Like Tree3Likes
 Old 07-23-2010, 02:28 PM   #81
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Yeah, my alkycontrol kit has a low level light as well, which is pretty handy.
The newer kits have also have a pressure sensor in the pump so that you know it is developing pressure, not just being sent power.
 Old 07-23-2010, 02:37 PM   #82
steedspeed's Avatar
Posts: 582   (View Stats)
steedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the world
Originally Posted by BrianGT3076 View Post
coolant is fine, no smoking, no clutch vibes. nothing changed. i didnt even know i knocked till i checked the log
If you didn't hear it then it probably wasn't anything to worry about. We twin turboed my buddies Camaro and he stomped on it for a block and it sounded like hammers. I tried to get him to stop but he stayed in it and blew the pistons to hell. That last knock was very loud lol!
The Horsepower Freaks BMW turbo kit has a feature that cuts the boost level if the methanol shows low/no pressure. That might be a good thing to work out for these cars.
Last edited by steedspeed; 07-23-2010 at 02:37 PM. Reason: MSF Database - Automerged Doublepost
steedspeed is offline   Reply With Quote
 Old 07-23-2010, 03:22 PM   #83
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Not hard at all, you can do it with conventional flow sensors. If anyone is interested Dano did something similar in his wmi setup. Cut's to spring pressure only on over flow and under flow events from the flow sensor. It's a labonte fail safe.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
Dano (07-23-2010), madvillain (07-24-2010), xcoldricex (07-23-2010)
 Old 07-23-2010, 03:25 PM   #84
nyghtryder's Avatar
Posts: 1,903   (View Stats)
nyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the world
looks sweet brian, subbing for the dyno
A Kabar is just a paper weight until it's in the hand of a Marine.
If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground.
COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS
NATOR PA
nyghtryder is offline   Reply With Quote
 Old 07-23-2010, 03:42 PM   #85
steedspeed's Avatar
It's a shame you can't go out and drive it like you stole it. I was really looking forward to hearing how it performs.
Our lesson for today is "patience".
Screw that! I wanna know now!!!! NOW DAMMNIT!!!!!
Lol!
The Following User Says Thank You to steedspeed For This Useful Post:
 Old 07-23-2010, 04:11 PM   #86
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Failsafe controller and boost cut solenoid FTW!
Truely a "set it and forget it" setup.
Labonte WMI Install How-to w failsafe
 Old 07-23-2010, 04:14 PM   #87
MattJackson86's Avatar
Posts: 1,407   (View Stats)
If 5KR was bad I would have been screwed a long time ago. For the longest time I had bad knock (3-6). Finally got it under control.
Good luck.
MattJackson86 is offline   Reply With Quote
The Following User Says Thank You to MattJackson86 For This Useful Post:
BrianZX10R (07-23-2010)
 Old 07-23-2010, 11:28 PM   #88
steedspeed's Avatar
How does it feel on the road Brian? Fast spool? Later? Better top end?
 Old 07-23-2010, 11:29 PM   #89
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
yeah didn't you get your dump tube fabbed already
 Old 07-24-2010, 01:16 AM   #90
BrianZX10R's Avatar
Posts: 1,163   (View Stats)
BrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the world
Groans: 88
so far it feels amazing leen. i think it will be better then my tubular. but i have not boosted 20 psi like i usually run. i am only at 16 and so i dont have a good comparison yet, and i wont till i get meth and fix my meth leak witch was the reason i was empty. my self sealing bulk head was leaking on my meth tank. its leaking from the quick connect.
1995 honda civic. 1.6L slow
2007 Kawasaki ZX10r
BrianZX10R is offline   Reply With Quote
 Old 07-24-2010, 09:19 AM   #91
steedspeed's Avatar
Sounds good!
I can't wait to hear how it is on a full 20psi pull.
mspeed313 likes this.
 Old 07-24-2010, 10:00 AM   #92
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
Groaned at 9 Times in 9 Posts
so when do you think you'll make another batch (of the IWG manis), steedspeed?
Sacrilicious is offline   Reply With Quote
 Old 07-24-2010, 10:20 AM   #93
BrianZX10R's Avatar
Groans: 88
Smile
just pulled all spark plugs and checked them and they all look the same and new. anyway here is pics with the dump tube made. these will also be added to the main post.
2007 Kawasaki ZX10r
The Following 2 Users Say Thank You to BrianZX10R For This Useful Post:
AJ713 (07-25-2010), jayspeed3 (07-25-2010)
 Old 07-24-2010, 10:23 AM   #94
mazdaspeed619sd's Avatar
Posts: 170   (View Stats)
mazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud of
does the screamer pipe hook back up to the dp? or is it a dump tube?
06 MS6 Black Mica
AWD BROTHERS SHALL UNITE!
Boys love straight lines.— Men love curves.— =)— Canyon/Circuit FTW!—
mazdaspeed619sd is offline   Reply With Quote
 Old 07-24-2010, 10:25 AM   #95
BrianZX10R's Avatar
Groans: 88
its a dump. externally gated
2007 Kawasaki ZX10r
 Old 07-24-2010, 10:45 AM   #96
steedspeed's Avatar
I won't be able to make any until I get moved into the new shop. Probably have some done in about 8 weeks as long as the dyno is good.
 Old 07-24-2010, 10:50 AM   #97
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
dayum. thats a nice tube. welded a bracket on it and everything
'08 CWP MS3 w/ T3 3071r
BrianZX10R (07-24-2010)
 Old 07-24-2010, 11:16 AM   #98
SRTie4k's Avatar
Posts: 1,715   (View Stats)
SRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the world
Groaned at 68 Times in 44 Posts
i have no meth so cant drive till i find somone who sells VP m1 meth in 5 gallon.
I need meth asap
More expensive than buying pure meth by the gallon, but its a good alternative when you run out and need some.
08.5 Mazdaspeed 3 - Cobb AP w/ Boost Targetting at 17psi, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, CP-E RMM, Bilstein Sports, Cobb Springs, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's
253WHP/274WTQ on a Mustang Dyno before tune, 282WHP/318WTQ in VD after tune
97 Suzuki TL1000S Naked - LeoVince Slip-Ons, K&N Filter, PCII, fully custom naked setup
89 Kawasaki 650SX Stand-Up Jetski
SRTie4k is offline   Reply With Quote
The Following 3 Users Say Thank You to SRTie4k For This Useful Post:
breakfstincluded (08-21-2011), BrianZX10R (07-24-2010), madvillain (07-24-2010)
 Old 07-24-2010, 12:05 PM   #99
pewpew
awesome! make sure you post a big announcement here so that we can all start ordering...
 Old 07-24-2010, 01:14 PM   #100
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
Troof, I used Heet for a while too and it worked great.
That dump tube is very nicely done too. Is it VTA or is it re-circed into the downpipe?
 Old 07-24-2010, 02:01 PM   #101
MPSdriver's Avatar
Posts: 136   (View Stats)
MPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the world
carry on, good stuff ahead I hope
MPSdriver is offline   Reply With Quote
The Following User Says Thank You to MPSdriver For This Useful Post:
 Old 07-24-2010, 05:38 PM   #102
madvillain's Avatar
Groans: 78
D'oh!
 Old 07-25-2010, 12:34 PM   #103
steedspeed's Avatar
Still can't find any Methanol?
 Old 07-25-2010, 12:38 PM   #104
BrianZX10R's Avatar
Groans: 88
i found a place local to my house. Its not VP m1 but its 99.99% pure or whatever so its the same shit. i wont have time to pick it up till friday or maybe my Gf will get it for me.
i dont get my self sealing bulk head for my meth tank till thursday so thursday night at the latest my car will be up and running for good hopefully.
2007 Kawasaki ZX10r
 Old 07-25-2010, 01:13 PM   #105
ILL3ST
xcoldricex's Avatar
so when did you schedule your dyno time?
 Old 07-25-2010, 02:57 PM   #106
BrianZX10R's Avatar
Groans: 88
i wont schedule a dyno until the weather will give me a 60 degree morning. just like all my other dynoes i need to keep things consistent.
2007 Kawasaki ZX10r
madvillain (07-25-2010), Sacrilicious (07-25-2010)
 Old 07-25-2010, 07:28 PM   #107
pewpew
no point in getting inconsistent numbers...it would be interesting to hear about how much the tune had to be tweaked for the mani, though.
 Old 07-25-2010, 08:47 PM   #108
BrianZX10R's Avatar
Groans: 88
i dont think the tune will need to be tweaked at all. as long as i get the same peak boost it will be the same
2007 Kawasaki ZX10r
The Following User Says Thank You to BrianZX10R For This Useful Post:
Sacrilicious (07-26-2010)
 Old 07-25-2010, 08:57 PM   #109
ILL3ST
xcoldricex's Avatar
since we don't get a dyno for awhile, make vids to hold us over until then
 Old 07-25-2010, 09:50 PM   #110
jmustang68's Avatar
Posts: 113   (View Stats)
jmustang68 has much to be proud ofjmustang68 has much to be proud ofjmustang68 has much to be proud ofjmustang68 has much to be proud ofjmustang68 has much to be proud ofjmustang68 has much to be proud ofjmustang68 has much to be proud ofjmustang68 has much to be proud ofjmustang68 has much to be proud ofjmustang68 has much to be proud of
^ +1
That Mani looks really clean! Can't wait so see some numbers.
Would like some vid of the extra noise as the EWG is venting.
09 CWP MS3
- Corksport SRI/Turbo Inlet,RMM Inserts, TMIC, LED Fogs and Interior
- Cobb AP (91+ SRI Tune) -RallyArmor UR Flaps - Stealthbox and 600Watt MTX Amp
- JBarone Short Shift Plate - Forge V2 BPV - Blue Calipers via G2
jmustang68 is offline   Reply With Quote
 Old 07-25-2010, 10:54 PM   #111
BrianZX10R's Avatar
Groans: 88
2007 Kawasaki ZX10r
 Old 07-25-2010, 10:58 PM   #112
madvillain's Avatar
Groans: 78
A NEW video, Brian. (=
kilik2 (07-27-2010)
 Old 07-25-2010, 11:00 PM   #113
PunjabiPlaya's Avatar
Posts: 5,131   (View Stats)
Groans: 131
nice noise, gorgeous roads
 Old 07-26-2010, 11:14 AM   #114
Captain
Not necessarily man. Our cars care about airflow, not boost. If you "up" the boost and hit higher loads (cause the mani flows better), then there is a chance you will need another tune.
My guess is it'll be fine, but i'm just saying, if the mani flows better, you'll be in "new" load territory, which wasn't ever specifically tuned.
www.permtuning.com
xcoldricex (07-26-2010)
 Old 07-26-2010, 05:20 PM   #115
steedspeed's Avatar
I agree. If it boosts sooner then you need more fuel sooner too and if it revs out higher and at more consistent boost level then you need to tune for that too. Either way you might as well get the most you can from the new setup. If it flows better then EGTs should drop allowing more timing for instance.
djuosnteisn (07-27-2010)
 Old 07-26-2010, 10:52 PM   #116
SRTie4k's Avatar
It sounds like there's a stampede of horses running beside your car at the end.
 Old 07-27-2010, 10:11 AM   #117
Captain
That's detonation...
HA..... /bad joke. It's probably Budweiser horses.
www.permtuning.com
NJSPEED3 (08-01-2010)
 Old 07-27-2010, 10:12 AM   #118
pewpew
say, what kinda mani do you use, dj?
The Following User Says Thank You to Sacrilicious For This Useful Post:
 Old 07-27-2010, 11:41 AM   #119
Captain
I have a one off DCR manifold. Tubular, 2" runners, pretty close to stock location. Flows well, but not ideal. I want a top mount. Probably buy that steedspeed top mount soon.
www.permtuning.com
 Old 07-27-2010, 12:48 PM   #120
pewpew
dang...too bad you had so much trouble fitting it...=/
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/new-steedspeed-turbo-manifold-installed-61481/
Club Probe/MX6 Québec • Afficher le sujet - mazdaspeed6 vs toyota tacoma trd (supercharged) This thread Refback 07-24-2010 04:53 AM
Gauging interest: SteedSpeed Turbo Manifold subparpunk03 MazdaSpeed 3/6 - Turbo Induction 737 07-14-2010 09:41 PM
steedspeed manifold ebay ms3boost MazdaSpeed 3/6 - Turbo Induction 4 05-25-2009 02:31 PM
High strength studs for turbo (manifold to head and manifold to turbo) bnoon MazdaSpeed 3/6 - Turbo Induction 4 03-11-2009 10:26 PM
Page generated in 0.57894 seconds with 36 queries
