 Old 11-08-2009, 04:57 PM   #1
11cruzito11's Avatar
Posts: 824   (View Stats)
11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world
Groaned at 5 Times in 2 Posts
Default Which Upgraded Turbo to Choose?
Hello all -
Wanted people's recommendation on what Big Turbo to choose from. Currently, my bottom block is at a Machine Shop and will have 9.5:1 Compression Wiseco Pistons and Pauter Rods.
I will run fully-bolted + Meth + EWG along with a Big Turbo.
Which Turbo do you all recommend?
Thanks,
Cobb AP, 504whp 492wtq
11cruzito11 is offline   Reply With Quote
 Old 11-08-2009, 05:05 PM   #2
D-Rick21's Avatar
Posts: 257   (View Stats)
D-Rick21 has a reputation beyond reputeD-Rick21 has a reputation beyond reputeD-Rick21 has a reputation beyond reputeD-Rick21 has a reputation beyond reputeD-Rick21 has a reputation beyond reputeD-Rick21 has a reputation beyond reputeD-Rick21 has a reputation beyond reputeD-Rick21 has a reputation beyond reputeD-Rick21 has a reputation beyond reputeD-Rick21 has a reputation beyond reputeD-Rick21 has a reputation beyond repute
speed3 or speed6? is it going to be a daily driver? what do you realisticly want for power? Can you deal with more lag or would you rather have a quiick spool over peak power?
cp-e Cold Air Intake
cp-e Rear Motor Mount
Turbosmart bypass valve
SU shifter bushings
D-Rick21 is offline   Reply With Quote
 Old 11-08-2009, 05:16 PM   #3
I have a speed3....my car is not a daily driver, i only use it every now and then.
I want to have at least 350whp.
Im looking for a big turbo, not the PG reworked one or the PTP SST.
 Old 11-08-2009, 05:18 PM   #4
silversurfer3's Avatar
Posts: 618   (View Stats)
silversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond repute
Groaned at 26 Times in 11 Posts
I have a gt35r for sale
Rota wheel whore #1
MOdS list
shaved with a razor moldings (EDGE cream)~de-BaGEd FTW~
painted StoCk wheels secret color ~ rattl;e caned RooF~ jdm painted brake conversion~ clear tint ~ light weight black hood and trunk with wing option ~ japanese amber side markers/ running lights ~ tw0 light weight car seats ~ shifter weight reduction ~ stock recaros with red stitching ~ mp3 mazda stereo
for sale: ms3 transmission second gear is worn out. Perfect if you want to Upgrade it or if you don't want to have any down time if you're trans is messed up!
PM me with offers
silversurfer3 is offline   Reply With Quote
 Old 11-08-2009, 05:21 PM   #5
danesti's Avatar
Posts: 4,186   (View Stats)
Groans: 137
2008 STi
Intake
Turboback
AP
 Old 11-08-2009, 05:51 PM   #6
D-Rick21's Avatar
there's a few options, starting from smaller to larger.
ATP GT3071R Bolt-On Garrett Turbo Upgrade MAZDASPEED3
ATP GT3076R Bolt-On Garrett Turbo Upgrade MAZDASPEED 3
ATP GT3582R Bolt-On Garrett Turbo Upgrade: MAZDASPEED3
you could also go with a gt28 that would come on a little faster then all of these but has less potential for power then the others, but would have a better powerband then the stock k04 and still more power. I don't think the speeds have a huge turbo aftermarket yet so there isn't a ton of choices.
SU shifter bushings
 Old 11-08-2009, 05:59 PM   #7
MS6_Auburn_Fan's Avatar
Posts: 481   (View Stats)
Or chose something that uses a T3/T4 exhaust housing and your choices will be infinite. The ATP exhausts housing don't flow for crap and a porting is recommended. A T3/T4 housing is by design a better flowing part. This may require a custom exhaust manifold and downpipe but there are some T3 flange'd exhaust manifolds out there you just have to look for them.
MS6_Auburn_Fan is offline   Reply With Quote
 Old 11-08-2009, 06:01 PM   #8
Is this a gt3582r? How much you asking for?
Originally Posted by danems6 View Post
3076
Does anyone know someone that sells a used gt3076r?
Last edited by 11cruzito11; 11-08-2009 at 06:08 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-08-2009, 06:22 PM   #9
danesti's Avatar
Groans: 137
In my very unprofessional opinion i would like to point out that the exhaust housings themselves are not that bad, just the wastegate opening could use some porting (the atp turbos are notorious for boost creep)
if your going to stay stock flange (much less effort), the atp turbos are about your only option.
if your willing to get some different flanges going, your options are much greater (like said above)
2008 STi
Intake
Turboback
AP
 Old 11-08-2009, 06:35 PM   #10
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
Give Race Roots a shout
2015 Mazda 6
The Following User Says NO Thank You to IshiKage For This Un-useful Post:
 Old 11-08-2009, 06:38 PM   #11
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
check this out Race Roots Manifold and Complete Turbosystem This is setup will give you the flexbility to go stock flange or not.
lol we were thinking the samething
Last edited by NJSPEED3; 11-08-2009 at 06:39 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to NJSPEED3 For This Useful Post:
IshiKage (11-08-2009)
 Old 11-08-2009, 07:08 PM   #12
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
I think the gt3067r or gt3582r are both great choices depending on your ultimate power goals...
STAY AWAY from any turbo designed to bolt to the OEM flange... The OEM flange is smaller than a T3 flange and will only limit the performance of your turbo...
The Following 3 Users Say Thank You to SSinstaller For This Useful Post:
11cruzito11 (11-08-2009), danesti (11-08-2009), NJSPEED3 (11-08-2009)
 Old 11-08-2009, 07:25 PM   #13
D-Rick21's Avatar
Be careful getting a used turbo, you are already using so much money building the engine so you don't want to waste more by taking a chance on a used one where it might have to be replaced or not preform as well as you may think. It's ultimately your choice, but yea the Race Roots system does look like a good setup so far.
SU shifter bushings
The Following User Says Thank You to D-Rick21 For This Useful Post:
 Old 11-08-2009, 09:32 PM   #14
danesti's Avatar
Groans: 137
i took a risk on a used turbo (off a blown motor). it ended up working out for me but yes i agree... be careful
2008 STi
Intake
Turboback
AP
 Old 11-08-2009, 09:56 PM   #15
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
GT3076 tuned at 18psi will get you in the ballpark 380 whp
The Following User Says Thank You to For This Useful Post:
IshiKage (11-09-2009)
 Old 11-17-2009, 09:05 AM   #16
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
What about the gt3071r? It sais it spools 500rpm quicker than gt3076 and is efficient to 22psi. I wonder if it will hold 20psi to redline.
 Old 11-17-2009, 11:51 AM   #17
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
welll, mine creeps to 24+, so i would say, yes, lol.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 11-17-2009, 11:57 AM   #18
Fagwagon's Avatar
Posts: 2,090   (View Stats)
Groans: 75
Do you have this up in the FS section?
 Old 11-21-2009, 07:57 AM   #19
cageyvet's Avatar
Posts: 715   (View Stats)
Borg Warner s256
 Old 11-21-2009, 07:19 PM   #20
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
gt55 for sure..
 Old 11-21-2009, 11:11 PM   #21
Miembro
nighthawk358's Avatar
Posts: 725   (View Stats)
nighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the world
Groans: 27
gt55 for sure..
is that a 20b?
2008.5 MS3 Metro Gray...slow
nighthawk358 is offline   Reply With Quote
 Old 11-22-2009, 12:29 AM   #22
madvillain's Avatar
Groans: 78
haha idk, but gt55's are like semi-truck turbos built for like 1200 horsepower
 Old 11-22-2009, 12:37 AM   #23
Buildabong's Avatar
Posts: 3,034   (View Stats)
Buildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the world
Groans: 213
Groaned at 274 Times in 187 Posts
are u fucking serious? atp? lawlzzzzzz
Atp super gay fuck going with the same gay mazdaspeed flangeronie
T3 precision sc62, or any t3 setup
Buildabong is offline   Reply With Quote
The Following User Says NO Thank You to Buildabong For This Un-useful Post:
Help me choose JohnMS3 MazdaSpeed 3/6 - Wheels & Tires 5 09-13-2009 12:39 PM
What to choose instead of a G8 ST? The Torrent GXP, of course Haltech Automotive News 0 01-16-2009 11:10 AM
Upgraded/reworked turbo questions red07 Mazdaspeed3/6 General Discussion 5 11-08-2008 12:08 PM
no upgraded stocker turbo dynos? digitaljedi MazdaSpeed 3/6 - Dyno Sheets/Discussions 8 09-08-2008 02:21 PM
Page generated in 0.45575 seconds with 34 queries
