Like Tree28Likes
 Old 02-29-2012, 07:53 AM   #1
RhoadBlock's Avatar
Posts: 793   (View Stats)
Groaned at 7 Times in 4 Posts
Neutral  :  +2 score
Default The Official MS3 Suspension Thread
Here is a comprehensive list of all suspension systems and components available for the MS3.
SPRINGS
AutoExe Low Down Spring
Drop: 1.2" front, 1.2" rear | Part Number: MBA700 | ~$500
Straight from Japan and designed for the Mazdaspeed "Axela"!
The roll is placed under control by the spring rate intensified within the range that has less impact on a ride quality, so that the vehicle height can be brought down by approx. 30 mm. For the riding taste, the car stability is improved by bringing its center of gravity down, which provides a desired tendency to the “person who enjoys driving.” Moreover, the clearance of tire house becomes reduced, which makes the whole car look low. As a result, a dynamic feeling is provided to the styling.
Corksport MS3 Lowering Spring Set
Drop: 1.2" front, 1.0" rear | Part Number: Axl-3-288-10 | ~$210
Approximately +25% increase in spring rate over OEM
Give your car the performance appearance and edge you have been looking for with the CorkSport Lowering Springs. By reducing ride height approximately 1.2"" in the front and 1.0"" in the rear, adding the CorkSport Lowering Springs to your Mazdaspeed 3 will result in a quicker turning response, crisper road feel, a more aggressive appearance, and a firmer spring rate, while maintaining excellent ride quality.
The CorkSport Advantage:
• Lower your car by approx. 1.2"" front and 1.0"" rear for improved handling and less wheel gap
• Crafted from high tensile strength spring steel for long lasting quality and performance
• OEM finish to ensure lasting durability and rust protection
• Average 25% increased spring rate over stock spring rate
• Backed by CorkSport limited two-year warranty
• CorkSport Service and Support: Receive full color installation instructions, all of the needed installation hardware, and knowledgeable telephone installation support.
Eibach Pro-Kit
Drop: 0.8" front, 0.7" rear | Part Number: 5549.140 | ~$205
The Eibach Pro-Kit lowering spring set improves your vehicle's looks and performance. Pro-Kit springs lower the vehicle's center of gravity, reducing body roll in the turns, dive under braking, squat during acceleration and give the car a more solid secure feel at all times. Pro-Kit Springs also minimize the ugly fender gap that makes a car look "lifted." Eibach Pro-Kit Springs..." The look that performs."
Eibach Sport Line
Drop: ~2.0" front, ~2.0" rear | Part Number: 4.4955 | ~$240
Eibach Sportline is the extreme-performance spring set created for the extreme enthusiast - the one who craves a race-car attitude for maximum street performance - with the lowest possible drop, but with the exceptional ride quality you expect from Eibach.
Engineered with the same care as our Pro-Kit springs, Eibach Sportline springs achieve legendary handling by aggressively lowering your car’s center of gravity, using our precision engineered progressive spring rates.
By radically lowering your car’s center of gravity, our Sportline springs dramatically reduce squat during acceleration, body roll in corners and nose-dive under braking. By using our proprietary, progressive spring design, our Sportline springs provide the ultimate balance between high performance, extreme lowering and comfortable ride quality. When combined with today’s wild 18, 19 or 20 wheels and tires, the result is a car that handles just as white-hot as it looks.
H&R Sport Springs
Drop: 1.3" front, 1.2" rear | Part Number: 51643-2 | ~$230
H&R Sport Springs are designed and engineered for each particular application and are the correct spring rate for low aggressive looks, high performance handling and no ride harshness!
The most popular spring in H&R's line-up, Sport Springs will lower your vehicle an average of 1.5 - 2 inches (depending upon the make and model of your vehicle) for a lower center of gravity, improved handling and a more aggressive appearance. Sport springs feature more control than that of the OE Sport spring, but is still comfortable for daily use. Sport springs are an excellent choice for street and occasional track use.
Mazdaspeed Lowering Springs & Rear Camber Kit
Drop: 0.6" front, 0.6" rear | Part Number: GRMS-8M-L25 | ~$440
OE+30% spring rate
Mazdaspeed designed lowering springs specifically made for the Mazdaspeed3. The springs will provide a 15mm drop over stock. They will increase the stock spring rate by 30%. This also includes a camber kit for the rear wheels.
sarm1084 and DCSTAR89 like this.
2007 MS6 - broked & gone
2006 MS6 - less broked
Last edited by RhoadBlock; 02-29-2012 at 08:40 AM. Reason: MSF Database - Automerged Doublepost
The Following 10 Users Say Thank You to RhoadBlock For This Useful Post:
Awal (06-01-2015), charlesfist (02-29-2012), jimbojonesI495 (02-20-2015), kaprikorn (02-23-2013), Ms3_Miami (11-05-2012), Raider (02-29-2012), sarm1084 (04-22-2018), SLOWHATCH (03-01-2012), Varomnia (11-18-2016), White Jade (07-10-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f12/official-mazdaspeed-3-suspension-thread-106600/
Whiteline RSB thickness advice This thread Refback 11-16-2014 12:49 AM
Installed JBR Rear Sway! - DFW Mazdas This thread Refback 10-08-2014 11:18 PM
Support Thread For Idiots That Nearly Have To Sell Their Nsx To Fund A Cocaine Habit - Page 577 - Almost Anything Goes - SkatePerception This thread Refback 11-02-2013 05:20 PM
The Official MS3 Suspension Thread - Mazdaspeed Forums This thread Refback 09-06-2013 03:41 AM
CORKSPORT Mazda3/MPS 3 Rear Adjustable Swaybar - Page 2 This thread Pingback 07-26-2012 12:25 AM
Caldwell's 08' MS3 - Page 11 - TriStateTuners.com :: Home of Tristate Auto Enthusiast This thread Refback 04-25-2012 06:08 PM
The Official MS6 Suspension Thread RhoadBlock MazdaSpeed 3/6 - Suspension & Brakes 182 07-24-2018 11:38 AM
Official: Mercedes-Benz offers new Ride Control suspension on SLS AMG Haltech Automotive News 1 04-13-2012 09:28 PM
Another.. is my suspension shot thread amc5 MazdaSpeed 3/6 - Suspension & Brakes 14 01-20-2012 08:16 AM
Another suspension noise/sound thread-Strut Bearing? Raider MazdaSpeed 3/6 - Suspension & Brakes 8 12-07-2011 09:57 PM
Page generated in 0.88778 seconds with 42 queries
