 Old 09-14-2011, 06:38 PM   #1
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
Default spiked to 25psi today
i have a 3076r and tuned to 20 lbs. if im doing a normal pull, it builds to 20 then holds great. today i was doing about 60 and dropped into 4th and punched it and i immediately spiked to 25 (i was watching my boost gauge to see how boost was building). hit all the fuel and boost cut shit and car is fine but im wondering why it might do this. im leaning toward something with either the iwg not being able to handle it or possibly my wgdc being messed up (stock solenoid). it is just strange because it only happens if i shift into gear at a higher rpm.
ideas anyone?
 Old 09-14-2011, 06:40 PM   #2
ideas anyone?
I hate to have you do it again, but if you can catch a log... that would be great.
 Old 09-14-2011, 06:41 PM   #3
manelscout4life's Avatar
Posts: 1,781   (View Stats)
Groans: 661
just tune to 25 psi. then it wont be a spike
The Following 19 Users Say Thank You to manelscout4life For This Useful Post:
Alpha (09-29-2011), bcmountainspeed (09-17-2011), BlueStreak (09-24-2011), Bucker (09-14-2011), Chimmike (09-16-2011), Chriscote (09-17-2011), dsmluck (09-17-2011), emag remrofni (09-15-2011), Erich (09-14-2011), kgb (09-15-2011), NJSPEED3 (09-14-2011), PapaSmurf (09-14-2011), rfinkle2 (09-14-2011), Speeed3 (09-17-2011), spoolin00 (09-17-2011), TexasSpeed3 (09-16-2011), themytb (09-14-2011), Tokay444 (09-16-2011), xhymer (09-16-2011)
 Old 09-14-2011, 06:44 PM   #4
Edit.. You don't even have to let it hit 25 psi, but just log what the wgdc is doing when this happens vs. your wgdc table and wgdc boost error comp table.
I'm tempted to say to lower your wgdc boost ramp limit high to 5, but my guess is an overly aggressive wgdc boost error comp table.
 Old 09-14-2011, 06:46 PM   #5
JacksonMS30's Avatar
Posts: 2,242   (View Stats)
Are you using an MBC or the stock bcs?
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M Twisted Top Mount -
- P.E.R.M.Tuning -
 Old 09-14-2011, 06:47 PM   #6
TWOptSL0W's Avatar
Groans: 125
well since im still on the solenoid, im pretty much maxing it out while im hitting the 20psi doing a normal pull. heres a log that i did recently (i think i have a slight boost leak because i dont think it should be maxed out yet, but that is constant throughout the log and the 25 spike so it shouldnt make a difference)
id also prefer not to do it again unless i have to. my map sensor wouldnt be able to give an accurate reading anyway since its the 2.5bar
The Following User Says Thank You to TWOptSL0W For This Useful Post:
 Old 09-14-2011, 06:49 PM   #7
TWOptSL0W's Avatar
Groans: 125
stocker. i think that *may* be my problem, but just trying ti figure it out
it spiked within a second of shifting gears. i took my foot off as soon as it shot up, but i dont think id be able to get it before it shoots up
Last edited by TWOptSL0W; 09-14-2011 at 06:49 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-14-2011, 06:50 PM   #8
So you are still running some wgdc throughout the entire rev band?
 Old 09-14-2011, 06:51 PM   #9
Why are you still using the stocker? You could get an MBC for less than $100 or you could get an EBCS for right at $100. The grimspeed EBCS is only $110 I think.
I'm just curious if you have a reason for sticking with the stocker...
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M.Tuning -
 Old 09-14-2011, 06:52 PM   #10
TWOptSL0W's Avatar
Groans: 125
not the entire thing, but its pretty much maxed till 5k then tapers down very quickly. the stock is crap to work with for a bt, but im testing it to see if its possible for any other guys who may want to do it
edit: ill prob end up with a gs ebc eventually but i wanna see if this one can work and give a good base wgdc for some peeps
The Following 2 Users Say Thank You to TWOptSL0W For This Useful Post:
JacksonMS30 (09-14-2011), rfinkle2 (09-14-2011)
 Old 09-14-2011, 06:55 PM   #11
gotcha
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M.Tuning -
The Following User Says Thank You to JacksonMS30 For This Useful Post:
 Old 09-14-2011, 06:56 PM   #12
You might give the wgdc ramp limiter high (set to 5 vs 10) a try and almost completely wipe wgdc out @ towards redline.
 Old 09-14-2011, 07:01 PM   #13
TWOptSL0W's Avatar
Groans: 125
so basically that would let the solenoid work at a slower rate? im sorry im not 100% familiar with the new wastegate tables. also, im a little confused as to why it happens when i shift to 4th in a higher rpm vs a wot log run where wgdc was maxed anyway
 Old 09-14-2011, 07:10 PM   #14
The wgdc boost error comp table is much like the old boost dynamics table.
Now that I think about it, it would be more beneficial to pump up you wgdc boost error comp overboost portion of your table.
The ramp limiter limits the amount of continuously multiplied correction the wgdc comp table can make to the wgdc table.
 Old 09-14-2011, 07:14 PM   #15
TWOptSL0W's Avatar
Groans: 125
would the ecu be able to compensate that quickly and the changes in wgdc work fast enough? it was literally milliseconds
 Old 09-14-2011, 07:16 PM   #16
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
i spiked 25 today also
at 104000 2 bent rods
tuned by nishan
The Following User Says Thank You to rigor For This Useful Post:
 Old 09-14-2011, 07:19 PM   #17
TWOptSL0W's Avatar
Groans: 125
yea well im not supposed to
 Old 09-14-2011, 07:20 PM   #18
POWERED BY POLSKA
themytb's Avatar
Posts: 762   (View Stats)
Groans: 38
I may be wrong here but I think when you downshift the ecu is moving faster than the spool, so the ecu reads rpm/throttle boost target, sees that its under target and adds boost error to the mix, ramping the wgdc higher than is actually needed and causing a spike. If i'm wrong I apologise for my newbness.
25%E85FREEKPERMED
The Following 4 Users Say Thank You to themytb For This Useful Post:
Bucker (09-14-2011), Chimmike (09-16-2011), G26 (09-14-2011), rfinkle2 (09-14-2011)
 Old 09-14-2011, 07:23 PM   #19
The ecu is pretty fast...I think,"is your bcs fast enough?" is the question.
I would try taking the stock overboost portion of the wgdc boost error comp table and multiply it by 1.5.
You could also introduce a small wgdc load error comp table to control load and hybrid tune as Fobio and Bluestreak call it.
 Old 09-14-2011, 07:24 PM   #20
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
tune it to 25psi , problem solved
stop being a pussy...if i can run 25 psi on a 71 u sure as shit can do it on a 76
The Following 2 Users Say Thank You to rodrigo For This Useful Post:
dsmluck (09-17-2011), xhymer (09-16-2011)
 Old 09-14-2011, 07:29 PM   #21
TWOptSL0W's Avatar
Groans: 125
i would rodrigo, but still on stock map sensor and ill change that out eventually but not now
 Old 09-14-2011, 07:30 PM   #22
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
NIGGAH IM ON THE STOCK MAP SENSOR TOO.....oops caps.
i just set all the cuts to like 40psi hahahahahahah
man fuck safety....its like fucking with a condom...sure the bitch can get pregnant, sure u can catch some bad shit....but we all know which way is more fun
BeastMS3 (09-16-2011)
 Old 09-14-2011, 07:32 PM   #23
TWOptSL0W's Avatar
Groans: 125
nah ill stick with being a puss and figure this out
 Old 09-14-2011, 07:35 PM   #24
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
I think your first step needs to be a boost leak test. You have a .55AR turbine 3076 and your spooling slower than my T3 gt35.
What does your WGDC table look like?
This is mine. I'm targeting 23psi, I hit 24.5 and immediately drop into the 23's all the way to redline.. Max WG boost dynamics is 15%. the 100% cells start the spool, the 90% forces the WG dynamics adjustment up as I haven't hit my target yet, the 30% cell prevents any significant spike, and the 40~41 cells hold me at my target, and ensure that downshifting and going WOT doesn't cause a massive boost spike..
Code:
100.00	100.00	100.00	100.00	100.00	100.00	100.00	90.00	30.00	40.00	40.00	40.00	41.00	41.00	41.00
The OEM BCS setup is junk--your forcing yourself to use high base WGDC values to hit your target boost, but that will cause the spikes your seeing. A good EBCS will allow you to run high WGDC to spool as fast as possible, but use much lower WCDG values and the WG dynamics to maintain once you hit your target..
The Following User Says Thank You to SSinstaller For This Useful Post:
rfinkle2 (09-15-2011)
 Old 09-14-2011, 07:40 PM   #25
TWOptSL0W's Avatar
Groans: 125
my wgdc is 80 until 3k then 100 till 5k then tapers off quick. i know the stock sucks but do you think thats whats holding me back? would a new ebc make that much of a difference? my boost leak is pretty minimal and small enough where it wont affect my spool at all if anything
 Old 09-14-2011, 07:55 PM   #26
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
yes. The EBCS is holding you back.
403whp/451ft/lb Dry Shot
 Old 09-14-2011, 07:59 PM   #27
TWOptSL0W's Avatar
Groans: 125
fine wheres the cheapest place to get a grimmspeed? hopefully that will be able to react faster and help with this overboost business
 Old 09-14-2011, 08:14 PM   #28
vrspeed10's Avatar
Posts: 1,035   (View Stats)
vrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the world
Groaned at 25 Times in 10 Posts
I second that.. Its got to be the bcs. I had a ds ebc in my msp and until i installed it that bitch would spike like crazy all the time. After i installed it the boost came on quick, hit set boost and would hold like a champ..
If your not first your last.
03 Speed Protege.. SOLD
10 Speed3 BT and getting my DRANK on!!!
vrspeed10 is offline   Reply With Quote
 Old 09-14-2011, 08:15 PM   #29
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
Exactly what is happening. I spike to 19 psi usually when I punch it above 3000 rpm.
The Following User Says Thank You to G26 For This Useful Post:
 Old 09-14-2011, 08:20 PM   #30
Bucker's Avatar
Groans: 451
i don't know what I spike to... Ap only fucking logs up to 22.63. @Cobb Tuning
 Old 09-14-2011, 08:33 PM   #31
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
i get that kind of issue with electronic boost controlling. it could not open wg fast enough and if you have internal wg that does not help. get rid of boost controller and put a 20psi spring in your wastegate if you got external problem solved =p
 Old 09-14-2011, 08:45 PM   #32
rigor's Avatar
Groans: 40
internal wg ftl on that deal me thinks, but not 100% sure
may have to deal with it or go ewg
or turn it up to 26 then your good 20 psi sucks anyway on this size turbo
tune better be on though gl
tuned by nishan
 Old 09-15-2011, 07:01 AM   #33
GrimmSpeed EBCS
GrimmSpeed
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M.Tuning -
 Old 09-15-2011, 06:59 PM   #34
TWOptSL0W's Avatar
Groans: 125
Yea I know them but is there a vendor that sells them any cheaper? Not being cheap I'm just not trying to spend money uselessly
 Old 09-15-2011, 07:29 PM   #35
Groans: 60
How is your OEM BCS connected? You should not need 100% WGDC above 3500psi--you should be hitting your 20psi around 4K..
Post your WGDC table, your boost error comp table, and your boost error ramp high limiter... and a third gear log, and we'll see if we can make it any better with you having to spend any money..
 Old 09-15-2011, 08:45 PM   #36
TWOptSL0W's Avatar
Groans: 125
oem bcs is basically t'd off from my boost source and iwg. i got a quick log today and ill post up my map so you can take a look that way. today it spiked to 25+ within an extremely short time. i have a hunch that my iwg may be actually stuck closed (see ATP 1 Bar iwg turbos )
i have an insane weekend coming up including me driving to georgia (from nj) tomorrow for a funeral monday and then back again in time for work here again on tuesday ( i may just not sleep for 3 days) so i wont be able to check it till tuesday or wednesday
 Old 09-15-2011, 08:55 PM   #37
Groans: 661
being t'd off of the bov causes a delay to the bc
 Old 09-16-2011, 02:49 AM   #38
TWOptSL0W's Avatar
Groans: 125
It's not off the bov. My boost source is directly after the turbo
 Old 09-16-2011, 06:24 AM   #39
Groans: 60
I've got the MS6 ATR, so I can't open your map. Could someone who has a 3 please post the info I asked for from the map.
Looking at your log you should only need 100% WGDC to 3000rpm~3500rpm, every value after that should be significantly lower...
If you get a chance drop all your WGDC targets by 40% above 3500rpm, and take a new third gear log, make sure to go WOT at 2900~3000rpm. It doesn't matter if you don't hit your target, you just need to be able to make a full pull..
 Old 09-16-2011, 06:50 AM   #40
I would post those tables for sure, but I'm @ work, with no ATR.
If it isn't posted by the time I get home, I'll post the tables up then.
SSinstaller (09-16-2011)
Log from today Ex_WRX_driver 2010 MS3 - ECU Computer Tuning 1 07-02-2011 11:40 AM
Today or Later? Stealth01 MazdaSpeed 3/6 - Suspension & Brakes 6 02-26-2011 05:22 PM
CEL today PheOniX MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 04-05-2010 09:47 AM
Overboosting 25psi on Stock Tune!? SoyBean MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 11-23-2009 02:50 PM
411whp with gt3076 @ 25psi... howd he do it phailerider MazdaSpeed 3/6 - Dyno Sheets/Discussions 63 01-05-2009 01:32 PM
Page generated in 0.56941 seconds with 32 queries
