![]() Join Date: Jul 2010 Location: CT
__________________ 2006 Mazdaspeed 6 | MS CAI | DP | TP | AP |
![]() Join Date: May 2011 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28
| Not Ranked : 0 score Since you have AP, do some logs at WOT. You will be able to see if it's holding boost or not. If you hear a whoosh go off before you lift, it probably is the stock bpv however.
__________________ 09 MGM Sport AP (MIA ) / Internals / TMIC / CAI / TIH / Downpipe / CBE / Short shifter / RMM / RSB |
Some stock bpvs leak, others don't. If you can do a boost leak test, you will be able to get an idea what the noise is / coming from a little better. | |
| The Following 4 Users Say Thank You to rfinkle2 For This Useful Post: |
![]() Join Date: Feb 2011 Location: Cleveland TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,751
Groans: 90
| Not Ranked : 0 score My stocker has been able to hold 20psi without an issue. A high pitched noise could be a boost leak, not necessarily from the BPV. The only issue I've had with my stock unit is that it opens during partial throttle during slow acceleration.
__________________ 2012 Triumph Street Triple SOLD -- 2010 Velocity Mica Red MS3 ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM |
![]() Join Date: Mar 2011 Location: Tulsa, OK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 36
| Not Ranked : 0 score I'm using the stocker right now, no issues for me and reaching 15psi yesterday. Edit: not pushing
__________________ 09 Black Mica MazdaSpeed 3 Mods: SURE Aeros, SURE Return, SURE Countershift, SURE Anchors, TRZ Dogbone RMM, E4 Perfomance STS, PG Test Pipe, H&R Sport Springs Appearance: Xentec HID Kit 35W 8K, Independant Fogs, 15% Tint, Blacked out LED Side Markers, LED License plate lights, Blacked out emblems, Smoked Taillights, Blacked out third brake light Last edited by ZsSpeed3; 08-09-2011 at 09:02 AM. |
| Blue 2 shims ![]() Join Date: Feb 2009 Location: Roswell, GA
Rep Power: 1476 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 954
Groans: 66
| Not Ranked : 0 score @ZsSpeed3 then you've got a problem because stock you should be at 15.4. @Broxer I'm spiking 21 and holding 19 on the stock bpv as well. @CTSpd6 everyone's is different like these guys are saying. Some hold, some don't, only your logs can tell you what your case is.
__________________ I used to drive a MazdaSPED 3. It was retarded fast. |
| The Following 3 Users Say Thank You to Nazarite For This Useful Post: |
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
![]() All in all, as others have mentioned, some stockers hold incredibly adequate while others take a face plant.. With that said, you need a monitoring device, go through all your piping and make sure everything is tight. While all the signs lead to a boost leak, that doesn't necessarily mean its a BPV leak. Good Luck
__________________ | |
| Not Ranked : 0 score I am using my DH to monitor and I haven't upgraded my turbo or anything. It was in the 15's almost 16, just didn't want to say something that made wasn't true. So.....wasn't "pushing" it, that's what it was holding till I let off the pedal.
__________________ 09 Black Mica MazdaSpeed 3 Mods: SURE Aeros, SURE Return, SURE Countershift, SURE Anchors, TRZ Dogbone RMM, E4 Perfomance STS, PG Test Pipe, H&R Sport Springs Appearance: Xentec HID Kit 35W 8K, Independant Fogs, 15% Tint, Blacked out LED Side Markers, LED License plate lights, Blacked out emblems, Smoked Taillights, Blacked out third brake light |
(Thread Starter) | Not Ranked : 0 score Thanks for the responses. I will do some logs after work.
Groans: 66
| Not Ranked : 0 score Hey man, we're just messing with you because you're talking about holding stock pressure while the guy right above you said he pushed it 5 psi more. Surely you see the irony. But hey, at least you're holding stock psi, some guys bpv's can't do that.
__________________ 2006 Mazdaspeed 6 | MS CAI | DP | TP | AP | |
If it sounds like someone is blowing through a blade of grass, or pinching a balloon opening and letting the air squeal out, it is probably a silicone coupler vibrating against a hard pipe. Boost leaks are almost impossible to diagnose from in the car while driving. | |
| The Following 3 Users Say Thank You to rfinkle2 For This Useful Post: |
| [MSF STIG] ![]() Join Date: Apr 2008 Location: Gloucester, VA
Rep Power: 2120 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,476
| Not Ranked : 0 score My OEM BPV worked perfectly at 21psi, but definitely began leaking at 23. If you look at the design, I believe that Mazda intended it to leak at higher (21psi+) boost levels....
__________________ `07 Speed6 Sport Tit Gray Sleeper Express... SOLD `11 Ducati 1198SP SBK Duc Red w/Termi exh; Redline flash-tune + PC-5; Sargent; Shift-tech, CDT, & EVR Carbon; 14F/39R gear w/FBF QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf, etc... a 182whp/105wtq The BIG DOG `12 Ducati 1100SP EVO Hyper Duc CORSE w/Termi exh; Redline flash-tune + PC-5; Ducshop Hyperstacks; 14F/41R gear w/FBF QC; Shift-tech, CDT, & BST(wheels) Carbon; R&G; ProGrip; Antigravity; Ducabike; Duc Perf, etc... a 95whp/75wtq The Hooligan `12 Aprilia RSV4 "Factory" SBK w/Akra Tit exh & race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL Pegs; Antigravity; Zero Gravity; AF1 Flat Carbon, etc... the 181whp/83wtq The Land Rocket `17 Ford Focus RS Nitrous Blue w/Cobb V3/AT; OZ Ultraleggera; Schroth harness The Super Fun Toy |
| The Following 5 Users Say Thank You to FORZDA 1 For This Useful Post: | BlueStreak (08-09-2011), helmetface (08-09-2011), mazdaspeed619sd (08-22-2011), redneckrecon (08-09-2011), rfinkle2 (08-09-2011) |
![]() Join Date: Sep 2008 Location: Toronto, Ontario, Canada
Rep Power: 2202 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,767
| Not Ranked : 0 score I am currently running 22.5PSI with no leaks. I have also successfully boost leak tested the BPV to values higher than that (remove return hose, plug TIP connection to return hose and pressurize system).
__________________ '07 CWP MS3 Forged. |
| The Following 3 Users Say Thank You to BlueStreak For This Useful Post: |
Groans: 219
@ZsSpeed3 - Ya I was only giving you flak because thats the ~pressure the stockers was meant to run at, give or take.
| The Following User Says Thank You to helmetface For This Useful Post: | rfinkle2 (08-09-2011) |
| Not Ranked : 0 score Whateva.... tampon has been removed. ha ha
![]() Join Date: Jun 2011 Location: royal palm beach, fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
| Not Ranked : 0 score if you have a DH boost/vac should be around -21.00.. i might be wrong.
__________________ 8.5 Mazdaspeed tres.- JBR SHIFT KNOB- JBR SHIFTER BUSHING- COBB SRI- SU ED TURBOSMART BPV- PROSPORT CF E-BRAKE- HYPERTECH- DASHHAWK- CP-E TMIC- CP-E RMM- CORKSPORTS RECIRC TUBE. on the list- SURE SSP- MUDFLAPS-CPE HPFP-COBB AP. |
| Not Ranked : 0 score My DH is messed up, missing a whole bunch of PID's. Won't let me do the Boost/Vac, just Boost PSI. Dumb thing, need a PC to update. all i have is a Mac.
![]() | | #19 | ![]() |
| Not Ranked : 0 score can you not update it? there is a download somewhere on this site for DH.
![]() | | #20 | ![]() |
| Not Ranked : 0 score You can tweak the stock BPV so it holds whatever you throw at it. Takes about 5 minutes and may not cost you anything. TRex posted my writeup here before I was a member, called something like "stock BPV leak? I may have a cost effective semi-solution". I've been running it for ~20k miles without a problem. |
![]() | | #21 | ![]() |
If leaking to atmosphere could it not be epoxied? Most aftermarket BPVs cause flutter - the HKS and pull type BPVs are well known for this. A little surge at LOW boost pressures is not bad - surge at high boost pressures starts to load the turbo shaft. | |
| The Following User Says Thank You to Lex For This Useful Post: | rfinkle2 (08-10-2011) |
![]() | | #22 | ![]() |
![]() Join Date: Mar 2011 Location: Trailerville, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 414
Groaned at 15 Times in 12 Posts
| Not Ranked : 0 score My stock valve was holding great at stock boost levels.
__________________ Cool sig coming soon. |
![]() | | #23 | ![]() |
| KR....i haz it ![]() Join Date: Apr 2009 Location: Philadelphia, PA
Rep Power: 1381 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,652
Groans: 166
| Not Ranked : 0 score I had that happen to me and I just unplugged it from the OBD port and plugged it back in.
__________________ Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts | CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp ![]() |
![]() | | #24 | ![]() |
__________________ `07 Speed6 Sport Tit Gray Sleeper Express... SOLD `11 Ducati 1198SP SBK Duc Red w/Termi exh; Redline flash-tune + PC-5; Sargent; Shift-tech, CDT, & EVR Carbon; 14F/39R gear w/FBF QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf, etc... a 182whp/105wtq The BIG DOG `12 Ducati 1100SP EVO Hyper Duc CORSE w/Termi exh; Redline flash-tune + PC-5; Ducshop Hyperstacks; 14F/41R gear w/FBF QC; Shift-tech, CDT, & BST(wheels) Carbon; R&G; ProGrip; Antigravity; Ducabike; Duc Perf, etc... a 95whp/75wtq The Hooligan `12 Aprilia RSV4 "Factory" SBK w/Akra Tit exh & race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL Pegs; Antigravity; Zero Gravity; AF1 Flat Carbon, etc... the 181whp/83wtq The Land Rocket `17 Ford Focus RS Nitrous Blue w/Cobb V3/AT; OZ Ultraleggera; Schroth harness The Super Fun Toy | |
![]() | | #25 | ![]() |
I've heard the flutter argument about shaft loading, but I've never seen any proof of this happening. Where surge does have an effect is at WOT/fully loaded. Yes, in that case, turbos sometimes explode. The converse argument for flutter is that it prevents a possible overrun situation. Meaning there is zero restriction on the turbo outlet while the BPV/BOV is open, where the turbo can spin as fast as possible. I'm not saying either is correct, because I don't have direct empirical evidence supporting either theory. I do, however, know of many turbo cars that have fluttered for thousands upon thousands of miles without a problem. | |
| The Following 2 Users Say Thank You to phate For This Useful Post: | mazdaspeed619sd (08-22-2011), rfinkle2 (08-11-2011) |
![]() | | #26 | ![]() |
![]() Join Date: Mar 2013 Location: Fort Myers
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score Sry to bring up an old post but i saw this because im having the same problem and was wondering what you did to fix it. if you could help me out that would be awesome if not ill keep searching. thanks |
![]() | | #27 | ![]() |
| Not Ranked : 0 score Is your problem a boost leak? If so locate it using a boost leak test Is the issue the BPV opening at part throttle? This is absolutely normal. If you want to VTA your OEM BPV you need to use the Guardian Angel which keeps it closed.
![]() | | #28 | ![]() |
| Not Ranked : 0 score I don't think it's a boost leak I just have the problem of where the bpv is opening up when just cruising up to speed at about 3 grand. All my numbers are good atf is 14.7 at idle 11.6 at wot. FP is round 430 at idle and between 1650-1750 at wot. |
![]() | | #29 | ![]() |
| Not Ranked : 0 score ok i have searched high and low and this is the only one that i have found but still no answer... i did the same tune as the OP and i have the same problem w the BPV blowing off in slow acceleration before i even take my foot off the pedal. just wondering if this is a problem or not. I dont suspect boost leak seeing as how it holds boost at high RMP. |
![]() | | #30 | ![]() |
| Not Ranked : 0 score How do you know the BPV is flowing off? Can you hear it? If it's blowing off during acceleration it might be faulty. Try blowing/sucking on the top port. If you can blow through that port the diaphragm is torn inside.
![]() | | #31 | ![]() |
| Not Ranked : 0 score Yes cuz when I was driving I felt it kinda fall and looked at the boost and saw it drop. So I turned down the radio and went through the gears again and before I would get to 3 grand it would blow of and boost would drop |
| Stock bpv question | 86AmishMs3 | Mazdaspeed3/6 General Discussion | 7 | 06-15-2011 12:19 AM |
| Resetting Stock ECU Question | vr4_3000 | MazdaSpeed 3/6 - ECU Computer Tuning | 9 | 04-06-2011 04:22 PM |
| SRI/CAI and Stock Air Box question(s) | Liquidplatspeed6 | Mazdaspeed3/6 General Discussion | 15 | 06-16-2010 11:58 PM |
| question what is our stock tire size ms3 | GFish | Mazdaspeed3/6 General Discussion | 4 | 09-27-2008 10:42 PM |
| Question: How to clean stock exhaust? | killyoutoo | MazdaSpeed 3/6 - Appearance | 7 | 04-02-2008 07:55 AM |
