![]() Join Date: Jun 2013 Location: Salt Lake City, UT
Rep Power: 0 ![]() Thanks: 2
Groaned at 8 Times in 4 Posts
![]() Join Date: Jul 2008 Location: Reston, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 86
| Not Ranked : 0 score I have an 09 MS3 and my turbo started smoking at 50k miles. As soon as it started I did research here on the forums. As a result of those searches, I bumped up my idle, added an OCC (which I should have done much sooner) and upgraded the banjo bolt. I haven't smoked since. I'm holding off as long as possible before having to replace the turbo. My hopes are that I caught it soon enough. I ran the Cobb OTS tunes for a while and just recently switched to a FreekTune. I highly recommend not bothering with any more OTS maps and work with Justin. He's running a sale right now and it's well worth the small price. Check out the vendor section for the sale info. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to nmmazdaspeed3 For This Useful Post: | jambisgone696 (04-11-2014) |
![]() Join Date: Sep 2012 Location: Phoenix, Arizona
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32
Groans: 89
Groaned at 9 Times in 9 Posts
| Not Ranked : 0 score Ots maps are......ok. but an etune is best for long term. I would stick with stage 1 ots until you have other supporting mods and then get an etune. Intake and occ would be the next things I suggest. Change to ngk or denso plugs. |
| The Following User Says Thank You to Big Dog For This Useful Post: | jambisgone696 (04-11-2014) |
