![]() Join Date: Feb 2009 Location: Flanders, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 224
__________________ 2008 Cosmic Blue Mazdaspeed 3 GT - COBB AP DIZZYTUNED for 30% E85//JBR Whale Penis//COBB TIP//COBB DP//COBB STS//COBB Knob//COBB shift weight//COBB Piping TR8L Core//Magnaflow CBE//Turbosmart BPV//PTP internals//SU RMM//TRZ tranny mount//Koni + H&R springs//Tinted 35% front, 20% rear//Lamin-X head-light & tail-light film//ASA GT1 18x8//Hankook Ventus V12 225/40// |
| jbr makes fall-a-parts. ![]() Join Date: Jan 2011 Location: Cambridge Ontario Canada
Rep Power: 13536 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,744
Groans: 793
| Not Ranked : 0 score The secondary needs to communicate with the primary for proper ol/cl operation
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
| The Following 2 Users Say Thank You to Tokay444 For This Useful Post: | EdgeAutosport.com (01-19-2012), thatsmrgimp2u (01-18-2012) |
![]() Join Date: Feb 2010 Location: Daphne, Alabama
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 236
| Not Ranked : 0 score You can disable the CEL with your ap. But if you have any type of vehicle inspection that reads your OBII port your gonna get a not ready signal from that secondary o2 sensor. You're in luck though the secondary o2 sensor is the cheaper of the two.. And you can usually pick it up at autozone, napa, or checkers. I wouldn't risk not running that sensor personally.. Gotta pay to play , would you rather spend $$ on a new engine or on a pretty cheap o2 sensor? |
![]() Join Date: Nov 2009 Location: Westchester NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 566
| Not Ranked : 0 score first, if you dont have an inspection that will fail bc of a not redy code just disable the cel for it. second if anybody tells you different here do not listen. the secondary o2 is necessary for closed loop fueling. and be careful buying the bosch or denso, i got the bosch and the cord was two short and also had a female plug on it so i was left with two female plugs. the best way to go about it is get an oem mazda one, you can prob find one cheap online i got one from a member off of here, but yes u need the secondary.
__________________ 2007 Mazdaspeed 6 - Ptp SST, Cobb AP, SSP 3.5" Intake, SURE Sidewinder, Autotech HPFP Internals, PTP 2150 psi HPRV, Cp-e Injector Seals, PTP Injector Studs, Jbarone TIG's, VTCS Delete, ETS 3.25" TMIC, M2 Catless Downpipe, Magnaflow Catback Exhaust, MD OCC, Denso ITV 22, H & R springs, Energy Suspension Rear Sway Bar Bushings, Dashhawk, Hawk HPs Pads, Centric Rotors, Street Unit Rear Motor Mount, TWM Stage II Shifter with Solid Bushings and Weighted Shift Knob, Autometer Mechanical Boost Gauge |
| The Following User Says Thank You to speedms6 For This Useful Post: | DISIindahead (01-18-2012) |
(Thread Starter) | Not Ranked : 0 score Okay thanks guys. I had no idea it was involved with closed loop fueling. I'm due for an oil change this week so I'll have a new one put in unless the shop can get my stock one out of there. But I have a feeling even if they do get it out that the threads will be jacked up.
![]() Join Date: Nov 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score Just buy an 02 simulator or make one... there just capacitors and resistors. I would like to see in writing a secondary o2 effecting fuel trims negatively and not allowing closed loop operation. The secondary o2 is only there to monitor the efficiency of the catalyst. It monitors the voltage to keep the cat at over 500 degrees.. when it cools it adds fuel and vice versa. It compares the pre cat signal to the post cat. If it never went to closed loop it would load the cat with excess hydrocarbons and destroy it. If anything vehicles would get better mileage without cats because the constant adding of fuel to keep the cat hot is a waste. Without a sensor it will see the lack of a heater circuit and defualt back to pre-programmed logic. I've removed several post cat sensors and never had an issue going into closed loop. The simulator simply makes it look like everything's good.
__________________ 06 Pearl White MS6 Grand Touring- Cobb SRI- Cobb TIP- BNR S3- P&P Tb- Devils Own Meth kit- CP-E TMIC- Cp-e catless DP- Magnaflow Cb- CP-e RMM-Autotech Internals- Cobb AP with ATR- JBR short shift kit- Brembo GT big brake kit- Custom fiberglass A pillar gauge pod- Intercooler temp gauge |
![]() Join Date: Dec 2008 Location: Toledo OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 324
| Not Ranked : 0 score Its been proved on this vehicle that it does infact affect your trims.... Correct me if im wrong but even if you clear the o2 in ap, you get another code for it not being there at all. I was troubleshooting a lean at idle issue I had some time back... this was my first troubleshooting procedure (completely removing it). Pretty sure the code that you clear in atr only disables the fact that it may be reading improperly, not the fact that it is absent.
__________________ | CP-E 75 Duro RMM/TMM + TBE | Corksport SR/TI | Forge BPV | Cobb AP- DJ Tuned | NGK Plugs | Hotchkis RSB @ 140% | PTP IM Gasket/TB Coolant Delete + BSD | Autotech FPi | AEM Meth Injection | SU TMIC | JBR SSP + Stage2 OCC |PG Oil Filter Conversion | Toyota Injector Seals | Bizzerko PnP IM | Grimmspeed EBCS | Ingalls ETD | Sonic Tuning S3 Coilovers |Fluids Rotella T6 A lot Rislone Engine Treatment Motorcraft XT-M5-QS(trans) VP Methanol ~Splash of E85~ |
| The Following User Says Thank You to thatsmrgimp2u For This Useful Post: | Vansquish (10-09-2013) |
but for example i had an o2 extender on, in closed loop it would go almost a full point rich for a while until enough exhaust gas reached the sensor, thus it was seeing so little exhaust gas it was compensating by adding fuel because it thought it was running lean, then as soon as enough gas reached the extender it would go lean for a second before settling, took the extender off and this completely stopped. now tell me it doesnt effect closed loop operation. open loop ran perfectly with or without the extender.
__________________ 2007 Mazdaspeed 6 - Ptp SST, Cobb AP, SSP 3.5" Intake, SURE Sidewinder, Autotech HPFP Internals, PTP 2150 psi HPRV, Cp-e Injector Seals, PTP Injector Studs, Jbarone TIG's, VTCS Delete, ETS 3.25" TMIC, M2 Catless Downpipe, Magnaflow Catback Exhaust, MD OCC, Denso ITV 22, H & R springs, Energy Suspension Rear Sway Bar Bushings, Dashhawk, Hawk HPs Pads, Centric Rotors, Street Unit Rear Motor Mount, TWM Stage II Shifter with Solid Bushings and Weighted Shift Knob, Autometer Mechanical Boost Gauge | |
| Not Ranked : 0 score It does affect it to a point.. it thought you still had a cat and was attempting to add fuel to heat it up. If he kept his disconnected completely that wouldn't happen. It would see an open circuit and not add the fuel. Now it would cause other issues like the cel and failed emissions test. But, if that was the case an o2 simulator which blindly just cycles rich and lean would mess up trims and guys wouldn't be able to tune properly yet they have been used since obd2 came out in the later half of 1995.
| Not Ranked : 0 score Ok i reread the posts and I though I read in there someone saying that his car would never enter closed loop if the secondary o2 was removed. On all the vehicles I've ever monitored without cats and with simulators it never prevented it from entering CL. If your point was simply that it affects the fuel trims in CL then I agree because it is trying to attain the correct catalyst temp, I worded the incorrectly. But.. his question was removing it entirely.
![]() Join Date: Jun 2010 Location: li, merrick, new york
Rep Power: 2273 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,757
| Not Ranked : 0 score Secondary o2 sensors never did or will effect fueling. It does not trim anything it just wants to make sure u have a cat and It's doing its job. Some manufactures got smart and if u have a secondary o2 code or detects no cat it pulls timing so u keep it, but u can over ride that with an o2 simulator.
__________________ First 500whp stock block mazdaspeed3 (503whp 423wtq) <3 Tokay. |
(Thread Starter) | Not Ranked : 0 score Hmm...well shit, now I'm not quite sure what to do. Someone above mentioned it affected their CL fueling, but others are saying it doesn't, whats the consensus? I don't want to remove the extender because I know I won't be able to weld in a cat before the sensor. I was thinking of having one welded in the test pipe section just for less smell and noise. How much are O2 simulators and where can you get them? I'll do some googling as well and see what comes up.
| Not Ranked : 0 score @djuosnteisn can you clear this up? I may have misunderstood our conversation about this when we were working on my car.
![]() Join Date: Nov 2010 Location: Rutherfordton, NC
Rep Power: 312 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 236
Groans: 31
Groaned at 28 Times in 15 Posts
| Not Ranked : 0 score Just have a new bung welded in and cap off the extender. Try googling how many not ready codes you can have in your county, and pass emissions. |
| Not Ranked : 0 score It does not effect any fueling , only primary o2 sensors do. That's only there because of the federal mandate to have it for emissions. Other wise it wouldn't exist.
![]() Join Date: Feb 2010 Location: NoVA/ Norfolk
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,285
Groans: 133
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score It had an effect on my car. I ran without it for about 3 or 4 days and the car was running like overall shit and very rich. My trims were all over the place and the exhaust sounded fat. As soon as I got the new sensor and threw it in, my car was instantly hitting my AFRs and the exhaust note had a noticeable difference to it.
__________________ 08.5 CWP MS3 GT PG Intake, TIP | Forge BPV | M2 Catless DP | HKS Catback | Cp-e FMIC| Autotech Internals | Self Tune | Bilstein Shocks | SPC Camber Arms | H&R Springs | Progress RSB | JBR SSP, Bushings, PMM | TWM Shift Knob | TRZ RMM, TMM | TRM C3 17x9| Dunlop Star Spec ZII (245/40) | Matt Damon OCC |
Groans: 60
1) To check for proper operation of the primary cat. 2) To correct calibration drift of the primary wideband O2. All wideband O2's need to be calibrated for time to time(our primary sensor is one), but narrow band sensors are very very accurate at stoich and do not drift, Our ecm compares the signal from the primary and secondary O2 sensor and continually corrects it calibration of the primary.. I have seen the effect first hand. I had a diode installed on the signal of the rear O2 to prevent a MIL for no cat, and within a very short amount of time the ECM reported AFR as read by my scantool showed .4pts richer than the actual AFR as reported by my innovate wideband(installed in my DP and calibrated monthly). When I removed the diode the two wideband outputs matched again (within about 50 miles of driving)...
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks | |
| The Following 4 Users Say Thank You to SSinstaller For This Useful Post: |
| patrick failman ![]() Join Date: Mar 2009
Rep Power: 2905 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,275
Groans: 74
| Not Ranked : 0 score sigh.
__________________ 2012 ingot silver mustang gt w/ 6 speed, 3.73 rear end, bama 93 tune, cat deletes, boss 302 oil cooler, roush cai, dynotech aluminum driveshaft, ford racing strut tower brace, dampers & springs, boss 302 sway bars, gt500 strut mounts, lower control arms & axle backs, j&m adjustable panhard bar, steeda upper control arm & 3 point braces, jlt catch can, barton short shifter & shift bracket |
![]() | | #19 | ![]() |
| Not Ranked : 0 score His issue isnt it reading improperly... Its stuck in his stock downpipe so hes checking to see if he can get away with out it.
![]() | | #20 | ![]() |
__________________ First 500whp stock block mazdaspeed3 (503whp 423wtq) <3 Tokay. | |
![]() | | #21 | ![]() |
Groans: 74
| Not Ranked : 0 score take the dp off, pb blast it, use a 7/8 inch or 22mm closed wrench and tap it with a dead blow hammer. problem solved.
| The Following User Says Thank You to karl-hungus For This Useful Post: | kmac (01-18-2012) |
![]() | | #22 | ![]() |
| Not Ranked : 0 score Id let the PB blast sit on there for a bit, maybe heat up the bung if you can. When i did my install i took them off when they were hot and they came out pretty easy.
| The Following User Says Thank You to thatsmrgimp2u For This Useful Post: | kmac (01-18-2012) |
![]() | | #23 | ![]() |
(Thread Starter) | Not Ranked : 0 score Did that actually, also used a breaker bar and an airgun, but by then the nut had rounded off a bit so it wasn't as effective.
![]() | | #24 | ![]() |
| Not Ranked : 0 score Well like I said it won't hurt anything if you need to drive the car without the rear o2. If it richens it up a little so what.. you can always get a universal o2 sensor... just make sure you get one with the same amount of wires. Use the included diagram and match up the signal/ ground and 2 heater wires to the factory harness, make sure you solder them. If my memory is any good the 2 blacks are heater circuit, white is ground the other is the signal.
![]() | | #25 | ![]() |
Groans: 60
![]() | | #26 | ![]() |
![]() Join Date: Sep 2011 Location: Jacksonville, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 360
| Not Ranked : 0 score The rear O2 does affect fuel trims. There is even a PID in IDS labeled "HO2SB12 fuel trim" or something similar. I can call the tech line tomorrow to ask them if you guys want. To settle it once and for all. Here is a snip from the service highlights manual. Rear HO2S feedback correction: Purpose: Corrects feedback amount according to deterioration of front HO2S and catalytic converter Correction condition • Engine coolant temperature is at set value or more • Engine speed is 500—4,250 rpm • Charging efficiency is 10—80% Correction amount • According to rear HO2S electromotive force→correction Last edited by timjs; 01-18-2012 at 06:02 PM. |
| The Following User Says Thank You to timjs For This Useful Post: | kmac (01-18-2012) |
![]() | | #27 | ![]() |
| Not Ranked : 0 score Your missing the point. He wanted to remove it completely. The extender pulls it out of the exhaust path to try and trick the sensor signal to imitating a cat.. that will cause more fuel to be added since the ecu thinks the cat is too cold. It will not add fuel blindly.. it only adds fuel to maintain the cat temp. It will see an open heater circuit, know the sensor is not connected and not do anything besides turn on the CEL. Please someone show me in writing from Mazda that I'm wrong. I was taught this 9 years ago from GM when they started widely using wideband o2's. I'm only trying to help this guy, I'm not just making this up off the top of my head. I was a Subaru tech, GM Master Tech certified for all platforms and a GM field engineer for 3 years after. I was an ASE L1 master tech at that time but now I work for the government due to a back injury so if things have changed in the past few years I would like to know.
![]() | | #28 | ![]() |
Groans: 60
OP, If you have to drive without the rear O2 for a short while until you can get a replacement, just take it easy and expect poor mileage, but your most likely not going to grenade your motor.. Long term it's a very bad idea.
| The Following User Says Thank You to SSinstaller For This Useful Post: | kmac (01-19-2012) |
![]() | | #29 | ![]() |
| Not Ranked : 0 score If you could call techline and post what they say I'm interested. I was unaware of any current system that allowed for on the fly ecu correction of the wideband from a narrowband secondary. I would like to know what they say would happen to the correction table if it was removed.
![]() | | #30 | ![]() |
| Not Ranked : 0 score I don't see where the argument is. We know that the rear O2 sensor does influence the fuel system. However, if it were removed, I'd expect the PCM to ignore it's input entirely, why? Because there isn't an input to take into account anymore. The MIL would illuminate. Codes will be set. And the PCM will continue to operate normally. There might be a little variance over time from the wideband "drifting" with age..but nothing short term that should mess anything up. Just my thoughts, I haven't actually removed a rear O2 and observed its effect. |
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score Regardless of who is correct, I appreciate all the input. Tomorrow I'm getting an oil change and my snow tires put on and hopefully they'll be able to get the stock sensor out of my dp that way I don't have to pay for a new one. But if its ruined I'll be getting it replaced.
![]() | | #32 | ![]() |
![]() Join Date: Nov 2009 Location: Chicago, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 789
Groaned at 6 Times in 4 Posts
| Not Ranked : 0 score Be happy that it wasn't your primary o2 that got stuck. Costed me 230$ for a new one
__________________ Mazdaspeed3 E85 ~ Sold 333/383 Mazdaspeed6 #10018 TiGrey Forged Internals, PTE5858. 2015' Freektuned on 93Octane 322/337 (stock top mount and BPV) 2016' Freektuned on e85/93 480/444 (maxed out 3bar map sensor) 2017' Freektuned on e85/93 525/497 (maxed out pte5858 @ 35/36psi & fueling) Mazda CX-5 AWD Daily |
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score Oh I was very happy about that. Not to rub it in for everyone who had lots of problems doing this install, but I was almost in shock at how easy it was (except for the stupid bracket attached to the dp) Maybe I'm just lucky.
![]() | | #34 | ![]() |
![]() Join Date: Nov 2010 Location: Kaunas, Lithuania
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 144
| Not Ranked : 0 score guys, sorry to bring back up the old thread, but I have a related question: how does the ECU use the second o2 sensor, if the cat is removed? Wouldn't it throw off the calibration stuff? I want to add a high flow cat to my downpipe, but there is no place for it except after both o2 sensors. |
![]() | | #35 | ![]() |
Nothing has changed since my tune, and if the primary 02 sensor was out of any type of calibration or anything of that nature, it would show in the fuel trims over time. They haven't moved, pretty much at all. All slightly positive of 0 most of the time just like always.
__________________ '06 Mazdaspeed 6 | |
| The Following User Says Thank You to timjs For This Useful Post: | Tokay444 (06-18-2014) |
![]() | | #36 | ![]() |
![]() Join Date: Nov 2010 Location: Manchester, England
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,709
| Not Ranked : 0 score not had a secondary o2 in for about 3k miles now with no issues
__________________ Tuned with by ![]() K1 Rods//Wiseco Pistons//CX Racing FMIC//JBR Widepath Intake//Custom 3" TBE//Grimmspeed EBCS//Forge BPV//JBR SSP//JBR RSB//JBR Side Mounts//ISC-N! coilovers//JBR BSD and Baffle//Sure TIG Set//Sure R3 RMM//KMD Internals//XS Power Exhaust Manifold//P&P Intake Manifold//Fidanza Flywheel//EM Organic Compound Clutch//GTX3071//DVC30 Meth Kit//3 Gauge Pod.....415WHP....so far!! |
| The Following User Says Thank You to skiptowncat For This Useful Post: | Tokay444 (06-18-2014) |
![]() | | #37 | ![]() |
Groans: 793
![]() | | #38 | ![]() |
Groans: 60
Why would you expect the trims change if it's calibration was off? The only way to see the problem is with a calibrated aftermarket wideband installed to compare to the OEM sensor readings. What you will eventually see is the actual AFR drift rich while the OEM sensor continues to show your targeted AFR..
![]() | | #39 | ![]() |
If the primary sensor swayed from actual AFR the fuel trims would show it. Let's say you're burning 14.7 with perfect 0 trims. Fast forward 6 months and you have some level of "deterioration" of the sensor. Now the true 14.7 is read by the sensor as something, let's say leaner. The PCM would correct by richening the mixture until the sensor tells it that it's burning 14.7 again. In reality, you would have a richer than target mixture, and positive fuel trims to show it. It would probably have to be an excessive amount of deterioration to cause this I would imagine, and at that point you would probably have already had other driveability issues and replaced the sensor.
![]() | | #40 | ![]() |
Groans: 60
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/no-secondary-o2-sensor-102543/ | ||||
| loki's logs - Page 16 | This thread | Refback | 07-27-2012 09:39 AM | |
| Secondary O2 sensor | shawn. | MazdaSpeed 3/6 - Turbo Induction | 4 | 01-08-2012 08:14 PM |
| Secondary injectors | cageyvet | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 3 | 02-13-2010 05:36 AM |
| Does secondary o2 (P0421) cause misfire (P0300)? | SonnyBonahoe | MazdaSpeed 3 - Engine, Transmission & Driveline | 18 | 11-24-2009 08:46 AM |
