 Old 08-14-2014, 01:12 AM   #1
mrQQ's Avatar
Posts: 1,164   (View Stats)
mrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the world
Default How to do leak test PRE-TURBO
Hi,
my car is running lean at WOT. Lex told me to do full leak test. It is leak free past turbo, but how do I test it pre-turbo?
If I connect it to air filter place, then it will leak through maf o-ring, as it is not meant to hold boost?
mrQQ is offline   Reply With Quote
 Old 08-14-2014, 02:59 AM   #2
btstarcher's Avatar
Posts: 4,852   (View Stats)
It shouldn't leak past the O-ring. How lean are you at WOT? Are you sure it's not just the MAF calibration?
SnailTune in progress
The Following 2 Users Say Thank You to btstarcher For This Useful Post:
calizoomzoom (08-14-2014), Snip (08-14-2014)
 Old 08-14-2014, 03:32 AM   #3
Snip's Avatar
Posts: 329   (View Stats)
In another topic he states that it's lean by approximately 10%.
Could also be maf calibration instead of a leak?
MazdaSpeed3 GT '07
AccessPort V2 Self tuned
The Following 2 Users Say Thank You to Snip For This Useful Post:
btstarcher (08-14-2014), calizoomzoom (08-14-2014)
 Old 08-14-2014, 05:32 AM   #4
mrQQ's Avatar
Apparently, it doesn't leak at all while testing.
It COULD be MAF Calibration, but I took Lex's JBR 3" as a base, which is 20% over stock, and its still lean by 10%. Even Lex said that it doesn't look normal...
Jbr is 2.875" ID.. stock is 2.61811.. so it's exactly 20% larger cross section, and not 30%..
 Old 08-14-2014, 08:24 AM   #5
Snip's Avatar
According to your numbers the JBR is approximately 10 % larger then stock.
100% = 2.618, that means 2.875 is 109.8%
So if lex's maf calibration is 20% more, then there you have your 10%
And according to your profile you have a cp-e cold air intake, so the maf calibration from cobb ots should be pretty close i think.
My cp-e xcel nano sri was pretty close with the cobb ots maf calibration.
I say you should redo the maf calibration
MazdaSpeed3 GT '07
The Following User Says Thank You to Snip For This Useful Post:
 Old 08-14-2014, 10:07 AM   #6
mrQQ's Avatar
No, not like that. Cross section is radius squared, so:
2.875^2 / 2.618^2 ~= 1.2
So that's a 20% increase and that's exactly what I have my MAF cal at. But from the logs, it's still 9% too lean. There is no way that 3" JBR is flowing 29% more than stock MAF....
 Old 08-14-2014, 10:18 AM   #7
Snip's Avatar
No, it's pi x diameter if you calculate it in another way, or pi x radius squared i believe.
Then it's (3.14 x 2.875) / (3.14 x 2.618) = 1.098 so roughly 10% increase.
MazdaSpeed3 GT '07
 Old 08-14-2014, 10:25 AM   #8
Ranyard's Avatar
Posts: 146   (View Stats)
Ranyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond repute
Pi X Diameter or Pi2r is circumference, Pi X r^2 is area, or cross section. totally different things.
"The eagle never lost so much time as when he submitted to learn from the crow" ...nobody
Ranyard is offline   Reply With Quote
The Following User Says Thank You to Ranyard For This Useful Post:
Snip (08-14-2014)
 Old 08-14-2014, 10:38 AM   #9
Snip's Avatar
I agree Ranyard, i had the formula wrong. I stand corrected.
But area is also 1/4pi x diameter.
Then i still get roughly 10 % of increase
(0.25 x 3.14 x 2.875) / (0.25 x 3.14 x 2.618) = 1.098
Where am I missing the point then? :-)
MazdaSpeed3 GT '07
 Old 08-14-2014, 10:43 AM   #10
mrQQ's Avatar
no, still the same pi and 1/2 cancel each other so all that remains is r1^2 / r2^2 which is 20%..
 Old 08-14-2014, 10:56 AM   #11
Snip's Avatar
but let's say you have 2.618 and you want to go to 2.875.
if you take 10% from 2.618 = 0.2618
add that to 2.618 = 2.8798 which is roughly what you want.
Adding 20% is 2.618 + 0.5236 = 3.1416 is not what you want.
I'm getting a bit confused now because i don't see what i'm doing wrong, because the formula with pi x r2 indeed gives 20% increase, but the other formula (1/4 x pi x diameter) gives 10%, and adding 10% to 2.618 also comes closest to 2.875, instead of adding 20%...
MazdaSpeed3 GT '07
 Old 08-14-2014, 11:09 AM   #12
mrQQ's Avatar
You are forgetting the square. Formula is pi x r squared.
The Following User Says Thank You to mrQQ For This Useful Post:
Snip (08-14-2014)
 Old 08-14-2014, 11:15 AM   #13
Snip's Avatar
Indeed,
again i stand corrected, the other formula i forgot the squared, it's 1/4 x pi x diameter^2
then you will also get 20% increase.
Sorry for disturbing your topic guys
But ontopic;
Since you can't find a leak, what is the smallest inner diameter of your cp-e intake? is that the same diameter then the JBR?
Otherwise it may be off there?
MazdaSpeed3 GT '07
How to do a leak down test? SharkDiver MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 11-23-2015 10:48 PM
OEM BPV How to Test for Leak? zer010gic MazdaSpeed 3/6 - Turbo Induction 1 02-22-2011 12:13 PM
Page generated in 0.31455 seconds with 23 queries
