![]() Join Date: Dec 2014 Location: San Diego
Rep Power: 0 ![]() Thanks: 3
Groaned at 4 Times in 1 Post
| The Following 4 Users Say NO Thank You to Just_Shep For This Un-useful Post: |
Rep Power: 3746 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| It's not a waste of money, but you can probably run the map. You should, however, take logs on a regular basis to ensure that your AFRs, load and boost are within spec.
| The Following User Says Thank You to Vansquish For This Useful Post: | Just_Shep (08-31-2015) |
![]() Join Date: Jan 2013 Location: Pocatello, ID
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
| Not Ranked : 0 score Definitely not a waste of money. The stock TIP is puny and restrictive. Check out the tuning section for how-to's on logging and tuning.
__________________ Power: Powered by Purple Drank, BNRS3, JBR 3.5, Grimspeed EBCS, 3-bar map, CP-e FMIC, Autotech HPFP, Forge V2 BPV, VTCS delete, DM OCC, Empire water pump pulley, BSD, JBR pan baffle, ebay downpipe, CP-e CBE, NGK step colder plugs, TIGs, CP-E Safe seals, DM EGR delete, etc. Handling: Eibach prokit, SPC camber arms, RX8 wheels, 235/40/18, Goodridge Stainless brake lines, EBC redstuff, mazda 5 rear brakes, Custom mid chasis brace, WR front strut brace, TB traction bar, TB trunk brace, JBR rear sway bar, Moog links, DM RMM, OEM poly filled PMM, CS TMM insert, JBR solid shifter bushings, AP shift hammer, Other: Android Stereo running torque pro, MZ style lip, Corksport LED lights, HIDs, lots of other random stuff |
![]() Join Date: Feb 2014 Location: TEXAS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,527
Groans: 64
| Not Ranked : 0 score Nice intro bruh. There is a thread here some where that discusses whether an after market TIH increases flow. With as common and reasonably priced as 3" intakes are now, I would suggest going that route instead. I was hesitant but finally grabbed my nuts and did it. I like it, and mine in all black errrthang looks clean and simple under the hood. As far as the map question, I agree try it out and log/monitor regularly as Vansquish suggested.
__________________ ~2013 BLACK MS3~ COBB: (APV3//Exhaust Hangers) CS: (TMIC//RP//Leather Knob//Battery Box//Interior LEDs) JBR: (3" SRI//80 Threesome//SSP//SSB//TB TIG//Coolant Bypass//Rice Flaps, EGR delete, OCC) Magnaflow CBE//GFB BOV//FREEKY DEEKY OTS+ 》》》SUPPORT YOUR MSF VENDORS《《《 |
(Thread Starter) | Not Ranked : 0 score Thanks, just wanted to get things squared away before I order the IC and the auto techs. I'm very familiar with logging so I'll be sure to check up with those.
__________________ 2008 ms3 20k miles MGM Cobb RMM // Cobb SRI // Damond OCC // Cobb AP // Autotechs // Cobb TIP // CNT TBE... on back order // pilot super sport tires // CXRacing fmic // forge v2 // |
| You should just get a 3.5in intake and you'll be done even if you go BT.
| The Following User Says Thank You to MS3Shadow For This Useful Post: | volcomcinematic (09-01-2015) |
| Is tunning needed with big turbo. | contreras | MazdaSpeed 3/6 - ECU Computer Tuning | 21 | 10-15-2012 12:27 AM |
| Tunning Noob question | apena85 | MazdaSpeed 3/6 - ECU Computer Tuning | 2 | 09-18-2012 03:03 AM |
| Best tunning for the money?? $$$ | mazdaspeed4life | MazdaSpeed 3/6 - ECU Computer Tuning | 5 | 03-12-2012 02:01 AM |
| Catless Downpipe Cobb AP tunning | YokiMazoku | MazdaSpeed 3/6 - ECU Computer Tuning | 4 | 09-21-2009 12:20 PM |
