Like Tree28Likes
 Old 07-07-2012, 11:22 AM   #41
mariomspeed's Avatar
Posts: 26   (View Stats)
mariomspeed is a jewel in the roughmariomspeed is a jewel in the roughmariomspeed is a jewel in the rough
i want to get the eibach pro-kit. any problems i should run into?
mariomspeed is offline   Reply With Quote
 Old 08-13-2012, 08:29 PM   #42
KillerSaiyan's Avatar
Posts: 22   (View Stats)
KillerSaiyan will become famous soon enough
I want a good suspension for occasional autoX and drag, but cant see myself putting out more than $1000 for it, seeing that its not my living, just occasional fun... I dont want BC though... possibly Sonic Tuning? def looking for rear sway bar kit to go with it also.
COBB AccessPort | HKS SSQ v4 | INJEN Cold Air Intake | CORKSPORT Turbo Inlet Pipe | EBAY (m2) Catless Long Downpipe | HKS Hi-Power Catback Exhaust | PTP Fuel Pump Internals | Grimmspeed EBCS | TWM Short Shifter | JBR 815 gram knob| SURE Short Shift Plate/Counterweight | STREETUNIT Shifter Bushings | STREETUNIT Rear Motor Mount | CORKSPORT SuperWhite interior LED Kit | HALO Angeleyes 7000k | DDM 6000k 35w (switching to 55w) HID Headlights | DDM 3000k 35w HID Fogs | Flat Black Evil M | Side Door Guard Removal | Evo Mod Grille| Tenzo-R dc-10 wheels| BC COILS| KENWOOD eXcelon Headunit (4v preouts) | ALPINE MRP-M500 Mono Amp (500w RMS) | ALPINE MRP-F300 4-way Amp (75w RMS x4) | ALPINE Type-R 12" Woofer | ALPINE Type-R 6.5 Door Speakersru
KillerSaiyan is offline   Reply With Quote
 Old 08-13-2012, 09:24 PM   #43
Todd98SE's Avatar
Posts: 1,077   (View Stats)
KW V1
Nliiitend1 likes this.
www.MOTOIQ.com
Beater Titan
Todd98SE is offline   Reply With Quote
 Old 08-20-2012, 07:42 PM   #44
silentwolf8's Avatar
Posts: 1,986   (View Stats)
silentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the world
Groans: 44
Question.. Does the OEM Struts off of a Pu fit the Wons..
Reason I ask: Thinking of getting coil-overs in the next month or so, and I have a buddy with his struts going out. If they fit I was just going to give him my OEM ones and save him some money.
Thanks.
ZOOM ZOOM left the Room
2013 SPW STi // COBB SRI w/Box // COBB BPV // UR Catless DP// UR CBE // COBB Lowering Springs // COBB Sway Bars // +1 NGK // DW65c FP
AWDTuning Tuned
silentwolf8 is offline   Reply With Quote
 Old 08-20-2012, 08:36 PM   #45
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
I believe the struts are directly interchangeable.
The shocks are not.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
 Old 08-20-2012, 08:37 PM   #46
jrdm91's Avatar
Posts: 10   (View Stats)
jrdm91 will become famous soon enoughjrdm91 will become famous soon enough
I'm new to the modding scene, I just want to confirm that the prices on the COBB and hotchkis sway bar is in fact both FSB and RSB.
Seeing that the hotchkis says "kit" that it is in fact F and R.
jrdm91 is offline   Reply With Quote
 Old 08-21-2012, 02:12 PM   #47
TRex's Avatar
Posts: 3,139   (View Stats)
^if it says kit then yes it is both
but pass on the FSB
 Old 08-21-2012, 04:32 PM   #48
Groans: 44
The shocks are not.
what makes the shocks not interchangeable?
AWDTuning Tuned
 Old 08-21-2012, 05:55 PM   #49
TRex's Avatar
^the pu's rear end has a slightly different setup from what i remember...but i cant tell how
genone
gen2
 Old 08-21-2012, 08:48 PM   #50
Groans: 44
hmm i would just assume they would fit cause the springs are matched.
AWDTuning Tuned
 Old 08-22-2012, 07:25 AM   #51
Nliiitend1's Avatar
The rear shock lower attachment point is different on the Pu than on the Won.
I know you need a longer bolt to put Won shocks on a Pu, so you'd probably need some sort of machined spacer or longer shock eye bushing to make a Pu shock work on a Won...
2008 MS3 GT
2016 MX-5 Club
TRex (08-24-2012)
 Old 08-22-2012, 07:44 AM   #52
Groans: 44
hmm.. well if i get the coils i guess it wouldnt hurt to check it out and maybe do a quick write up on the matter. Im sure he wouldn't care.
thanks for the help
AWDTuning Tuned
 Old 08-24-2012, 03:35 AM   #53
jrdm91's Avatar
but pass on the FSB
That what I figured. I'm not sure if I can bass on the FSB it's rattling fucking annoyingly as of now, so I have to make sure it's not anything more than the bushings or end links, I may have to replace it if it's more than that.
Thanks for the heads up of not needing to change it though. Much appreciated.
 Old 08-24-2012, 11:07 AM   #54
Todd98SE's Avatar
but pass on the FSB
That isn't necessarily true. It all depends on how you like to setup your suspension. Most people skip the front bar because its a huge PITA to install not because its not needed. Again it depends on the type of driving you do and your preference for setup.
www.MOTOIQ.com
Beater Titan
 Old 08-24-2012, 11:11 AM   #55
I have had both for years. The handling is better with both than just the rear, as I had the rear for a month until I did the front. Well worth it imo. Front just sucks to install.
Familyguy427 (01-19-2013), Todd98SE (08-24-2012)
 Old 08-24-2012, 11:34 AM   #56
TRex's Avatar
while im sure there are benefits in steering response
you cant argue the fact that sway bars reduce traction in the area they are installed
rsb lifts the inside wheel decreasing the traction in the rear inducing oversteer
fsb again attempts left that inside wheel...decreasing front traction and inducing understeer
personally in auto cross my biggest issues came from understeer and general lack of front traction through turns
heavy rsb and disconnecting my fsb during runs solved this
im not saying that this is the end all be all setup and of course you need to decide what is best for what kind events you run, but my personal opinion is to run no or a lighter fsb....im actually looking to source a regular 3 fsb to run always
 Old 08-24-2012, 11:43 AM   #57
Todd98SE's Avatar
For AutoX i'm sure a MZ3 or no bar is the hot ticket. For a track like Big Willow or Buttonwillow no front bar is the quick way to sliding backwards off track.
A large front bar can also reduce camber loss under roll which increases traction, all I'm getting at is a larger front bar is a preference depending on your preferred style and setup. In a heavy FWD camber limited Macpherson strut car a larger FSB can actually increase lateral front grip.
ouchmonkey and sarm1084 like this.
www.MOTOIQ.com
Beater Titan
The Following 3 Users Say Thank You to Todd98SE For This Useful Post:
Familyguy427 (01-19-2013), sarm1084 (04-22-2018), TRex (08-24-2012)
 Old 08-24-2012, 11:57 AM   #58
Todd98SE's Avatar
Let me add that the bar you choose plays a big role as well, not all are created equal. The OEM MS3 FSB size is 26mm solid IIRC. I have ran the 28.5mm solid Racing Beat FSB and currently run the 27mm solid Whiteline FSB. The Racing Beat was a bit to stiff and the Whiteline on the soft setting is a perfect match with the Tripoint rear bar on full stiff.
sarm1084 likes this.
www.MOTOIQ.com
Beater Titan
 Old 09-07-2012, 08:39 AM   #59
BierbaumC's Avatar
Posts: 5   (View Stats)
BierbaumC is an unknown quantity at this point
I couldn't find anything in this thread that was related to this..
Does anyone know if the KW V3 front c/o has an adjustment for the camber?
BierbaumC is offline   Reply With Quote
 Old 09-07-2012, 11:38 AM   #60
Nliiitend1's Avatar
None of the KW setups for the MS3 include any type of camber adjustment, but they can be used with Corksport's camber plates.
2008 MS3 GT
2016 MX-5 Club
BierbaumC (09-07-2012)
 Old 09-07-2012, 12:38 PM   #61
BierbaumC's Avatar
I was leaning toward KW but now that I see the BCs include this camber plate, I'm leaning that way.
Does anyone have those on their MS3?
If so, did it require modifying the strut tower itself?
 Old 09-07-2012, 03:18 PM   #62
Nliiitend1's Avatar
KW >>>>>>> BC
All day, every day.
The option of included camber plates isn't worth choosing BC over KW.
Todd98SE likes this.
2008 MS3 GT
2016 MX-5 Club
Todd98SE (09-07-2012)
 Old 09-07-2012, 03:28 PM   #63
Todd98SE's Avatar
KW >>>>>>> BC
All day, every day.
I found KW V1 for under $1k online and after adding the Corksport camber plates still came close to the BC price. As @Nliiitend1 said dont waste your time with BC.
Nliiitend1 and sarm1084 like this.
www.MOTOIQ.com
Beater Titan
The Following 2 Users Say Thank You to Todd98SE For This Useful Post:
Nliiitend1 (09-07-2012), sarm1084 (04-22-2018)
 Old 09-10-2012, 11:40 AM   #64
LLIo6oH's Avatar
Posts: 17   (View Stats)
LLIo6oH has a spectacular aura aboutLLIo6oH has a spectacular aura aboutLLIo6oH has a spectacular aura about
I think it's time to add CorkSport coilovers
CorkSport Mazdaspeed 3 Coilovers
LLIo6oH is offline   Reply With Quote
The Following User Says Thank You to LLIo6oH For This Useful Post:
Awal (06-01-2015)
 Old 10-15-2012, 07:18 PM   #65
StanceWerk's Avatar
Posts: 8   (View Stats)
StanceWerk is infamous around these parts
Groaned at 16 Times in 4 Posts
anyone know about the megan racing coils.
StanceWerk is offline   Reply With Quote
 Old 10-15-2012, 07:48 PM   #66
Nliiitend1's Avatar
Taiwanese cookie-cutter junk.
2008 MS3 GT
2016 MX-5 Club
Todd98SE (10-16-2012)
 Old 10-16-2012, 09:01 PM   #67
StanceWerk's Avatar
im sorry i dont know what that means i understood they are junk but why?
my other thought is going with h&r
 Old 10-17-2012, 10:54 AM   #68
Nliiitend1's Avatar
http://www.mazdaspeedforum.org/forum/foru...-setups-39059/
2008 MS3 GT
2016 MX-5 Club
MINATI (01-31-2015), Todd98SE (10-17-2012)
 Old 11-05-2012, 04:43 PM   #69
MS3MYK's Avatar
Posts: 1,967   (View Stats)
Would the Eibach Sportline Part Number: 4.4555 work on the MS3??? I know its for the MZ3 but its the only part number i can find for the Sportlines through my work.
2008.5 CWP Speed3 GT - SOLD /
1991 Ford Mustang LX 5.0 SSP
 Old 11-05-2012, 06:04 PM   #70
Nliiitend1's Avatar
Will they "fit?"
Yes.
Will they "work?"
Not well.
They're too soft and too low.
2008 MS3 GT
2016 MX-5 Club
 Old 11-29-2012, 09:02 AM   #71
bmoneyms3's Avatar
Posts: 37   (View Stats)
bmoneyms3 is infamous around these partsbmoneyms3 is infamous around these parts
Groaned at 41 Times in 13 Posts
i had road magnet springs on my last speed3
bmoneyms3 is offline   Reply With Quote
 Old 12-10-2012, 10:47 AM   #72
vivalawham's Avatar
Posts: 16   (View Stats)
vivalawham is on a distinguished road
I see the Cobb FSB/RSB kit listed as $380 - on their website it is listed as $535. Can it be found elsewhere for that much less? Am I missing something?
Fgonz662 likes this.
vivalawham is offline   Reply With Quote
 Old 01-19-2013, 04:49 PM   #73
Familyguy427's Avatar
Posts: 1,476   (View Stats)
Familyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the world
Groaned at 22 Times in 12 Posts
The Hotchkis FSB is now 32mm and is adjustable though on the website it does not say it is.
Old: 29mm 35% stiffer than stock/ 560 lbs/ in
New: 32mm 35% stiffer than stock/ 560 lbs/ in
I don't get why the percents are the same with a bigger sway bar unless the thickness of the walls is different yet I can't find supporting evidence.
Sent while eating rice
Familyguy427 is offline   Reply With Quote
The Following User Says Thank You to Familyguy427 For This Useful Post:
Koke382 (01-19-2013)
 Old 01-27-2013, 02:32 PM   #74
pixelNate's Avatar
Posts: 621   (View Stats)
pixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the world
You can get them for $380 here: http://www.mazdaspeedstore.com/mazda...ed3-p-194.html
Back when I first got my 'Speed theirs were the shiz. I dreamed of a set of their springs with these bars.
2008 Cosmic Blue Mica
pixelNate is offline   Reply With Quote
 Old 02-03-2013, 09:26 PM   #75
WAHBAM's Avatar
Posts: 283   (View Stats)
WAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the world
Groaned at 21 Times in 9 Posts
Do you guys recommend sway bars before coilovers?
2010 Black Mica Mazdaspeed3
MODS in chronological order of installtion
AEM CAI, JBR SSP Stage 2, JBR Heavy Shift Knob, JBR 80 Duro Billet Rear Motor Mount, CP-E NVISCID Turbo Inlet Pipe. & COBB AP
Debating on Rear Sway Bars, Springs, or internals next...
WAHBAM is offline   Reply With Quote
 Old 02-03-2013, 09:42 PM   #76
Design's Avatar
Posts: 1,887   (View Stats)
Groaned at 9 Times in 5 Posts
Most agree the OEM dampers are the weakest link. If your endgame is to do coilovers, I and most others would recommend those first.
09 CWP MS3 GT
Ownership & Build Thread
The Following User Says Thank You to Design For This Useful Post:
WAHBAM (02-03-2013)
 Old 03-11-2013, 08:43 AM   #77
joey's Avatar
Posts: 63   (View Stats)
joey is a name known to alljoey is a name known to alljoey is a name known to alljoey is a name known to alljoey is a name known to alljoey is a name known to all
Hi guys.. I might get fried for this, but I tried searching for this. Maybe one of you could direct me. I recently sold my gen1 and got a 2013 genpu. Now my gen1 had coilovers. Is there a way of installing them into the pu? All I see different is the rear shocks upper mounting. Thx in advance
Versatune :: FMIC :: 3" SRI :: 3" TIP :: HKS SSQv4 :: 3" Turboback :: Devil's Own WMI Stg2 kit :: Autotech HPFP :: JBR EGR delete :: JBR BSD & Baffle plate :: Racing Logic coilovers :: TRZ TMM :: AWR PMM :: Poly bushes all round :: SURE RMM :: SURE Shortcut&Counter weight :: SURE g/knob :: PG PCV fix :: Aeroforce dual Interceptor gauges :: Apexi TT :: HDI Stg2 Evo boost controller :: VIBE ICE
joey is offline   Reply With Quote
 Old 03-11-2013, 10:01 AM   #78
Nliiitend1's Avatar
Actually, the upper mount is the same.
It's the lower mount that is slightly different.
From what I can remember, you just need a longer bolt than the Gen 2 uses for the bottom of the shock. Some guys have used the the OEM bolt that is used on the camber arms on that bottom mount with good results.
2008 MS3 GT
2016 MX-5 Club
 Old 03-13-2013, 03:25 AM   #79
joey's Avatar
Damn! It would be so awesome if I could use my gen1 coilies on the genpu. Why does the online shops sell the coilies for the 2007-2009 and then 2010-2013? Do you think its an sales angle? Thx for the reply
 Old 04-17-2013, 01:27 AM   #80
msantana101's Avatar
Posts: 1,517   (View Stats)
Please forgive me if I missed it in this thread, but are the H&R springs interchangeable between gen 1 and 2? I have searched a bit on google and could not find a definitive answer to this question. Thanks.
FreekTuned
Will915 (06-22-2013)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f12/official-mazdaspeed-3-suspension-thread-106600/
Whiteline RSB thickness advice This thread Refback 11-16-2014 12:49 AM
Installed JBR Rear Sway! - DFW Mazdas This thread Refback 10-08-2014 11:18 PM
Support Thread For Idiots That Nearly Have To Sell Their Nsx To Fund A Cocaine Habit - Page 577 - Almost Anything Goes - SkatePerception This thread Refback 11-02-2013 05:20 PM
The Official MS3 Suspension Thread - Mazdaspeed Forums This thread Refback 09-06-2013 03:41 AM
CORKSPORT Mazda3/MPS 3 Rear Adjustable Swaybar - Page 2 This thread Pingback 07-26-2012 12:25 AM
Caldwell's 08' MS3 - Page 11 - TriStateTuners.com :: Home of Tristate Auto Enthusiast This thread Refback 04-25-2012 06:08 PM
The Official MS6 Suspension Thread RhoadBlock MazdaSpeed 3/6 - Suspension & Brakes 182 07-24-2018 11:38 AM
Official: Mercedes-Benz offers new Ride Control suspension on SLS AMG Haltech Automotive News 1 04-13-2012 09:28 PM
Another.. is my suspension shot thread amc5 MazdaSpeed 3/6 - Suspension & Brakes 14 01-20-2012 08:16 AM
Another suspension noise/sound thread-Strut Bearing? Raider MazdaSpeed 3/6 - Suspension & Brakes 8 12-07-2011 09:57 PM
Page generated in 0.58988 seconds with 40 queries
