> MazdaSpeed 6 - How-To's
Like Tree6Likes
 Old 04-18-2011, 08:23 PM   #1
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Thumbs up How To CPE Injector Seals + Studs + EGR Delete
Thanks again to Skates for helping me out this weekend. Before you start, you'll need to remove your throttle body, intake manifold, and fuel rail cover. Jimmer307 already did a great "how to" that covers all this here: How-To: Injector & Intake Manifold Removal. Remember to be careful with the hard fuel line when you pull the fuel rail off. In the "how to" link above, after you take out the two screws holding it in (green dots in that thread), carefully pull the hard line out to the right, just far enough so the fuel rail clears it.
I'm just going to go over how to do the injector seal upgrade, using studs + nuts to replace the stock torx bolts, and the egr block off (because I did this at the same time). If you're upgrading your seals, and you haven't already deleted the egr, this is a great time to do it. Just pull the battery and remove your tip/sri and you can get at the egr tube easily. I went w/ the SU EGR Block off plate StreetUnit EGR Block Off Plate: MAZDASPEED 6, MAZDASPEED 3, CX-7 and it worked great. I also removed the dumb tube altogether, and plugged the mani w/ a 1/2 NPT plug that Skates had kicking around (not sure of length, and not pictured, but I'd guess about 3/4" long or so. I went with the CPE upgraded injector seals (only ones I know of) found here:
CPE MZR 2.3 DISI SAFEseal&#8482 Injector Seals for Mazdaspeed 3 / 6 / CX-7 - Revolution Performance Motorsports!
I got the studs and nuts from Fastenal (you can get them elsewhere), but here are the ones I used, including the part numbers:
0349266 (Qty =5) M8x1.25 x 50 Metric Alloy Steel Stud 1 $3.15 =$15.75
90701 (Qty =8) M8-1.25 DIN 6923 Steel Class 8.8 Zinc Flange Nut 1 $0.1597 =$1.28
You only need 4 studs and 4 nuts, but I got an extra stud and twice as many nuts just in case.
So here are the CPE seals, the injector removal tool that comes with them (we needed it for one), and the SU EGR block off plate:
So here's a pic with some shit labeled and an overview in case you haven't seen this stuff before:
Closer shot of 2 of the 4 bolts and crows feet:
One injector didn't come out (also don't forget to unplug each injector from the wire harness from below the fuel rail):
So we used the tool that came w/ the CPE seals to tap it out. It works very well and got the injector out in less than a minute. EDIT: To use the CPE injector removal tool, you just slide the block end of it over the injector that is stuck in the block (you'll see how it fits), and then slap the metal cylinder up along the long bolt to the top a bunch of times and the force gently pulls the injector out. Don't rape the thing.. it doesn't take a ton of force... just start out like Adam Sandler "at a medium pace" and you should be fine.
Okay, as shown in the pic w/ the writing above, we're removing the 4 torx bolts, which hold the crows feet in, which hold your injectors in. YOU NEED TO KEEP THE WASHERS FROM THOSE 4 BOLTS TO RE-USE, AND YOU HAVE TO CUT THE TORX BOLTS TO GET THEM OFF. So, unscrew them, and here they are:
NOTE that the washers are cupped so you can't just buy them. They also don't slide off, but Anthony will happily fly himself out to your house (at his expense) to cut them off for you if you don't have tools:
You must also drill the washers out a tiny bit with a 5/16" bit. It barely removes anything, but you need to take a little off so they will fit over the studs.
Okay, so now the washers ready, and it's time to put the studs in. We used some Loctite Red on the studs, so they won't go anywhere:
Hand thread the studs in, and wipe down excess Loctite Red:
Now remove the ghetto seals from your injectors, and clean the injectors. I forgot to take a pic of this, but if you really need one, I think I have some injectors in my storage unit somewhere. It's a super small black washer that's probably all blown out. The CPE seals are HUGE in comparison. After removing stock washers and cleaning injectors, the CPE seals may not slide right on. 3 of the 4 of mine slide right on, but one was a little too snug. Do not force it or hammer it.. just apply heat for about 30 seconds or so:
After it was heated, the last one slide right on. Here's all 4 mounted & ready to go:
Don't forget to put the crows feet back on, and it takes a little fanagling to get the rail back on. Mine wasn't lining up right away on the studs, so we decided to take the injectors off the rail, and put them back in first. They slid right in. Make sure to lube up the blue rings before pushing the rail back on afterwards:
Also, make sure to put the black washers on top of the blue rubber rings (seen better in this pic):
After you (carefully, firmly, and evenly) push the fuel rail back on to the injectors (while keeping the hard fuel line just out of the way), make sure to put some oil on the blue rubber ring on the hard fuel line so that it slides in nicely. We also used some air tool lubricant on the nut side of the studs for proper torque.
Then plug everything back up, and you're done! Also, some people ask about that foam thingy under the intake mani. It is not necessary, although it may help quite down the racket. I ditched mine, as now you can see your injector bolts + studs you just put on from outside the car if you want to gawk at them, lol:
As for the EGR..... Here's a close up of my intake runners:
And here's the primary culprit:
Last time I had the mani off was before the ATR cel defeats were out, and I needed a sticker, so I couldn't do this at the time. Just remove that dumb tube, and re-use the two bolts and attach the SU plate to the top. Use some RTV Copper on the SU block off plate and here:
And use some on the 1/2 NPT bolt that you use to plug the mani. We used some anti-seize at first, and I had a leak. We put some RTV copper on, and we tightened the shit out of it. It is pretty much completely flush to where it attaches... a couple turns tighter that this:
That's all folks. If you do the EGR delete (and I hope you did), make sure to cut a map w/ the cel turned off. Just go to "edit" then "advanced parameters" then "toggles (base)" and UN-check P0401. I have no cel. Enjoy!
The Following 95 Users Say Thank You to dougefresh_ For This Useful Post:
-cj- (05-05-2011), 3mazdaspeed (04-27-2011), 801MS3 (05-16-2011), 802MS3 (04-19-2011), agentgordon27 (04-27-2013), AJ713 (04-21-2011), ak_spray (06-12-2012), Alpha (04-19-2011), amggilly305 (10-10-2012), anavrinIV (04-28-2014), Andrewbox (06-23-2013), Arnie1229 (02-27-2015), bertrand_CX_7 (04-19-2011), BlueStreak (04-19-2011), Boro (06-24-2012), Broxer (09-02-2011), Castillo817 (02-02-2016), Cataphract_40 (06-18-2011), Ckmazdaspeed3 (04-19-2011), cld12pk2go (04-19-2011), daztdMS6 (01-19-2012), dereeek (12-03-2011), djuosnteisn (04-19-2011), Docnox (06-12-2011), Domino81 (01-22-2012), doubleflusher (04-23-2011), efispeed (04-23-2011), EwMPS (06-19-2013), Fail_6 (12-07-2011), Fobio (04-24-2011), G Sp33dy (04-16-2012), ganque (07-19-2011), h.h.sk1nny (11-25-2011), H3R3TIC (03-30-2012), i8urgti (06-18-2011), impossible (01-09-2016), JacksonMS30 (04-25-2011), jack_hammer (05-31-2012), jracer (04-18-2011), Juyoung (07-06-2013), karl-hungus (04-18-2011), Kfunk (03-31-2013), kilo101 (10-26-2015), kpsoerensen (01-20-2012), LiEast (04-30-2011), LumberJack (10-19-2013), magicka (06-14-2011), mason (06-11-2011), Mast (11-24-2013), MATT DAMOND (04-20-2011), mazda.speed3 (04-19-2011), MD1032 (11-18-2015), Micha (10-14-2012), Miltron (04-04-2013), Mizzle (07-30-2011), Monotonous ONE (04-18-2011), ms3blackmica (11-25-2012), MS6FL (06-04-2011), ms6mil (04-04-2013), mtnrunner (04-19-2011), Muzzybud (05-09-2016), MZRSpeeder6 (04-09-2012), Night Wolf (04-19-2011), nlgiebel (08-03-2015), p057 (02-12-2012), PapaBruno (12-30-2016), Pointless (04-11-2013), QwkEVO (03-08-2012), Realgib3 (04-19-2011), rfinkle2 (04-23-2011), rigor (04-23-2011), rob ms6gt (05-11-2011), robry (01-02-2013), Sacrilicious (01-19-2012), Snyeed (04-22-2012), speed23 (04-19-2011), speedtoz (04-19-2011), Sterling (01-03-2014), superskaterxes (04-20-2011), thehead (03-29-2012), the_caruch (04-18-2011), Toddy22587 (04-19-2011), Tokay444 (11-02-2013), triplejumper18 (04-19-2011), turbo test (06-18-2011), turd burglar (04-18-2011), TWOptSL0W (07-27-2011), wankular (04-20-2011), wette460 (06-13-2011), wolly6973 (05-10-2011), xcoldricex (04-21-2011), XLT_66 (05-04-2011), xxdjfate76xx (04-18-2011), zpele (06-02-2011), [R]usty (09-24-2014)
 Old 04-18-2011, 08:26 PM   #2
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
yikes!!! nice work.
The Following User Says Thank You to karl-hungus For This Useful Post:
dougefresh_ (04-18-2011)
 Old 04-18-2011, 08:37 PM   #3
Originally Posted by pat failman View Post
yikes!!! nice work.
Thanks man! Skates did all the injector work and I just helped when I could. I thought this may help some folks out though. I've taken my fuel rail off (for other reasons, lol), but I definitely would've liked some pics to do this.
EDIT: I'm forgetting something minor here... we put air tool lubricant on something, and I can't remember what the hell it was. I asked skates to take a look through this for accuracy and to add/edit as he sees fit. Hopefully he'll get a chance tomorrow
 Old 04-19-2011, 02:59 AM   #4
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
Probably put the air tool lube on the nut side of the stud for proper torque. Nice write up. I'm so glad I pulled the EGR when I first got the car and put up with the code for two years. My intake runners and valves are nice and clean.
The Following 2 Users Say Thank You to jmhinkle For This Useful Post:
dougefresh_ (04-19-2011), superskaterxes (04-20-2011)
 Old 04-19-2011, 03:11 AM   #5
SilverDemon's Avatar
Posts: 3,034   (View Stats)
Originally Posted by dougefresh_ View Post
You must also drill the washers out a tiny bit with a 5/8" bit. It barely removes anything, but you need to take a little off so they will fit over the studs.
Nice wright up....but make a change to the drill size for the washers...it is 5/16" not 5/8"
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 6 Users Say Thank You to SilverDemon For This Useful Post:
Alpha (04-19-2011), djuosnteisn (04-19-2011), dougefresh_ (04-19-2011), impossible (01-09-2016), rfinkle2 (02-03-2014), superskaterxes (04-20-2011)
 Old 04-20-2011, 11:36 AM   #6
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
lol it wouldent take long for someone to realize why 5/8's wasent the right size. you wouldent even have a washer left if u drilled through it with that size haha
guh, seeing that pict with the face shield makes me regret ever having grinded metal without googles in the past.
2 hour ER visit with tiny vibrating knife to get metal shard out of your cornea FTL
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
dougefresh_ (04-20-2011)
 Old 04-20-2011, 11:56 AM   #7
Man, you're lucky your didn't lose eyesight in that eye. The vibrating knife in your eye sounds like a good motivator to wear goggles/shield. I actually took a vid of that if you need another reminder . Thanks again for the help bro
Other than me losing a clip Ant luckily had a spare of, this install was butta. I wonder where that blue clip went? lol Me wonders if it jumped into my intercooler and hitched a ride home, haha.
RYNORO1 likes this.
 Old 04-20-2011, 12:38 PM   #8
bbogue4's Avatar
Posts: 232   (View Stats)
bbogue4 has a reputation beyond reputebbogue4 has a reputation beyond reputebbogue4 has a reputation beyond reputebbogue4 has a reputation beyond reputebbogue4 has a reputation beyond reputebbogue4 has a reputation beyond reputebbogue4 has a reputation beyond reputebbogue4 has a reputation beyond reputebbogue4 has a reputation beyond reputebbogue4 has a reputation beyond reputebbogue4 has a reputation beyond repute
Does the car feel or drive different?
bbogue4 is offline   Reply With Quote
 Old 04-20-2011, 12:58 PM   #9
Nope. Just one of those pita + wallet mods that are a necessary evil . I can't tell you how psyched I am that both of those things are done though. Wait, yes I can... I'm very psyched!
The Following User Says Thank You to dougefresh_ For This Useful Post:
bbogue4 (04-20-2011)
 Old 04-20-2011, 10:51 PM   #10
Axle Breaker
jmhinkle's Avatar
Groans: 162
Real men pull them out with tweezers in the bathroom mirror. Been there done that. I still didn't learn to wear safety glasses until my job made it a requirement. Once I paid for my bionic eyes out of my own pocket I started wearing safety glasses regularly at home.
 Old 04-19-2011, 04:19 AM   #11
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
you bitch, you beat me to this diy. fuuuu
The Following 4 Users Say Thank You to dooderek For This Useful Post:
ak_spray (06-12-2012), djuosnteisn (04-19-2011), dougefresh_ (04-19-2011), impossible (01-09-2016)
 Old 04-19-2011, 08:43 AM   #12
Speedie6's Avatar
Posts: 1,838   (View Stats)
Thanks. I hadn't done mine yet. But, I intend to this weekend. It looks like a bitch though. I'm apprehensive. I bought new stock bolts from the dealer so that I could do that part first before even taking apart the car. So, when I get done, I'll have used stock bolts to give away. I also bought the gromets that jmhinkle I think it was that recommended.
The Following 2 Users Say Thank You to Speedie6 For This Useful Post:
dougefresh_ (04-19-2011), Grab21 (11-25-2011)
 Old 04-19-2011, 09:41 AM   #13
FIXED. Thanks bro! I think all rail bolts and the nuts on the studs are 16-19 ft-lbs. We torqued mine to 18. As sad is this sounds, it was my first time using a torque wrench, LOL!! I still don't have one... thus "the bolt snapper" haha. Also, my runners are extra dirty bc I haven't been running meth... D05 nozzle was too big and once I switched from water to meth it was causing some knock (like 1KR). However, there was meth in my OCC, so I just toggled that shit off last November, so it hasn't really seen meth yet. I could have tuned for it, but I had other issues at the time, so I just toggled it off. How's the fmic coming along?
FIXED & thanks! THANK YOU for creating these!!!
Slow ass . It never hurts to have more than one write up, and you may run into issues I didn't that others will as well. When I first did the fuel rail myself last year, I was looking at THREE how to intake mani removals at the same time, lol. They all helped. I kinda glazed over the fuel rail and didn't mention buying new grommets.
If you have the right tools, it's not bad at all, esp if you've at least taken the mani off before. If you're using stock bolts, all you have to do is take the rail + injectors out, clean them, ditch the stock washers, put the CPE seals on, and put it back together. If you haven't it's a great time to do the OCC as well (you can see my Matt Damond kit w/ the check valve in the pics... that was last year).
I also didn't mention bleeding off pressure... I went through 3 hpfp's last year, so I didn't even consider it a step, lol. There's several ways to do this.. we just undid the rail, and hard fuel line and bleed pressure from where the hard fuel line detaches, and put some rags under it. You could also just loosen the 19mm nut just below the hpfp, which is what I always did w/ the hpfp swaps, but it's harder to catch all the gas. Just make sure to put a large zip tie a couple inches below that nut so it doesn't slide away if you go that route. I was only holding 200 PSI at idle back then, so it wasn't much fuel. Quite a bit came out of rail this time... just have some rages under it.
SilverDemon (04-19-2011)
 Old 04-19-2011, 11:35 AM   #14
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Excellent write-up. This is my new reference from now on
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 04-20-2011, 11:37 PM   #15
MSP611's Avatar
Posts: 2,291   (View Stats)
Nice write up I'll be doin this when I get back from desert with turbo rebuild
In progress:
dougefresh_ (04-21-2011)
 Old 04-21-2011, 12:40 AM   #16
Axle Breaker
jmhinkle's Avatar
Groans: 162
Heading to our neighbood?
 Old 04-21-2011, 01:31 AM   #17
MSP611's Avatar
Whatcha mean?? I live in Germany for now if thts wat u mean
In progress:
 Old 04-21-2011, 02:03 AM   #18
Axle Breaker
jmhinkle's Avatar
Groans: 162
LOL. Your location said Utah and when someone speaks of the desert, they are usually referring to AZ or NM. Thought you were coming our way.
 Old 04-21-2011, 03:02 AM   #19
MSP611's Avatar
Nope I mean the real desert. And I wish I could come on by. I haven't changed my location cuz I've only had my phone here, no reg inet cuz I've been gone so much
In progress:
 Old 04-21-2011, 10:52 AM   #20
Exclamation YOU MAY FAIL INSPECTIONS WITH THE CEL DEFEATS
OK, I'm going to have a bit of a problem here and so may you. The GreatNY was asking me if the CEL defeats leave the ECU in the ready state or not:
Only reason i ask is because a common issue with "disabling" the egr thru aftermarket flash tuning is that at times it causes the monitor for that particular item to never reach ready state. Happened on a lot of stangs, divided and evos.
2oo1 and up vehicles are allowed to have one monitor not ready. And still pass legally. So if you have that one and one more not ready. Then u fail.
2ooo and below were allowed two monitors to not be ready state and still legally pass.
I'm working w/ Shane at Cobb for a beta AP manager, so I shot him an email, and got some shitty news:
Disabling DTCs through AccessPORT maps will set that particular code to the "not ready" state indefinitely. It is in this way that we prevent the CEL from coming up on your dash when it normally would due to mechanical changes to the vehicle.
You may want to check your local safety and emissions regulations to determine if any "not ready" codes are permitted while still passing the test. The reason I say this is that in Utah (where our headquarters were formerly located), you are allow to have one "not ready" DTC and still pass emissions.
My issue is I wanted to go w/ a catless DP, which is what DJ was planning on making. That and the egr delete will give me 2 'not ready' codes, and I'll fail . If I move to FL next year, then it won't matter (no inspections), but that's not set in stone. I'd rather swap the egr back on than a dp, but now I gotta think about. Fuuuhhhkkk
Not sure if everyone is aware that ^that is how the cel defeats work. I hope they can change it to keep them in the 'ready' state :/
The Following 4 Users Say Thank You to dougefresh_ For This Useful Post:
Broxer (09-02-2011), djuosnteisn (04-21-2011), jmhinkle (04-21-2011), LiEast (04-30-2011)
 Old 04-21-2011, 01:07 PM   #21
MSP611's Avatar
Good info^
In progress:
dougefresh_ (04-24-2011)
 Old 04-21-2011, 02:08 PM   #22
paulwalll's Avatar
Posts: 324   (View Stats)
paulwalll is the leader of the worldpaulwalll is the leader of the worldpaulwalll is the leader of the worldpaulwalll is the leader of the worldpaulwalll is the leader of the worldpaulwalll is the leader of the worldpaulwalll is the leader of the worldpaulwalll is the leader of the worldpaulwalll is the leader of the worldpaulwalll is the leader of the worldpaulwalll is the leader of the world
nice write up. what is the reason behind using studs instead of the stock bolts?
2008.5 cwp ms3-sold
2014 Black Mustang GT Premium w/track package
paulwalll is offline   Reply With Quote
The Following 2 Users Say Thank You to paulwalll For This Useful Post:
dougefresh_ (04-21-2011), Phoenix Speed3 (03-20-2015)
 Old 04-21-2011, 02:23 PM   #23
Captain
Fear lol.
I think it's more of a "why not" thing, instead of a "why".
Many of us have reused stock hardware, and only one person i can think of had them back out again.
www.permtuning.com
dougefresh_ (04-21-2011), LiEast (04-30-2011), Phoenix Speed3 (03-20-2015)
 Old 04-21-2011, 02:26 PM   #24
Two nuns and a pack mule
AtTheDriveIn's Avatar
Posts: 1,527   (View Stats)
Awesome write up, Doug. Looks like I might have to pay Anthony a visit sometime soon. It looks like an easy install, but I don't have the right tools unfortunately
AtTheDriveIn is offline   Reply With Quote
The Following User Says Thank You to AtTheDriveIn For This Useful Post:
 Old 04-21-2011, 05:46 PM   #25
Axle Breaker
jmhinkle's Avatar
Groans: 162
Doug, good info on the codes for people. Something to consider is that most of them can be defeated with hardware except the EGR. If you solder in a diode, you can eliminate the 2nd O2 code. Worked fine for me for a long time before getting an AP. The VTCS can all be wired out quite simply with a relay. The only true not ready you will and should have to deal with is the EGR.
The Following 5 Users Say Thank You to jmhinkle For This Useful Post:
djuosnteisn (04-21-2011), doubleflusher (04-23-2011), dougefresh_ (04-21-2011), Realgib3 (04-21-2011), superskaterxes (04-23-2011)
 Old 04-21-2011, 06:09 PM   #26
Thanks. I'm glad TheGreatNY asked me about it, or I wouldn't have known to dig deeper. He said you can do the egr, but it sounds like a nightmare:
The only way to essentially disable the egr is to reprogram the duty cycle a certain way and there is also another part to making it work as well. But it requires major time to do it. Because every car would need something programmed completely different.
^So yeah, looks like the egr del will be my 1 'not ready,' lol. I haven't removed the flappers yet so I don't have to worry about that just yet. Is soldering in the diode pretty easy? Sounds like it is... where does it go, exactly?
 Old 04-21-2011, 06:13 PM   #27
Captain
I wonder if a diode would affect wideband calibration. As i understand it... and it's purely theory imo still, but very plausible theory.... the narrow band rear o2 sensor is used to "calibrate" the primary wideband. If there's a diode in the rear o2 sensor... it may throw off what the ecu interprets from the wideband. Your 11.8 AFRs may very well be 11.3's... or somewhere around there.
This was news to me until a few weeks ago. And it's still not proven, just speculation, but very possible speculation lol.
Is that diode still in there joel? We should pull it out, put some miles on the car, and see if your wot AFRs and fuel trims adjust. Would be an interesting experiment, and who knows, maybe your running richer than you think right now..... which would me we can safely lean it out some more and get mo powa
www.permtuning.com
 Old 04-21-2011, 06:00 PM   #28
irishking03's Avatar
Posts: 2,136   (View Stats)
I was going to buy the seals but I dont think I would be able to do this myself. ANyone wanna help that in the PA/NJ area let me know.. LOL
2009 Metro Grey Numbers Fully Bolted.
Nator Pa Dyno Day: 311HP 328TQ Pump 93
Nator Pa Dyno Day: 310HP 329TQ Pump 93
End of Drive 9/24/2013
2012 Liquid Silver
Cobb AP
 Old 04-21-2011, 06:07 PM   #29
aviator79's Avatar
Posts: 3,934   (View Stats)
just have him put a HF cat on there and be done with it.
 Old 04-21-2011, 06:07 PM   #30
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
i use two anti foulers on my 2nd o2 and no cell..i have a catless atp downpipe
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
The Following User Says Thank You to jracer For This Useful Post:
 Old 04-21-2011, 06:20 PM   #31
Wouldn't anti-foulers possibly have the same effect as the 2nd 02 is seeing less as well?
EDIT: Here's a link for 'how to- anti-fouler 02" for the anti-fouler challenged like myself: http://forums.evolutionm.net/evo-how...ouler-how.html. I'm just gonna pop those in for inspection time, and then remove them and disable the CEL as to avoid any possible secondary 02 sensor calibration rigamarou.
djuosnteisn (04-25-2011)
 Old 04-23-2011, 03:00 PM   #32
Axle Breaker
jmhinkle's Avatar
Groans: 162
The anti fouler changes your cat efficiency code to a slow to react code. They are stupid and useless.
Dustin, no I don't have the diode anymore. Pulled it back when I got the AP a few years ago now. If I had to get emissions, I would probably put it back in to get down to one code though.
The Following User Says Thank You to jmhinkle For This Useful Post:
 Old 04-23-2011, 03:06 PM   #33
Must Have Teh 10's!
doug, you have the AP, why would u want to fuck around with any of this?
dougefresh_ (04-23-2011)
 Old 04-23-2011, 03:11 PM   #34
Axle Breaker
jmhinkle's Avatar
Groans: 162
Reading>you?
Did you not catch all the not ready code issues for emissions? LOL
 Old 04-23-2011, 03:31 PM   #35
Must Have Teh 10's!
lol what not ready codes? thats the point of the AP haha
 Old 04-23-2011, 09:46 PM   #36
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
the AP is the one setting them to not ready. when you deactivate a code it sets that sensor to not ready. to pass inspections in certain places you are only allowed to have one not ready. i don't think there is any way around this, even with the AP.
The Following User Says Thank You to bova For This Useful Post:
 Old 04-23-2011, 10:45 PM   #37
The Great NY's Avatar
Posts: 360   (View Stats)
The Great NY is the leader of the worldThe Great NY is the leader of the worldThe Great NY is the leader of the worldThe Great NY is the leader of the worldThe Great NY is the leader of the worldThe Great NY is the leader of the worldThe Great NY is the leader of the worldThe Great NY is the leader of the worldThe Great NY is the leader of the worldThe Great NY is the leader of the worldThe Great NY is the leader of the world
yea doing the egr delete with the AP the right way may not be possible. in order to delete the EGR fully without setting the monitor permanently to "not ready" requires manipulation of the duty cycle of the valve. you need to put it so low that removing the EGR wont trip the cel due low flow. but also shows as still functioning to the ecu.
i havent seen a table in ATR that can manipulate this to that point or that precise. but to be honest, its not something that you would get the first time either. as it will be different inputs for every vehicle. being as the egr functions at part throttle only, that leaves a lot of MAP area to manipulate.
i have personally only seen two or three type of software flashing methods that could do this. unless i missed something in my research.
the other way to disable it, well moreso trick it. would be logging only the EGR. that way you can get as much resolution as possible to what its doing and where. you would then need to make a circuit that can mimic that as closely as possible to most of the cruising range (the area where you do 90% of your part throttle driving). im in the middle of making my circuit for my car, but need to do some more logging.
its possible but just tedious. being as i hadnt made one since my mustang builds, im a bit rusty on what parts i needed, so im calculating from scratch.
i find it hard to believe that the rear O2 effects the calibration of the upstream. that just makes no sense being as they are two separate entities and only correlate to each other in term of cat efficiency by determining the difference between the AFR before the cat and after. and check to see if it within the buffer to not trip a code. if it anything it would be the other way around imo. having the Wideband influence the downstream. but even that doesnt seem much plausible. but again, we are dealing with mazdas here. so you never know. interested in finding out tho for sure.
The Great NY is offline   Reply With Quote
The Following User Says Thank You to The Great NY For This Useful Post:
 Old 07-05-2012, 12:06 PM   #38
jomc111's Avatar
Posts: 585   (View Stats)
jomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the world
Subbed for reference
2012 Cadillac CTS-V
2014 focus st
2010 Taurus sho- sold
2009 speed 3 gt cwp -was once a monster -sold
jomc111 is offline   Reply With Quote
 Old 07-05-2012, 12:09 PM   #39
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
instead of bumping an old thread for your "reference", you can go to the top of the page, where it says "thread tools". under there, you can select "subscribe to this thread".
it's fun to do bad things
The Following 2 Users Say Thank You to jack_hammer For This Useful Post:
ak_spray (07-05-2012), Don06speed6 (07-05-2012)
 Old 04-23-2011, 08:33 PM   #40
2zz mr-s
dooderek's Avatar
Groans: 239
ill take pics of the stock injector seals when i get back, its a real "lol"
The Following 2 Users Say Thank You to dooderek For This Useful Post:
djuosnteisn (04-25-2011), dougefresh_ (04-23-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f111/how-cpe-injector-seals-studs-egr-delete-78250/
EGR ventil pomoc! Zablokujte - Mazda 6 Mazda 6 fórum: Fórum / Fórum Mazda Atenza This thread Refback 08-26-2013 01:35 AM
Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum - How to: Top mount turbo set up!! This thread Refback 11-18-2012 07:54 AM
EGR valve help! Block off - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 03-18-2012 04:51 PM
How To TOP MOUNT TURBO SET UP! Easy, Breezy, Beautiful MS6 only because Race Car | SpeedForums.org This thread Refback 12-06-2011 12:14 PM
HOW TO: Top Mount Turbo Set Up This thread Refback 07-07-2011 07:02 PM
How to: Top mount turbo set up!! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 06-14-2011 03:09 PM
Club de Usuarios de Mazda • Ver Tema - Sabeis Bloquear EGR en MPS? This thread Refback 05-09-2011 11:28 PM
CP-e Injector Seals ak_spray Revolution Performance Motorsports 11 01-25-2012 10:20 PM
Injector seals essejkcamraw MazdaSpeed 3/6 - Turbo Induction 703 05-17-2011 09:12 PM
Injector seals... how do you know you need them? MS3 Ventura MazdaSpeed 3 - Engine, Transmission & Driveline 2 03-09-2011 01:29 PM
Page generated in 0.77451 seconds with 39 queries
