![]() Join Date: Jan 2011 Location: Vancouver BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 130
(Thread Starter) | Not Ranked : 0 score After installing the TS BOV, CS TIP and various other tubes, I just want to make sure my DH reporting a range of -18 to -25 psi is normal. TIA.
__________________ 2006 Moist Metallica Silver Speed6 GT #6557 @ 267,000km Leakdown results was 50% or more across all four. slow rebuild in progress Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses. Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB. SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate. Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs. To order: Fullrace Exhaust Mani. FMIC. Damond side mounts. New built motor. Still thinking about Flowmasters |
| Not Ranked : 0 score FYI -18 to -25 isn't psi. Vacuum is in in/hg on the DH. How many in Hg in 1 psi you ask? The answer is 2.0360206576. You are reading -8.84psi to -12.28psi which is normal I guess, not knowing your altitude. I pretty much run the same range. Pay attention to your long term fuel trims. They should be <5% across the closed loop RPM range. You can monitor those with the DH.
| The Following User Says Thank You to dale_gribble For This Useful Post: | Marcus (03-19-2014) |
__________________ 2006 Moist Metallica Silver Speed6 GT #6557 @ 267,000km Leakdown results was 50% or more across all four. slow rebuild in progress Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses. Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB. SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate. Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs. To order: Fullrace Exhaust Mani. FMIC. Damond side mounts. New built motor. Still thinking about Flowmasters | |
(Thread Starter) | Not Ranked : 0 score They're hovering around 7-8%.
| Not Ranked : 0 score Ya that's OK. Well within the range of the ecm being able to manage.
![]() Join Date: Nov 2010 Location: Long Island, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 581
Groans: 31
| Not Ranked : 0 score Stock in psi is -10.6ish idle, -8.8/9 with a/c condenser on. In NY, about sea level+80ft |
| The Following User Says Thank You to kby For This Useful Post: | Marcus (03-20-2014) |
(Thread Starter) | Not Ranked : 0 score Thanks as I'm also coastal and about 120 above sea level.
![]() Join Date: Feb 2014
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score I usually run around 16 in.Hg at idle. I'm a little more than a mile above sea level normally. |
| Official: Pics Aplenty: 2013 Range Rover in Morocco (with 1971 Range Rover) | Haltech | Automotive News | 0 | 11-07-2012 06:10 PM |
| Spy Shots: Next Range Rover Sport shot at close range | Haltech | Automotive News | 0 | 07-16-2012 02:20 PM |
| Classic Mashup: 2011 Range Rover vs. 1993 Range Rover | Haltech | Automotive News | 0 | 12-30-2010 07:20 AM |
| Normal vacuum at idle? | Thestaplegunkid | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 4 | 01-05-2010 08:51 AM |
| whats normal ms3 power on a mustang dyno? | Wenis Prinkle | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 10 | 08-13-2009 09:28 PM |
