![]() Join Date: Jun 2012 Location: Montreal, QC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 927
| Not Ranked : 0 score The 582 (CX-7) as smaller exhaust A/R and compressor wheel than both the 881 and 882 I once took apart a 582 (CX-7) and 881 (MS6) side by side, and two difference I saw is the journal bearing design and the oil inlet banjo (the CX-7 banjo as a smaller oil passage) Maybe Mazda made some change to the turbo at some point to prevent the smoking issue (by restricting the oil intake and altering the journal bearing design for the lessen oil pressure) 881 may be the old version, and 882 the new version? Anyhow, before I put the MS6 turbo in my CX-7, I rebuilt it with the original journal bearing (the two version are included in the rebuilt kit), and put the turbo on the car with a MS6 banjo bolt (bigger oil inlet hole)... a while after, I begin to have smoking issue The minute I put the CX-7 banjo bolt back, the smoking issue was gone (the CX-7 banjo as a small opening like the Bnoon bolt) Maybe you just need a rebuilt (with the new journal bearing design) and Bnoon bolt?
__________________ 2011 CX-7 AWD 2.3 turbo Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner"When the turbo spins the bull$hit ends" BOOST the replacement for displacement |
| Gen 1 vs Gen 2 piston and rod differences | Lex | MazdaSpeed 3 - Engine, Transmission & Driveline | 42 | 08-14-2019 02:43 PM |
| K04 Differences: K0422-582 vs. K0422-881 / K0422-882 | BAT-man | 2010 MS3 - Turbo Induction | 92 | 12-07-2016 09:02 PM |
| any differences between K04's? | btstarcher | MazdaSpeed 3/6 - Turbo Induction | 5 | 04-09-2013 04:52 PM |
| Going from 93 to 91...what kind of differences will I see | Stangcobra | MazdaSpeed 3/6 - ECU Computer Tuning | 16 | 09-13-2012 07:29 PM |
| Gen 1 - Gen 2 differences? | steedspeed | 2010 MS3 - Turbo Induction | 15 | 11-05-2010 08:44 AM |
