Like Tree27Likes
 Old 06-21-2012, 05:35 AM   #1
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
Default Lets talk about Bigger Throttle Bodies
so im slowly putting all of the pieces together to make the most EFFICIENT power i can out of my setup. Being that Scotts IM is the next and pretty much last part i need to complete my setup i figured why not upgrade the TB at the same time.
its been said that a 60mm (stock size) can take you north of 600-800whp. Im not sure how (or why) people would use a 2" (usable area) TB to achieve that but its only good for about 525CFM when tested at NA levels (aka no boost). hopefully @06Speed6 can chime in here.
now with a turbo you can always PUSH through restrictions to gain more power but you will have diminishing returns and are just hurting the VE of your engine/setup. Regardless of the numbers the stock TB wont continue to make efficient WHP above 450-500.
so the thing about TB's is that the way the TPS and ECU correlate is VERY finicky and you must match the voltage ranges perfectly or else you will throw codes and the ECU freaks out.
this is what our stock (MS6, havent verified for the 3) voltage correlation looks like:
its basically an inverse relationship between TPS1 and TPS2 from 0.5 to 4.5V. This is done as sort of a "check" with one another to make sure the throttle plate is at the correct angle and everytime you key on the TB goes through a startup check to ensure this.
now theres 6 wires on our TB, 2 for the motor itself, 1 for TPS1 and TPS2, 5v reference, and ground as u can see here.
now AFAIK @Erich is running the dodge hemi TB which is nearly identical to ours in voltage correlation and wiring configuration but uses a different bolt pattern and connector. its 80mm which is just shy of 3" worth of usable area. some tests that i have read online said this is good for 900-1100CFM worth of air on NA applications (aka even before boost is applied).
here is what i dug up about the 2005+ hemi 5.7L TB.
5.7L 6.1L 6.4L Hemi V8 Throttle Bodies - The Fastman
Dodge Part #53032801AC, currently about ~$130 brand new
it looks like the dodge TB goes from 0.3 to 4.7v which is still ok because our ECU's codes only get thrown below 0.2v and above 4.85/4.9v depending on which TPS it is.
now the shitty part is i have not been able to locate a pigtail/harness for this TB ANYWHERE. i have searched high and low and other then cutting one off at a junk yard we're SOL as far as getting this to be a clean install. the VW MK4 VR6 uses an almost identical connector stock except you just need to shave one little part off or something. they have apparently been using these TB's for years for their BT cars.
does anyone else have anything to add to this? @SPEED6 KILLAH? research you have done? for all you experts asking why we just cant use the v6/CX-9 TB is because their voltage correlation is completely different as seen below. AFAIK @kmac is running this TB but he had to hack the shit out of the TPS sensors to get it to work and said it wasent worth it.
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
The Following 49 Users Say Thank You to superskaterxes For This Useful Post:
06Speed6 (06-21-2012), 6oost3d (06-22-2012), ABolewski (05-06-2013), Alejo_NIN (07-16-2012), Alpha (06-21-2012), anavrinIV (02-02-2013), AZSPEED3 (06-21-2012), BobbleHead (07-14-2012), Boosted Beluga (06-21-2012), ccspeed3 (06-21-2012), charlesfist (07-23-2012), cld12pk2go (06-22-2012), dan7225 (06-21-2012), Dano (06-21-2012), darkcherry (06-21-2012), Dash08 (06-22-2012), djuosnteisn (06-21-2012), Dmurray06 (06-21-2012), Don06speed6 (06-21-2012), doubleflusher (06-21-2012), dougefresh_ (06-22-2012), Easter Bunny (06-21-2012), EdgeAutosport.com (06-21-2012), El_Diablo (09-26-2013), helmetface (06-21-2012), J'sSpeed3 (06-21-2012), JacksonMS30 (07-03-2012), jmhinkle (12-13-2012), jreiden1 (06-14-2013), Justspeed (10-02-2013), kritz (06-21-2012), Mchart (06-23-2012), Menace1 (01-31-2013), Micha (05-19-2013), mrmonk7663 (06-21-2012), MS3-a(sore)ASS-rex (06-21-2012), nswartz19 (06-22-2012), redmnsterut (06-21-2012), rigor (07-03-2012), SarcasticOne (01-20-2013), silentwolf8 (06-25-2012), SilverDemon (06-21-2012), SPEED6 KILLAH (06-21-2012), TiGraySpeed6 (06-21-2012), Tomas (12-18-2012), trf5000 (06-21-2012), TWOptSL0W (07-04-2012), uncorked11 (05-29-2013), xPEPEx (06-26-2012)
 Old 06-21-2012, 05:55 AM   #2
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Good research. This effectively kills the cx9 72mm option. The hemi option is still in play, but at almost 3" it is somewhat "large" for mild turbos it would seem, bnr, 2871, etc. Surely there has to be other TBs in a 70mm range that could work.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
The Following User Says Thank You to mrmonk7663 For This Useful Post:
superskaterxes (06-21-2012)
 Old 06-21-2012, 06:12 AM   #3
SilverDemon's Avatar
Posts: 3,034   (View Stats)
*sniff.....sniff*
Hmmmm I smell some custom work that needs to be started.....
kritz likes this.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 9 Users Say Thank You to SilverDemon For This Useful Post:
06Speed6 (06-21-2012), bcmurphy87 (06-21-2012), Boosted Beluga (06-21-2012), dougefresh_ (06-22-2012), i8urgti (07-13-2012), JacksonMS30 (07-03-2012), Roddiy (05-23-2013), superskaterxes (06-21-2012), TWOptSL0W (07-04-2012)
 Old 06-21-2012, 06:18 AM   #4
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
So many fucking numbers!
NATOR PA
The Following 5 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
Domino81 (06-22-2012), dougefresh_ (06-22-2012), jack_hammer (06-21-2012), lilred (06-21-2012), SilverDemon (06-21-2012)
 Old 06-21-2012, 07:25 AM   #5
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
subscribes
tries to look intelligent
fails, but wants to read along anyway....
340hp / 371tq
The Following 8 Users Say Thank You to TiGraySpeed6 For This Useful Post:
amoosenamedhank (06-22-2012), bcmurphy87 (06-21-2012), dougefresh_ (06-22-2012), jack_hammer (06-21-2012), lilred (06-21-2012), MS3inDC (02-05-2013), redmnsterut (06-21-2012), xI Leveler Ix (07-20-2012)
 Old 06-21-2012, 07:46 AM   #6
@kmac is successfully running a bigger throttle body as well.
InFeXIoN (06-21-2012), kmac (06-23-2012)
 Old 06-21-2012, 07:47 AM   #7
Don06speed6's Avatar
Posts: 2,492   (View Stats)
Groans: 62
In for the epicness to follow.
Cobb AP(FREEK TUNED)/CS TBE/SURE AEROS/CPE TIH/ ITV 22/SU RMM/KMD INTERNALS/SURE DREADNAUGHT/JUGGERNAUGHT/WHITELINE RSB/SURE ANCHORS/SURE COUNTERWEIGHT/SURE SHORTCUT/JBR HEAVY KNOB/JBR EGR DELETE/SPC BALL JOINTS/CENTRIC BLANKS/HPS PADS/BNOON BOLT/ALTERED CUSTOMS FMIC/TURBO XS RFL
 Old 06-21-2012, 07:58 AM   #8
InFeXIoN's Avatar
Posts: 1,159   (View Stats)
InFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the world
Groaned at 42 Times in 15 Posts
But as stated not worth the headaches to get it to work. =(
GTX3071R EWG, DNP Tubular Manifold, SSP Ported/VTCS deleted intake manifold, DCR VVT Actuator, CP-E FMIC, Cobb AP, JBR 3.5" WP Intake ||| JBR 80 Duro RMM, JBR 80 Duro PSMM ||| CNT Racing Catless full 3" DP/TP, Speed Daddy 3" CBE ||| AEM Water/Methanol Kit, Autotech FP Internals, PTP Inj Seals, Synapse Engineering Bypass Valve, Matt Jackson map sensor harness, 3 Bar map sensor, Grimmspeed 3-port EBCS, NGK 1 Step Colder Plugs ||| Sure AGS 621G, Sure Shortcut, JBR Solid Base Bushings and Weight ||| AMR Engineering Coilovers, JBR Rear Sway, JBR Rear Camber Arms, XXR 527 18x8.75 +35 Chromium Black ||| CP-E Tow Plate, Rotella T6, FoMoCo XT-M5-QS, JBR OCC, JBR EGR Delete, JBR TB Gasket, JBR TIG and Coolant Bypass, EBC Redstuff.
Build Complete!!!!
InFeXIoN is offline   Reply With Quote
 Old 06-21-2012, 08:01 AM   #9
Liquid3Speed's Avatar
Posts: 110   (View Stats)
Liquid3Speed has a brilliant futureLiquid3Speed has a brilliant futureLiquid3Speed has a brilliant futureLiquid3Speed has a brilliant futureLiquid3Speed has a brilliant futureLiquid3Speed has a brilliant futureLiquid3Speed has a brilliant futureLiquid3Speed has a brilliant futureLiquid3Speed has a brilliant futureLiquid3Speed has a brilliant futureLiquid3Speed has a brilliant future
As for the pig tail, why not just go to a chrysler dealer and buy the connector body, seals, and terminals, then make the "pigtail"? It would only take 10 minutes to make.
Cobb AP // Cobb SRI // Cobb TIP // Autotech Internals // Synapse BPV // JBR 88a // H&R Springs
Liquid3Speed is offline   Reply With Quote
 Old 06-21-2012, 08:23 AM   #10
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
Neutral  +1 score
I have been do some research come across a honda civic si TB that skunk2 make 72mm that should bolt on and work. Now the connector sytle that on the skunk2 mazda use to used on there 03 to 05 mazda 6 2.3 before swtiching over to a new style connector. If we can contact skunk2 to make it so that all we do just swap the TP module on the TB over to theirs..
http://cms.skunk2.com/id/480/Drive-B...Throttle-Body/
I also have tooking a part DISI TB to see how it looks inside here are some picture..
TP module so the two bottom pin are for the motor and the middle hole is to apply support from a center pin on the throttle body and the top read the tp position
TP adjust screw reference
reference screw for self check when trun on and off the car and of always go through a self check.. That is the loud clicking noise when the car off for about a couple sec and key on and engine off..
Now on this gear it has magnets that the TP module picks up
86AmishMs3 likes this.
SPEED6 KILLAH is offline   Reply With Quote
The Following 29 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
06Speed6 (06-21-2012), 6oost3d (06-22-2012), 86AmishMs3 (06-22-2012), Boosted Beluga (06-21-2012), charlesfist (07-23-2012), darkcherry (06-21-2012), Dash08 (06-22-2012), djuosnteisn (06-21-2012), Don06speed6 (06-21-2012), doubleflusher (06-21-2012), dougefresh_ (06-22-2012), Easter Bunny (06-21-2012), El_Diablo (09-26-2013), Erich (06-21-2012), Ingle (06-21-2012), JacksonMS30 (07-03-2012), kritz (06-21-2012), Mchart (06-23-2012), Micha (05-19-2013), ms3blackmica (07-22-2013), MS3inDC (02-05-2013), NJSPEED3 (07-12-2012), Roddiy (05-23-2013), SilverDemon (06-21-2012), TiGraySpeed6 (06-21-2012), Tomas (07-23-2012), TWOptSL0W (07-04-2012), wolly6973 (06-23-2012), xPEPEx (06-26-2012)
 Old 06-21-2012, 08:35 AM   #11
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
Potentially dumb question: why not just use a ported tb? Not a big enough difference?
Sent from my LG-MS690 using Tapatalk 2
it's fun to do bad things
 Old 06-21-2012, 08:40 AM   #12
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
I have a Grimmspeed ported TB and it's only a minor enlargement.
Like the jump from Asian to white man's penis.
What we really want is a black man's penis sized TB.
I'm just trying to put this in a context that most members will understand.
Beanfab / Tuned by Nishan
The Following 40 Users Say Thank You to doubleflusher For This Useful Post:
06Speed6 (06-21-2012), ABolewski (05-06-2013), AZSPEED3 (06-21-2012), bcmurphy87 (06-21-2012), BMON3YZOOMIN (06-23-2012), BrianB6 (06-21-2012), charlesfist (07-23-2012), daafisch (06-21-2012), Dano (06-21-2012), Dash08 (06-22-2012), Domino81 (06-22-2012), Don06speed6 (06-21-2012), dougefresh_ (06-22-2012), Easter Bunny (06-21-2012), El_Diablo (09-26-2013), Erich (06-21-2012), faeker (06-26-2012), Ingle (06-21-2012), JacksonMS30 (07-03-2012), jack_hammer (06-21-2012), kritz (06-21-2012), laxplayermjd (06-21-2012), lilred (06-21-2012), Mchart (06-23-2012), Micha (05-19-2013), Monotonous ONE (06-21-2012), nighthawk358 (06-22-2012), NJSPEED3 (07-12-2012), Prediluted (07-19-2012), qtrmile beast (06-21-2012), radioflyer (06-21-2012), Roddiy (05-23-2013), Sid3wayS (06-22-2012), silentwolf8 (06-25-2012), silvapain (06-21-2012), SilverDemon (06-21-2012), TWOptSL0W (07-04-2012), wolly6973 (06-23-2012), xdm88 (06-26-2012), xPEPEx (06-26-2012)
The Following User Says NO Thank You to doubleflusher For This Un-useful Post:
dooderek (06-22-2012)
 Old 06-21-2012, 09:08 AM   #13
Were they unable to port it further? I assume the remachined the throttle plate?
Another thing to consider. If the ECU uses the throttle position to determine tip-in enrichments and idle which it does at least to some extent, changing the size dramatically will affect driveability and you may see the car behaving more abruptly during transitions. I would get in touch with COBB and ask about tip in enrichment tables as these will come into play here.
dougefresh_ (06-22-2012), TiGraySpeed6 (06-21-2012)
 Old 06-21-2012, 09:15 AM   #14
Here is a question for everyone (I am probably off on this, but hear me out)
What is the largest size outlet on the compressor side of everyone's turbo?
What is the largest size I/C piping that most people are running?
Am I wrong in thinking that if I increase the size of the TB, that it will not make much of a difference, since the maximum amount of air can only pass through the smallest point of the intake system?
I really do not have much in the way of experience in exactly how this will pan out, since most people are running a turbo that has, lets say a 2.5" outlet, along with 2.5" I/C piping.
Something to think about before we jump into the bigger is always better idea.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 6 Users Say Thank You to SilverDemon For This Useful Post:
06Speed6 (06-21-2012), Boosted Beluga (06-21-2012), charlesfist (07-23-2012), doubleflusher (06-21-2012), dougefresh_ (06-22-2012), Easter Bunny (06-21-2012)
 Old 06-21-2012, 09:16 AM   #15
Groans: 1,443
Yes.
They also replaced the bolts that hold the plate to the shaft. They have smaller heads.
People can replace the bolts on their own, as it's a fairly simple procedure.
 Old 06-21-2012, 09:45 AM   #16
Must Have Teh 10's!
you have part numbers? ive never heard of doing this....................
 Old 06-21-2012, 10:06 AM   #17
bcmurphy87's Avatar
Posts: 1,435   (View Stats)
So after readin this i came to the conclusion that the hemi should be more than enough for us? Im not the most critical thinker here, but i know i love POWA.
06 Speed6 GT- Sold
 Old 06-21-2012, 10:06 AM   #18
Must Have Teh 10's!
AFAIK the turbo outlet is negligent cause its part of the "source". obvi garrett isent going to design a turbo outlet that is too small for the wheel inside.
here's what their turbo tech says about IC piping
Charge Tubing
The duct diameter should be sized with the capability to flow approximately 200 - 300 ft/sec. Selecting a flow diameter less than the calculated value results in the flow pressure dropping due to the restricted flow area. If the diameter is instead increased above the calculated value, the cooling flow expands to fill the larger diameter, which slows the transient response.
For bends in the tubing, a good design standard is to size the bend radius such that it is 1.5 times greater than the tubing diameter.
The flow area must be free of restrictive elements such as sharp transitions in size or configuration.
For our example:
Tubing Diameter: velocity of 200 - 300 ft/sec is desirable. Too small a diameter will increase pressure drop, too large can slow transient response.
Velocity (ft/min) = Volumetric Flow rate (CFM) / Area (ft2)
for my estimated 915CFM im going to need 3-3.25" IC piping to stay in that 200-300FPS range. now my coldside is 3" and ive always heard you do a larger cold side then hot but im not sure why lol (wasent the reason behind me doing it).
i found this fancy chart online that references CFM to air speed. apparently after 0.4 Mach air becomes turbulent so you want to avoid that. it looks like 2.5" piping can still support 900 CFM but of course its at the top of the range for smooth flow.
2" piping
1.57 x 2 = 3.14 sq in
300 cfm = 156 mph = 0.20 mach
400 cfm = 208 mph = 0.27 mach
500 cfm = 261 mph = 0.34 mach
585 cfm max = 304 mph = 0.40 mach
2.25" piping
3.9740625 sq in = 1.98703125 x 2
300 cfm = 123 mph = 0.16 mach
400 cfm = 164 mph = 0.21 mach
500 cfm = 205 mph = 0.26 mach
600 cfm = 247 mph = 0.32 mach
700 cfm = 288 mph = 0.37 mach
740 cfm max = 304 mph = 0.40 mach
2.5" piping
4.90625 sq in = 2.453125 x 2
300 cfm = 100 mph = 0.13 mach
400 cfm = 133 mph = 0.17 mach
500 cfm = 166 mph = 0.21 mach
600 cfm = 200 mph = 0.26 mach
700 cfm = 233 mph = 0.30 mach
800 cfm = 266 mph = 0.34 mach
900 cfm = 300 mph = 0.39 mach
913 cfm max = 304 mph = 0.40 mach
2.75" piping
5.9365625 sq in = 2.96828125 x 2
300 cfm = 82 mph = 0.10 mach
400 cfm = 110 mph = 0.14 mach
500 cfm = 137 mph = 0.17 mach
600 cfm = 165 mph = 0.21 mach
700 cfm = 192 mph = 0.25 mach
800 cfm = 220 mph = 0.28 mach
900 cfm = 248 mph = 0.32 mach
1000 cfm = 275 mph = 0.36 mach
1100 cfm max = 303 mph = 0.40 mach
3.0" piping
7.065 sq in = 3.5325 x 2
300 cfm = 69 mph = 0.09 mach
400 cfm = 92 mph = 0.12 mach
500 cfm = 115 mph = 0.15 mach
600 cfm = 138 mph = 0.18 mach
700 cfm = 162 mph = 0.21 mach
800 cfm = 185 mph = 0.24 mach
900 cfm = 208 mph = 0.27 mach
1000 cfm = 231 mph = 0.30 mach
1100 cfm = 254 cfm = 0.33 mach
1200 cfm = 277 mph = 0.36 mach
1300 cfm max= 301 mph = 0.39 mach
and if the stock TB can only support 525CFM then it will always become a restriction past that even if more boost is added. just doesent make sense to put a restriction anywhere in the system if u can help it.
P.S. lex brings up a good point about the tip-in tables. We should def check with @Cobb Tuning and @David@COBB about this =D
The Following 16 Users Say Thank You to superskaterxes For This Useful Post:
06Speed6 (06-21-2012), bcmurphy87 (06-21-2012), Dano (06-21-2012), doubleflusher (06-21-2012), dougefresh_ (06-22-2012), El_Diablo (09-26-2013), Ingle (06-21-2012), JacksonMS30 (07-03-2012), Micha (05-19-2013), NJSPEED3 (07-12-2012), silvapain (06-21-2012), SilverDemon (06-21-2012), SPEED6 KILLAH (06-21-2012), TiGraySpeed6 (06-21-2012), TWOptSL0W (07-04-2012), wolly6973 (06-23-2012)
 Old 06-21-2012, 10:09 AM   #19
bcmurphy87's Avatar
We have an AWFUL lot of chevys in the local yards around here and the pull-a-parts. Good chance i could score a few. Perks of living in the dirty south where rednecks and gansta ride chevys.
No clue what i need to get though what year make and models work for this?
06 Speed6 GT- Sold
The Following User Says Thank You to bcmurphy87 For This Useful Post:
 Old 06-21-2012, 10:09 AM   #20
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
Sliverdemon has a point.
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 06-21-2012, 10:11 AM   #21
bcmurphy87's Avatar
My cold side is now almost complete 3.5 for the blow thru and i will be adding the 3in section for the 5th port so it seems it should already out flow the stock TB correct?
06 Speed6 GT- Sold
 Old 06-21-2012, 10:16 AM   #22
Must Have Teh 10's!
AFAIK its any dodge 5.7/6.1L hemi from 2005+, so like durango/charger/ram/dakota
 Old 06-21-2012, 10:34 AM   #23
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Restrictions are cumulative. So it never hurts to remove one, even if there are still other's up or down stream. It'll at least remove that one contribution to pressure drop and restriction.
Key point is to identify the "largest restriction" and address it first... otherwise there are diminished returns. Kinda like how the k04 becomes the biggest restriction at a certain point, and every bolt on in the world won't make much of a difference in power... only lots of octane and very aggressive tunes.
Good shit Ant. Thanks for combining all the links and stuff in one concise thread
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
Last edited by djuosnteisn; 06-21-2012 at 10:34 AM. Reason: MSF Database - Automerged Doublepost
The Following 16 Users Say Thank You to djuosnteisn For This Useful Post:
06Speed6 (06-21-2012), 86AmishMs3 (06-22-2012), charlesfist (07-23-2012), doubleflusher (06-21-2012), dougefresh_ (06-22-2012), El_Diablo (09-26-2013), Erich (06-21-2012), JacksonMS30 (07-03-2012), NJSPEED3 (07-12-2012), Roddiy (05-23-2013), SilverDemon (06-21-2012), SPEED6 KILLAH (06-21-2012), superskaterxes (06-21-2012), TiGraySpeed6 (06-21-2012), uncorked11 (06-21-2012), wolly6973 (06-23-2012)
 Old 06-21-2012, 10:35 AM   #24
Thanks for the charts skates.. I think there is something I/we are missing. Going by the references you supplied us with, it would stand to reason that 99% of the I/C kits that are sold are of the incorrect size on the cold side (at least for the BT applications). Maybe I need to re-evaluate my I/C set up to really understand what needs to happen.
Much more brainstorming in my future!! hahaha
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
06Speed6 (06-21-2012), Boosted Beluga (06-21-2012), doubleflusher (06-21-2012), dougefresh_ (06-22-2012), NJSPEED3 (07-12-2012), superskaterxes (06-21-2012)
 Old 06-21-2012, 10:43 AM   #25
The Panda's Avatar
Posts: 1,229   (View Stats)
The Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the world
Groaned at 8 Times in 7 Posts
Im going to dig in this as well...
2011 BLACK MS3
ZZB on GT3076 Rebuild in progress
The Panda is offline   Reply With Quote
 Old 06-21-2012, 10:48 AM   #26
Here is the part number for the pigtail harness connector
user1260 likes this.
The Following 5 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
06Speed6 (06-21-2012), doubleflusher (06-21-2012), jreiden1 (06-14-2013), Tomas (07-23-2012), TWOptSL0W (07-04-2012)
 Old 06-21-2012, 10:52 AM   #27
708
Erich's Avatar
Posts: 4,274   (View Stats)
I am not using the HEMI throttle body. Mine is off the 3.6 liter Jeep (also challenger, avenger, chrysler 200, etc.) and is part number 05184349ac. I believe the opening is 80mm and it tapers to 74mm at the plate.
The Following 6 Users Say Thank You to Erich For This Useful Post:
06Speed6 (06-21-2012), dougefresh_ (06-22-2012), El_Diablo (09-26-2013), jreiden1 (06-14-2013), Roddiy (05-23-2013), wolly6973 (06-23-2012)
 Old 06-21-2012, 10:55 AM   #28
Must Have Teh 10's!
thanks for clarifying!
do u mean this one?
3.6L V6 Throttle Bodies - The Fastman
 Old 06-21-2012, 11:00 AM   #29
Captain
I just wanna throw my $.02 out there on the CFM stuff.
CFM is NOT = airflow. CFM is purely defined by the displacement of the motor, volumetric efficiency, and rpm.
Once you define things like the fluid (air), temperature, pressure (boost), etc of the medium... it becomes a mass flow (like g/s or lb/min).
The "CFM" in ant's above post are more likely airflows (dunno bout units)... considering they increased with higher boost. Real CFM won't change with boost, only the airflow will.
www.permtuning.com
The Following 9 Users Say Thank You to djuosnteisn For This Useful Post:
06Speed6 (06-21-2012), charlesfist (07-23-2012), doubleflusher (06-21-2012), dougefresh_ (06-22-2012), Erich (06-21-2012), MarkyMark (06-21-2012), phate (06-21-2012), rfinkle2 (06-21-2012), wolly6973 (06-23-2012)
 Old 06-21-2012, 11:03 AM   #30
For the people who dont wanna go big can get a 66mm some one just need to make a spacer to center it out
The Following 13 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
06Speed6 (06-21-2012), charlesfist (07-23-2012), djuosnteisn (06-21-2012), doubleflusher (06-21-2012), dougefresh_ (06-22-2012), El_Diablo (09-26-2013), Erich (06-21-2012), JacksonMS30 (07-03-2012), kritz (06-21-2012), mrmonk7663 (06-21-2012), NJSPEED3 (07-12-2012), rfinkle2 (06-21-2012), SilverDemon (06-21-2012)
 Old 06-21-2012, 11:05 AM   #31
POWERED BY POLSKA
themytb's Avatar
Posts: 762   (View Stats)
Groans: 38
Damn it, I was all excited because I had something smart to say. You beat me to it haha.
25%E85FREEKPERMED
The Following User Says Thank You to themytb For This Useful Post:
 Old 06-21-2012, 11:27 AM   #32
708
Erich's Avatar
do u mean this one?
No part number associated with that one so I can't say for sure. Just went out and took a picture of mine and measured it. Sorry for the crappy picture... trying to hit the iPhone soft button while holding it one handed at a weird angle while trying to hold the IC piping out of the way with the other hand was a pain. I Measured 79mm at the entrance, but it is likely 80, again a function of trying to get the calipers into an odd spot. (Wrong information.)
Edit: I was wrong. Not 80 74. Was in a hurry when I took the measurement and not paying close enough attention. My TB is in fact 74mm at the entrance (just measure it several times for accuracy). Sorry for the misinformation.
The Following 7 Users Say Thank You to Erich For This Useful Post:
06Speed6 (06-21-2012), djuosnteisn (06-21-2012), doubleflusher (06-21-2012), Easter Bunny (06-21-2012), kritz (06-21-2012), rfinkle2 (06-21-2012), wolly6973 (06-23-2012)
 Old 06-21-2012, 11:44 AM   #33
MarkyMark's Avatar
Posts: 1,624   (View Stats)
Groans: 62
As long as we get the AccessPort tables figured out for drivability, what's stopping me from making a larger throttle body from billet aluminum that accepts the factory gears/electronics?
xPEPEx and kritz like this.
MarkyMark is offline   Reply With Quote
The Following 19 Users Say Thank You to MarkyMark For This Useful Post:
06Speed6 (06-21-2012), charlesfist (07-23-2012), cld12pk2go (06-22-2012), dan7225 (06-21-2012), djuosnteisn (06-21-2012), doubleflusher (06-21-2012), Easter Bunny (06-21-2012), forgedzoomzoom (06-21-2012), InFeXIoN (06-21-2012), JacksonMS30 (07-03-2012), kritz (06-21-2012), nighthawk358 (06-22-2012), NJSPEED3 (07-12-2012), redmnsterut (06-21-2012), SilverDemon (06-21-2012), themytb (06-21-2012), TWOptSL0W (07-04-2012), wolly6973 (06-23-2012), xPEPEx (06-26-2012)
 Old 06-21-2012, 11:54 AM   #34
708
Erich's Avatar
See my last post for corrected information. My TB is not 80mm at the entrance it is 74. We had talked about some others, and tried two others (I don't have part numbers for the other two we tried, you would have to ask John but one of them was 80 tapering to 74) before deciding on this one. The other two we tried were never driven on, just wired in and checked for response.
 Old 06-21-2012, 11:56 AM   #35
Must Have Teh 10's!
it would have to be sub $150-200 cause thats the cost of the hemi TB and connector.
make it happen!!!!!!!
xPEPEx likes this.
The Following 4 Users Say Thank You to superskaterxes For This Useful Post:
06Speed6 (06-21-2012), djuosnteisn (06-21-2012), JacksonMS30 (07-03-2012), xPEPEx (06-26-2012)
 Old 06-21-2012, 12:04 PM   #36
redmnsterut's Avatar
Posts: 838   (View Stats)
redmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the world
I say this! I started reading and got lost with all the numbers, but subbed for future awesomeness
SURE RMM | SURE Shift Weight | SURE SSP | CP-E CAI | CP-E DP | CP-E TIP | COBB AP |SnailD Tunned| TEIN Springs | SU Turbosmart BPV | Autotech HPFP Internals | Autolite XP step colder plugs | JBR Heavy Shift Knob | CXracing FMIC | Block8 Single Gauge Pod | MSD DashHawk
Waiting to be installed: SURE Dreadnaught | JBR Shifter Bushings | SU Boost Tubes | P&P Intake Manifold
Soon to come:SURE Intake/TB TIG | SURE Juggernaught | RSB |
286awhp / 346lbs tq @4500 ft ASL
redmnsterut is offline   Reply With Quote
 Old 06-21-2012, 12:11 PM   #37
708
Erich's Avatar
There are definitely rougher transitions on and off throttle. I was able to compensate for this some by flattening the APP Translation tables down low. The rest was adjusting driving style. Would still be nice to have the tables to properly account for the issue though.
 Old 06-21-2012, 12:12 PM   #38
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
As SS stated, the OE TB can support up to ~450WHP. That means a BNR S3 /2871 doesn't need an upgrade period and it would be arguable to upgrade for a GT/GTX3071.
larger TBs are for the big boys
 Old 06-21-2012, 12:12 PM   #39
Groans: 1,443
Nothing, you sexy motherfucker.
The Following 4 Users Say Thank You to doubleflusher For This Useful Post:
bcmurphy87 (06-21-2012), Dano (06-21-2012), NJSPEED3 (07-12-2012), TWOptSL0W (07-04-2012)
 Old 06-21-2012, 12:28 PM   #40
MarkyMark's Avatar
Groans: 62
I'll have to go measure the overall dims of the throttle body, but I'm thinking around 40-50 in material. Could be wrong. I'll add this to my list. Maybe I could get started soon, seems easy enough.
I'll have to add in the cost of fancy packaging though, so that's about $60 right there
With this being said, if I can get something to incorporate stock hardware, where do i get this hardware from?
Core exchange program? I could reverse engineer the little parts, but that would drive the cost sky high.
I highly doubt the TB gears/electronics can be ordered separate from the body itself. @SPEED6 KILLAHwould know that.
The Following 9 Users Say Thank You to MarkyMark For This Useful Post:
06Speed6 (06-21-2012), AZSPEED3 (06-21-2012), charlesfist (07-23-2012), djuosnteisn (06-21-2012), InFeXIoN (06-21-2012), JacksonMS30 (07-03-2012), NJSPEED3 (07-12-2012), superskaterxes (06-21-2012), wolly6973 (06-23-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/lets-talk-about-bigger-throttle-bodies-116929/
Throttle body This thread Refback 08-06-2013 09:04 AM
Lets talk fuel pump internals Javi Mazdaspeed3/6 General Discussion 63 04-10-2014 04:44 PM
Lets talk Compressor AR superskaterxes MazdaSpeed 3/6 - Turbo Induction 16 03-30-2012 10:54 AM
Lets talk turbo sizing bf360 MazdaSpeed 3/6 - Turbo Induction 23 12-17-2009 03:49 PM
Lets talk clutches Death-From-A-Mile MazdaSpeed 3 - Engine, Transmission & Driveline 4 11-03-2008 08:37 PM
Page generated in 0.70816 seconds with 42 queries
