Like Tree104Likes
 Old 02-02-2017, 12:05 PM   #41
Djohns's Avatar
Posts: 3,944   (View Stats)
Originally Posted by MunkieJunkie View Post
Yeah I don't have an account there, you could pop on over and see if there's any interest.
Done.
sarm1084 likes this.
2010 black mica speed3
Soon:built motor
MunkieJunkie (02-02-2017)
 Old 02-02-2017, 12:23 PM   #42
[R]usty's Avatar
Posts: 2,204   (View Stats)
So what exactly would they fabricate? Brackets and brake lines?
2010 Mazdaspeed3 w/tech
 Old 02-02-2017, 12:32 PM   #43
MunkieJunkie's Avatar
Posts: 51   (View Stats)
MunkieJunkie has much to be proud ofMunkieJunkie has much to be proud ofMunkieJunkie has much to be proud ofMunkieJunkie has much to be proud ofMunkieJunkie has much to be proud ofMunkieJunkie has much to be proud ofMunkieJunkie has much to be proud ofMunkieJunkie has much to be proud ofMunkieJunkie has much to be proud of
All they fabricate is a mounting kit, the rest is up to the consumer.
MunkieJunkie is offline   Reply With Quote
 Old 02-02-2017, 12:37 PM   #44
MoMS3's Avatar
Posts: 235   (View Stats)
MoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond repute
I want to say that we really should focus on RS brake adaptation vs CTS-V (Granted I'll take what I can get haha). The 6 piston CTS-V sit on a 14" rotor (370z track pack rotors), but those calipers are $380 apiece vs $150ish for the 4 piston per caliper.
RS brakes on the other hand use a 13.75" rotor and have a newer design monoblock caliper. The one thing I'm concerned about if we go above 13" rotor size is the wheel diameter due to the fact the RS brakes on an ST require RS equivalent wheels aka 19".
Basically, if we want this to happen, sounds like for now we're limited to 4 piston cts-v setup, since we need it to work for the 17" wheel crowd if we are wanting to convice ctsvbrakeswap guys to take the mazdaspeed/FoST plunge.
2012 Velocity Red Mica MS3 Tech
For Powah: JBR Tru 3.5" WP, CP-E TMIC, UR V3 Catless DP/Reso. TP, CS Resonated CBE, CS HPFP Internals, Cobb AP, DM PMM, DM TMM, CS Stg 2 RMM, CS Shifter Bushings, CS Dual VTA BPV, South Bend Stage 3 Endurance clutch, Damond Motorsports SSP, CS 3.5bar MAP, Stratified S-OTS+ Stg 3 E85 tune for summer, Pump S-OTS+ Stage 3 for winter, for now
Handling: JBR .250 RSB w/ billet brackets.
So I can see/be seen better: DDM LED for Nagare Accent lights, DDM Switchbacks Front turn signals, Osram CBI's, ADVmonster LED Fogs
To-do List: BNR S4, maybe S5...bottom end build, probably should do brakes/suspension at some point. Shooting for a 450-500whp daily driver.
MoMS3 is offline   Reply With Quote
The Following User Says Thank You to MoMS3 For This Useful Post:
sarm1084 (11-09-2018)
 Old 02-02-2017, 12:57 PM   #45
I would imagine the 6 piston and 4 piston would mount up to the same bracket? Also, from what I'm seeing the RS calipers are carrying a pretty hefty price.
How I envisioned it is they fabricate the bracket/mounting hardware, and whoever buys decides whether they want the 4 or 6 piston. Then from there they can buy the rotors accordingly. That way if you're running stock wheels you can buy the 4 piston for your application, but the 6 piston is always available should you run a larger wheel.
Correct me if I'm wrong though, I could very possibly be looking at it the wrong way.
 Old 02-02-2017, 02:32 PM   #46
MoMS3's Avatar
I don't think they'd be able to use the same brackets given that the 4 piston setup specs a 12.75" rotor vs 6 piston on 14" rotor, to me it would seem the brackets would mount the 6 piston caliper further out from the hub to accommodate the .625" increase in radius of the rotor. Not to mention the mounting points for the 6 piston look completely different in their location
The Following 3 Users Say Thank You to MoMS3 For This Useful Post:
MunkieJunkie (02-02-2017), nindoja (02-02-2017), sarm1084 (11-09-2018)
 Old 02-02-2017, 03:40 PM   #47
Voltwings's Avatar
Posts: 3,713   (View Stats)
A 14" rotor will sit inside an 18" rim. It clears the barrell, the issue would be are we able to run a rim with enough offset to keep the spokes off the caliper. We dont really need an increase in rotor size. It would be nice, but the stock brakes can be tracked with relatively little fuss from a heat capacity standpoint.
Just whatever fixed caliper option we can get for better for wear is all this platform really needs.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
cnyms6 (02-02-2017), sarm1084 (11-09-2018)
 Old 02-02-2017, 04:17 PM   #48
Gotcha, I see it now. The 4 piston is definitely a solid looking caliper, and for 150 each is bonkers.
Excited to see where this goes.
The Following 2 Users Say Thank You to MunkieJunkie For This Useful Post:
 Old 02-02-2017, 06:26 PM   #49
Djohns's Avatar
https://mazdaspeeds.org/index.php?th...01/#post-33003 Linky to other thread.
Soon:built motor
 Old 02-02-2017, 08:32 PM   #50
ryguy 3's Avatar
Posts: 353   (View Stats)
Definately interested.
Sent from my SM-G920P using Tapatalk
 Old 02-02-2017, 09:52 PM   #51
ThOrZwAr's Avatar
Posts: 43   (View Stats)
UPDATE:
Here's what they replied to my email.
"Do you have a link to a thread on the forum we could take a look at? Or start a thread to gain interest? If there is enough interest we could start looking into making a Mazda kit."
I'll link them this thread, and I'm sure the more people that see this/the more interest we get the higher chance we have of getting a kit made.
I'd totally be down with a bbk that's decently priced... GROUP BUY!
 Old 02-04-2017, 11:12 PM   #52
cyber-ms3's Avatar
Posts: 197   (View Stats)
cyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond repute
Groaned at 6 Times in 2 Posts
I am interested
cyber-ms3 is offline   Reply With Quote
 Old 02-05-2017, 08:13 PM   #53
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
Fuck all that 'oem is good enough' talk, nothing wrong with more options with less weight up front. I'm glad they finally responded to someone with a MS3 after I got the cold shoulder from them in June. I'm also interested but still likely will pursue the smaller 4 pot Wilwoods from Fastbrakes to run a 15" wheel up front
 Old 02-05-2017, 08:40 PM   #54
Djohns's Avatar
I have a feeling I'd like the price point of these. To be honest if I can fit a 16" wheel for my winter set up I'd be happy and more than likely pursue these.
Soon:built motor
Nailedit187 (02-05-2017)
 Old 02-05-2017, 09:09 PM   #55
impossible's Avatar
Groans: 30
Maybe the gen1 V Brembos but the gen2 ones I doubt will clear a 16" with the brackets made for a 320mm rotor
 Old 02-05-2017, 09:12 PM   #56
Djohns's Avatar
I'm pretty sure the gen1 brembos would, which is the ones I'd be looking at. Plus those are cheaper.
Soon:built motor
 Old 02-05-2017, 10:36 PM   #57
Astrall's Avatar
Posts: 109   (View Stats)
Astrall is a splendid one to beholdAstrall is a splendid one to beholdAstrall is a splendid one to beholdAstrall is a splendid one to beholdAstrall is a splendid one to beholdAstrall is a splendid one to beholdAstrall is a splendid one to behold
100% Interested and would gladly buy a kit once it becomes available!
Astrall is offline   Reply With Quote
 Old 02-06-2017, 12:16 AM   #58
NiL
NiL's Avatar
Posts: 27   (View Stats)
NiL is just really niceNiL is just really niceNiL is just really niceNiL is just really nice
I would buy this if it came out. I watched the caliper flex video on youtube and cringed hard.
NiL is offline   Reply With Quote
 Old 02-06-2017, 09:11 AM   #59
nindoja's Avatar
Posts: 2,395   (View Stats)
For drag that might be fine, but I've seen nothing but fail from the Wilwoods on the track. I can't remember who @maisonvi; maybe?), but they were warping rotors at the track like nobody's business.
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
 Old 02-06-2017, 09:55 AM   #60
impossible's Avatar
Groans: 30
Awesome, and I doubt they had brake ducting to keep the rotors cooled. Evo guys never had a problem with them
 Old 02-21-2017, 02:24 PM   #61
MoMS3's Avatar
Any updates?
 Old 02-21-2017, 04:59 PM   #62
Mattyhawk1's Avatar
Posts: 739   (View Stats)
I'm attaching a spreadsheet of calipers and rotor dimensions I researched when I was looking at this exact thing years ago. Might be helpful.
Mattyhawk1 is offline   Reply With Quote
The Following 2 Users Say Thank You to Mattyhawk1 For This Useful Post:
sarm1084 (11-09-2018), vortk355 (09-15-2018)
 Old 03-01-2017, 10:57 AM   #63
No update, haven't heard back from them.
The Following User Says Thank You to MunkieJunkie For This Useful Post:
 Old 03-15-2017, 09:47 AM   #64
KingKhan's Avatar
Posts: 4   (View Stats)
KingKhan is an unknown quantity at this point
Would also be interested if they made a kit for the speed 6
KingKhan is offline   Reply With Quote
 Old 03-15-2017, 11:32 AM   #65
acidplant's Avatar
Posts: 60   (View Stats)
acidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant future
I to am interested If they add A Speed6 kit for this
acidplant is offline   Reply With Quote
 Old 03-17-2017, 05:29 AM   #66
Interested for an ms6 only if they can fit 16" wheels.
Edit: After some poking around on Centric's site and @Mattyhawk1;s spreadsheet, it looks like evo rotors are our best bet. Comparatively speaking the rotors are fairly similar to the sti rotors that are used in the subaru kits, the evo rotors are just 6mm smaller in diameter, 10mm shorter in height, and 2mm thicker. Now it's just a matter of making brackets.
 Old 03-17-2017, 10:29 AM   #67
knocturnal's Avatar
Posts: 266   (View Stats)
Interested
Mods:
Stratified Tuned Stage 2 OTS+
273whp/330wtq
SnailD Tuned on Meth
316whp/359wtq
412whp/373wtq
 Old 03-17-2017, 09:40 PM   #68
Majmun's Avatar
Posts: 14   (View Stats)
Majmun will become famous soon enough
Interested
Sent from my VS995 using Tapatalk
Majmun is offline   Reply With Quote
 Old 03-22-2017, 05:36 PM   #69
I got tired of waiting for them to not do this.
sarm1084 and ryguy 3 like this.
The Following 9 Users Say Thank You to Mazdazilla6 For This Useful Post:
Code Monkey (03-23-2017), connor_cwp (03-22-2017), KingKhan (03-23-2017), Mattyhawk1 (03-23-2017), MoMS3 (03-22-2017), monkey.bones.007 (03-22-2017), MunkieJunkie (05-05-2017), ryguy 3 (03-24-2017), [R]usty (03-24-2017)
 Old 03-22-2017, 06:00 PM   #70
MoMS3's Avatar
So you're going to design one for us MS3 losers riiiight??
 Old 03-22-2017, 06:06 PM   #71
It's too far out right now to say yes but I'm not saying no.
 Old 03-22-2017, 06:11 PM   #72
MoMS3's Avatar
So in other words...two weeks?
 Old 03-23-2017, 09:01 AM   #73
KingKhan's Avatar
This is awesome!!!!! Definitely let us know how it goes, and if you offer to make and sell these.
 Old 03-28-2017, 01:20 PM   #74
Didn't get a chance to test fit this past weekend due to rain. Should hopefully be test fitting thursday.
EwMPS, macdiesel and sarm1084 like this.
The Following 3 Users Say Thank You to Mazdazilla6 For This Useful Post:
cyber-ms3 (03-28-2017), PearlySpeed (03-28-2017), sarm1084 (11-09-2018)
 Old 03-30-2017, 10:57 AM   #75
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
Speaking of CTS v.... this is what i have found out for those that have the Brembo BBK for the MS6...
So i have finally found some alternative brake pads for the Brembo BBK for the MS6... They are the rear brake pads for the 2005 CTS-v.. But i have a question for the brake gods out there..
Will this pads work for a replacement pad for the MS6 front pads? Will the slants on either end hurt performance? I only drag race so no auto crossing or rallying.
What i am concerned about is that slants on both sides of the pads if it makes any difference..
Sorry for the upside down pics...
track weight 3220
street weight 3370
 Old 03-30-2017, 11:09 AM   #76
No it won't affect anything. Pad coverage only affects pad life and wear characteristics. Your braking force is determined by hydraulic pressure in the system (force), your piston size(s) (area), your rotor diameter (lever arm), and pad compound (friction coefficient). Nothing to worry about.
FYI that's a common pad shape, used by lots of cars so you have a lot of compound options.
The Following 4 Users Say Thank You to Mazdazilla6 For This Useful Post:
Code Monkey (03-30-2017), qtrmile beast (03-30-2017), sarm1084 (11-09-2018), Voltwings (03-30-2017)
 Old 03-30-2017, 06:26 PM   #77
Test fit #1 was a failure. The evo rotor won't work with this caliper. Going to look at other rotor options. From there I can work on bracket dimensions. The bracket is probably going to be a tad more complex than I originally thought.
impossible (05-04-2017), JSmith (03-31-2017), sarm1084 (11-09-2018), Voltwings (03-30-2017)
 Old 03-30-2017, 06:30 PM   #78
MoMS3's Avatar
Did you check into 2000 Mustang Cobra R rotors? I remember seeing those as a possibility IIRC
Here is a pic with dimensions from Centric
The Following 2 Users Say Thank You to MoMS3 For This Useful Post:
qtrmile beast (03-31-2017), sarm1084 (11-09-2018)
 Old 03-30-2017, 06:55 PM   #79
It's a bit on the thin side. Also, for my purposes I'm not trying to make diameter larger. But thanks for the suggestion. I'm thinking the 2005 sti rotor might possibly work.
 Old 03-31-2017, 04:31 PM   #80
I just bought these for my speed
Brakes Database MS3/MS6!
Post 96
track weight 3220
street weight 3370
The Following User Says Thank You to qtrmile beast For This Useful Post:
Miata v8 swap vs rx7 v8 swap blake0521 Miata - General Questions 13 01-21-2015 07:05 PM
GREEK MAZDA 3 MPS XYZ 6-POT BRAKE KIT SERVICE - NEW BRAKE PADS FERODO DS 2500 & NEW CASTROL REACT SRF RACING BRAKE FLUID dgiannitakis MazdaSpeed 3/6 - Suspension & Brakes 5 05-05-2014 01:30 PM
New big brake possibilities? We share front brake calipers with audis/vws breakfasteatre MazdaSpeed 3/6 - Suspension & Brakes 15 11-03-2012 09:18 PM
Hawk HPS brake pads & Goodridge brake lines in stock for the 07-11 MS3. Chris@Xtreme Mazdaspeed3/6 General Discussion 3 08-06-2011 08:56 PM
Hawk Pads, Racing Brake Lines, and ATE Brake Fluid! Race Roots Mazdaspeed3/6 General Discussion 11 09-25-2009 02:04 PM
Page generated in 0.60288 seconds with 39 queries
