 Old 04-20-2009, 12:23 AM   #1
steven88's Avatar
Posts: 773   (View Stats)
steven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the world
Groaned at 9 Times in 5 Posts
Default P0421 on my CP-E Catted downpipe
P0421
Warm Up Catalyst Efficiency Below Threshold (Bank 1)
So I threw a P0421 code on my cp-e catted downpipe...this is actually the 3rd time it has happened now....past few weeks I have been throwing it and I just erase the code with my Equus DTC reader...but it keeps coming back after a few hundred miles
What do you guys think it is? According to the internet, it might be the catalytic converter or the o2 sensor itself
For those who have Cp-e catted downpipe, what would you suggest?
steven88 is offline   Reply With Quote
 Old 04-20-2009, 07:23 AM   #2
Crossbow's Avatar
Posts: 709   (View Stats)
Crossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the world
Call or Email Cp-e .
Crossbow is offline   Reply With Quote
 Old 04-20-2009, 07:46 AM   #3
ElBartoRex's Avatar
Posts: 1,186   (View Stats)
ElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the world
I have been getting the same code for over a year from my TurboXS catless downpipe. Its just your run of the mill cat inefficiency code. It is not uncommon for a cat code to trigger from a high flow cat-- the sensor thinks your stock cat is dying. A spacer will fix it but the spacer trick seems to be hit or miss on this car. The diode will work as well though in my experience the light still comes on every 600-800 miles.
2007 Mazdaspeed3 Sport, True Red
ElBartoRex is offline   Reply With Quote
 Old 04-20-2009, 07:53 AM   #4
mike8748's Avatar
Posts: 396   (View Stats)
mike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the world
I have the TurboXS DP, no CATS and I got the O2 extender off eBay:
eBay Motors: o2 oxygen sensor extender 02 EFIE HHO HYDROGEN MAP MAF (item 160328833335 end time May-16-09 1031 PDT)
Over 2k miles and still going w/ no CEL's
07'MazdaSpeed3 Stage2+SF 93 FMIC Custom Map
Current Mods: COBB AP, COBB SRI, COBB Inlet, COBB Cold Air Box, COBB Shift Weight, COBB STS, COBB PCV Catch Can, COBB Rear Sway Bar, M3M FMIC, TWM Shifter Bushings, FORGE BPV, Nator Rear MM, TurboXS DP, TurboXS RP, TB BYPASS MOD, MSD Dash Hawk, Denso 2-Step Colder plugs, Eibach Springs, BSD, KMD ver2 internals, EGR delete, PTP intake cooler kit, CNT Racing CBE, PG Exhaust Manifold
mike8748 is offline   Reply With Quote
 Old 04-20-2009, 07:56 AM   #5
steven88's Avatar
i thought the TXS already comes with an extender built into the downpipe?
 Old 04-20-2009, 08:25 AM   #6
stormin84's Avatar
Posts: 128   (View Stats)
stormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the world
i get the same code with my catted cp-e downpipe, i know another person with a mazda 3gt with a header and gets the same code too. i just clear it with my dashhawk
Falken FK-452 | 215-40R18 | Konig Hotswap |35% Tints| Greddy TT| Cobb Sri| Cobb Shifter| Cobb AP| Cobb Springs| Cobb RSB | Cobb Inlet Pipe |TS BOV |Dashhawk| COBB FMIC |CPE MM|CPE DP|
STILL TO COME: |Whatever I can get my hands on before she kills me|
stormin84 is offline   Reply With Quote
 Old 04-20-2009, 10:03 AM   #7
zoomed777's Avatar
Posts: 33   (View Stats)
zoomed777 has a spectacular aura aboutzoomed777 has a spectacular aura aboutzoomed777 has a spectacular aura about
Try the diode fix, my TXS stealth kit has not thrown any CEL's. I have about 4k miles on it and not 1 CEL yet.
zoomed777 is offline   Reply With Quote
 Old 04-20-2009, 01:29 PM   #8
steven88's Avatar
and it never came back?
 Old 04-20-2009, 01:36 PM   #9
jlefebvre123's Avatar
Posts: 165   (View Stats)
jlefebvre123 has a reputation beyond reputejlefebvre123 has a reputation beyond reputejlefebvre123 has a reputation beyond reputejlefebvre123 has a reputation beyond reputejlefebvre123 has a reputation beyond reputejlefebvre123 has a reputation beyond reputejlefebvre123 has a reputation beyond reputejlefebvre123 has a reputation beyond reputejlefebvre123 has a reputation beyond reputejlefebvre123 has a reputation beyond reputejlefebvre123 has a reputation beyond repute
i got turbo xs dp and rp and igot that error once while driving on cruise on the highway for four hours but i just cleared it and moved on
jlefebvre123 is offline   Reply With Quote
 Old 04-20-2009, 01:42 PM   #10
ElBartoRex's Avatar
it does and it doesn't work (for me)
 Old 07-09-2009, 11:29 PM   #11
steven88's Avatar
how often do you guys throw this code? every 1k?
 Old 07-11-2009, 09:43 PM   #12
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
i get the same, always have. i have the cpe catted downpipe. i clear it with my dashhawk and it stays away for a week or so (100-200 miles.) if i leave it alone, it comes and goes whenever it feels.
catted downpipe? tbone Mazdaspeed3/6 General Discussion 3 02-03-2009 04:00 PM
cp-e catted downpipe bova MazdaSpeed 6 - Engine, Transmission & Driveline 10 12-01-2008 11:16 PM
Page generated in 0.30111 seconds with 27 queries
