners during Autox, so that's NOT an issue.
But as with any shock upgrade and lowering spring, you need to make sure you don't top out during compression too soon, so check bump stops, as I said.
From Delaware
 Old 05-10-2016, 01:43 PM   #173
joscreven's Avatar
Just talked with Bilstein. They confirmed the HD (B6) are meant for stock ride height and are not recommended for lowering, so I'm really not sure how it ever got into the forums that this was gospel. The B8 is recommended for lowered height. That being said, they didn't say you can't use the HDs.
This again brings up the question of how everyone that is using the HDs with lowering springs feels about the handling of the car.
 Old 05-10-2016, 01:55 PM   #174
Eth Fiend
phate's Avatar
The handling with OTS B6's is fine, but SOFT. That's it. I autocrossed the car for a season with them and H&R springs. There is much better out there, but really for most people they do just fine.
I can tell you with 100% certainty that the B6's are just fine, dimension wise, to run with lowering springs. Dampers aren't position sensitive, they're velocity sensitive. You'll just be running the piston lower in the body than you would be with a B8, but that isn't an issue. You won't damage them, they won't provide any different damping than if you ran them with stock height springs.
The B8's offer a little more damping, and I think that's a good thing for the MS6. The rear could definitely use a little more than the B6's provide.
For people who aren't worried about performance, the B6's work great and don't degrade the handling at all. They're more comfortable than stock and they should last forever. If you want a very slight bump in performance, go with the B8's. If you want the ability to turn them into coil overs down the road, either will work but I have a slight preference for the B6's because they should allow a bit more droop travel before full extension.
-06 MS6
SpeedRebirth (05-10-2016)
 Old 05-10-2016, 02:10 PM   #175
joscreven's Avatar
Phate, forgive me if this is a dumb question, but the B6s are still stiffer than the stock MS6 suspension, correct? I don't mind it being a little firmer. I plan on AutoXing at some point, but as anyone that daily drives 99% of my time will be in normal (crap) roads in some amount of traffic.
 Old 05-10-2016, 02:25 PM   #176
Eth Fiend
phate's Avatar
It's been a while, lol. I'd say low speed damping of the B6 is very similar to stock in the front, a little less in the rear. High speed damping on both are less than stock, so the bump handling is better and more comfortable.
-06 MS6
 Old 05-10-2016, 02:30 PM   #177
joscreven's Avatar
Thanks for all the comments. I can offer some opinions when I get my set up complete. Thanks again.
phate (05-10-2016)
 Old 05-10-2016, 06:27 PM   #178
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
Great to hear that Bilsteins are working nicely on our cars and that quality is much better than the chinese coils that a lot of people use. I'm going with B12 Pro kit because stock ride height is fugly and they are "tuned" as a kit together with the Eibach springs so they should perform perfectly and as phate said, last forever. Love how cheap they are too
I'll DD my car and go for spirited drives ofc. 500awhp should test them pretty good
Question, one should replace the top hat right? My oems looked like fried fries
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
 Old 06-04-2017, 04:14 PM   #179
abdeel98's Avatar
Posts: 1   (View Stats)
abdeel98 is an unknown quantity at this point
PAO MOTORING Coilover For Mazda 3 2010-2013 Mazdaspeed 3 Coil Suspension Coilovers Spring Strut absorber Airmatic. Anybody knows anything about this set on sale in amazon? I wonder? See link below...
https://www.amazon.com/MOTORING-2010...trut+shock+kit
abdeel98 is offline   Reply With Quote
 Old 06-04-2017, 08:20 PM   #180
KevinK2 (06-05-2017)
 Old 04-28-2018, 09:26 PM   #181
Marcus's Avatar
Posts: 777   (View Stats)
Marcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the world
I did a search in this thread and nothing came up so, a PSA regarding Moog "adjustable" ball joints for the Speed6.
They can only be adjusted before they're pressed in... dont make my mistake. I opted to try those since it would've been SPC #3 for the right.
I should also state I'm not too impressed with H&R Coils after 4 months. I should've went with B8's and CS or custom springs.
2006 Moist Metallica Silver Speed6 GT #6557 @ 267,000km
Leakdown results was 50% or more across all four. slow rebuild in progress
Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses.
Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB.
SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate.
Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs.
To order: Fullrace Exhaust Mani. FMIC. Damond side mounts. New built motor. Still thinking about Flowmasters
Marcus is offline   Reply With Quote
 Old 07-24-2018, 11:11 AM   #182
MichaelAress's Avatar
Posts: 8   (View Stats)
MichaelAress can only hope to improve
Groaned at 6 Times in 2 Posts
Default The Official MS6 Suspension Thread
I seem to find a lot of threads have old links to nowhere a lot are stickies. Seems like they shouldnt be a sticky anymore if the links are all dead.
MichaelAress is offline   Reply With Quote
 Old 07-24-2018, 11:38 AM   #183
jcolton's Avatar
It's often hard to keep links live forever....especially to products...manufacturers/resellers are constantly changing their website. This post still contains all of the information you are looking for, it's just not spoon fed to you. Run a Google search on a couple of these things that you find interesting and instead of complaining that none of the links work, maybe offer some replacement links to the products you were interested in for those that come next. That's how we all work together in a forum to keep info current and to maintain the library of knowledge here.
Tres3 likes this.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f12/official-mazdaspeed-6-suspension-thread-99915/
Foro Club Mazda España ? Ver Tema - amortiuadores Mps This thread Refback 02-28-2015 12:57 AM
Mazda MPS Owners Club • View topic - So.. i finally placed an order for these.. This thread Refback 05-01-2012 12:06 PM
The Official MS3 Suspension Thread RhoadBlock MazdaSpeed 3/6 - Suspension & Brakes 199 07-02-2018 11:27 AM
Official: Mercedes-Benz offers new Ride Control suspension on SLS AMG Haltech Automotive News 1 04-13-2012 09:28 PM
Another.. is my suspension shot thread amc5 MazdaSpeed 3/6 - Suspension & Brakes 14 01-20-2012 08:16 AM
Another suspension noise/sound thread-Strut Bearing? Raider MazdaSpeed 3/6 - Suspension & Brakes 8 12-07-2011 09:57 PM
Page generated in 0.42734 seconds with 30 queries
