Like Tree4Likes
 Old 07-22-2009, 12:32 PM   #161
bnoon's Avatar
Posts: 1,770   (View Stats)
OK, just FYI to all who ordered from the latest batch. The bolts are on backorder. I was able to get 2 more bolts and got those drilled. Sending those two out today to:
L****** P***** (name deleted at user request)
Joseph LoCurto
The rest are on back order. If it looks like it will be a while until the bolts come off of backorder, I'll look at issuing refunds next week if the buyers wish.
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
 Old 07-23-2009, 12:33 PM   #162
late8's Avatar
Posts: 34   (View Stats)
late8 is a splendid one to beholdlate8 is a splendid one to beholdlate8 is a splendid one to beholdlate8 is a splendid one to beholdlate8 is a splendid one to beholdlate8 is a splendid one to beholdlate8 is a splendid one to behold
pm sent
late8 is offline   Reply With Quote
 Old 07-25-2009, 09:08 AM   #163
bnoon's Avatar
Originally Posted by late8 View Post
pm sent
Refunded. Watch this thread for more updates.
UPDATE: Found more bolts and ordered them. I will have tracking on my bolt order Monday and give you guys a schedule based on that delivery.
2002 BMW M3 - Sold!
 Old 07-27-2009, 01:17 PM   #164
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
PayPal Sent!
Thanks!
 Old 07-28-2009, 07:13 AM   #165
bnoon's Avatar
Got a call on the bolts and they will be here Friday or Monday. Updates as I get them.
2002 BMW M3 - Sold!
 Old 07-28-2009, 12:38 PM   #166
hnda etr's Avatar
Groans: 90
You got my order right?
 Old 07-28-2009, 11:45 PM   #167
Wenis Prinkle's Avatar
Posts: 176   (View Stats)
Wenis Prinkle has much to be proud ofWenis Prinkle has much to be proud ofWenis Prinkle has much to be proud ofWenis Prinkle has much to be proud ofWenis Prinkle has much to be proud ofWenis Prinkle has much to be proud ofWenis Prinkle has much to be proud ofWenis Prinkle has much to be proud ofWenis Prinkle has much to be proud of
Groaned at 143 Times in 33 Posts
The only way to tell is pull your dp off and look and see if you see oil residue there, then u know for sure its coiming from the turbo seals, whick it prob is, i had to have mine replaced around 20,000 miles, smokeg like a choo choo train after running it har and then stoppping or at idle randomly, if it smoked under full throttle it coould just be all the blow by, and contaminated fuel, oil ect burning off due to the shitty oem pcv and egr system, search new oil catch can write up, that will cure booth crank presure and VC pressure at full boost and vacum unlike any other OCC set up plus you only need one OCC!! look it up
Wenis Prinkle is offline   Reply With Quote
 Old 07-29-2009, 02:27 PM   #168
bnoon's Avatar
I don't know. Are you Roy Hamilton, Mike King, or Chad Miller? No details on screen name in those payments and can't tell from your user name.
I've looked at a couple of torn apart replaced turbos at the local Mazda dealership and confirmed what several rebuilders have already stated... that almost ALL of the turbos replaced under warranty DIDN'T have bad seals. It's the PCV pressure combined with the oil pressure at the feed line that makes them push oil past the seals. Just because it pushes oil past the seals doesn't make the seals bad or vice versa, in most cases it's simply being over pressurized. Further proof by many people that get their turbo replaced and it still smokes just as bad or worse with the new turbo.
2002 BMW M3 - Sold!
 Old 07-29-2009, 04:07 PM   #169
hnda etr's Avatar
Groans: 90
Sorry...
Roy...
Thanks!
 Old 07-29-2009, 04:15 PM   #170
hnda etr's Avatar
Groans: 90
I wonder if venting the OEM PCV to atmosphere would be better than keeping the PCV system in a closed loop by running an OCC.... That would at least relieve the pressure in the crankcase?
Hmmm... now that I think about it, running a second, good quality, PCV as part of the OCC setup would prevent the crankcase pressure build up right?
 Old 07-31-2009, 01:26 PM   #171
stormin84's Avatar
Posts: 128   (View Stats)
stormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the world
hey bnoon is the bolt suppose to look like this or did something happen when you were drilling the hole on the side. because i sure can't put it in the turbo like that, the threads are fucked up....
Falken FK-452 | 215-40R18 | Konig Hotswap |35% Tints| Greddy TT| Cobb Sri| Cobb Shifter| Cobb AP| Cobb Springs| Cobb RSB | Cobb Inlet Pipe |TS BOV |Dashhawk| COBB FMIC |CPE MM|CPE DP|
STILL TO COME: |Whatever I can get my hands on before she kills me|
stormin84 is offline   Reply With Quote
 Old 07-31-2009, 02:22 PM   #172
ZoomByU's Avatar
Posts: 1,236   (View Stats)
ZoomByU is the leader of the worldZoomByU is the leader of the worldZoomByU is the leader of the worldZoomByU is the leader of the worldZoomByU is the leader of the worldZoomByU is the leader of the worldZoomByU is the leader of the worldZoomByU is the leader of the worldZoomByU is the leader of the worldZoomByU is the leader of the worldZoomByU is the leader of the world
Groaned at 9 Times in 9 Posts
its pretty irrelivant too the whole bold issue but my buddy has an 07 audi A4 and he just put a turbo back on his car. he was talking all sorts of shit about how awesome it is....until he called me up that night like "hey man when i pulled into my garage my exhaust wa smoking!!!" i just laughed n joked about his turbo wa shot and blah blah blah. then just told him "welcome to the smoking turbo club" lmfao.
just wanted people to see its not only our cars.
ZoomByU is offline   Reply With Quote
 Old 07-31-2009, 05:03 PM   #173
darth vader's Avatar
Posts: 665   (View Stats)
darth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the world
Umm, duh, it's a banjo fitting, that part is where the female part of the banjo sits so, it's not threaded into anything.
darth vader is offline   Reply With Quote
 Old 08-03-2009, 08:18 AM   #174
bnoon's Avatar
That's the part of the threads I had to grind down to punch set it better. Not all of them look like that, just the ones that have trouble getting the tiny bit started. It does not effect the function in any way as that part of the threads are not used (that area is inside the banjo fitting, no need for threads).
EDIT: On a side note, my bolts came in today and I'll get them machined tonight.
2002 BMW M3 - Sold!
 Old 08-05-2009, 10:42 AM   #175
hnda etr's Avatar
Groans: 90
progress update?
 Old 08-05-2009, 12:30 PM   #176
bnoon's Avatar
Bolts are finished and shipped today. Will update later with shipped list of peeps as I have done in this thread before.
2002 BMW M3 - Sold!
 Old 08-05-2009, 01:04 PM   #177
hnda etr's Avatar
Groans: 90
saweet!
 Old 08-05-2009, 05:44 PM   #178
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
Cool, I forgot I actually bought one of these.
 Old 08-05-2009, 09:41 PM   #179
Speedn3's Avatar
Posts: 642   (View Stats)
Speedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond repute
yeah me too....
Speedn3 is offline   Reply With Quote
 Old 08-06-2009, 04:17 AM   #180
BIGGERDAKINE's Avatar
Posts: 43   (View Stats)
BIGGERDAKINE is a glorious beacon of lightBIGGERDAKINE is a glorious beacon of lightBIGGERDAKINE is a glorious beacon of lightBIGGERDAKINE is a glorious beacon of lightBIGGERDAKINE is a glorious beacon of light
Jus got my dp/rp installed today. Didn't even know I was smoking out the car behind me until the light turned green and sped off. Shit I feel bad... are there any more restrictors available?
BIGGERDAKINE is offline   Reply With Quote
 Old 08-06-2009, 06:59 AM   #181
bnoon's Avatar
Yup, I found a stockpile of bolts and will keep a few in stock at all times now.
2002 BMW M3 - Sold!
 Old 08-06-2009, 11:04 AM   #182
Axle Breaker
jmhinkle's Avatar
Groans: 162
You got that new list of shipped bolts?
 Old 08-06-2009, 08:22 PM   #183
austin102085's Avatar
Posts: 1,195   (View Stats)
any one with the bolt installed pm me ASAP!!!!!!!
2008.5 Mazdaspeed 3
513whp MS3<-- for now (sold)
 Old 08-06-2009, 10:08 PM   #184
Babyface's Avatar
Posts: 320   (View Stats)
Babyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the world
I need one of these!
Babyface is offline   Reply With Quote
 Old 08-07-2009, 12:21 PM   #185
bnoon's Avatar
Sorry for the delay guys. These were shipped Wednesday via post office with delivery conf numbers as listed below.
Michael N
Pittsburgh, PA
03060320000325252698
Jimmy L
Leonardo, NJ
03060320000325252742
Joel H
Rio Rancho, NM
03060320000325258615
Thomas A
sussex, NJ
03060320000325257991
Paul B
Memphis, TN
03060320000325252704
Brian S
Placentia, CA
03060320000325252728
Roy H
Mission Hills, CA
03060320000325252735
2002 BMW M3 - Sold!
The Following 2 Users Say Thank You to bnoon For This Useful Post:
hnda etr (08-07-2009), jmhinkle (08-08-2009)
 Old 08-08-2009, 12:33 PM   #186
Axle Breaker
jmhinkle's Avatar
Groans: 162
Got mine today. Thanks.
Installed. We'll see if it does anything for my smoke machine.
Last edited by jmhinkle; 08-08-2009 at 01:03 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-08-2009, 01:11 PM   #187
bnoon's Avatar
I thought I blew my shit up today... was working on my air/water ver 2.0 and thought I could temporarily plug off the valve cover PCV hose. Smoked so bad I think I sent a smoke signal message for the Injuns on the reservation to attack! LOL! So just FYI to those that think the PCV system sucks so bad, it actually does work at least somewhat. I'll have to put a filter on there temporarily instead of plugging it and I'll just have to deal with the f-ed up fuel trims until I get a chance to tap back into metered air after the MAF section I made.
2002 BMW M3 - Sold!
 Old 08-08-2009, 08:56 PM   #188
Axle Breaker
jmhinkle's Avatar
Groans: 162
No hope for my turbo. Smokes just like it always did. Damn. More reason to get that 3071.
 Old 08-09-2009, 07:28 AM   #189
bnoon's Avatar
What all have you done to help the smoke issue?
2002 BMW M3 - Sold!
 Old 08-09-2009, 07:46 AM   #190
Axle Breaker
jmhinkle's Avatar
Groans: 162
Let's see, I've been on a 40wt since June of last year when the car had about 5000 miles on it. I've had an SM OCC since about 2000 miles. I added the 2nd OCC to the valve cover last fall sometime. I tried your bolt. I've had WI since January. None of it matters. Once I put the CBE on it has bellowed smoke like crazy. If you have an open exhaust, it's not gonna take long to start puffing if you have one of the crappy ones like me. I have way to many mods to even attempt to go to the dealer. Just gonna finish it off with a new huffer and be done with this POS one.
 Old 08-09-2009, 01:45 PM   #191
bnoon's Avatar
I feel your pain. I smoked for over a year before getting to this point and I still worry every day that I'm going to see it billow yet again.
After going through this latest air/water fabrication, I've decided to test some other PCV fixes to see if I can eliminate the need for the bolt all together. When I had the valve cover hose plugged it smoked worse than it ever had before. This morning I put a breather on it and it stopped again.
Prior to putting the breather on though, I plugged in my vacuum/boost gauge and wasn't seeing any vacuum at all under idle, but DashDaq was reading -10 psi at idle. I open the port on my catch can and feel enough to suck my finger as if I were sucking on a straw... so somewhere between the catch can and valve cover there's a HUGe loss of that neg pressure. Thinking stock PCV may be clogged again, not that the flow path is very good at all anyway though. Going to relocate that sucker for sure this time. I like PTP's relocation position as far as layout goes, but I don't like the fact that it's basically venting the baffle area of the valve cover from one end to the other, which isn't really going to lower crankcase pressure any at all.
2002 BMW M3 - Sold!
 Old 08-09-2009, 09:04 PM   #192
Starting to give up on this whole exhaust smoke... might just suck it up and reinstall the stock cats. Well maybe just the mid cat just to cover it up a bit
 Old 08-10-2009, 05:07 AM   #193
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
Why? This has worked for several people in including myself...
09 MGM MS3
 Old 09-21-2013, 06:27 PM   #194
midlifecamry's Avatar
Posts: 14   (View Stats)
midlifecamry is a jewel in the roughmidlifecamry is a jewel in the roughmidlifecamry is a jewel in the rough
Bnoon,
I've searched the forums for "smoke idle" and other variations and I'm not finding anything current.
Is there a current thread for this?
I just turned my 06 MS6 into a stop light BBQ by adding a CPE turbo back exhaust and I'm feeling super tarded and am thinking about selling the car rather than replacing the turbo or going through the pain of eating the cost of the CPE exhaust and re-installing the OEM exhaust system. Not even sure replacing the turbo is a solution, as CPE sells new turbos for $1200 with a disclaimer about smoke at idle.
midlifecamry is offline   Reply With Quote
The Following User Says NO Thank You to midlifecamry For This Un-useful Post:
jm211 (09-21-2013)
 Old 09-21-2013, 07:27 PM   #195
jk_ms3's Avatar
Posts: 1,390   (View Stats)
Groans: 40
Originally Posted by midlifecamry View Post
Bnoon,
Wow. You just won the oldest zombification of a thread ever.
You need to search some more. You've got a few options regarding your problem, but you need to do the legwork first. Posting in a 4 year old thread isn't the way to do it. (And actually, if you'd read first, you might not have had your problem at all.)
On deck: VG Sharkfin Antenna
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/quest-cure-oil-smoke-once-all-29600/
cataliseur This thread Refback 11-15-2014 03:27 PM
Turbo à changer - Page 3 This thread Refback 07-12-2014 08:23 PM
Probleme sur mon speed6 2006 This thread Refback 05-13-2014 04:27 PM
Mps exhaust blowing white smoke at idle This thread Pingback 11-08-2009 01:20 AM
Has anyone seen this??? WTF! - Colorado Mazda Club This thread Refback 10-05-2009 02:44 PM
Mazda6 / Atenza > Smokey smokey This thread Refback 07-29-2009 07:37 PM
Smokey smokey - Mazda6 / Atenza This thread Refback 07-20-2009 01:31 PM
Mazdaspeed 3/6 K04 Hybrid turbocharger 330WHP!!! - Page 5 - StreetUnitForum.com This thread Refback 07-14-2009 07:17 PM
Need to quit? - Mazda6 / Atenza This thread Refback 06-15-2009 07:57 PM
Help cure my tranny worries Meder MazdaSpeed 3 - Engine, Transmission & Driveline 38 12-17-2010 02:42 PM
Wheel quest bioevolve MazdaSpeed 3/6 - Wheels & Tires 14 03-07-2009 10:02 AM
Does WI cure KR? MS3 Ventura MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 4 01-18-2009 10:55 AM
Page generated in 0.53980 seconds with 34 queries
