 Old 09-12-2011, 10:36 AM   #41
shadesofgray19's Avatar
Posts: 794   (View Stats)
Yes, not all K04's are the same. Ours is still shit. Audi's don't have the displacement that we do.
 Old 09-14-2011, 06:54 AM   #42
martin_nj's Avatar
Posts: 581   (View Stats)
martin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the world
Groaned at 9 Times in 5 Posts
hey all -
how about something like this?
GT3071R Bolt On Turbo Kit for Mazdaspeed3 (2007 thru 2010) : atpturbo.com
claims to bolt into the stock location with minimal mods ...
obvs that price can be lower if you buy from the right SoUrces
2009 Mazdaspeed3 SOLD!
Summit Point Main 1:32.725 (on all seasons)
Lime Rock Park 1:05.419 (R888)
Pittsburgh Int. 1:09.594 (R888)
NJMP Lightning 1:21.203 (R888)
2013 Ford Mustang GT
NJMP Lightning - 1:25.04 (stock car with 235/18 pirelli all seasons)
NJMP Lightning - 1:20.087 (modded car with 245 summers)
Pocono North - 1:06.xx (Dunlop SP600 245x18) wet
Pocono North - 1:00.655 (275mm Conti Slicks)
Lime Rock - 1:07.2 (Dunlop SP600 245x18)
1989 Honda CRX Si
VIR Full Course - slowww
Summit Point Main 1:35.230
Renault Spec Racer
Lime Rock Park 1:04
VIR Full Course 2:30
martin_nj is offline   Reply With Quote
 Old 09-14-2011, 10:14 AM   #43
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Umm... You new here?
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 09-14-2011, 12:48 PM   #44
martin_nj's Avatar
not really new just haven't been following the turbo sections...
what's the scoop on these?
1989 Honda CRX Si
Renault Spec Racer
Lime Rock Park 1:04
 Old 09-14-2011, 01:36 PM   #45
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
Lol
The Following User Says Thank You to dooderek For This Useful Post:
easy (09-14-2011)
 Old 09-14-2011, 01:58 PM   #46
martin_nj's Avatar
not helpful
phate's quote actually applies to me =P
1989 Honda CRX Si
Renault Spec Racer
Lime Rock Park 1:04
 Old 09-14-2011, 02:09 PM   #47
Tokay444's Avatar
Groans: 793
Just about everyone who's gone bt is using it or a 3076...
Demodded.
The Seals
 Old 09-14-2011, 02:24 PM   #48
martin_nj's Avatar
hahah yes that i know
since this is an OEM replacement i was asking more along the lines of its advertised "bolt on"ness
the BT guys are usually going top mount nowadays and the OP and I both want simple stock replacement. no rerouting water lines/oil lines etc
1989 Honda CRX Si
Renault Spec Racer
Lime Rock Park 1:04
 Old 09-14-2011, 02:35 PM   #49
They are bolt on in that they can bolt on to the stock exhaust mani and downpipe, that's it. You need to rework oil and coolant lines. You need a new tip. I don't think they will work with the TMIC.
 Old 09-14-2011, 02:37 PM   #50
martin_nj's Avatar
ah really? damn that sucks =\
i have the cobb silicone tip even that won't fit?
so my only real bolt on if i'm looking to minimize downtime and fabrication is the S3 from bnr?
1989 Honda CRX Si
Renault Spec Racer
Lime Rock Park 1:04
 Old 09-14-2011, 02:40 PM   #51
Tokay444's Avatar
Groans: 793
And I don't know anyone who is top mount turbo on an ms3.
If your tip fits the stock turbo, it won't fit a bt.
Demodded.
The Seals
Last edited by Tokay444; 09-14-2011 at 02:40 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-14-2011, 02:40 PM   #52
martin_nj's Avatar
tokay - are you kidding me? you a good troll =P
^^ this is re not knowing anyone top mounted
CALLIN ALL BIG TURBO MAZDAS
HOW TO: TOP MOUNT TURBO SET UP!!
http://www.mazdaspeedforum.org/forum/foru...-pt-4-a-85857/
re: TIP i see... i guess when i read the ATP's description i assumed it would be a stock bolt on...
obvs having bigger inlet, and better headers and bigger exhaust would help things make more power but yah....
1989 Honda CRX Si
Renault Spec Racer
Lime Rock Park 1:04
The Following User Says NO Thank You to martin_nj For This Un-useful Post:
Tokay444 (09-14-2011)
 Old 09-14-2011, 03:05 PM   #53
Ziggo's Avatar
Posts: 3,843   (View Stats)
Those are all MS6s. If there was a topmount twinscroll manifold available for the MS3 I would have been all over it.
Zigatapatalka
Ask Me About My:
 Old 09-14-2011, 03:08 PM   #54
martin_nj's Avatar
zigg i read your BNR thread - if you had to do it again would you have done anything differently? besides the twin scroll top mount you just mentioned hehe
1989 Honda CRX Si
Renault Spec Racer
Lime Rock Park 1:04
 Old 09-14-2011, 03:24 PM   #55
Ziggo's Avatar
Nah, it's exactly what I thought it would be. I needed a replacement for my dying k04 and figured I would get a bit of a performance bump at the same time to what I felt was within the stock bottom end's ability to withstand reliably. I wasn't expecting it to exceed the stock clutch's limits, but there isn't much data on big turbo speeds in road racing type environments and didn't think I would be so knock limited, but those things would have happened with a larger turbo as well.
I will probably upgrade again to something 3071/3076ish when there is a twin scroll setup available so I can push the boost a bit more on the top end without losing transient response. The BNR can handle 22psi to redline comfortably, but in order to carry a 2.1/2.3 load to redline in the Texas heat it seems like I will need more like 26psi up top, which I wasn't expecting.
TL;DR notes:
K04 was dying/dead
Needed replacement ASAP
BNR performs great as a stock replacement with probably 30-50hp capability bump
Will be upgrading again when bolt on twin scroll setup is available due to stupid I texas temperatures.
Zigatapatalka
Ask Me About My:
 Old 09-14-2011, 03:30 PM   #56
Ziggo's Avatar
I guess I should add:
K04 @ 290g/s in 80* ambient- shaft play
BNR @ 320g/s in 95* ambient - still working like a champ
So it's not just a power bump, it's a reliability bump as well.
Zigatapatalka
Ask Me About My:
 Old 09-14-2011, 04:09 PM   #57
Tokay444's Avatar
Groans: 793
You suck.
Demodded.
The Seals
 Old 09-15-2011, 07:35 AM   #58
martin_nj's Avatar
that sucks you'll have to upgrade twice =\
sans the texas heat what is the max you think the S3 can support? 400 wheel?
1989 Honda CRX Si
Renault Spec Racer
Lime Rock Park 1:04
 Old 09-15-2011, 07:58 AM   #59
Ziggo's Avatar
Like I said, needed something right away cause I didn't feel like staying off the track for a year till something I really wanted was available.
You might be able to squeeze 400wheel by reall stressing the turbo, using meth, and possibly E85 to let you run assloads of timing, but I don't think that would be smart for someone who tracks the car cause you are going to hurt the reliability. I wouldn't expect more than 350 out of it reliably without getting crazy.
Ask Me About My:
 Old 09-15-2011, 06:42 PM   #60
dixie789456's Avatar
Posts: 635   (View Stats)
dixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the world
Groaned at 25 Times in 15 Posts
See the post RIGHT above yours for your answer.
so then the problem is with earlier turbos.... not the design of the engine.
dixie789456 is offline   Reply With Quote
 Old 09-16-2011, 03:57 AM   #61
Tokay444's Avatar
Groans: 793
No. The problem is with the size of the oil restriction hole, or lack there of, combined with where the oil return dumps back into the block.
The new turbos have a revised restriction. Somethin that was easily remedied on the earlier ones as well. WITHOUT turbo replacement. Some engines also required more vacuum so that that the return line would actully return, and not choke up. Hence the new valve cover vent kit. Not a new turbo.
Demodded.
The Seals
 Old 09-17-2011, 01:51 AM   #62
MSP611's Avatar
Posts: 2,291   (View Stats)
where is this valve cover vent kit u speak of? i have read much about it but have not seen many kits out there
In progress:
 Old 09-17-2011, 06:07 AM   #63
Tokay444's Avatar
Groans: 793
It's a tsb.
New valve cover. New tip, and some misc. parts.
Demodded.
The Seals
 Old 09-17-2011, 09:14 AM   #64
MSP611's Avatar
ahhhh lame... i jst do ye olde breather on the valve cover and a venturi set up on my OCC
In progress:
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/stock-turbo-replacement-upgrade-90844/
Design's Long Term Ownership/Build Thread This thread Refback 06-27-2015 05:41 PM
Turbo seals? : mazdaspeed6 This thread Refback 02-24-2015 05:36 PM
PTP super stock turbo upgrade. Anyone have/had one? Nataphen MazdaSpeed 3/6 - Turbo Induction 77 08-04-2010 08:05 AM
PTP super stock turbo upgrade. Any experiences? Nataphen 2010 MS3 - Turbo Induction 2 05-01-2010 10:37 AM
Stock Turbo & Medieval Manifold Upgrade ian101 MazdaSpeed 3/6 - Turbo Induction 14 06-10-2009 07:16 PM
Billet compressor wheel upgrade for the stock turbo!!!! ptperformance Mazdaspeed3/6 General Discussion 52 05-13-2009 05:20 PM
Stock turbo upgrade mdogg MazdaSpeed 3/6 - Turbo Induction 20 03-31-2008 02:14 PM
Page generated in 0.42048 seconds with 26 queries
