 Old 07-21-2017, 08:16 AM   #1
tom10122's Avatar
Posts: 116   (View Stats)
tom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to all
Default How to run on wastegate spring pressure?
I'm replacing my turbo tommorrow and I'm still waiting to hear back about a tune. It has to be done tomorrow because that's my buddy's day off and he's letting me use his lift, so it's gotta be out of there too.
This is my first turbo car so I'm not knowledgeable on Ebcs and such, what is it I actually disconnect to run wastegate pressure? I remember when I went to look at another speed6 something was disconnected that caused it to actually overboosting, definitely want to avoid that.
Sent from my XT1565 using Tapatalk
tom10122 is offline   Reply With Quote
 Old 07-21-2017, 04:21 PM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Just disconnect the 2 pin harness at the boost control solenoid. Do not touch the vacuum lines.
The Following User Says Thank You to SSinstaller For This Useful Post:
tom10122 (07-21-2017)
 Old 07-21-2017, 04:25 PM   #3
tom10122's Avatar
Thanks! I'm assuming the vaccum lines cause the over boosting? I'm going to need to disconnect at least one line to swap the turbo out sadly right?
 Old 07-23-2017, 07:05 AM   #4
MSMS3's Avatar
Posts: 2,826   (View Stats)
Yes, just follow the CS PDF install instructions, with pictures, install all lines, and then unplug the EBCS cable until you get your tune.
How do you select a wastegate spring? Chimmike MazdaSpeed 3/6 - Turbo Induction 4 03-28-2010 01:01 AM
1 bar wastegate spring and boost spike, johnac08 MazdaSpeed 3/6 - Turbo Induction 3 08-29-2009 12:47 PM
wastegate spring ms3boost MazdaSpeed 3/6 - Turbo Induction 5 06-15-2009 03:41 PM
Page generated in 0.25228 seconds with 22 queries
