 Old 03-10-2009, 02:18 PM   #1
ms3boost's Avatar
Posts: 400   (View Stats)
ms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to behold
Default SST K04 w/ forge wga
would it be worth it to get a forge wga when i get my sst, iam also not going to be installing it till the protuner is available for the ap, is it worth it to get the actuator
ms3boost is offline   Reply With Quote
 Old 03-10-2009, 03:55 PM   #2
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
i'm going to be putting one on mine when i'm not lazy, it's sitting in the box.
 Old 03-10-2009, 05:55 PM   #3
Haltech's Personal Bitch
PDXImportRacer's Avatar
Posts: 275   (View Stats)
PDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond repute
I will be getting an SST from PTP soon and Surgeline will be making a map for it. If you have slightly different mods Tim can alter it for you if you provide datalogs or detailed info on what needs to be done. Keep an eye out for the #s I put down I am thinking they will be impressive.
PDXImportRacer is offline   Reply With Quote
The Following User Says Thank You to PDXImportRacer For This Useful Post:
802MS3 (03-10-2009)
 Old 03-10-2009, 07:30 PM   #4
I<3Groceries's Avatar
Posts: 1,990   (View Stats)
EWG?
 Old 03-10-2009, 06:59 PM   #5
RayRayBauder's Avatar
Posts: 1,999   (View Stats)
RayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the world
Groans: 234
Groaned at 154 Times in 122 Posts
cool setup. pretty much what i want to do eventually when i get money.
'08 MazdaSpeed3 - sold
RayRayBauder is offline   Reply With Quote
 Old 03-11-2009, 03:07 PM   #6
External Waste Gate
 Old 03-11-2009, 03:08 PM   #7
Or if you ment are we going to use one, then that answer is yes. Tial 38mm v-band
 Old 03-11-2009, 03:15 PM   #8
MS3Zoom24's Avatar
Posts: 317   (View Stats)
MS3Zoom24 has a reputation beyond reputeMS3Zoom24 has a reputation beyond reputeMS3Zoom24 has a reputation beyond reputeMS3Zoom24 has a reputation beyond reputeMS3Zoom24 has a reputation beyond reputeMS3Zoom24 has a reputation beyond reputeMS3Zoom24 has a reputation beyond reputeMS3Zoom24 has a reputation beyond reputeMS3Zoom24 has a reputation beyond reputeMS3Zoom24 has a reputation beyond reputeMS3Zoom24 has a reputation beyond repute
Sorry for the question but SST?? What is acronym for. Im pretty good with this kind of stuff but I have no clue
08.5 MS3
Cobb AP-ATR tune; AEM CAI; COBB TIP; Test Pipe; PG piping/GS FMIC; AT Internals; HKS SSQV; Denso ITV22s; SURE counter weight; Cobb RSB; Swift spec R springs; Koni Sports; SU RMM, shifter bushings; Hankook Ventus V12 EVO 2
Team Beachbody Coach, Contact me to get started
GF2revolution.com
MS3Zoom24 is offline   Reply With Quote
 Old 03-11-2009, 04:09 PM   #9
Shooting for a screamer pipe? Or, will you dump it back into the exhaust? If so, where at? DP?
 Old 03-11-2009, 03:18 PM   #10
PTP's Super Stock Turbo. Check out PTP's section or website for info.
 Old 03-11-2009, 04:19 PM   #11
Dump back into the DP under the car.
 Old 03-11-2009, 04:54 PM   #12
ssmspeed3's Avatar
Posts: 40   (View Stats)
ssmspeed3 has a spectacular aura aboutssmspeed3 has a spectacular aura about
cool
ssmspeed3 is offline   Reply With Quote
 Old 03-11-2009, 04:54 PM   #13
ssmspeed3's Avatar
neat
 Old 03-17-2009, 08:48 PM   #14
ptperformance's Avatar
Posts: 4,123   (View Stats)
We will have our WGA on the site here over the weekend as well.
Is a WGA worth the money spent, very much so. You have to tune them and that is where most people get frustrated. They are not easy to tune and require some time to get right. If you take the time to get the WGA set up, it will reward you with great numbers and boost holding all the way to redline. Hope this helps.
forge or hks kraz3y MazdaSpeed 3/6 - Turbo Induction 50 08-26-2008 01:09 PM
Forge VTA TurboMazda1313 MazdaSpeed 3/6 - Turbo Induction 9 06-27-2008 04:00 PM
Page generated in 0.33327 seconds with 27 queries
