| Police ![]() Join Date: Dec 2009 Location: Guadalajara MX
Rep Power: 3113 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,737
Groaned at 9 Times in 9 Posts
(Thread Starter) | Sup guys, I'm tempted to upgrade my stock K04. But as most of you know, the Mexican FAIL-ECU doesn't recognizes COBB AccessPort and COBB is "too busy" to help us... ![]() So, without a custom tune we only have Hypertech or Piasini as a solution. I have the Hypertech and it has worked great on my car... But... I've been checking lots of threads of turbo upgrade uptions such as PTP, ATP, BNR... that I'm tempted to get one of those... I don't want an extremely BIG turbo, but something that can go PNP without any other issue... (Maybe BNR Stage 1 or 2..) What options do you recommend? Will it work with my Hypertech tune? Should I use a manual boost controller? Thanks everyone in advance!
__________________ SOLD MS3 GT 2009 - Garret GTX3076R -CP-E 4' TIP // CP-E big MAF intake // Turbosmart compact BPV // Lamin-X yellow fog covers // Hella Xtreme yellow fog bulbs // Eonon 7" screen // Prosport Boost Gauge // Ventpod Single Gauge Pod // CPE TowPlate // MSD Dashhawk // COBB AccessPort // USDM ECU // CM Downpipe // Ingalls Torque Damper // Denso ITV24 // GV style front lip // TRZ rear motor mount // PG/Godspeed FMIC // Magnaflow CBE // COBB counter shiftweight // CPE PMM // CPE TMM // Autotech HPFP internals // PERM tune in progress // COBB EBCS // HPFPupgrade injector seals // Apex-i TT // PERM tune // Final numbers: 427 WHP - 471 WTQSOLD: BMW 325ci coupe Formula 1 package 2001 - Daily driven FTW! MS3 vs Focus ST vs Camaro LS1 ---> Click here TEH MEXICAN'T PERM! Current whip: 2013 BMW 135i ///M Sport - BMW Performance Exhaust System - BurgerTuning JB4 - Golf Tee Mod - COBB Charge Pipe - BMW Blackline taillights - BMW Performance CF rear spoiler - 8K LED Angel eyes |
![]() Join Date: Sep 2008 Location: Lynchburg, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,559
| Not Ranked : 0 score only one way to find out man, buy one and be the guinea pig! Then i will follow you if it works good, if you blow up, ill be safe. Its a win-win.
__________________ 09 MGM MS3 BNR S3 V2, Freek'd Corn Toon, Cobb AP V3, Cobb FMIC w/ JBR piping, JBR WP 3.5 silicone, Cobb EBCS, Turbo XS Catless DP and TP, CPE Nexus CBE, Autotechs, GFB Hybrid BPV, Damond Trilogy mounts (FTMFW), Bilstein B14 Coils, RX8 R3s |
| The Following User Says Thank You to Addikted To Boost For This Useful Post: | Dre (07-30-2010) |
![]() Join Date: May 2010 Location: St.Louis
Rep Power: 146 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 59
| Not Ranked : 0 score Wonderful question, anyone with viable info to be the guide for the masses?
__________________ thehatingnetwork.com |
| Not Ranked : 0 score The big question is regarding boost control. If you choose to use the stock solenoid and ECU with a non stock turbo and wastegate you can run into issues (too much or too little boost). Using an independent boost controller in this case my address the issue. |
| Not Ranked : 0 score How will smoking crack rocks affect this particular situation?
![]() Join Date: Jun 2008 Location: Edinburg, Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 669
Groans: 31
Groaned at 12 Times in 5 Posts
| Not Ranked : 0 score I got a US ECU that you can buy from me, that's if you want to go CP-e or Cobb tunes. Only thing is I haven't found the spare key for the ECU so you will have to reprogram your keys to the ECU.
2009 Rally Yellow Cobalt SS/TC K&N Intake, Badmab Catless Downpipe, ZZP FMIC Kit, Forge BPV, Mpx Exhaust, Dual Aeroforce Gauges, R1 Concept Drilled and Slotted Rotors, E85 Tune 310 WHP 330 WTQ 93 Octane 347 WHP 386 WTQ E85 | |
![]() Join Date: Nov 2008 Location: Irving, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,506
| Not Ranked : 0 score that's like living on borrowed time. don't do it.
__________________ 2008.5 Crystal White Pearl MS3 A lot of mods Check out my big turbo build! |
| So i did a custom tune... | R.MS3 | MazdaSpeed 3/6 - ECU Computer Tuning | 21 | 03-24-2011 04:54 PM |
| Custom AP tune Dyno runs | Snyeed | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 13 | 07-28-2010 04:48 PM |
| CUSTOM dyno tune at COBB HQ 3-12-09 | ljudgeii | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 66 | 10-09-2009 02:56 PM |
| Will be getting a custom tune soon!! DYNO DAY!! | johnac08 | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 18 | 02-21-2009 07:39 PM |
| Surgeline Custom Tune w/ ETS TMIC TXS TBE Cobb SRI | PDXImportRacer | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 25 | 11-16-2008 12:21 PM |
